Anyone do successfully DFU OTA from Linux ?
I'm tring to build a FOTA broadcaster machine using a raspberry-pi with bluez. or any other Linux small linux embedded system.
The idea is that after testing the board with an already pre-programmed firmware. it get the final production firmware from OTA.
I'm asking if someone has already played with DFU using linux ?
  • Unfortunately, we don't have an example using bluez, but maybe someone else have. The requirements for the central can be found here if you want to try to implement it yourself.
    For anyone landing here from a search: yes, this works well on Linux today.
    We needed the same thing — flashing boards from a Linux bench at the end of
    test — so we built a small CLI for it in Go:
    github.com/.../ed-nrfdfu
    It talks to BlueZ over D-Bus and runs Nordic Secure DFU over BLE straight
    from the terminal, no phone and no GUI, so it drops into a production
    script. It's a single static binary and we publish linux/arm64 builds, so
    it runs on a Raspberry Pi with nothing to install.
        go install github.com/E-DEVICE/ed-nrfdfu@latest
        ed-nrfdfu --mac "AA:BB:CC:DD:EE:FF" --dfuPath firmware.zip
    One prerequisite worth stating: it expects the device to already be
    advertising in DFU/bootloader mode. It does not trigger the buttonless
    transition from your application firmware. But this features could be added quickly.
    The license is Apache 2.0 so do what ever you feel with this repo.
    It's a developer aid rather than a certified production
    component. Linux/BlueZ is what we use daily; the macOS and Windows backends
    are implemented but not yet tested against real hardware.
