When communicating with twi in ble_app_NUS, error code 0x00000011 occurs.
hello,
To use twi communication in ble_app_NUS, I configured the program by referring to the twi_sensor example.
As you can see in the source code below, when the BSP_EVENT_KEY_0 event occurs, in void bsp_event_handler(bsp_event_t event)
nrf_drv_twi_tx(&m_twi, TOUCH_ADDR, TWI_reg, sizeof(TWI_reg), false); It was configured to call .
void twi_init (void)
    ret_code_t err_code;
    const nrf_drv_twi_config_t twi_config = {
       .scl                = I2C_CLK_PIN_NUMBER,
       .sda                = I2C_DATA_PINNUMBER,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi);
    uint32_t err_code;
    switch (event)
        case   BSP_EVENT_ADVERTISING_STOP :
            printf("> BSP_EVENT_ADVERTISING_STOP\r\n");
        case BSP_EVENT_KEY_0 :
            err_code = nrf_drv_twi_tx(&m_twi, PIC_TOUCH_ADDR, TWI_reg, sizeof(TWI_reg), false);
However, when nrf_drv_twi_tx is called, error 0x00000011 occurs and the fault function below is called.
__WEAK void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
I do not know the cause of error 0x00000011.
