I am trying to commissioning the Android chip-tool with matter light bulb and using rpi3 and nrf52840 Dongle as OTBR and after scanning then after thta i have to fill the thread crediantial that is in the dataset on the OTBR.
After some process it failed commissioning. what is the issue and how resolve it.
Logs of the matter light Bulb (nrf52840DK)
30539 [DL]CHIPoBLE advertising mode changed to slow I: 30546 [DL]CHIPoBLE advertising started I: BLE advertising is already enabled I: 153106 [DL]BLE connection established (ConnId: 0x00) I: 153111 [DL]Current number of connections: 1/1 I: 153115 [DL]CHIPoBLE advertising stopped I: 153119 [DL]NFC Tag emulation stopped D: 153727 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 153734 [BLE]local and remote recv window sizes = 5 I: 153739 [BLE]selected BTP version 4 I: 153742 [BLE]using BTP fragment sizes rx 244 / tx 244. D: 153861 [DL]ConnId: 0x00, New CCCD value: 0x0002 D: 153866 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6) D: 153874 [IN]BLE EndPoint 0x20012460 Connection Complete I: 153879 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 247) D: 153951 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 153960 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 153967 [EM]>>> [E:43280r S:0 M:261877196] (U) Msg RX from 0:2FF82E554D1BED19 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest) I: 153980 [EM]<<< [E:43280r S:0 M:104233135] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse) I: 153992 [IN](U) Sending msg 104233135 to IP address 'BLE' D: 153998 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 140) D: 154131 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 154177 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 154184 [EM]>>> [E:43280r S:0 M:261877197] (U) Msg RX from 0:2FF82E554D1BED19 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1) I: 155845 [EM]<<< [E:43280r S:0 M:104233136] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2) I: 155857 [IN](U) Sending msg 104233136 to IP address 'BLE' D: 155862 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 132) E: 155870 [DL]Long dispatch time: 1693 ms, for event type 16388 D: 155976 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 156022 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 156029 [EM]>>> [E:43280r S:0 M:261877198] (U) Msg RX from 0:2FF82E554D1BED19 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3) I: 156041 [EM]<<< [E:43280r S:0 M:104233137] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport) I: 156053 [IN](U) Sending msg 104233137 to IP address 'BLE' D: 156058 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 35) I: 156067 [SC]SecureSession[0x20003320]: Moving from state 'kEstablishing' --> 'kActive' D: 156075 [IN]SecureSession[0x20003320]: Activated - Type:1 LSID:55342 D: 156081 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:55342 PSID:31550! I: 156090 [SVR]Commissioning completed session establishment step 156096 [DIS]Updating services using commissioning mode 0 E: 156101 [DIS]Failed to remove advertised services: 3 D: 156106 [DL]Using Thread extended MAC for hostname. I: 156112 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=0 E: 156122 [DIS]Failed to advertise extended commissionable node: 3 D: 156127 [DIS]Scheduling extended discovery timeout in 900s E: 156133 [DIS]Failed to finalize service update: 3 D: 156138 [DL]CHIPoBLE advertising set to off I: 156142 [SVR]Device completed Rendezvous process E: 156146 [DL]Long dispatch time: 125 ms, for event type 16388 D: 156156 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 156165 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 156173 [EM]>>> [E:43281r S:55342 M:96750399] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 156184 [IM]Received Read request I: 156205 [EM]<<< [E:43281r S:55342 M:175653482] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData) I: 156216 [IN](S) Sending msg 175653482 on secure session with LSID: 55342 D: 156223 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 156336 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 156344 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 21) D: 156427 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 156435 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 156443 [EM]>>> [E:43282r S:55342 M:96750400] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 156455 [FS]GeneralCommissioning: Received ArmFailSafe (30s) I: 156462 [EM]<<< [E:43282r S:55342 M:175653483] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 156474 [IN](S) Sending msg 175653483 on secure session with LSID: 55342 D: 156480 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 156562 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 156570 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 156578 [EM]>>> [E:43283r S:55342 M:96750401] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 156595 [EM]<<< [E:43283r S:55342 M:175653484] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 156607 [IN](S) Sending msg 175653484 on secure session with LSID: 55342 D: 156613 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 156697 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 156705 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 156713 [EM]>>> [E:43284r S:55342 M:96750402] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 156725 [ZCL]OpCreds: Certificate Chain request received for PAI I: 156734 [EM]<<< [E:43284r S:55342 M:175653485] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 156746 [IN](S) Sending msg 175653485 on secure session with LSID: 55342 D: 156752 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 156831 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 156839 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 156921 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 156929 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 48) D: 157012 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 157020 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) 157028 [EM]>>> [E:43285r S:55342 M:96750403] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 157040 [ZCL]OpCreds: Certificate Chain request received for DAC I: 157049 [EM]<<< [E:43285r S:55342 M:175653486] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 157061 [IN](S) Sending msg 175653486 on secure session with LSID: 55342 D: 157068 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 157146 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 157154 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 157281 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 157289 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 77) D: 157371 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 157379 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 157388 [EM]>>> [E:43286r S:55342 M:96750404] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 157400 [ZCL]OpCreds: Received an AttestationRequest command I: 157439 [ZCL]OpCreds: AttestationRequest successful. I: 157448 [EM]<<< [E:43286r S:55342 M:175653487] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 157460 [IN](S) Sending msg 175653487 on secure session with LSID: 55342 D: 157467 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 157551 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 157559 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 157686 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 157694 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 235) D: 157821 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 157866 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 157875 [EM]>>> [E:43287r S:55342 M:96750405] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 157887 [FS]GeneralCommissioning: Received ArmFailSafe (600s) I: 157894 [EM]<<< [E:43287r S:55342 M:175653488] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 157905 [IN](S) Sending msg 175653488 on secure session with LSID: 55342 D: 157912 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 158001 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 158009 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 158018 [EM]>>> [E:43288r S:55342 M:96750406] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 158030 [ZCL]OpCreds: Received a CSRRequest command I: 158203 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded I: 158242 [ZCL]OpCreds: CSRRequest successful. I: 158249 [EM]<<< [E:43288r S:55342 M:175653489] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 158260 [IN](S) Sending msg 175653489 on secure session with LSID: 55342 D: 158267 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) E: 158275 [DL]Long dispatch time: 266 ms, for event type 16388 D: 158361 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 158369 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 138) D: 158451 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 158497 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 158587 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 158596 [EM]>>> [E:43289r S:55342 M:96750407] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 158608 [ZCL]OpCreds: Received an AddTrustedRootCertificate command I: 158678 [ZCL]OpCreds: AddTrustedRootCertificate successful. I: 158684 [EM]<<< [E:43289r S:55342 M:175653490] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 158696 [IN](S) Sending msg 175653490 on secure session with LSID: 55342 D: 158703 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 68) E: 158710 [DL]Long dispatch time: 124 ms, for event type 16388 D: 158766 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) 158774 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 158857 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 158866 [EM]>>> [E:43290r S:55342 M:96750408] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 158878 [ZCL]OpCreds: Received an AddNOC command I: 158886 [FP]Validating NOC chain I: 158954 [FP]NOC chain validation successful I: 158958 [FP]Added new fabric at index: 0x1 I: 158962 [FP]Assigned compressed fabric ID: 0x279D17E1A4181155, node ID: 0x0000000000000007 I: 158970 [TS]Last Known Good Time: 2023-09-11T15:30:13 I: 158975 [TS]New proposed Last Known Good Time: 2021-06-10T00:00:00 I: 158981 [TS]Retaining current Last Known Good Time I: 159007 [ZCL]OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0x000000000001B669 D: 159016 [DL]Using Thread extended MAC for hostname. I: 159021 [DIS]Advertise operational node 279D17E1A4181155-0000000000000007 I: 159027 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC I: 159035 [EM]<<< [E:43290r S:55342 M:175653491] (S) Msg TX to 1:FFFFFFFB00000000 [1155] --- Type 0001:09 (IM:InvokeCommandResponse) I: 159047 [IN](S) Sending msg 175653491 on secure session with LSID: 55342 D: 159053 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) E: 159061 [DL]Long dispatch time: 204 ms, for event type 16388 D: 159126 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 159134 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 159143 [EM]>>> [E:43291r S:55342 M:96750409] (S) Msg RX from 1:FFFFFFFB00000000 [1155] --- Type 0001:08 (IM:InvokeCommandRequest) I: 159161 [EM]<<< [E:43291r S:55342 M:175653492] (S) Msg TX to 1:FFFFFFFB00000000 [1155] --- Type 0001:09 (IM:InvokeCommandResponse) I: 159173 [IN](S) Sending msg 175653492 on secure session with LSID: 55342 D: 159179 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 159261 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 159269 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 159278 [EM]>>> [E:43292r S:55342 M:96750410] (S) Msg RX from 1:FFFFFFFB00000000 [1155] --- Type 0001:08 (IM:InvokeCommandRequest) D: 159301 [DL]OpenThread State Changed (Flags: 0x1006c100) D: 159307 [DL] Network Name: OpenThread D: 159310 [DL] PAN Id: 0x8D09 D: 159313 [DL] Extended PAN Id: 0x66510FAB3CD4CFA2 D: 159318 [DL] Channel: 26 D: 159321 [DL] Mesh Prefix: fdde:ad00:beef::/64 D: 159326 [DL]OpenThread State Changed (Flags: 0x1100101d) D: 159331 [DL] Device Role: DETACHED D: 159335 [DL] Thread Unicast Addresses: D: 159339 [DL] fdde:ad00:beef:0:4ffc:ea2c:5e4b:7f1e/64 valid D: 159345 [DL] fe80::18fa:b70d:ad3e:4f0e/64 valid preferred I: 160770 [DL]SRP Client was started, detected server: fdce:5ec6:4314:73b8:a301:4401:79ce:0b91 D: 160779 [DL]OpenThread State Changed (Flags: 0x301932b7) D: 160784 [DL] Device Role: CHILD D: 160788 [DL] Network Name: OpenThread-8d09 D: 160792 [DL] PAN Id: 0x8D09 D: 160795 [DL] Extended PAN Id: 0x66510FAB3CD4CFA2 D: 160799 [DL] Channel: 26 D: 160802 [DL] Mesh Prefix: fdce:5ec6:4314:73b8::/64 D: 160807 [DL] Partition Id: 0x53A5A14C D: 160811 [DL] Thread Unicast Addresses: D: 160815 [DL] fdcf:380a:fa8d:1:ac0d:8c55:d66a:7e8/64 valid preferred D: 160821 [DL] fdce:5ec6:4314:73b8:0:ff:fe00:8404/64 valid rloc 160828 [DL] fdce:5ec6:4314:73b8:4ffc:ea2c:5e4b:7f1e/64 valid D: 160834 [DL] fe80::18fa:b70d:ad3e:4f0e/64 valid preferred D: 160842 [DL]OpenThread State Changed (Flags: 0x00000001) D: 160847 [DL] Thread Unicast Addresses: D: 160851 [DL] fdcf:380a:fa8d:1:ac0d:8c55:d66a:7e8/64 valid preferred D: 160858 [DL] fdce:5ec6:4314:73b8:0:ff:fe00:8404/64 valid rloc D: 160864 [DL] fdce:5ec6:4314:73b8:4ffc:ea2c:5e4b:7f1e/64 valid D: 160871 [DL] fe80::18fa:b70d:ad3e:4f0e/64 valid preferred I: 160879 [EM]<<< [E:43292r S:55342 M:175653493] (S) Msg TX to 1:FFFFFFFB00000000 [1155] --- Type 0001:09 (IM:InvokeCommandResponse) I: 160892 [IN](S) Sending msg 175653493 on secure session with LSID: 55342 D: 160898 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 70) D: 160906 [DL]Using Thread extended MAC for hostname. I: 160911 [DIS]Advertise operational node 279D17E1A4181155-0000000000000007 I: 160918 [SVR]Operational advertising enabled D: 160971 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 161931 [DL]SRP update succeeded I: 161934 [DIS]Setting operational delegate post init I: 161943 [SWU]Stopping the watchdog timer I: 161947 [SWU]Starting the periodic query timer, timeout: 86400 seconds E: 161954 [SVR]Server initialization complete I: 161958 [DIS]Updating services using commissioning mode 0 D: 161963 [DL]Using Thread extended MAC for hostname. I: 161968 [DIS]Advertise operational node 279D17E1A4181155-0000000000000007 I: 161975 [DL]advertising srp service: 279D17E1A4181155-0000000000000007._matter._tcp D: 161983 [DL]Using Thread extended MAC for hostname. I: 161989 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=0 I: 161998 [DL]advertising srp service: 8148112BC8324207._matterc._udp D: 163491 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 163571 [DL]SRP update succeeded D: 165998 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 166056 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 168576 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 171084 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 171186 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 173706 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) BLE GAP connection terminated (reason 0x13) I: 304118 [DL]Current number of connections: 0/1 E: 313933 [BLE]ack recv timeout, closing ep 0x20012460 D: 313938 [IN]Clearing BLE pending packets. I: 313942 [BLE]Releasing end point's BLE connection back to application. I: 313948 [DL]Closing BLE GATT connection (ConnId 00) I: 757892 [FS]Fail-safe timer expired E: 757896 [SVR]Failsafe timer expired D: 757899 [IN]SecureSession[0x20003320]: MarkForEviction Type:1 LSID:55342 I: 757906 [SC]SecureSession[0x20003320]: Moving from state 'kActive' --> 'kPendingEviction' D: 757914 [IN]SecureSession[0x20003320]: Released - Type:1 LSID:55342 E: 757920 [SVR]Commissioning failed (attempt 1): 32 D: 757928 [IN]SecureSession[0x20003320]: Allocated Type:1 LSID:55344 D: 757934 [DL]CHIPoBLE advertising set to on I: 757938 [DIS]Updating services using commissioning mode 1 D: 757943 [DL]Using Thread extended MAC for hostname. I: 757948 [DIS]Advertise operational node 279D17E1A4181155-0000000000000007 D: 757955 [DL]Using Thread extended MAC for hostname. I: 757961 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1 I: 757971 [DL]advertising srp service: 8148112BC8324207._matterc._udp E: 757977 [ZCL]OpCreds: Got FailSafeTimerExpired E: 757981 [ZCL]OpCreds: Proceeding to FailSafeCleanup on fail-safe expiry! D: 757988 [IN]Expiring all sessions for fabric 0x1!! E: 757993 [FP]Reverting pending fabric data for fabric 0x1 E: 757999 [FP]Warning: metadata not found during delete of fabric 0x1 I: 758048 [FP]Fabric (0x1) deleted. I: 758052 [ZCL]OpCreds: Fabric index 0x1 was removed I: 758056 [DIS]Updating services using commissioning mode 1 D: 758062 [DL]Using Thread extended MAC for hostname. I: 758067 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1 I: 758077 [DL]advertising srp service: 8148112BC8324207._matterc._udp I: 758083 [DL]removing srp service: 279D17E1A4181155-0000000000000007._matter._tcp I: 758203 [TS]Pending Last Known Good Time: 2023-09-11T15:30:13 I: 758210 [TS]Previous Last Known Good Time: 2023-09-11T15:30:13 I: 758216 [TS]Reverted Last Known Good Time to previous value E: 758222 [FP]Warning: metadata not found during delete of fabric 0x1 E: 758232 [ZCL]OpCreds: failed to delete fabric at index 1: d8 I: 758238 [NP]Reverting Thread operational dataset E: 758252 [DL]Long dispatch time: 356 ms, for event type 32782 I: 758257 [FS]Fail-safe cleanly disarmed I: 758263 [DL]CHIPoBLE advertising started D: 758267 [DL]OpenThread State Changed (Flags: 0x11002046) D: 758272 [DL] Device Role: DISABLED D: 758276 [DL] Thread Unicast Addresses: D: 758280 [DL] fdcf:380a:fa8d:1:ac0d:8c55:d66a:7e8/64 valid preferred D: 758288 [DL]OpenThread State Changed (Flags: 0x10000000) I: 758295 [DL]NFC Tag emulation started I: 788267 [DL]CHIPoBLE advertising mode changed to slow I: 788275 [DL]CHIPoBLE advertising starI: 30527 [DL]CHIPoBLE advertising mode changed to slow I: 30534 [DL]CHIPoBLE advertising started
and if i am trying to the commissioning with Linux_chip-tool it work fine.
