BLE Radio Fault
we recently received our new custom PCBAs with nRF52833. this is the 2nd rev of our design and the first design functioned as expected. with this new board, I am able to program the device and run simple print hello world. when I loaded our developed FW where one of the first things we do is advertise, the app crashes  with the following output:
and after running the addr2line, I get the following
the app seems to crash without much info as to what is causing it. I have a feeling it has something to do with the 32MHz crystal but this is the same crystal as our original design with the same load capacitance. one of the major differences with the new board design is we added the external 32kHz crystal but I have not even configured to use it. any help as to what may be causing this issue would be greatly appreciated.
here is the code
main.c
void main(void)
	int err;
	//uint32_t pin_read = 0;
	// nRF52833 Revision 2 Errata
	// [246] System: Intermittent extra current consumption when going to sleep
	// Extra current consumption in the range of 350 µA when in System On Idle.
	// A high-speed peripheral (CPU for example) accesses a RAM block which is being accessed by
	// a low-speed peripheral through the DMA bus, with a specific timing, and the high-speed peripheral has
	// higher priority than the low-speed peripheral.
	// NOTE: Workaround consequences: Up to 40 µA current increase when the 16 MHz clock is used.
	*(volatile uint32_t *)0x4007AC84ul = 0x00000002ul;
	//  Errata [20]. This anomaly applies to IC Rev. Revision 2, build codes QIAA-Bx0, QDAA-Bx0, CJAA-Bx0.
	// Symptoms is RTC registers will not contain the correct/expected value if read.
	// Consequences is RTC configuration cannot be determined by reading RTC registers.
	NRF_CLOCK->EVENTS_LFCLKSTARTED  = 0;
	NRF_CLOCK->TASKS_LFCLKSTART     = 1;
	while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0) {}
	NRF_RTC0->TASKS_STOP = 0;
	static const nrfx_power_config_t pwr_config = {
		.dcdcen = true,
	err = nrfx_power_init(&pwr_config);
	if (err != NRFX_SUCCESS) {
		LOG_ERR("nrfx_power_init error: 0x%08X", err);
		return;
	k_sem_init(&data_upload_ready, 0, 3);
	k_sem_init(&hall_data_fifo_ready, 1, 1);
	k_work_init(&acq_mode_info.work_item, acquisition_mode_update_work_handler);
	k_work_init(&m_hall_sensors_work.work_item, hall_sensors_work_handler);
	bt_ready();
    start_advertisement();
    while (1) {
		//k_sleep(K_SECONDS(1));
		k_msleep(1500);
		LOG_INF("This is a test..................");
		__WFE();
		//UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
ble functions
nrfx_err_t start_advertisement(void)
	nrfx_err_t err = NRFX_SUCCESS;
	if(bt_is_ready())
		// BT_LE_ADV_CONN_CUSTOM->interval_max = 0x0140;
		// BT_LE_ADV_CONN_CUSTOM->interval_min = 0x0140;
		LOG_INF("starting advertisement................");
		err = bt_le_adv_start(BT_LE_ADV_CONN_CUSTOM_200m/*BT_LE_ADV_CONN*/, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
		if (err) {
			LOG_INF("Advertising failed to start (err %d)\n", err);
			return err;
		LOG_INF("Advertising successfully started\n");
		//bt_le_per_adv_start()
	return err;
int bt_ready(void)
	int err;
	awakens_callbacks.notif_changed = awakens_callbacks.notif_changed;
	awakens_callbacks.data_received = awakens_callbacks.data_received;
    err = bt_enable(NULL);
	if (err) {
		LOG_INF("Bluetooth init failed (err %d)", err);
		return err;
	LOG_INF("Bluetooth initialized\n");
	// err = bt_le_adv_start(BT_LE_ADV_CONN_CUSTOM/*BT_LE_ADV_CONN*/, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
	// if (err) {
	// 	LOG_INF("Advertising failed to start (err %d)\n", err);
	// 	return err;
	// LOG_INF("Advertising successfully started\n");
    bt_conn_auth_cb_register(&auth_cb_display);
    return 0;
  • also, what can i enable so that I can scope the 32MHz signal?
    Thanks
    The assert indicates that the HFXO is not running when MPSL expects it to. In other words, the HFXO on your new board have a too long startup-time for some reason. Could it be a manufacturing issue on one specific board? If not, which 32 MHz crystal do you use and which load capacitors? Have you had the design reviewed by us? If not, we should take a look at your 32 MHz crystal and surrounding circuitry.
    You cannot probe directly on the crystal, as that will affect it. However you can get it divided by 4 using the approach shown in this post.
  • Hi Einar,
    Thank you for your response! I agree, I am sure its the 32MHz crystal not operating as it should. the board was reviewed by Nordic and its the same crystal and load capacitors as the original board. the only thing that changed with regards to the radio is the matching circuitry because the antenna on this board is shorter than the previous and less than the required length. Can the matching circuitry cause this issue?
    the crystal part number is ECS-320-CDX-2152 and the load capacitance is 10pF (0201 package)
    Thanks
  • Hi Einar,
    I figured out the issue; for whatever reason, one of the 32MHz load capacitors measured a short across it. I will need to take it off and see what the issue may be. But I programmed another board and its now working. Thank you for your help
