QSPI Erratum 122 QSPI power consumption in idle NRF52840
I've noticed I have high power consumption from the QSPI peripheral and have seen various posts on the fix for this relating to Erratum 122. I need some guidance on implementation.
 nRF52840 QSPI Power Consumption  this post explains the problems and the proposed solution:
    *(volatile uint32_t *)0x40029010ul = 1ul;
    *(volatile uint32_t *)0x40029054ul = 1ul;
    nrf_drv_qspi_uninit();
I saw in another post  RE: QSPI high current improvements for anomaly 122 in nrf52840 it mentions  a Zephyr PR where this issue was fixed? (https://github.com/zephyrproject-rtos/zephyr/pull/34405
A couple of questions:
- Why do I see high current draw if there is a fix in Zephyr?
- I've tried implementing the above code snippet and it does reduce current but I guess i have to re-init each time i want to use the qspi? can you provide a minimum example of how i should be doing this init / uninit in latest sdk?
