Strange ARCH_HAS_STACK_PROTECTION behavior
I'm developing custom board based on nrf52833. After creating new board via nRF connect extension I tried to enable FOTA. And got next warning.
warning: HW_STACK_PROTECTION (defined at arch/Kconfig:258) was assigned the value 'y' but got the
value 'n'. Check these unsatisfied dependencies: ARCH_HAS_STACK_PROTECTION (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_HW_STACK_PROTECTION and/or look up
HW_STACK_PROTECTION in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
But if I try to enable HW_STACK_PROTECTION via Kconfig gui it says "Direct Dependencies: (=y)".
This is not happening if I select nRF52833 kit as project board. What should I do to resolve this? What is the difference between custom board and development kit in means of dependencies?
Result prj.conf just in case
CONFIG_SECURE_BOOT=y
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_IS_BOOTLOADER=y
CONFIG_BUILD_S1_VARIANT=y
CONFIG_USERSPACE=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT=y
And build log. I realize that there also bunch of other warning, but at least I can somewhat understand how to resolve them.
Building untitled
/bin/sh -c west build --build-dir /home/yura/Documents/nrf/door_opener/app/untitled/build /home/yura/Documents/nrf/door_opener/app/untitled --pristine --board door_opener --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="/home/yura/Documents/nrf/door_opener" -DCONF_FILE:STRING="/home/yura/Documents/nrf/door_opener/app/untitled/prj.conf"
-- Application: /home/yura/Documents/nrf/door_opener/app/untitled
-- CMake version: 3.20.5
-- Found Python3: /home/yura/ncs/toolchains/1f9b40e71a/usr/local/bin/python3.8 (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: /home/yura/.cache/zephyr
-- Zephyr version: 3.3.99 (/home/yura/ncs/v2.4.2/zephyr)
-- Found west (found suitable version "1.0.0", minimum required is "0.7.1")
-- Board: door_opener
-- Found host-tools: zephyr 0.16.0 (/home/yura/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.0 (/home/yura/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk)
-- Found Dtc: /home/yura/ncs/toolchains/1f9b40e71a/usr/bin/dtc (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: /home/yura/Documents/nrf/door_opener/boards/arm/door_opener/door_opener.dts
-- Generated zephyr.dts: /home/yura/Documents/nrf/door_opener/app/untitled/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /home/yura/Documents/nrf/door_opener/app/untitled/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /home/yura/Documents/nrf/door_opener/app/untitled/build/zephyr/dts.cmake
Parsing /home/yura/ncs/v2.4.2/zephyr/Kconfig
Loaded configuration '/home/yura/Documents/nrf/door_opener/boards/arm/door_opener/door_opener_defconfig'
Merged configuration '/home/yura/Documents/nrf/door_opener/app/untitled/prj.conf'
Configuration saved to '/home/yura/Documents/nrf/door_opener/app/untitled/build/zephyr/.config'
Kconfig header saved to '/home/yura/Documents/nrf/door_opener/app/untitled/build/zephyr/include/generated/autoconf.h'
-- Found GnuLd: /home/yura/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
-- Found assembler: /home/yura/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
=== child image b0 -  begin ===
loading initial cache file /home/yura/Documents/nrf/door_opener/app/untitled/build/b0/child_image_preload.cmake
-- Application: /home/yura/ncs/v2.4.2/nrf/samples/bootloader
-- Generated zephyr.dts: /home/yura/Documents/nrf/door_opener/app/untitled/build/b0/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /home/yura/Documents/nrf/door_opener/app/untitled/build/b0/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /home/yura/Documents/nrf/door_opener/app/untitled/build/b0/zephyr/dts.cmake
helpful too.
warning: UART_NRFX (defined at drivers/serial/Kconfig.nrfx:6) has direct dependencies (DT_HAS_NORDIC_NRF_UART_ENABLED || DT_HAS_NORDIC_NRF_UARTE_ENABLED) && SERIAL with value n, but is currently being y-selected by the following symbols:
 - SECURE_BOOT_DEBUG_UART (defined at /home/yura/ncs/v2.4.2/nrf/subsys/bootloader/Kconfig:222), with value y, direct dependencies <choice SECURE_BOOT_DEBUG_BACKEND> (value: y), and select condition <choice SECURE_BOOT_DEBUG_BACKEND> (value: y)
warning: UART_CONSOLE (defined at drivers/console/Kconfig:43) has direct dependencies SERIAL && SERIAL_HAS_DRIVER && CONSOLE with value n, but is currently being y-selected by the following symbols:
error: Aborting due to Kconfig warnings
Merged configuration '/home/yura/ncs/v2.4.2/nrf/samples/bootloader/prj.conf'
Merged configuration '/home/yura/ncs/v2.4.2/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration '/home/yura/Documents/nrf/door_opener/app/untitled/build/b0/zephyr/misc/generated/extra_kconfig_options.conf'
CMake Error at /home/yura/ncs/v2.4.2/zephyr/cmake/modules/kconfig.cmake:339 (message):
  command failed with return code: 1
  /home/yura/ncs/v2.4.2/nrf/cmake/modules/kconfig.cmake:29 (include)
  /home/yura/ncs/v2.4.2/zephyr/cmake/modules/zephyr_default.cmake:115 (include)
  /home/yura/ncs/v2.4.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  /home/yura/ncs/v2.4.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  CMakeLists.txt:9 (find_package)
CMake Error at /home/yura/ncs/v2.4.2/nrf/cmake/multi_image.cmake:440 (message):
  CMake generation for b0 failed, aborting.  Command: 1
  /home/yura/ncs/v2.4.2/nrf/cmake/multi_image.cmake:169 (add_child_image_from_source)
  /home/yura/ncs/v2.4.2/nrf/samples/CMakeLists.txt:18 (add_child_image)
See also "/home/yura/Documents/nrf/door_opener/app/untitled/build/CMakeFiles/CMakeOutput.log".
See also "/home/yura/Documents/nrf/door_opener/app/untitled/build/CMakeFiles/CMakeError.log".
FATAL ERROR: command exited with status 1: /home/yura/ncs/toolchains/1f9b40e71a/usr/local/bin/cmake -DWEST_PYTHON=/home/yura/ncs/toolchains/1f9b40e71a/usr/local/bin/python3.8 -B/home/yura/Documents/nrf/door_opener/app/untitled/build -GNinja -DBOARD=door_opener -DNCS_TOOLCHAIN_VERSION:STRING=NONE -DBOARD_ROOT:STRING=/home/yura/Documents/nrf/door_opener -DCONF_FILE:STRING=/home/yura/Documents/nrf/door_opener/app/untitled/prj.conf -S/home/yura/Documents/nrf/door_opener/app/untitled
    In this case, I think the warning for UART_NRFX  and UART_CONSOLE causes the build error if you use the default custom board files which don't include UART. You can compare the board files of the custom board and nRF52833DK.
    Even using nRF52833DK to build with your configs, it would get the HW_STACK_PROTECTION warning. However, it would not cause the build to fail.
    Amanda H.
