BLE battery level server(peripheral)
currently I am working for a ble battery level indication server. For that I followed one example called ble_app_bps.
And I configured  for battery level simulation. My question here is how can I send a battery level counter value(for example 0% to 20%) to the nrf connect app in smartphone?
means the real sensor(or battery level) value ,not the simulated value Please help me in this case.
//ble peripheral as advertiser/battery level Indication server
//header files
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "nrf_ble_qwr.h"
#include "nrf_ble_gatt.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_bas.h"
#include "sensorsim.h"
#include "ble_srv_common.h"
#include "ble_conn_params.h"
//macros
#define APP_BLE_CONN_CFG_TAG  1
#define APP_BLE_OBSERVER_PRIO 3
#define DEVICE_NAME         "Satyabrata_BLE"
#define MIN_CON_INTERVAL    MSEC_TO_UNITS(100,UNIT_1_25_MS)//minimum conn interval(7.5ms to 4.0 secs)
#define MAX_CON_INTERVAL    MSEC_TO_UNITS(200,UNIT_1_25_MS)//maximum conn interval(7.5 ms to 4.0 secs)
#define SLAVE_LATENCY       0                              //no of times the slave skips the conn interval
#define CONN_SUP_TIMEOUT    MSEC_TO_UNITS(2000,UNIT_10_MS)//time between two succsessful conn events(100ms to 32s)
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)
#define MAX_CONN_PARAMS_UPDATE_COUNT    3
#define APP_ADV_INTERVAL    300
#define APP_ADV_DURATION    0
#define BATTERY_LEVEL_MEAS_INTERVAL     APP_TIMER_TICKS(2000)                   /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL               81                                      /**< Minimum battery level as returned by the simulated measurement function. */
#define MAX_BATTERY_LEVEL               100                                     /**< Maximum battery level as returned by the simulated measurement function. */
#define BATTERY_LEVEL_INCREMENT         1                                       /**< Value by which the battery level is incremented/decremented for each call to the simulated measurement function. */
NRF_BLE_QWR_DEF(m_qwr);
NRF_BLE_GATT_DEF(m_gatt);
BLE_ADVERTISING_DEF(m_advertising);
APP_TIMER_DEF(m_battery_timer_id);                                      /**< Battery timer. */
BLE_BAS_DEF(m_bas);                                                     /**< Structure used to identify the battery service. */
//private variables
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;
static sensorsim_cfg_t      m_battery_sim_cfg;                          /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t    m_battery_sim_state;                        /**< Battery Level sensor simulator state. */
static ble_uuid_t m_adv_uuids[] =                                       /**< Universally unique service identifiers. */
    {BLE_UUID_BATTERY_SERVICE,            BLE_UUID_TYPE_BLE}
//private functions
//step-9 gatt initialization
static void gatt_init()
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt,NULL);
//step-8 gap initialization
ret_code_t err_code;
ble_gap_conn_params_t    gap_conn_params;
ble_gap_conn_sec_mode_t  sec_mode;
err_code = sd_ble_gap_device_name_set(&sec_mode,(const uint8_t *)DEVICE_NAME,strlen(DEVICE_NAME));
memset(&gap_conn_params,0,sizeof(gap_conn_params));
gap_conn_params.min_conn_interval = MIN_CON_INTERVAL;
gap_conn_params.max_conn_interval = MAX_CON_INTERVAL;
//step-13 error handler for queue writer
APP_ERROR_HANDLER(nrf_error);
//step-12 initialize services
ble_bas_init_t     bas_init;
err_code = nrf_ble_qwr_init(&m_qwr,&qwr_init);
  // Initialize Battery Service.
    memset(&bas_init, 0, sizeof(bas_init));
    // Here the sec level for the Battery Service can be changed/increased.
    bas_init.bl_rd_sec        = SEC_OPEN;
    bas_init.bl_cccd_wr_sec   = SEC_OPEN;
    bas_init.bl_report_rd_sec = SEC_OPEN;
    bas_init.evt_handler          = NULL;
    bas_init.support_notification = true;
    bas_init.p_report_ref         = NULL;
    bas_init.initial_batt_level   = 100;
    err_code = ble_bas_init(&m_bas, &bas_init);
//step-16 create an event handler for connection parameters update
static void on_conn_params_evt(ble_conn_params_evt_t *p_evt)
if(p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED)
err_code = sd_ble_gap_disconnect(m_conn_handle,BLE_HCI_CONN_INTERVAL_UNACCEPTABLE);
if(p_evt->evt_type == BLE_CONN_PARAMS_EVT_SUCCEEDED)
//step-15 create an error handler for connection parameters update
//step-14 connection params init
memset(&cp_init,0,sizeof(cp_init));
cp_init.p_conn_params  = NULL;
cp_init.error_handler = conn_params_error_handler;
cp_init.evt_handler   = on_conn_params_evt;
//step-11 create advertisement event handler
switch(ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("fast advertising....");
case BLE_ADV_EVT_IDLE:
//step-10 advertising init
ble_advertising_init_t init;
memset(&init,0,sizeof(init));
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
err_code = ble_advertising_init(&m_advertising,&init);
ble_advertising_conn_cfg_tag_set(&m_advertising,APP_BLE_CONN_CFG_TAG);
//step-7 ble event handler
static void ble_evt_handler(ble_evt_t const *p_ble_evt,void *p_context)
ret_code_t err_code = NRF_SUCCESS;
switch(p_ble_evt->header.evt_id)
NRF_LOG_INFO("device is disconnected");
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("device is connected");
err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr,m_conn_handle);
NRF_LOG_DEBUG("phy update request");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
err_code = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle,&phys);
}//switch case end
//step-6 ble stack init
static void ble_stack_init()
uint32_t ram_start = 0;
err_code = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG,&ram_start);
NRF_SDH_BLE_OBSERVER(m_ble_observer,APP_BLE_OBSERVER_PRIO,ble_evt_handler,NULL);
//step-4 init power management
static void pwr_management_init(void)
ret_code_t err_code = nrf_pwr_mgmt_init();
//step-3 init bsp leds for ble
static void leds_init(void)
ret_code_t err_code = bsp_init(BSP_INIT_LEDS,NULL);
/**@brief Function for performing battery measurement and updating the Battery Level characteristic
 *        in Battery Service.
static void battery_level_update(void)
    uint8_t  battery_level=0;
   // battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
      battery_level = battery_level + 1;
      if(battery_level == 8) battery_level = 0;
    err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
    if ((err_code != NRF_SUCCESS) &&
        (err_code != NRF_ERROR_INVALID_STATE) &&
        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
        APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer timeout.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in]   p_context   Pointer used for passing some arbitrary information (context) from the
 *                          app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    battery_level_update();
//step-2 init app timer
static void timers_init(void)
 // Create timers.
    err_code = app_timer_create(&m_battery_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                battery_level_meas_timeout_handler);
//1st step initialize the logger
static void log_init()
//step-5 idle state handle
if(NRF_LOG_PROCESS() == false)
   nrf_pwr_mgmt_run();
//step-17 start the advertisement
ret_code_t err_code = ble_advertising_start(&m_advertising,BLE_ADV_MODE_FAST);
/**@brief Function for initializing the sensor simulators.
static void sensor_simulator_init(void)
    m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
    m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
    m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
    m_battery_sim_cfg.start_at_max = true;
    sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
/**@brief Function for starting application timers.
static void application_timers_start(void)
    // Start application timers.
    err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
/**@brief Function for application main entry.
   log_init();//done
   timers_init();//done
   //leds_init();//done
  pwr_management_init();//done
  ble_stack_init();//done
  gap_params_init();//done
  gatt_init();//done
  advertising_init();//done
  services_init();//done
  //sensor_simulator_init();//done
  conn_params_init();//done
  NRF_LOG_INFO("Battery Level Server application started.....");
  application_timers_start();//done
  advertising_start();//done
 //enter main loop
for(;;)
    idle_state_handle();
Here is the main.c file attached.
SDK - nrf5_SDK_17.1.0
DK - nrf52840
IDE - Segger embedded studio
Thanks & Regards
Satyabrata Senapati
  • Satyabrata Senapati said:
    Actually when I am sending some static battery level value using ble_bas_battery_level_update() ,it is displaying perfectly .But its not working for a counter value lets for testing purpose.means simply it should display the counter value
    1) Could you post some pictures that shows how it display things when it's working , and when it's not working.
    2) And also post some code snippet that shows how you are doing this.
  • ok. Let me send.
    This is the screen shot of nrf_connect app.
    And the code snippet is given below
    uint8_t battery_level;
    // sensorsim_increment(&m_battery_sim_state, &m_battery_sim_cfg);
    //battery_level = battery_level + 1;
    // if(battery_level == 8) battery_level = 0;
    battery_level = 10;
    // Create timers.
    And in main()
    log_init();//done
    gatt_init();//done
    //enter main loop
    for(;;)
    Thats it.
  • It looks to be working.
    You are sending battery_level = 10
    battery_level = 10;
    and this is also shown in the app
  • Hi sigurd,
    Actually this is working. But my case is if I am sending the counter value its not working. Its not showing the counted value in nrfconnect app.you can see I have commented in the code snippet.
