Security failed level 1 err 9 connecting error with bonded device
Hi all!
I'm developing a BLE device implementing automation IO profile, peripheral role.
I can connect normally and discover all services and characteristics from nRF Connect android app, but after bonding, I never can connect again, I receive
Security failed: 3C:CD:5D:3F:DC:50 (public) level 1 err 9
Disconnected (reason 61)
Am I missing something? Do I need to manually save bond information?
My code is the following:
Thanks!
Pedro.
  • Hi Pedro,
    Are you able to upload your project so I can try to reproduce the error on my end? The pairing fails because the link is encrypted/decrypted incorrectly, which is unusual error. The bonding information should be stored to flash automatically be the Zephyr host.
    Vidar
  • Hi Vidar,
    Attached to this post you can find the project.
    Thanks for your help!
    ble-io-bridge-periph.zip
    Edit: I'm using ncs 2.0.2
    I think the problem may be that all setting values, including the bond data, are reloaded again in get_adv_name(). Please try to replace the settings_load() call in this function with settings_load_subtree("app/ble_name"); and see if you get the same result.
  • Hi Vidar,
    Thanks for your answer. I've tried completely removing second call to settings api. Now it's a simple program that just show a single characteristic, but I still receive the same error when trying to connect, after the bonding is done.
    Could you please test it to check if you receive the same error?
    Thanks!
    ble-io-bridge-periph-v2.zip
  • Hi Pedro,
    I've not been able to reproduce the error here. Please try my modified version of your project attached below and see if you get the same result.
    ble-io-bridge-periph-mod.zip
    Vidar
    Edit: Forgot to remove the reduntant call to settings_load_subtree("app/ble_name") in attached code. It is not needed now as I moved the storage_init() function before settings_load(),
1 2 3 4 5 »
