Security failed level 1 err 9 connecting error with bonded device
Hi all!
I'm developing a BLE device implementing automation IO profile, peripheral role.
I can connect normally and discover all services and characteristics from nRF Connect android app, but after bonding, I never can connect again, I receive
Security failed: 3C:CD:5D:3F:DC:50 (public) level 1 err 9
Disconnected (reason 61)
Am I missing something? Do I need to manually save bond information?
My code is the following:
#include <zephyr/zephyr.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/gatt.h>
#include <zephyr/settings/settings.h>
#include <device.h>
#include <drivers/flash.h>
#include <storage/flash_map.h>
#include <fs/nvs.h>
#include <stdio.h>
#include <string.h>
#include "../cfg/config.h"
#include "ble.h"
#include <zephyr/kernel.h>
#include <zephyr/sys/reboot.h>
#include <inttypes.h>
LOG_MODULE_REGISTER(ble);
static void ccc_changed(const struct bt_gatt_attr *attr, uint16_t value) {
static ssize_t uart_tx_chr_read(struct bt_conn *conn, const struct bt_gatt_attr *attr, void *buf, uint16_t len, uint16_t offset) {
	return 0;
static ssize_t uart_rx_chr_write(struct bt_conn *conn, const struct bt_gatt_attr *attr, const void *buf, uint16_t len, uint16_t offset, uint8_t flags){
	return 0;
static ssize_t device_name_chr_write(struct bt_conn *conn, const struct bt_gatt_attr *attr, const void *buf, uint16_t len, uint16_t offset, uint8_t flags){
	char prueba[100] = {};
	memcpy(prueba, buf, len);
	printk("Nuevo nombre: %s\n", prueba);
	return 0;
/* Custom service variables */
#define BT_UUID_SERVER_UART BT_UUID_128_ENCODE(0x0003CDD0, 0x0000, 0x1000, 0x8000, 0x00805f9b0131)
static struct bt_uuid_128 server_uart_tx_uuid = BT_UUID_INIT_128(
	BT_UUID_128_ENCODE(0x0003CDD1, 0x0000, 0x1000, 0x8000, 0x00805f9b0131));
static struct bt_uuid_128 server_uart_rx_uuid = BT_UUID_INIT_128(
	BT_UUID_128_ENCODE(0x0003CDD2, 0x0000, 0x1000, 0x8000, 0x00805f9b0131));
static const uint8_t device_name[] = DEF_BLE_NAME;
static struct bt_uuid_16 automation_io_uuid = BT_UUID_INIT_16( 0x1815 );
static struct bt_uuid_16 device_name_uuid = BT_UUID_INIT_16( BT_UUID_GAP_DEVICE_NAME_VAL );
/* UART custom service declaration */
BT_GATT_SERVICE_DEFINE(automation_io_svc,
	BT_GATT_PRIMARY_SERVICE(&automation_io_uuid),
	BT_GATT_CHARACTERISTIC(&device_name_uuid.uuid,
			       BT_GATT_CHRC_WRITE_WITHOUT_RESP | BT_GATT_CHRC_NOTIFY,
				   BT_GATT_PERM_READ | BT_GATT_PERM_WRITE,
				   NULL, device_name_chr_write, NULL
	BT_GATT_CHARACTERISTIC(&server_uart_tx_uuid.uuid,
				   BT_GATT_PERM_READ,
				   uart_tx_chr_read, NULL, NULL
	BT_GATT_CCC(ccc_changed,
		    BT_GATT_PERM_READ | BT_GATT_PERM_WRITE),
	BT_GATT_CHARACTERISTIC(&server_uart_rx_uuid.uuid,
			       BT_GATT_CHRC_WRITE_WITHOUT_RESP,
				   BT_GATT_PERM_WRITE,
				   NULL, uart_rx_chr_write, NULL
static struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, device_name, sizeof(device_name)-1),
    BT_DATA(BT_DATA_UUID16_ALL, &automation_io_uuid.val, sizeof(automation_io_uuid.val)),
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		printk("Connection failed (err %u)\n", err);
		return;
	printk("Connected\n");
	printk("Disconnected (reason %u)\n", reason);
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		printk("Security changed: %s level %u\n", addr, level);
	} else {
		printk("Security failed: %s level %u err %d\n", addr, level,
			err);
BT_CONN_CB_DEFINE(conn_callbacks) = {
	.connected        = connected,
	.disconnected     = disconnected,
	.security_changed = security_changed,
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	printk("Passkey for %s: %06u\n", addr, passkey);
static void auth_cancel(struct bt_conn *conn)
	printk("Pairing cancelled: %s\n", addr);
static void pairing_complete(struct bt_conn *conn, bool bonded)
	printk("Pairing completed: %s, bonded: %d\n", addr, bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	printk("Pairing failed conn: %s, reason %d\n", addr, reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.cancel = auth_cancel,
static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
int ble_init(void) {
    int err;
	LOG_INF("%s", "Starting BLE");
	err = bt_conn_auth_cb_register(&conn_auth_callbacks);
	if (err) {
		printk("Failed to register authorization callbacks.\n");
		return -1;
	err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
	if (err) {
		printk("Failed to register authorization info callbacks.\n");
		return -1;
 	err = bt_enable(NULL);
	if (err) {
		LOG_ERR("%s", "BLE enable error");
		return -1;
	else {
		LOG_INF("%s", "Bluetooth initialized");
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
		LOG_INF("%s", "Settings loaded");
	/* Start advertising  */
	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), NULL, 0);
	if (err) {
		LOG_ERR("Advertising failed to start (err %d)", err);
		return -1;
	return 0;
Thanks!
Pedro.
  • Hi Vidar,
    I tried with 4645.zephyr.hex, I see when scanning Nordic_HIDS_keyboard, then I connect and try to bond. I confirm from phone side, but when trying to confirm from nRF52 DK side, it does nothing when pressing button 1. Maybe our nrF52 DK is damaged.
    You can send me same example but with no display or keyboard callbacks, so it can bond without having to confirm.
    Pedro.
  • Hi Pedro,
    I've re-built the sample without the IO capabilities, so it defaults to LESC just works pairing and I also disabled NFC OOB pairing support. Hope it works.
    8737.zephyr.hex
    Vidar
  • Hi Vidar,
    It connects and bonds correctly to P20 pro, but then, when try to connect, it never connects again:
    Connected 3C:CD:5D:3F:DC:50 (public)
    Advertising successfully started
    W: Not connected!
    Disconnected from 3C:CD:5D:3F:DC:50 (public) (reason 61)
    Advertising continued
    W: Not connected!
    W: Not connected!
    I tried also with a Xiaomi Mi 9T Pro and all work ok, even after bonding. But I tried with an old Samsung Galaxy J5 with Android 5.1.1 and it bonds, but for some reason, it can not discover services and characteristics.
    I hope this helps.
    Pedro.
  • Hi Pedro,
    Do you have an extra DK or nRF52840 Dongle laying around that you can use to capture a sniffer trace with the nRF Sniffer.
    I've created a new hex file which will print the encryption key (LTK). You can use JLink RTT Viewer if you have problems viewing UART logs.
    2742.zephyr.hex
    Vidar
  • Hi Vidar,
    If done tests again with both mobiles.
    Huawei P20 Pro
    Now it works fine. It connects correctly after bonding. See UART log and sniffer trace. p20-pro.pcapng
    *** Booting Zephyr OS build v3.3.99-ncs1-1 ***
    Starting Bluetooth Peripheral HIDS keyboard example
    [00:00:00.007,385] <inf> fs_nvs: nvs_mount: 6 Sectors of 4096 bytes
    [00:00:00.007,415] <inf> fs_nvs: nvs_mount: alloc wra: 0, fd0
    [00:00:00.007,415] <inf> fs_nvs: nvs_mount: data wra: 0, 1c
    [00:00:00.007,568] <inf> bt_sdc_hci_driver: hci_driver_open: SoftDevice Controller build revision:
                                                e0 7e 2e c1 5e 05 85 23  46 15 dc fa 8e 29 7d 70 |.~..^..# F....)}p
                                                10 93 a5 fc                                      |....
    [00:00:00.010,192] <inf> bt_hci_core: hci_vs_init: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:00.010,223] <inf> bt_hci_core: hci_vs_init: HW Variant: nRF52x (0x0002)
    [00:00:00.010,253] <inf> bt_hci_core: hci_vs_init: Firmware: Standard Bluetooth controller (0x00) Version 224.11902 Build 2231721665
    [00:00:00.010,681] <inf> bt_hci_core: bt_init: No ID address. App must call settings_load()
    [00:00:00.011,291] <inf> bt_hci_core: bt_dev_show_info: Identity: D7:06:A1:24:26:8D (random)
    [00:00:00.011,352] <inf> bt_hci_core: bt_dev_show_info: HCI: version 5.4 (0x0d) revision 0x1077, manufacturer 0x0059
    [00:00:00.011,383] <inf> bt_hci_core: bt_dev_show_info: LMP: version 5.4 (0x0d) subver 0x1077
    Connected 79:E9:E4:BA:EC:DB (random)
    Security changed: 79:E9:E4:BA:EC:DB (random) level 2
    [00:00:16.172,271] <inf> bt_keys: bt_keys_show_sniffer_info: SC LTK: 0x9817d9b2bac95f1571a50ab7c81db99b
    Pairing completed: 3C:CD:5D:3F:DC:50 (public), bonded: 1
    Output report has been received 3C:CD:5D:3F:DC:50 (public)
    The operations done were: connect -> bond -> disconnect -> connect -> disconnect -> connect
    Samsung Galaxy J5
    Can not discover services. I did connect -> bond -> disconnect -> connect. See UART log and sniffer trace. galaxy-j5.pcapng
                                                10 93 a5 fc                                      |....
    [00:00:00.011,322] <inf> bt_hci_core: bt_dev_show_info: Identity: D7:06:A1:24:26:8D (random)
    Connected 78:C3:E9:2F:A2:A1 (public)
    Security changed: 78:C3:E9:2F:A2:A1 (public) level 2
    [00:00:19.207,000] <inf> bt_keys: bt_keys_show_sniffer_info: Legacy LTK: 0xd1eb5ef3da7190910bc8048ae2db095d (peripheral)
    [00:00:19.207,061] <inf> bt_keys: bt_keys_show_sniffer_info: Legacy LTK: 0x3e34fdd7dd50cad6199205f79ce5f009 (central)
    Pairing completed: 78:C3:E9:2F:A2:A1 (public), bonded: 1
    Disconnected from 78:C3:E9:2F:A2:A1 (public) (reason 19)
    I hope it helps.
    Pedro.
