BT_HCI_ERR_INSUFFICIENT_SECURITY during re-discovery
Note. This issue only occurs if using the Nordic Soft Device controller or the Packetcraft controller.
I am working with the nRF5340 audio development boards.
I have a project with a central device (used as a Broadcast Assistant) and a peripheral device (used as an audio broadcast receiver). They both form an ACL connection and exchange data.
Whenever the receiver is syncing to a broadcast source and it gets disconnected from the central for whatever reason, the central manages to re-connect to the peripheral, however the BASS discovery fails with BT_HCI_ERR_INSUFFICIENT_SECURITY. The following error is displayed :
<wrn> bt_gatt: gatt_exchange_mtu_func: conn 0x200018c8 err 0x0e
The only way to solve this is by rebooting the receiver / peripheral.
For both the central and receiver applications, bonding is disabled in the proj.conf as follows :
CONFIG_BT_BONDABLE=n
In that case, I can't understand why the BASS re-discovery would fail due to a security error error.
As mentioned above. This only happens when using the Nordic Soft Device controller or the Packetcraft controller. Using the Zephyr controller, the re-discovery works fine without this security problem.
How can there be this security issue only when using those two controllers, and by using the Zephyr controller with the exact same configuration (bonding disabled etc.) it is fine?
Below are the logs from my central application when it re-connects. Thanks in advance for any help or suggestions.
Disconnected from device EE:0B:7C:30:59:12 (random) (reason 0x3e)
About to connect to EE:0B:7C:30:59:12
Connection pending..
Successfully connected to device EE:0B:7C:30:59:12 (random)
Now discovering..
[00:01:04.517,425] <wrn> bt_gatt: gatt_exchange_mtu_func: conn 0x200018c8 err 0x0e
[00:01:04.517,456] <dbg> bt_bap_broadcast_assistant: service_discover_func: Could not discover BASS
Error! BASS discover failed (-6)
  • Hi Paul,
    muli said:
    Do you mean to capture traces from the receiver device again, but using the Zephyr controller instead of the Packetcraft one?
    Yes correct.
    muli said:
    The disconnect still happens when using that controller , but oddly the re-connect and re-discovery works fine with that one.
    Does this mean in the traces provided previously, they don't have the part when the re-connection and re-discovery failed ?
    muli said:
    On another note, before I integrated the Scan Delegator into that audio application, I had a Nordic Uart Service (NUS) implemented there so that a commander could connect and send messages to the receiver over the NUS. It used to disconnect randomly in the exact same way if it was syncing to broadcast streams during the connection.
    I think this matched with the theory from our R&D team that the ACL connection is effected by broadcast ISO regardless which service was used in the GATT server.
    muli said:
    Just on observation today (for what it's worth), I flashed the receiver device with the Zephyr sample ncs\v2.5.0\zephyr\samples\bluetooth\broadcast_audio_sink .It contains a Scan Delegator.  I flashed this together with the Packetcraft controller. The disconnect never happens when using this together with my Broadcast Assistant application.
    Sorry for maybe trivial question, did you mean you the disconnect never happens when combine the firmware with Broadcast Assistant code or when you use it to connect to your Broadcast Assistant board ?
  • Does this mean in the traces provided previously, they don't have the part when the re-connection and re-discovery failed ?
    The traces were captured during the part when the re-connection and re-discovery failed yes. I just don't understand why we don't see packets showing it.
    Yes, I agree
    No, not a trivial question at all. I think there are so many parts and combinations here so it gets confusing:)
    The disconnect never happens when I instead flash this sample to my receiver board instead of the updated Nordic audio application : ncs\v2.5.0\zephyr\samples\bluetooth\broadcast_audio_sink , and with the same Packetcraft controller
    Of course this sample / application is not as complex as the Nordic audio application, but this does connect to my Broadcast Assistant application and receives the same commands from it for the Scan Delegator, and then receives broadcast data from the broadcast devices. The connection never drops between the two boards in that case.
    The Broadcast Assistant application remains the same for every test.
  • Hi Paul
    I will take over this case from Hung since I have a bit more experience with LE Audio.
    It is interesting that it all works fine when switching to the broadcast_audio_sink application. Have you tried to capture a sniffer trace when everything works, to see if there is some critical difference that can be spotted in the trace?
    I think we should try to reproduce the issue internally so that we can do some tests on our own, speeding up the investigation into the issue.
    Would you be able to share your code so that I can try to reproduce the issue here?
    If you don't want to share your code in a public ticket just let me know, and I will make the ticket private.
    Best regards
    Torbjørn
  • Hi  . Thanks for looking into this. I haven't actually collected sniffer traces when connected to the broadcast_audio_sink application. I wasn't sure if there is much point.
    What's a real headache is that when I am capturing traces when the problem occurs with the other receiver application, there are no packets indicating what is wrong. We can't see why it disconnected and the re-connection with failed GATT discovery.
    What could be worth trying, to replicate this, is take the existing Nordic audio application as it is, add just add the ability to have an ACL connection from a central device. Connect the central device, keep switching audio broadcasts on the receiver and see that the connection to the central drops at some point.
    I can try and share my code next week also.
    Paul
  • Hi
    I've taken the latest Nordic audio application from nrf\applications\nrf5340_audio
    I've made some modifications to start advertising if it's a receiver device as follows :
    bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), NULL,0);
    and allows a connection from a central device.
    When a central is connected and the receiver is streaming broadcast audio, occasionally the connection drops and I get this error and crash :
    HL [00:01:13.699,676] <inf> bt_mgmt: Disconnected: C2:DA:2D:C3:36:C7 (random) (reason 0x08)
    HL [00:01:13.699,707] <wrn> streamctrl_broadcast_sink: Unexpected/unhandled bt_mgmt event: 6
    HL [00:01:13.699,707] <err> bt_mgmt_adv: No valid advertising data stored
    HL [00:01:13.699,737] <err> bt_mgmt: ERR_CHK Err_code: [-2] @ line: 177
    HL [00:01:13.699,737] <err> os: r0/a1:  0x00000003  r1/a2:  0x00000004  r2/a3:  0x00000003
    HL [00:01:13.699,737] <err> os: r3/a4:  0x00060591 r12/ip:  0x0000000c r14/lr:  0x0006061b
    HL [00:01:13.699,768] <err> os:  xpsr:  0x41100000
    HL [00:01:13.699,768] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000010  s[ 2]:  0x20017a70  s[ 3]:  0x0006fdd4
    HL [00:01:13.699,768] <err> os: s[ 4]:  0x20017a78  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
    HL [00:01:13.699,768] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00009903  s[10]:  0x00006d6f  s[11]:  0x200033d0
    HL [00:01:13.699,798] <err> os: s[12]:  0x00000002  s[13]:  0x200033d0  s[14]:  0x00000002  s[15]:  0x20017a70
    HL [00:01:13.699,798] <err> os: fpscr:  0x00000004
    HL [00:01:13.699,829] <err> os: Faulting instruction address (r15/pc): 0x00009910
    HL [00:01:13.699,829] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
    HL [00:01:13.699,859] <err> os: Current thread: 0x20004208 (sysworkq)
    HL [00:01:13.699,859] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
