USB CDC ACM: RX data gets overwritten in app_usbd_cdc_acm_read_any() at end of data transmission
To handle RX of USB CDC ACM we are polling data using:
ret = app_usbd_cdc_acm_read_any(&m_app_cdc_acm, m_rx_buffer, MIN(BUFFER_SIZE,size));
On
case NRF_SUCCESS:
rx_size = app_usbd_cdc_acm_rx_size(&m_app_cdc_acm);
copy_rx_data(buffer, n, m_rx_buffer);
We assume data has been transferred to our use buffer `m_rx_buffer` and get the data directly.
On
case NRF_ERROR_IO_PENDING:
usb_txrx_state = USB_TXRX_STATE_RX;
We assume data has been NOT been transferred and assume to we get the data in the event handler instead.
void cdc_acm_user_ev_handler(app_usbd_class_inst_t const * p_inst,
app_usbd_cdc_acm_user_event_t event)
app_usbd_cdc_acm_t const * p_cdc_acm = app_usbd_cdc_acm_class_get(p_inst);
last_usb_cdc_event = event;
ret_code_t ret;
switch (event)
case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
rx_size = app_usbd_cdc_acm_rx_size(p_cdc_acm);
This works well until the end of the data (583 bytes in total) is transferred.
On the NEXT TO LAST call to app_usbd_cdc_acm_read_any() we get NRF_SUCCESS and get correct data.
On the last call to app_usbd_cdc_acm_read_any() we get NRF_ERROR_IO_PENDING, but we see that correct data anyway has still been transferred to m_rx_buffer.
But because we assume there are no data directly available (it should be fetched in event handler) we make an intermediate call to:
while (app_usbd_event_queue_process()) {
To finalize the transfer event handler.
Stepping through app_usbd_event_queue_process() we see the following sequence of calls ...
#if (APP_USBD_CONFIG_SOF_HANDLING_MODE == APP_USBD_SOF_HANDLING_COMPRESS_QUEUE)
if (p_event_item->sof_cnt > 0)
if (p_event_item->start_frame > USBD_FRAMECNTR_FRAMECNTR_Msk)
p_event_item->start_frame = 0;
sof_event.drv_evt.data.sof.framecnt = (p_event_item->start_frame)++;
--(p_event_item->sof_cnt);
app_usbd_event_execute(&sof_event);
return true;
#endif // (APP_USBD_CONFIG_SOF_HANDLING_MODE == APP_USBD_SOF_HANDLING_COMPRESS_QUEUE)
==> app_usbd_event_execute(&(p_event_item->evt));
* @brief @ref app_usbd_class_methods_t::event_handler
static ret_code_t cdc_acm_event_handler(app_usbd_class_inst_t const * p_inst,
app_usbd_complex_evt_t const * p_event)
ASSERT(p_inst != NULL);
ASSERT(p_event != NULL);
ret_code_t ret = NRF_SUCCESS;
switch (p_event->app_evt.type)
case APP_USBD_EVT_DRV_EPTRANSFER:
==> ret = cdc_acm_endpoint_ev(p_inst, p_event);
static ret_code_t cdc_acm_endpoint_ev(app_usbd_class_inst_t const * p_inst,
==> ret = cdc_acm_rx_block_finished(p_inst);
static ret_code_t cdc_acm_rx_block_finished(app_usbd_class_inst_t const * p_inst)
==> memcpy(p_cdc_acm_ctx->rx_transfer[0].p_buf,
p_cdc_acm_ctx->internal_rx_buf,
bytes_to_cpy);
The final memcpy finally COPIES OLD DATA from p_cdc_acm_ctx into our user buffer (which contained good data).
So there seems to be some internal USB stack state machine problem here ...
To summarise:
1. Correct data is transferred from app_usbd_cdc_acm_read_any() even if we got NRF_ERROR_IO_PENDING.
2. Consective call app_usbd_event_queue_process() copies old data (i.e. overwrites good data) to user buffer. This should not be possible if USB state contained in p_cdc_acm_ctx is valid.
3. We dont get APP_USBD_CDC_ACM_USER_EVT_RX_DONE event as expected until user buffer is overwritten by app_usbd_event_queue_process()
We are using SDK 17.0.2.
We have enabled APP_USBD_CDC_ACM_CONFIG_LOG_ENABLED, but it does not give any good indication.
One addional note: This is size dependent as well. So if last call returns data pending (which seems to be size dependent) internal buffer seems to be corrupted.
615 OK
593 - 599 OK
581-592 NOK
  • Aha, so you are on a Windows machine?
    lsusb is UNIX utility so that could be a problem on Windows.
    I am working from Ubuntu 20.04.
    lsusb and usb_connected? part is only for robustness of the script and could be removed if neccesary.
    # Open protocol towards serial client
    loop do
    if usb_connected? then
    show "BLE device connected. Connect to USB serial port."
    sp = SerialPort.new(serial_dev, 115200, 8, 1, SerialPort::NONE)
    break
    show "BLE device not connected to USB port. Wait ..."
    sleep 10
    end
    end
    could be replaced by
  • Thanks for the tip, Peter. I commented out the USB connected check and it seems the script can progress past that now.
    However, it seems the test is not running as expected:
    When I tried the first project you sent instead, my PC doesn't even accept the USB device..
    Do you have any idea what is wrong? I will dive into it in a bit, but asking in case something makes sense for you immediately.
    By the way, I am thinking about modifying the projects so that the device just listens, and the Ruby script immediately sends a fixed size packet. Do you think there is any problem with this?
  • Actually I have not tried exactly this sample on Windows.
    Question is if the USB device is detected by Windows or not. Can you check?
    On Linux, device may alter between e.g. two devices e.g. ttyACM2 and ttyACM3
    I think we had to introduce a delay specifically for Windows compared with Linux in another project.
    So you could try to introduce a delay between usb_config() and usb_write() and/or include a set of process_usb_events() between operations.
    Hope this helps.
    I will also try on a Windows machine tomorrow and compare ...
    Best regards / Peter
  • I tried this on a Windows machine ...
    But unfortunately I couldn't get Nordic USB CDC ACM sample to work on Windows or my sample.
    Device was not detected by Device Manager.
    USB CDC ACM Example
    I also tried on Linux and there both variants was detected by the OS.
    I tested on a Windows 10 machine and assume that no drivers are needed.
    If you could test on a Linux machine I think it would simplify things, but I will also make a new attempt on Windows next week.
    Have you tested the Nordic USB CDC sample on your machine?
