nRF7002dk nrf5340 bus fault after shutting down interface
I am working on a low power sensor logging project using the nRF7002dk. So far, I have updated the main loop in the wifi/sta sample and in place of the:
k_sleep(K_FOREVER);
I have added:
status = net_mgmt(NET_REQUEST_WIFI_DISCONNECT, iface, NULL, 0);
status = net_if_down(iface);
k_sleep(K_SECONDS(2)); // will be longer in production, shortened for testing
status = net_if_up(iface);
k_sleep(K_SECONDS(2)); // allow the interface time to come up
I also have code verifying the statuses are returned as 0, but haven't posted that here to simplify my post.
I find that after a few connections, there is a kernel panic when trying to bring the interface back up.
[00:04:56.560,913] <inf> sta: State: SCANNING
[00:04:56.861,053] <inf> sta: ==================
[00:04:56.861,083] <inf> sta: State: SCANNING
[00:04:57.150,177] <err> os: ***** BUS FAULT *****
[00:04:57.150,177] <err> os: Precise data bus error
[00:04:57.150,207] <err> os: BFAR Address: 0x40000b08
[00:04:57.150,207] <err> os: r0/a1: 0x20000200 r1/a2: 0x20000580 r2/a3: 0x20000289
[00:04:57.150,207] <err> os: r3/a4: 0x20000588 r12/ip: 0x2003cca0 r14/lr: 0x200006a8
[00:04:57.150,238] <err> os: xpsr: 0x01000000
[00:04:57.150,238] <err> os: Faulting instruction address (r15/pc): 0x0003e97a
[00:04:57.150,268] <err> os: >>> ZEPHYR FATAL ERROR 25: Unknown error on CPU 0
[00:04:57.150,299] <err> os: Current thread: 0x20003470 (unknown)
The kernel panics stop if I add a 1 second delay between the net_mgmt and net_if_up calls.
It appears that I can not shut down the interface immediately after disconnecting or something is not cleaned up that causes issues when bringing the interface back up. Obviously in production code, I would like to replace the delay with a check to ensure the disconnect has completed in case it takes longer than 1 second. How can I determine when it is safe to shut down the interface?
    I rebased, ensuring that the commit changes were included and am able to confirm that the commit does fix the issue I was seeing. I was able to connect & disconnect without crashes around an hour.
    However, I tested this fix in my main project which I've uploaded here: https://dl.defelsko.com/downloads/nordic_test.zip
    After about an hour I got an error:
    [2023-10-19 10:19:11] 200
    [2023-10-19 10:19:11] No ip.
    [2023-10-19 10:19:11] OK
    [2023-10-19 10:19:11] [00:48:05.573,913] <inf> sta: Disconnection request done (0)
    [2023-10-19 10:19:11] [00:48:05.580,200] <inf> sta: ==================
    [2023-10-19 10:19:11] [00:48:05.580,230] <inf> sta: State: DISCONNECTED
    [2023-10-19 10:19:11] [00:48:05.580,444] <inf> sta: Disconnect requested
    [2023-10-19 10:19:11] disconnect:0
    [2023-10-19 10:19:11] [00:48:05.598,815] <err> wifi_nrf: nrf_wifi_hal_buf_map_tx: Called for already mapped TX buffer
    [2023-10-19 10:19:11] [00:48:05.598,846] <err> os: ***** MPU FAULT *****
    [2023-10-19 10:19:11] [00:48:05.598,846] <err> os: Data Access Violation
    [2023-10-19 10:19:11] [00:48:05.598,846] <err> os: MMFAR Address: 0xd0
    [2023-10-19 10:19:11] [00:48:05.598,876] <err> os: r0/a1: 0x00009879 r1/a2: 0x00000000 r2/a3: 0x00000006
    [2023-10-19 10:19:11] [00:48:05.598,876] <err> os: r3/a4: 0x00000001 r12/ip: 0x2000270b r14/lr: 0x00035393
    [2023-10-19 10:19:11] [00:48:05.598,907] <err> os: xpsr: 0x01000000
    [2023-10-19 10:19:11] [00:48:05.598,907] <err> os: Faulting instruction address (r15/pc): 0x000353bc
    [2023-10-19 10:19:11] [00:48:05.598,937] <err> os: >>> ZEPHYR FATAL ERROR 19: Unknown error on CPU 0
    [2023-10-19 10:19:11] [00:48:05.598,968] <err> os: Current thread: 0x20003540 (unknown)
    [2023-10-19 10:19:11] [00:48:05.693,786] <err> coredump: #CD:BEGIN#
    [2023-10-19 10:19:11] [00:48:05.698,913] <err> coredump: #CD:5a4501000300050013000000
    [2023-10-19 10:19:11] [00:48:05.705,566] <err> coredump: #CD:4102004400
    [2023-10-19 10:19:11] [00:48:05.711,029] <err> coredump: #CD:799800000000000006000000010000000b27002093530300bc53030000000001
    [2023-10-19 10:19:11] [00:48:05.721,191] <err> coredump: #CD:a018012000000000000000000000000000000000000000000000000000000000
    [2023-10-19 10:19:11] [00:48:05.731,353] <err> coredump: #CD:00000000
    [2023-10-19 10:19:11] [00:48:05.736,633] <err> coredump: #CD:4d01004035002008360020
    [2023-10-19 10:19:11] [00:48:05.743,133] <err> coredump: #CD:e0380020705e0020000000000080000000000000000000000000000000000000
    [2023-10-19 10:19:11] [00:48:05.753,295] <err> coredump: #CD:b5a20600000000000000000000000000ffffffff10000000e45d0020e4100020
    [2023-10-19 10:19:11] [00:48:05.763,488] <err> coredump: #CD:64788c0084100320c0000000647800b028180120000000009835002098350020
    [2023-10-19 10:19:11] [00:48:05.773,651] <err> coredump: #CD:0000000000000000000000000000000000000000000000000000000000000000
    [2023-10-19 10:19:11] [00:48:05.783,843] <err> coredump: #CD:0000000000000000000000000000000000000000000000005812012000080000
    [2023-10-19 10:19:11] [00:48:05.794,006] <err> coredump: #CD:000000008c1500200000000000000000f8180120000000004035002000000000
    [2023-10-19 10:19:11] [00:48:05.804,168] <err> coredump: #CD:0000000000000000
    [2023-10-19 10:19:11] [00:48:05.810,150] <err> coredump: #CD:4d010058120120581a0120
    [2023-10-19 10:19:11] [00:48:05.816,650] <err> coredump: #CD:f0f0f0f0aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [2023-10-19 10:19:11] [00:48:05.826,812] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    [2023-10-19 10:19:11] [00:48:05.837,005] <err> coredump: #CD:aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    This project includes code from the wifi/sta, net/sockets/http_get, and bluetooth/peripheral_lbs samples. Most of the bluetooth code has been removed, but it does advertise, which I have been using when logging is off to ensure the code is still running and has not crashed. If you set the name of an access point and password in the configuration, this code should connect to wifi, hit the HTTP end point with an incrementing value, disconnect and shut down wifi, pause and bring the interface back up and reconnect every few seconds. You'll see I have commented out tracks of code where I ran the http_get portion of code in an endless loop to ensure it didn't have any memory leaks.
    The issue I was seeing has been fixed, but I am still unable to achieve stable operation with this mode of operation.
    Applications can be developed with wireless coexistence. You could have a look at Wi-Fi Bluetooth LE coexistence and its documentation.
    Dejan
    To rule out any issues related to BLE or to wireless coexistence we have commented out the Bluetooth code in our project. It failed with exactly the same error message as provided above. We do not think wireless coexistence is related to the crashes because it still crashes even with Bluetooth disabled.
    Here is our project with Bluetooth commented out: https://dl.defelsko.com/downloads/nordic_test_no_ble.zip
    I have tested your project for little more than 1 hour and could not reproduce your issue.
    With a purpose of reproducing the issue, it would be useful if you could test multiple times with the same board and also use another board if you have it available for testing. You should also consider connecting to another access point to check if the issue appears there as well.
    Dejan
    The error we have been getting when testing with our main development board and new WiFi 6 access point occurs after 2 or 3 hours and we see the message I posted previously. We have tested this 5 or 6 times with the same result every time.
    Today, as suggested, we tested on a different development board and with a different (older WiFi 4) access point.
    After 3 hours, it stopped operating with this message:
    [2023-10-25 14:29:12] addrinfo @0x2006c038: ai_family=1, ai_socktype=1, ai_protocol=6, sa_family=1, sin_port=5000
    [2023-10-25 14:29:12] sock = 9
    [2023-10-25 14:29:12] OK
    [2023-10-25 14:29:12] FAIL
    We restarted the development board and after 3 hours got the same message.
    Neither board has run for 4 continuous hours without crashing, but they always run longer than an hour and a half.
    Switching routers/development boards does not fix the problem.
