nRF7002dk nrf5340 bus fault after shutting down interface
I am working on a low power sensor logging project using the nRF7002dk. So far, I have updated the main loop in the wifi/sta sample and in place of the:
k_sleep(K_FOREVER);
I have added:
status = net_mgmt(NET_REQUEST_WIFI_DISCONNECT, iface, NULL, 0);
status = net_if_down(iface);
k_sleep(K_SECONDS(2)); // will be longer in production, shortened for testing
status = net_if_up(iface);
k_sleep(K_SECONDS(2)); // allow the interface time to come up
I also have code verifying the statuses are returned as 0, but haven't posted that here to simplify my post.
I find that after a few connections, there is a kernel panic when trying to bring the interface back up.
[00:04:56.560,913] <inf> sta: State: SCANNING
[00:04:56.861,053] <inf> sta: ==================
[00:04:56.861,083] <inf> sta: State: SCANNING
[00:04:57.150,177] <err> os: ***** BUS FAULT *****
[00:04:57.150,177] <err> os: Precise data bus error
[00:04:57.150,207] <err> os: BFAR Address: 0x40000b08
[00:04:57.150,207] <err> os: r0/a1: 0x20000200 r1/a2: 0x20000580 r2/a3: 0x20000289
[00:04:57.150,207] <err> os: r3/a4: 0x20000588 r12/ip: 0x2003cca0 r14/lr: 0x200006a8
[00:04:57.150,238] <err> os: xpsr: 0x01000000
[00:04:57.150,238] <err> os: Faulting instruction address (r15/pc): 0x0003e97a
[00:04:57.150,268] <err> os: >>> ZEPHYR FATAL ERROR 25: Unknown error on CPU 0
[00:04:57.150,299] <err> os: Current thread: 0x20003470 (unknown)
The kernel panics stop if I add a 1 second delay between the net_mgmt and net_if_up calls.
It appears that I can not shut down the interface immediately after disconnecting or something is not cleaned up that causes issues when bringing the interface back up. Obviously in production code, I would like to replace the delay with a check to ensure the disconnect has completed in case it takes longer than 1 second. How can I determine when it is safe to shut down the interface?
    In Wi-Fi 4 case, we would need to get more information about the cause of failure, and we could get this from your code. Could you share relevant piece of code from which we could get more information what causes error to appear?
    Please note that in case your code contains any private or sensitive information, I can make this case private.
    Dejan
    I have already provided my code.
    Here is our project with Bluetooth commented out: https://dl.defelsko.com/downloads/nordic_test_no_ble.zip
    The only differences between that and what I am running are that my code obviously has an SSID and password, and in http_get.c I've specified the address of an internal test server which posts a PHP endpoint which just returns the posted data.
    Yes, you are right. We will look into it.
    Thank you for this information.
    Dejan
    Could you try to use possible fix given below?
     overlay-debug.conf | 14 ++++++++++++++
     prj.conf           |  4 ++++
     src/main.c         |  7 +++++++
     3 files changed, 25 insertions(+)
     create mode 100644 overlay-debug.conf
    diff --git a/overlay-debug.conf b/overlay-debug.conf
    new file mode 100644
    index 0000000..dd83de0
    --- /dev/null
    +++ b/overlay-debug.conf
    @@ -0,0 +1,14 @@
    +CONFIG_SHELL=y
    +CONFIG_SHELL_BACKEND_SERIAL=y
    +CONFIG_SHELL_STACK_SIZE=4096
    +CONFIG_NET_SHELL=y
    +CONFIG_SHELL_GETOPT=y
    +CONFIG_SHELL_CMDS_RESIZE=n
    +CONFIG_NRF700X_UTIL=y
    +CONFIG_NET_L2_WIFI_SHELL=y
    +CONFIG_NET_STATISTICS=y
    +CONFIG_NET_STATISTICS_WIFI=y
    +CONFIG_NET_STATISTICS_USER_API=y
    +CONFIG_SYS_HEAP_RUNTIME_STATS=y
    +# Enable for debugging connection issues
    +# CONFIG_WPA_SUPP_LOG_LEVEL_DBG=y
    diff --git a/prj.conf b/prj.conf
    index 9b91578..32695f2 100644
    --- a/prj.conf
    +++ b/prj.conf
    @@ -107,3 +107,7 @@ CONFIG_NET_HTTP_LOG_LEVEL_DBG=y
     CONFIG_THREAD_NAME=y
     CONFIG_RESET_ON_FATAL_ERROR=n
    +# debugging
    diff --git a/src/main.c b/src/main.c
    index d9bcfe7..a3a76aa 100644
    --- a/src/main.c
    +++ b/src/main.c
    @@ -416,6 +416,12 @@ int wifi_poweron(struct net_if *iface)
     //~ #define BT_LE_ADV_CONN_DEF BT_LE_ADV_PARAM(BT_LE_ADV_OPT_CONNECTABLE, 0x0640, 0x0680, NULL)
    +void dump_rpu_stats(void)
    +	shell_execute_cmd(shell_backend_uart_get_ptr(), "wifi_util tx_stats 0");
    +	shell_execute_cmd(shell_backend_uart_get_ptr(), "wifi_util rpu_stats all");
     	//volatile unsigned int *myPointer = (volatile unsigned int *) 0x5002B500;
    @@ -505,6 +511,7 @@ int main(void)
     			while (!have_ip) {
     				attempt++;
     				printf("%d\n",attempt);
    +				dump_rpu_stats();
     				if (attempt==200) {
     					printf("No ip.\n");
     					err=-99;
    Please make sure that you build with overlay-debug.conf by providing extra argument    -DOVERLAY_CONFIG=overlay-debug.conf. If the issue is still present, please provide full logs, and elf files.
    Dejan
    I have tested the changes you provided, they made no difference to the behavior. They all appear to be related to adding more debug output.
    I tested with both access points and have uploaded my elf files and logs here: dl.defelsko.com/.../nordic_logs_nov1.zip
