nRF7002dk nrf5340 bus fault after shutting down interface
I am working on a low power sensor logging project using the nRF7002dk. So far, I have updated the main loop in the wifi/sta sample and in place of the:
k_sleep(K_FOREVER);
I have added:
status = net_mgmt(NET_REQUEST_WIFI_DISCONNECT, iface, NULL, 0);
status = net_if_down(iface);
k_sleep(K_SECONDS(2)); // will be longer in production, shortened for testing
status = net_if_up(iface);
k_sleep(K_SECONDS(2)); // allow the interface time to come up
I also have code verifying the statuses are returned as 0, but haven't posted that here to simplify my post.
I find that after a few connections, there is a kernel panic when trying to bring the interface back up.
[00:04:56.560,913] <inf> sta: State: SCANNING
[00:04:56.861,053] <inf> sta: ==================
[00:04:56.861,083] <inf> sta: State: SCANNING
[00:04:57.150,177] <err> os: ***** BUS FAULT *****
[00:04:57.150,177] <err> os: Precise data bus error
[00:04:57.150,207] <err> os: BFAR Address: 0x40000b08
[00:04:57.150,207] <err> os: r0/a1: 0x20000200 r1/a2: 0x20000580 r2/a3: 0x20000289
[00:04:57.150,207] <err> os: r3/a4: 0x20000588 r12/ip: 0x2003cca0 r14/lr: 0x200006a8
[00:04:57.150,238] <err> os: xpsr: 0x01000000
[00:04:57.150,238] <err> os: Faulting instruction address (r15/pc): 0x0003e97a
[00:04:57.150,268] <err> os: >>> ZEPHYR FATAL ERROR 25: Unknown error on CPU 0
[00:04:57.150,299] <err> os: Current thread: 0x20003470 (unknown)
The kernel panics stop if I add a 1 second delay between the net_mgmt and net_if_up calls.
It appears that I can not shut down the interface immediately after disconnecting or something is not cleaned up that causes issues when bringing the interface back up. Obviously in production code, I would like to replace the delay with a check to ensure the disconnect has completed in case it takes longer than 1 second. How can I determine when it is safe to shut down the interface?
    Thank you for testing and for providing required files.
    We will look into it. I will get back to you with new information as soon as possible.
    Dejan
    Could you provide sniffer trace for Wi-Fi 4 communication?
    In wi-fi 4 case, what is the criterion for OK/FAIL? Are OK and FAIL status codes from httpbin.org?
    Dejan
  • In wi-fi 4 case, what is the criterion for OK/FAIL? Are OK and FAIL status codes from httpbin.org?
    We are not using httpbin.org as I mentioned previously:
    I've specified the address of an internal test server which posts a PHP endpoint which just returns the posted data.
    I added httpbin.org to the code provided so that you could see how the http post code functions. You will likely need a PHP endpoint on your own server to test this, I found that httpbin.org appears to have DoS protections that prevent this test from working continuously.
    I do not know what the criterion for OK/FAIL are. That is why I posted in the DevZone asking for help. I assume they come from somewhere in your driver code or is a message being passed through from the modem?
    Has any progress been made on the initial WiFi 6 issue where an MPU fault occurs when you disconnect & bring the interface down while to obtain an IP address? Based on the logs, it appears that the problem there is that once I give up waiting for an IP and try to disconnect and bring the interface down, the MPU fault occurs. I assume that is related to background processing not being cleaned up?
    Based on your comment, is it correct that OK/FAIL is not coming from your internal server?
    This is still work in progress.
    For further debugging we would need sniffer trace of wi-fi 4 communication. Could you provide it?
    Dejan
  • Based on your comment, is it correct that OK/FAIL is not coming from your internal server?
    That is correct.
    I will work on gathering that today and will provide the sniffer trace and console logs once they are available.
