Hi!
I need to include a specific .h for each board. How can I know, in compiling time, which board is being compiled?
Something like:
#ifdef BOARD_A #include "board-a.h" #endif
Thanks!
Pedro.
Hi!
Something like:
Thanks!
Pedro.
If you are using segger embedded studio as your IDE then you have to go to project options there you select the common setting from the drop down menu, usually it's in release, then you go to preprocessor settings and there you will find something like definitions you double click on that and you will see BOARD_PCA10056 if the example is made for that. There you can write BOARD_CUSTOM and then in the boards.h file you can see which board is highlighted.
Hi!
I'm using NCS v2.0.2 with Zephyr and Visual Studio Code. How can be done with this SDK?
Thanks!
In nRF Connect SDK you can use the CONFIG_BOARD_<BOARD_NAME> config, which comes from the selected build target. For example, for nRF52 DK you can use:
#ifdef CONFIG_BOARD_NRF52DK_NRF52832 #include "board-nrf52dk.h" #endif
This configuration is defined in the Kconfig.board file for each board, also for custom boards, for example: zephyr/boards/arm/nrf52dk_nrf52832/Kconfig.board.
Marte
Thank you Marte!
It's exactly what I needed.
Pedro.
