Installing ESB when using bootloader
I am doing a bootloader to support updates via ESB. I am using MicroLib. I am not using SoftDevice.
My project mapping:
Bootloader 0x0000-0xBFF Application Vector Table 0xC00 Application 0x1000-0x7FFF
My bootloader pulls the reset vector out of the Application Vector Table and successfully starts the Application. I also am processing interrupts by doing a jump in my bootloader to the appropriate address in the Application Vector Table per other examples found on the Forum. My problem is that I had to disable all of the ESB calls to get the application to run. I see addresses to nrf_impala routines in the Application Vector Table. How do I handle these to properly initialize ESB (and anything else I am missing)? My guess is that the initialization/library installation is normally done by __main(). I jump directly to main() in my application since the application vector table is at the wrong spot, so __main() crashes in my application. I don’t want to overwrite my original vector table for safety reasons.
I am following the example from this post devzone.nordicsemi.com/.../.
I have verified that my bootloader transfers to the application and correctly processes the interrupts. All of my variables are zero-initialized. I modified my arm_startup_nrf51.s routine to set all RAM to 0. I copied my hex file from page 0 of the application below. I am trying to understand what all the values are from 0xC0 - 0x1F8. I assume that these are used by __main. Some initialize static/global variables ( I have handled this ). The others appear to be addresses. I don't know how to deal with these. Is there source code for __main() available?
Any suggestions? I am hoping this is a common problem that has already been solved. I haven’t been able to find an appropriate example anywhere on the Forum. I have attempted to decipher the initial section below.
Vector Table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nd of Vector Table
:1000C000 034885460 0F006F8 00480047 6D600000 D0 46854803 ?? F806F000 ?? 47004800 ?? 0000606D main() in application - handled in ARM_startup_nrf51 - jump to main instead of __main :1000D000 00400020 064C0125 064E05E0 E36807CC F1 20004000 Top of RAM 25014C06 ?? E0054E06 ?? CC0768E3 ?? :1000E000 2B430C3C 98471034 B442F7D3 FFF7ECFF 96 3C0C432B ?? 34104798 ?? D3F742B4 ?? FFECF7FF ?? :1000F000 18010000 48010000 02E008C8 121F08C1 F2 00000118 ? address 118 has 148 in it ? 00000148 Start address of .data initialization section C808E002 ?? C1081F12 ?? :10010000 002AFAD1 70477047 002001E0 01C1121F 98 D1FA2A00 ?? 47704770 ?? E0012000 ?? 1F12C101 ?? :10011000 002AFBD1 70470000 48010000 00010020 C8 D1FB2A00 ?? 00007047 ?? 00000148 Start of .data initialization section 20000100 Start of Application RAM (.data is at start) [DONE] :10012000 4C000000 F8000000 94010000 4C010020 89 0000004C ?? 000000F8 ?? 00000194 End of this section of hex file 2000014C Start address of .bss section [DONE] :10013000 E8060000 08010000 94010000 00300020 E3 000006E8 Length of .bss section 00000108 ?? 00000194 End of this section of hex file 20003000 Start of stack [DONE] :10014000 00100000 08010000 0024F400 00000000 7E 00001000 Size of stack [DONE] 00000108 ?? 00F42400 Start of initialized variable data 00F42400 Used by System_Nrf.o (4 bytes) - SystemCoreClock - Not used in application [IGNORE]
:10015000000000000000000000000000000000009F :10016000000000000000000000000000000000008F :10017000000000000000000000000000000000007F :1001800000000000000000000000000067240000E4 :04019000F128000052 [PROBLEM] 20000140 => 40 + 148 = 188 .data 0x20000140 Section 12 nrf_state_machine.o(.data) :0801F000 67240000 F1280000 63 nrf_impl_state_fun_timeslot_start 0x00002467 Thumb Code 1162 nrf_impala.o(.text) nrf_impl_state_fun_device_send_packet 0x000028f1 Thumb Code 74 nrf_impala.o(.text) End of initialized variable data
  • Hi, you need to forward execution to the reset handler of the application in order for the application to be properly initialized (load static variables, vector table, etc.) __main. Assume 0xC000 is a typo, should be 0xC00(?),but is there a particular reason for not linking the application vector table together with the application like in the SDK examples?
    That being said, it does sound like the interrupts are not being forwarded correctly from the bootloader to the app. I would suggest to try a simple example that uses interrupts (e.g,\nRF51_SDK_10.0.0\examples\peripheral\led_softblink) and see whether or not the interrupts are being forwarded correctly from the bootloader.
  • You are correct - table starts at 0xC00. Can you provide the link to the SDK example? I can't seem to locate it. Is there a way to locate the application vector table at an address other than 0x00000000? I don't have a reason for my method. I assume this has already been solved somewhere, but I can't locate the appropriate example.
    I have verified that the interrupts are forwarded correctly in my routine. See my modified question above.
  • Here is the interrupt handler in my bootloader. It shows how the interrupts are forwarded to the application. I have verified it.
    NMI_Handler .. .. SWI0_IRQHandler
    EXPORT NMI_Handler
    EXPORT SWI0_IRQHandler
    APPLICATION_VECTOR_TABLE EQU 0x0C00
    MRS  R0, PSR
    ; Mask to get the interrupt number
    ANDS R0, R0, #0x3F
    EXTERN bootloader_active
    LDR  R1, =bootloader_active
    LDR  R2, [R1]
    CMP  R2, #1
    BEQ  bootload
    LDR  R2, =APPLICATION_VECTOR_TABLE
    ; Irq address position = IRQ No * 4
    LSLS R0, R0, #2
    ; Fetch the user vector offset
    LDR	 R0, [R0, R2]
    ; Jump to user interrupt vector
    BX	 R0
    ; Bootloader IRQ handlers - currently none used
    bootload CMP R0, #27 BEQ RTC0
    ; RETURN code needed?
    ; RTC0 put here for sample. Copy as needed.
    RTC0 EXTERN RTC0_IRQHandler_Bootloader[WEAK] LDR R0,=RTC0_IRQHandler_Bootloader B execute
    execute BX R0
