nRF52DK nRF52832 UART asynchronous receive
I am working through the Nordic Developer Academy and got stuck at lesson 4 (UART receive)
https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/lessons/lesson-4-serial-communication-uart/topic/uart-driver/
In particular, I am confused about this part:
I have created a sample project and connected external CP2102 USB->Serial adapter to P0.06 and P0.08 pins.
The code that I use:
 * Copyright (c) 2012-2014 Wind River Systems, Inc.
#include <zephyr/kernel.h>
#include "stdio.h"
#include "zephyr/drivers/uart.h"
const struct device *uart = DEVICE_DT_GET(DT_NODELABEL(uart0));
static uint8_t tx_buf[] =  {"nRF Connect SDK Fundamentals Course \n\r"};
static uint8_t rx_buf[10] = {0}; //A buffer to store incoming UART data
const struct uart_config uart_cfg = {
		.baudrate = 115200,
		.parity = UART_CFG_PARITY_NONE,
		.stop_bits = UART_CFG_STOP_BITS_1,
		.data_bits = UART_CFG_DATA_BITS_8,
		.flow_ctrl = UART_CFG_FLOW_CTRL_NONE
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
	switch (evt->type) {
	case UART_TX_DONE:
		printf("transmission complete \n");
	case UART_TX_ABORTED:
		// do something
	case UART_RX_RDY:
		printf("rx rdy \n");
		if((evt->data.rx.len) != 0){
			printf("data received = %s \n", evt->data.rx.buf[evt->data.rx.offset]);
	case UART_RX_BUF_REQUEST:
		printf("requesting buffer \n");
		// do something
	case UART_RX_BUF_RELEASED:
		printf("buffer released \n");
		// do something
	case UART_RX_DISABLED:
		printf("rx disabled \n");
		uart_rx_enable(dev, rx_buf, sizeof(rx_buf), 100);
	case UART_RX_STOPPED:
		// do something
	if (!device_is_ready(uart)) {
    	return;
	int err;
	err = uart_callback_set(uart, uart_cb, NULL);
	if (err) {
		return err;
	uart_rx_enable(uart, rx_buf, sizeof(rx_buf), 100);
	err = uart_tx(uart, tx_buf, sizeof(tx_buf), SYS_FOREVER_US);
	if (err) {
		return err;
	while(1){
		k_msleep(1000);
	return 0;
I am having issues understanding how to properly print out all the received data:
I tried to do:
	case UART_RX_RDY:
but when I send the data via UART (using Termite) , the following is printed:
I would appreciate if someone could clarify how to correctly print out all the received data.  Thanks in advance
Just for testing, I have also tried to print:
    case UART_RX_RDY:
        printf("data: %s \n", rx_buf);
and the logs are as following: (captured using Termite):
As you can see, it receives the first message (ping) correctly, but after that, the buffer overflows (rx_buf is 10 bytes size) and then it cannot print out the data correctly)
  • > At this point, I am not sure how exactly  uart_event.rx.len and uart_event.rx.offset works as it does not seem to show proper values once I change to second dual buffer.
    I've tested with your example.
    I understand now the irritation, I would consider it also as bug.
    When the buffers are switched, it seems that only the first received byte is forwarded. And the others then with the next UART_RX_RDY. Looks like the number of available byte is calculated wrong, when the buffers are swapped.
    Edited:
    I've checked my "working example" and the difference in the "prj.conf" is
    CONFIG_UART_0_ASYNC=y
    CONFIG_UART_0_NRF_HW_ASYNC=y
    CONFIG_UART_0_NRF_HW_ASYNC_TIMER=2
    CONFIG_NRFX_TIMER2=y
    with that, also your example works as you expect and the irritation is gone. :-).
  • Hello. Thank you very much for all your insights.
    I have played around more with my project (Async_UART_debug) branch and I have found something interesting. printk and prinf statements have huge effect on it.
    Even replacing printk statements with cause the Async UART reception to behave differently.
    The full code (also available in my repository, UART_async_working branch.
    #include "stdio.h"
    #include "my_gpio.h"
    #include <zephyr/sys/ring_buffer.h>
    #define LOG_LEVEL 4
    LOG_MODULE_REGISTER(nrf52_learning);
    #define UART_BUF_SIZE 20
    #define UART_RX_TIMEOUT_MS 1000
    K_SEM_DEFINE(rx_disabled, 0, 1);
    // UART RX primary buffers
    uint8_t uart_double_buffer[2][UART_BUF_SIZE];
    uint8_t *uart_buf_next = uart_double_buffer[1];
    uint8_t complete_message[UART_BUF_SIZE];
    uint8_t complete_message_counter = 0;
    bool currently_active_buffer = 1; // 0 - uart_double_buffer[0] is active, 1 - uart_double_buffer[1] is active
    static const struct device *dev_uart;
    	switch (evt->type)
    	case UART_TX_DONE:
    		// do something
    	case UART_RX_RDY:
    		printk("Received %i bytes \n", evt->data.rx.len);
    		printk("Offset = %i  \n", evt->data.rx.offset);
    		if (currently_active_buffer == 0)
    			// read all characters one by one till new line is found
    			for (int i = 0 + evt->data.rx.offset; i < UART_BUF_SIZE; i++)
    				complete_message[complete_message_counter] = uart_double_buffer[0][i];
    				complete_message_counter++;
    				if (uart_double_buffer[0][i] == '\n')
    					printk("complete_message = %s \n", complete_message);
    					memset(&complete_message, 0, sizeof(complete_message)); // clear out the buffer to prepare for next read.
    		if (currently_active_buffer == 1)
    				complete_message[complete_message_counter] = uart_double_buffer[1][i];
    				if (uart_double_buffer[1][i] == '\n')
    		uart_rx_buf_rsp(dev_uart, uart_buf_next, UART_BUF_SIZE);
    		currently_active_buffer = !currently_active_buffer;
    		uart_buf_next = evt->data.rx_buf.buf;
    		k_sem_give(&rx_disabled);
    		// do something
    void app_uart_init()
    	dev_uart = DEVICE_DT_GET(DT_NODELABEL(uart0));
    	if (!device_is_ready(dev_uart))
    		return 0;
    	int err;
    	err = uart_callback_set(dev_uart, uart_cb, NULL);
    	if (err)
    		return err;
    	uart_rx_enable(dev_uart, uart_double_buffer[0], UART_BUF_SIZE, UART_RX_TIMEOUT_MS);
    	app_uart_init();
    and my prj.conf:
    CONFIG_SERIAL=y
    CONFIG_UART_ASYNC_API=y
    CONFIG_LOG=y
    I have removed most debugging printf/prink statements and only left one or two. You can see that it seems to work now. I am able to send/receive messages and uart_event.rx.len/uart_event.rx.offset seems to be correct now.
    It would be very interesting to hear response from nordic about what exactly is happening and also about the additional options that you have suggested:
    UPDATE
    I can confirm that after adding additional prj.conf options that you have suggested, it works much better. I have even managed to get it to work with additional printf/printk statements just by adding these extra options.
    I have even tested it out on my master branch (the branch where I had all the issues initially).
    See the full code below:
    #include "stdio.h"
    #define LOG_LEVEL 4
    	switch (evt->type)
    	case UART_TX_DONE:
    		// do something
    	case UART_RX_RDY:
    		printf("Received %i bytes \n", evt->data.rx.len);
    		printf("Offset = %i  \n", evt->data.rx.offset);
    		printf("evt->data.rx.buf: [");
    		for (int i = 0; i < UART_BUF_SIZE; i++)
    			printf("%u, ", evt->data.rx.buf[i]);
    		printf("] \n");
    		printf("uart_double_buffer[0]: [");
    			printf("%u, ", uart_double_buffer[0][i]);
    		printf("] \n");
    		printf("uart_double_buffer[1]: [");
    			printf("%u, ", uart_double_buffer[1][i]);
    		printf("] \n");
    		printf("Constructing a complete message \n");
    					printf("new line found at buffer 0 index = %i \n", i);
    					printf("complete_message = %s \n", complete_message);
    					printf("new line found at buffer 1 index = %i \n", i);
    			printf("currently active buffer is uart_double_buffer[0] \n");
    			printf("currently active buffer is uart_double_buffer[1] \n");
    		printf("Old buffer has been released \n");
    		// do something
    		return 0;
    	int err;
    	if (err)
    		return err;
    	app_uart_init();
    and my prj.conf:
    # nothing here
    CONFIG_GPIO=y
    CONFIG_SERIAL=y
    CONFIG_LOG=y
    See the logs below:
    As you can see from the logs above, I have bunch of printf statements but that does not have any negative effect on receiving data. And yes, I am aware that using printf statements in callback itself is not a good practise, but that is just for testing purposes!
  •  Hello. It has been a while. Perhaps you had some time to look at our latest discussion with  ?
    We have discovered some interesting things about ASYNC UART and it would be really nice to get to the bottom of this.
  •    Thank you for the input, it's been very valuable to the discussion
    Regarding answering directly to a specific comment, you can use the quote funcitonality.
    zazas321 said:
    AHaug Hello. It has been a while. Perhaps you had some time to look at our latest discussion with Achim Kraus ?
    @zazas321, I've seen the discussion that has been ongoing here and I have nothing more to contribute to it other than the items that has already been discussed.
    I find in my own experiments as well that a larger buffer is required to allow for enough time to pass so that the buffers can fill, send, swap and empty properly
    Andreas
  • It has been a while but I still believe some things are not fully clear regarding ASYNC UART. Perhaps some things will be clarified at some point:
    POINT 1
    The async UART lesson in the code academy (https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/lessons/lesson-4-serial-communication-uart/topic/exercise-1-5/)
    can only be used in cases where the fixed length serial data is being received which is not what most UART use cases are like.
    POINT 2
    In order to use async UART when trying to receive varying length serial data (strings) with terminator, double buffer approach should be used because we need to handle a scenario where the buffer fills up but the full message hasnt been received and we need to stitch 2 buffers together to build a complete message.
    I have created some test code to test this out:
    #include "stdio.h"
    #define LOG_LEVEL 4
    #define UART_BUF_SIZE 24
    	switch (evt->type)
    	case UART_TX_DONE:
    		// do something
    	case UART_RX_RDY:
    		// do something
    		return 0;
    	int err;
    	if (err)
    		return err;
    	app_uart_init();
    and prj.conf
    CONFIG_SERIAL=y
    CONFIG_LOG=y
    And I have tested it out on the nRF52840DK NRF52840
    The problem with the above code is that once the buffer fills up (UART_BUF_SIZE set to 24), the complete message will not be constructed properly out of 2 buffers. This can be easily observed here:
    POINT 3
    After many hours of debugging the code above, I have figured out what was causing the issues. It turned out to be printf staments. I have removed most of the printf statements and only left the complete_message print. The full code:
    #include "stdio.h"
    #define LOG_LEVEL 4
    	switch (evt->type)
    	case UART_TX_DONE:
    		//printf("transmission complete \n");
    		// do something
    	case UART_RX_RDY:
    		//printf("Received %i bytes \n", evt->data.rx.len);
    		//printf("Offset = %i  \n", evt->data.rx.offset);
    		//printf("Constructing a complete message \n");
    					//printf("new line found at buffer 0 index = %i \n", i);
    					//printf("new line found at buffer 1 index = %i \n", i);
    			//printf("currently active buffer is uart_double_buffer[0] \n");
    			//printf("currently active buffer is uart_double_buffer[1] \n");
    		//printf("Old buffer has been released \n");
    		//printf("rx disabled \n");
    		// do something
    		return 0;
    	int err;
    	if (err)
    		return err;
    	app_uart_init();
    and prj.conf:
    CONFIG_SERIAL=y
    CONFIG_LOG=y
    And when I try to send the exact same sequence of messages using serial terminal, it seems to work fine even after the UART buffer fills up:
    POINT 4
    4. Additionally, I have found out that if you add options :
    in the prj.conf, then the complete messages will be received even if I use many printf statements. I do not fully understand why and how which is quite frustrating.
    The full code:
    #include "stdio.h"
    #define LOG_LEVEL 4
    	switch (evt->type)
    	case UART_TX_DONE:
    		// do something
    	case UART_RX_RDY:
    		// do something
    		return 0;
    	int err;
    	if (err)
    		return err;
    	app_uart_init();
    and prj.conf:
    CONFIG_SERIAL=y
    CONFIG_LOG=y
    Despite the solution being found, it is still not fully clear to me what is the best way to handle ASYNC UART varying length data reception. I could not find enough information/examples available to fully understand the different methods of handling ASYNC UART reception and I am hoping to get some clarifications regarding this.
    • Is this expected behaviour that a few printf statements in uart_cb causes weird behaviour as have been shown above?
    •  If above is true, I am concerned about other high priority tasks or callbacks interrupting the UART reception and causing similar issues even when all print statements are removed from the callback itself. Is ASYNC UART affected by other Zephyr RTOS threads running or it is independent and not affected at all?
    • During the discussion above it has been mentioned that it is recommended to use larger UART_BUF_SIZE but that did not help in any way. The only thing that does is just simply requires more serial data to be received before it fills up and eventually breaks.
    • Throughout this discussion, other things have been suggested such as using additional config options:
    which seem to help when having multiple print statements in the callback.
    I would highly appreciate if someone with good Zephyr and ASYNC UART knowledge could shed some light here and cover the issues that I have encountered and the solutions that I have found. I believe the solutions that I have discovered are not the most optimal and not the best way to handle UART ASYNC data reception. I also believe that this should be relevant for other developers who are working with ASYNC UART.
