I am working through the Nordic Developer Academy and got stuck at lesson 4 (UART receive)
In particular, I am confused about this part:
I have created a sample project and connected external CP2102 USB->Serial adapter to P0.06 and P0.08 pins.
The code that I use:
/* * Copyright (c) 2012-2014 Wind River Systems, Inc. * * SPDX-License-Identifier: Apache-2.0 */ #include <zephyr/kernel.h> #include <zephyr/drivers/gpio.h> #include "stdio.h" #include "zephyr/drivers/uart.h" const struct device *uart = DEVICE_DT_GET(DT_NODELABEL(uart0)); static uint8_t tx_buf[] = {"nRF Connect SDK Fundamentals Course \n\r"}; static uint8_t rx_buf[10] = {0}; //A buffer to store incoming UART data const struct uart_config uart_cfg = { .baudrate = 115200, .parity = UART_CFG_PARITY_NONE, .stop_bits = UART_CFG_STOP_BITS_1, .data_bits = UART_CFG_DATA_BITS_8, .flow_ctrl = UART_CFG_FLOW_CTRL_NONE }; static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data) { switch (evt->type) { case UART_TX_DONE: printf("transmission complete \n"); break; case UART_TX_ABORTED: // do something break; case UART_RX_RDY: printf("rx rdy \n"); if((evt->data.rx.len) != 0){ printf("data received = %s \n", evt->data.rx.buf[evt->data.rx.offset]); } break; case UART_RX_BUF_REQUEST: printf("requesting buffer \n"); // do something break; case UART_RX_BUF_RELEASED: printf("buffer released \n"); // do something break; case UART_RX_DISABLED: printf("rx disabled \n"); uart_rx_enable(dev, rx_buf, sizeof(rx_buf), 100); break; case UART_RX_STOPPED: // do something break; default: break; } } int main(void) { if (!device_is_ready(uart)) { return; } int err; err = uart_callback_set(uart, uart_cb, NULL); if (err) { return err; } uart_rx_enable(uart, rx_buf, sizeof(rx_buf), 100); err = uart_tx(uart, tx_buf, sizeof(tx_buf), SYS_FOREVER_US); if (err) { return err; } while(1){ k_msleep(1000); } return 0; }
I am having issues understanding how to properly print out all the received data:
I tried to do:
but when I send the data via UART (using Termite) , the following is printed:
I would appreciate if someone could clarify how to correctly print out all the received data. Thanks in advance
Just for testing, I have also tried to print:
case UART_RX_RDY: printf("rx rdy \n"); printf("data: %s \n", rx_buf); break;
