Error on commissioning step 'FindOperational' while pairing matter sample over ble-wifi
I use the Matter Light bulb example on nRF7002 DK. I have built it on sdk-nrf-v2.4.99-dev2. I use chip-tool v2.4.1 on UBUNTU 23.10 (on Raspberry Pi)
I try commissioning over ble-wifi. I use this command: sudo ./chip-tool pairing ble-wifi 1 tm 012345678 20202021 3840
After the WiFiNetworkEnable step I have the error:
BLE scan error: src/platform/Linux/bluez/ChipDeviceScanner.cpp:154: CHIP Error 0x00000032: Timeout
The chip-tool output:
[1697294747.035202][32395:32395] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1697294747.035721][32395:32395] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
[1697294747.035898][32395:32395] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
[1697294747.036016][32395:32395] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
[1697294747.036387][32395:32395] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-8oYcc3)
[1697294747.037066][32395:32395] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1697294747.037144][32395:32395] CHIP:DL: NVS set: chip-counters/reboot-count = 2 (0x2)
[1697294747.037782][32395:32395] CHIP:DL: Got Ethernet interface: eth0
[1697294747.038146][32395:32395] CHIP:DL: Found the primary Ethernet interface:eth0
[1697294747.038552][32395:32395] CHIP:DL: Got WiFi interface: wlan0
[1697294747.038628][32395:32395] CHIP:DL: Failed to reset WiFi statistic counts
[1697294747.038678][32395:32395] CHIP:IN: UDP::Init bind&listen port=0
[1697294747.038810][32395:32395] CHIP:IN: UDP::Init bound to port=39055
[1697294747.038833][32395:32395] CHIP:IN: UDP::Init bind&listen port=0
[1697294747.038929][32395:32395] CHIP:IN: UDP::Init bound to port=52554
[1697294747.038951][32395:32395] CHIP:IN: BLEBase::Init - setting/overriding transport
[1697294747.038969][32395:32395] CHIP:IN: TransportMgr initialized
[1697294747.039005][32395:32395] CHIP:FP: Initializing FabricTable from persistent storage
[1697294747.039144][32395:32395] CHIP:TS: Last Known Good Time: 2023-07-11T08:00:09
[1697294747.039590][32395:32395] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x99A797A4F8C34467, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
[1697294747.041597][32395:32395] CHIP:ZCL: Using ZAP configuration...
[1697294747.046270][32395:32395] CHIP:DL: Avahi client registered
[1697294747.047688][32395:32395] CHIP:CTL: System State Initialized...
[1697294747.047840][32395:32395] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1697294747.047882][32395:32395] CHIP:CTL: Setting attestation nonce to random value
[1697294747.047910][32395:32395] CHIP:CTL: Setting CSR nonce to random value
[1697294747.048297][32395:32397] CHIP:DL: CHIP task running
[1697294747.048569][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
[1697294747.048854][32395:32397] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1697294747.048904][32395:32397] CHIP:CTL: Setting attestation nonce to random value
[1697294747.048939][32395:32397] CHIP:CTL: Setting CSR nonce to random value
[1697294747.062410][32395:32397] CHIP:CTL: Generating NOC
[1697294747.074484][32395:32397] CHIP:FP: Validating NOC chain
[1697294747.117598][32395:32397] CHIP:FP: NOC chain validation successful
[1697294747.117640][32395:32397] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
[1697294747.117664][32395:32397] CHIP:TS: Last Known Good Time: 2023-07-11T08:00:09
[1697294747.117682][32395:32397] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1697294747.117698][32395:32397] CHIP:TS: Retaining current Last Known Good Time
[1697294747.119793][32395:32397] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
[1697294747.121520][32395:32397] CHIP:TS: Committing Last Known Good Time to storage: 2023-07-11T08:00:09
[1697294747.123183][32395:32397] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 99A797A4F8C34467)
[1697294747.134875][32395:32397] CHIP:CTL: Setting wifi credentials from parameters
[1697294747.134917][32395:32397] CHIP:CTL: Setting attestation nonce to random value
[1697294747.134952][32395:32397] CHIP:CTL: Setting CSR nonce to random value
[1697294747.134977][32395:32397] CHIP:CTL: Commission called for node ID 0x0000000000000001
[1697294747.140106][32395:32396] CHIP:DL: TRACE: Bus acquired for name C-7e8b
[1697294747.147339][32395:32397] CHIP:DL: PlatformBlueZInit init success
[1697294747.153708][32395:32396] CHIP:BLE: BLE removing known devices.
[1697294747.156302][32395:32396] CHIP:BLE: BLE initiating scan.
[1697294747.197506][32395:32396] CHIP:BLE: New device scanned: DD:FD:F2:53:5E:88
[1697294747.197641][32395:32396] CHIP:BLE: Device discriminator match. Attempting to connect.
[1697294747.684375][32395:32396] CHIP:DL: ConnectDevice complete
[1697294748.780809][32395:32396] CHIP:DL: Char1 /org/bluez/hci0/dev_DD_FD_F2_53_5E_88/service000c
[1697294748.780868][32395:32396] CHIP:DL: Char1 /org/bluez/hci0/dev_DD_FD_F2_53_5E_88/service000c
[1697294748.780966][32395:32396] CHIP:DL: Char1 /org/bluez/hci0/dev_DD_FD_F2_53_5E_88/service0001
[1697294748.780994][32395:32396] CHIP:DL: Char1 /org/bluez/hci0/dev_DD_FD_F2_53_5E_88/service000c
[1697294748.781019][32395:32396] CHIP:DL: Char1 /org/bluez/hci0/dev_DD_FD_F2_53_5E_88/service0001
[1697294748.781040][32395:32396] CHIP:DL: Char1 /org/bluez/hci0/dev_DD_FD_F2_53_5E_88/service000c
[1697294748.781063][32395:32396] CHIP:DL: Char1 /org/bluez/hci0/dev_DD_FD_F2_53_5E_88/service0001
[1697294748.781144][32395:32396] CHIP:DL: Char1 /org/bluez/hci0/dev_DD_FD_F2_53_5E_88/service000c
[1697294748.781209][32395:32396] CHIP:DL: Char1 /org/bluez/hci0/dev_DD_FD_F2_53_5E_88/service000c
[1697294748.781235][32395:32396] CHIP:DL: Char1 /org/bluez/hci0/dev_DD_FD_F2_53_5E_88/service000c
[1697294748.781257][32395:32396] CHIP:DL: Char1 /org/bluez/hci0/dev_DD_FD_F2_53_5E_88/service000c
[1697294748.781281][32395:32396] CHIP:DL: Char1 /org/bluez/hci0/dev_DD_FD_F2_53_5E_88/service000c
[1697294748.781311][32395:32396] CHIP:DL: New BLE connection 0xffff80032890, device DD:FD:F2:53:5E:88, path /org/bluez/hci0/dev_DD_FD_F2_53_5E_88
[1697294748.781439][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16385
[1697294748.781475][32395:32397] CHIP:DIS: Closing all BLE connections
[1697294748.781533][32395:32397] CHIP:IN: BleConnectionComplete: endPoint 0xaaaae4fd6aa0
[1697294748.782037][32395:32397] CHIP:IN: SecureSession[0xffff780095a0]: Allocated Type:1 LSID:1189
[1697294748.782090][32395:32397] CHIP:SC: Assigned local session key ID 1189
[1697294748.782200][32395:32397] CHIP:EM: <<< [E:8633i S:0 M:131244374] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
[1697294748.782270][32395:32397] CHIP:IN: (U) Sending msg 131244374 to IP address 'BLE'
[1697294748.782311][32395:32397] CHIP:IN: Message appended to BLE send queue
[1697294748.782340][32395:32397] CHIP:SC: Sent PBKDF param request
[1697294749.186604][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1697294749.278805][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16388
[1697294749.278922][32395:32397] CHIP:BLE: subscribe complete, ep = 0xaaaae4fd6aa0
[1697294749.280933][32395:32396] CHIP:DL: Indication received, conn = 0xffff80032890
[1697294749.281493][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1697294749.281569][32395:32397] CHIP:BLE: peripheral chose BTP version 4; central expected between 4 and 4
[1697294749.281624][32395:32397] CHIP:BLE: using BTP fragment sizes rx 244 / tx 244.
[1697294749.281672][32395:32397] CHIP:BLE: local and remote recv window size = 5
[1697294749.282265][32395:32397] CHIP:IN: BLE EndPoint 0xaaaae4fd6aa0 Connection Complete
[1697294749.410673][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1697294749.503595][32395:32396] CHIP:DL: Indication received, conn = 0xffff80032890
[1697294749.503925][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1697294749.504201][32395:32397] CHIP:EM: >>> [E:8633i S:0 M:36006713] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
[1697294749.504285][32395:32397] CHIP:EM: Found matching exchange: 8633i, Delegate: 0xffff7800c2a0
[1697294749.504388][32395:32397] CHIP:SC: Received PBKDF param response
[1697294749.504612][32395:32397] CHIP:SC: Peer assigned session ID 33323
[1697294749.504790][32395:32397] CHIP:SC: Found MRP parameters in the message
[1697294749.564747][32395:32397] CHIP:EM: <<< [E:8633i S:0 M:131244375] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
[1697294749.564807][32395:32397] CHIP:IN: (U) Sending msg 131244375 to IP address 'BLE'
[1697294749.565174][32395:32397] CHIP:SC: Sent spake2p msg1
[1697294749.635834][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1697294751.078232][32395:32396] CHIP:DL: Indication received, conn = 0xffff80032890
[1697294751.078921][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1697294751.079232][32395:32397] CHIP:EM: >>> [E:8633i S:0 M:36006714] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
[1697294751.079310][32395:32397] CHIP:EM: Found matching exchange: 8633i, Delegate: 0xffff7800c2a0
[1697294751.079516][32395:32397] CHIP:SC: Received spake2p msg2
[1697294751.130857][32395:32397] CHIP:EM: <<< [E:8633i S:0 M:131244376] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
[1697294751.130907][32395:32397] CHIP:IN: (U) Sending msg 131244376 to IP address 'BLE'
[1697294751.131345][32395:32397] CHIP:SC: Sent spake2p msg3
[1697294751.255785][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1697294751.257694][32395:32396] CHIP:DL: Indication received, conn = 0xffff80032890
[1697294751.258165][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1697294751.258588][32395:32397] CHIP:EM: >>> [E:8633i S:0 M:36006715] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
[1697294751.259121][32395:32397] CHIP:EM: Found matching exchange: 8633i, Delegate: 0xffff7800c2a0
[1697294751.259544][32395:32397] CHIP:SC: SecureSession[0xffff780095a0]: Moving from state 'kEstablishing' --> 'kActive'[1697294751.259782][32395:32397] CHIP:IN: SecureSession[0xffff780095a0]: Activated - Type:1 LSID:1189
[1697294751.259837][32395:32397] CHIP:IN: New secure session activated for device <FFFFFFFB00000000, 0>, LSID:1189 PSID:33323!
[1697294751.259928][32395:32397] CHIP:CTL: Remote device completed SPAKE2+ handshake
[1697294751.259983][32395:32397] CHIP:TOO: Pairing Success
[1697294751.260032][32395:32397] CHIP:TOO: PASE establishment successful
[1697294751.260090][32395:32397] CHIP:CTL: Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
[1697294751.260152][32395:32397] CHIP:CTL: Performing next commissioning step 'ReadCommissioningInfo'
[1697294751.260204][32395:32397] CHIP:CTL: Sending request for commissioning information
[1697294751.260300][32395:32397] CHIP:DMG: SendReadRequest ReadClient[0xffff780137e0]: Sending Read Request
[1697294751.260730][32395:32397] CHIP:EM: <<< [E:8634i S:1189 M:161582293] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
[1697294751.260831][32395:32397] CHIP:IN: (S) Sending msg 161582293 on secure session with LSID: 1189
[1697294751.261722][32395:32397] CHIP:DMG: MoveToState ReadClient[0xffff780137e0]: Moving to [AwaitingIn]
[1697294751.390795][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1697294751.484339][32395:32396] CHIP:DL: Indication received, conn = 0xffff80032890
[1697294751.485093][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1697294751.573097][32395:32396] CHIP:DL: Indication received, conn = 0xffff80032890
[1697294751.573738][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1697294751.574060][32395:32397] CHIP:EM: >>> [E:8634i S:1189 M:169693654] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
[1697294751.574141][32395:32397] CHIP:EM: Found matching exchange: 8634i, Delegate: 0xffff780137f0
[1697294751.574373][32395:32397] CHIP:DMG: ReportDataMessage =
[1697294751.574436][32395:32397] CHIP:DMG: {
[1697294751.574491][32395:32397] CHIP:DMG: AttributeReportIBs =
[1697294751.574565][32395:32397] CHIP:DMG: [
[1697294751.574623][32395:32397] CHIP:DMG: AttributeReportIB =
[1697294751.574700][32395:32397] CHIP:DMG: {
[1697294751.574759][32395:32397] CHIP:DMG: AttributeDataIB =
[1697294751.574840][32395:32397] CHIP:DMG: {
[1697294751.574913][32395:32397] CHIP:DMG: DataVersion = 0xdc16d884,
[1697294751.574983][32395:32397] CHIP:DMG: AttributePathIB =
[1697294751.575054][32395:32397] CHIP:DMG: {
[1697294751.575127][32395:32397] CHIP:DMG: Endpoint = 0x0,
[1697294751.575204][32395:32397] CHIP:DMG: Cluster = 0x31,
[1697294751.575281][32395:32397] CHIP:DMG: Attribute = 0x0000_0003,
[1697294751.575363][32395:32397] CHIP:DMG: }
[1697294751.575530][32395:32397] CHIP:DMG:
[1697294751.575618][32395:32397] CHIP:DMG: Data = 35,
[1697294751.575689][32395:32397] CHIP:DMG: },
[1697294751.575779][32395:32397] CHIP:DMG:
[1697294751.575841][32395:32397] CHIP:DMG: },
[1697294751.575930][32395:32397] CHIP:DMG:
[1697294751.575989][32395:32397] CHIP:DMG: AttributeReportIB =
[1697294751.576065][32395:32397] CHIP:DMG: {
[1697294751.576131][32395:32397] CHIP:DMG: AttributeDataIB =
[1697294751.576197][32395:32397] CHIP:DMG: {
[1697294751.576267][32395:32397] CHIP:DMG: DataVersion = 0xb42131a8,
[1697294751.576343][32395:32397] CHIP:DMG: AttributePathIB =
[1697294751.576421][32395:32397] CHIP:DMG: {
[1697294751.576490][32395:32397] CHIP:DMG: Endpoint = 0x0,
[1697294751.576583][32395:32397] CHIP:DMG: Cluster = 0x28,
[1697294751.576677][32395:32397] CHIP:DMG: Attribute = 0x0000_0004,
[1697294751.576750][32395:32397] CHIP:DMG: }
[1697294751.576832][32395:32397] CHIP:DMG:
[1697294751.576912][32395:32397] CHIP:DMG: Data = 32773,
[1697294751.576989][32395:32397] CHIP:DMG: },
[1697294751.577065][32395:32397] CHIP:DMG:
[1697294751.577124][32395:32397] CHIP:DMG: },
[1697294751.577210][32395:32397] CHIP:DMG:
[1697294751.577269][32395:32397] CHIP:DMG: AttributeReportIB =
[1697294751.577343][32395:32397] CHIP:DMG: {
[1697294751.577402][32395:32397] CHIP:DMG: AttributeDataIB =
[1697294751.577468][32395:32397] CHIP:DMG: {
[1697294751.577537][32395:32397] CHIP:DMG: DataVersion = 0xb42131a8,
[1697294751.577613][32395:32397] CHIP:DMG: AttributePathIB =
[1697294751.577692][32395:32397] CHIP:DMG: {
[1697294751.577764][32395:32397] CHIP:DMG: Endpoint = 0x0,
[1697294751.577858][32395:32397] CHIP:DMG: Cluster = 0x28,
[1697294751.577952][32395:32397] CHIP:DMG: Attribute = 0x0000_0002,
[1697294751.578041][32395:32397] CHIP:DMG: }
[1697294751.578123][32395:32397] CHIP:DMG:
[1697294751.578205][32395:32397] CHIP:DMG: Data = 65521,
[1697294751.578280][32395:32397] CHIP:DMG: },
[1697294751.578355][32395:32397] CHIP:DMG:
[1697294751.578415][32395:32397] CHIP:DMG: },
[1697294751.578498][32395:32397] CHIP:DMG:
[1697294751.578555][32395:32397] CHIP:DMG: AttributeReportIB =
[1697294751.578627][32395:32397] CHIP:DMG: {
[1697294751.578687][32395:32397] CHIP:DMG: AttributeDataIB =
[1697294751.578755][32395:32397] CHIP:DMG: {
[1697294751.578826][32395:32397] CHIP:DMG: DataVersion = 0xf47beac4,
[1697294751.578902][32395:32397] CHIP:DMG: AttributePathIB =
[1697294751.578982][32395:32397] CHIP:DMG: {
[1697294751.579062][32395:32397] CHIP:DMG: Endpoint = 0x0,
[1697294751.579135][32395:32397] CHIP:DMG: Cluster = 0x30,
[1697294751.579228][32395:32397] CHIP:DMG: Attribute = 0x0000_0003,
[1697294751.579316][32395:32397] CHIP:DMG: }
[1697294751.579433][32395:32397] CHIP:DMG:
[1697294751.579521][32395:32397] CHIP:DMG: Data = 0,
[1697294751.579599][32395:32397] CHIP:DMG: },
[1697294751.579673][32395:32397] CHIP:DMG:
[1697294751.579732][32395:32397] CHIP:DMG: },
[1697294751.579816][32395:32397] CHIP:DMG:
[1697294751.579873][32395:32397] CHIP:DMG: AttributeReportIB =
[1697294751.579947][32395:32397] CHIP:DMG: {
[1697294751.580007][32395:32397] CHIP:DMG: AttributeDataIB =
[1697294751.580071][32395:32397] CHIP:DMG: {
[1697294751.580149][32395:32397] CHIP:DMG: DataVersion = 0xf47beac4,
[1697294751.580225][32395:32397] CHIP:DMG: AttributePathIB =
[1697294751.580303][32395:32397] CHIP:DMG: {
[1697294751.580382][32395:32397] CHIP:DMG: Endpoint = 0x0,
[1697294751.580476][32395:32397] CHIP:DMG: Cluster = 0x30,
[1697294751.580570][32395:32397] CHIP:DMG: Attribute = 0x0000_0002,
[1697294751.580659][32395:32397] CHIP:DMG: }
[1697294751.580741][32395:32397] CHIP:DMG:
[1697294751.580822][32395:32397] CHIP:DMG: Data = 0,
[1697294751.580897][32395:32397] CHIP:DMG: },
[1697294751.580971][32395:32397] CHIP:DMG:
[1697294751.581030][32395:32397] CHIP:DMG: },
[1697294751.581117][32395:32397] CHIP:DMG:
[1697294751.581173][32395:32397] CHIP:DMG: AttributeReportIB =
[1697294751.581250][32395:32397] CHIP:DMG: {
[1697294751.581310][32395:32397] CHIP:DMG: AttributeDataIB =
[1697294751.581375][32395:32397] CHIP:DMG: {
[1697294751.581440][32395:32397] CHIP:DMG: DataVersion = 0xf47beac4,
[1697294751.581516][32395:32397] CHIP:DMG: AttributePathIB =
[1697294751.581596][32395:32397] CHIP:DMG: {
[1697294751.581675][32395:32397] CHIP:DMG: Endpoint = 0x0,
[1697294751.581770][32395:32397] CHIP:DMG: Cluster = 0x30,
[1697294751.581847][32395:32397] CHIP:DMG: Attribute = 0x0000_0001,
[1697294751.581938][32395:32397] CHIP:DMG: }
[1697294751.582020][32395:32397] CHIP:DMG:
[1697294751.582097][32395:32397] CHIP:DMG: Data =
[1697294751.582169][32395:32397] CHIP:DMG: {
[1697294751.582251][32395:32397] CHIP:DMG: 0x0 = 60,
[1697294751.582346][32395:32397] CHIP:DMG: 0x1 = 900,
[1697294751.582440][32395:32397] CHIP:DMG: },
[1697294751.582505][32395:32397] CHIP:DMG: },
[1697294751.582581][32395:32397] CHIP:DMG:
[1697294751.582640][32395:32397] CHIP:DMG: },
[1697294751.582726][32395:32397] CHIP:DMG:
[1697294751.582789][32395:32397] CHIP:DMG: AttributeReportIB =
[1697294751.582865][32395:32397] CHIP:DMG: {
[1697294751.582925][32395:32397] CHIP:DMG: AttributeDataIB =
[1697294751.582990][32395:32397] CHIP:DMG: {
[1697294751.583058][32395:32397] CHIP:DMG: DataVersion = 0xf47beac4,
[1697294751.583133][32395:32397] CHIP:DMG: AttributePathIB =
[1697294751.583211][32395:32397] CHIP:DMG: {
[1697294751.583291][32395:32397] CHIP:DMG: Endpoint = 0x0,
[1697294751.583368][32395:32397] CHIP:DMG: Cluster = 0x30,
[1697294751.583532][32395:32397] CHIP:DMG: Attribute = 0x0000_0000,
[1697294751.583622][32395:32397] CHIP:DMG: }
[1697294751.583706][32395:32397] CHIP:DMG:
[1697294751.583786][32395:32397] CHIP:DMG: Data = 0,
[1697294751.583850][32395:32397] CHIP:DMG: },
[1697294751.583925][32395:32397] CHIP:DMG:
[1697294751.583984][32395:32397] CHIP:DMG: },
[1697294751.584063][32395:32397] CHIP:DMG:
[1697294751.584100][32395:32397] CHIP:DMG: AttributeReportIB =
[1697294751.584138][32395:32397] CHIP:DMG: {
[1697294751.584159][32395:32397] CHIP:DMG: AttributeDataIB =
[1697294751.584182][32395:32397] CHIP:DMG: {
[1697294751.584206][32395:32397] CHIP:DMG: DataVersion = 0xdc16d884,
[1697294751.584233][32395:32397] CHIP:DMG: AttributePathIB =
[1697294751.584256][32395:32397] CHIP:DMG: {
[1697294751.584288][32395:32397] CHIP:DMG: Endpoint = 0x0,
[1697294751.584322][32395:32397] CHIP:DMG: Cluster = 0x31,
[1697294751.584347][32395:32397] CHIP:DMG: Attribute = 0x0000_FFFC,
[1697294751.584379][32395:32397] CHIP:DMG: }
[1697294751.584408][32395:32397] CHIP:DMG:
[1697294751.584436][32395:32397] CHIP:DMG: Data = 1,
[1697294751.584463][32395:32397] CHIP:DMG: },
[1697294751.584489][32395:32397] CHIP:DMG:
[1697294751.584510][32395:32397] CHIP:DMG: },
[1697294751.584535][32395:32397] CHIP:DMG:
[1697294751.584554][32395:32397] CHIP:DMG: ],
[1697294751.584603][32395:32397] CHIP:DMG:
[1697294751.584623][32395:32397] CHIP:DMG: SuppressResponse = true,
[1697294751.584644][32395:32397] CHIP:DMG: InteractionModelRevision = 1
[1697294751.584664][32395:32397] CHIP:DMG: }
[1697294751.585401][32395:32397] CHIP:CTL: ----- NetworkCommissioning Features: has WiFi. endpointid = 0
[1697294751.585467][32395:32397] CHIP:CTL: Successfully finished commissioning step 'ReadCommissioningInfo'
[1697294751.585497][32395:32397] CHIP:CTL: Commissioning stage next step: 'ReadCommissioningInfo' -> 'ArmFailSafe'
[1697294751.585524][32395:32397] CHIP:CTL: Performing next commissioning step 'ArmFailSafe'
[1697294751.585546][32395:32397] CHIP:CTL: Arming failsafe (60 seconds)
[1697294751.585611][32395:32397] CHIP:DMG: ICR moving to [AddingComm]
[1697294751.585639][32395:32397] CHIP:DMG: ICR moving to [AddedComma]
[1697294751.585744][32395:32397] CHIP:EM: <<< [E:8635i S:1189 M:161582294] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1697294751.585784][32395:32397] CHIP:IN: (S) Sending msg 161582294 on secure session with LSID: 1189
[1697294751.586159][32395:32397] CHIP:DMG: ICR moving to [CommandSen]
[1697294751.796634][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1697294751.888361][32395:32396] CHIP:DL: Indication received, conn = 0xffff80032890
[1697294751.888794][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1697294751.889236][32395:32397] CHIP:EM: >>> [E:8635i S:1189 M:169693655] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1697294751.889320][32395:32397] CHIP:EM: Found matching exchange: 8635i, Delegate: 0xffff80034758
[1697294751.889408][32395:32397] CHIP:DMG: ICR moving to [ResponseRe]
[1697294751.889516][32395:32397] CHIP:DMG: InvokeResponseMessage =
[1697294751.889572][32395:32397] CHIP:DMG: {
[1697294751.889629][32395:32397] CHIP:DMG: suppressResponse = false,
[1697294751.889688][32395:32397] CHIP:DMG: InvokeResponseIBs =
[1697294751.889785][32395:32397] CHIP:DMG: [
[1697294751.889852][32395:32397] CHIP:DMG: InvokeResponseIB =
[1697294751.889933][32395:32397] CHIP:DMG: {
[1697294751.889995][32395:32397] CHIP:DMG: CommandDataIB =
[1697294751.890065][32395:32397] CHIP:DMG: {
[1697294751.890128][32395:32397] CHIP:DMG: CommandPathIB =
[1697294751.890294][32395:32397] CHIP:DMG: {
[1697294751.890399][32395:32397] CHIP:DMG: EndpointId = 0x0,
[1697294751.890546][32395:32397] CHIP:DMG: ClusterId = 0x30,
[1697294751.890623][32395:32397] CHIP:DMG: CommandId = 0x1,
[1697294751.890690][32395:32397] CHIP:DMG: },
[1697294751.890759][32395:32397] CHIP:DMG:
[1697294751.890829][32395:32397] CHIP:DMG: CommandFields =
[1697294751.890899][32395:32397] CHIP:DMG: {
[1697294751.890979][32395:32397] CHIP:DMG: 0x0 = 0,
[1697294751.891057][32395:32397] CHIP:DMG: 0x1 = "" (0 chars),
[1697294751.891137][32395:32397] CHIP:DMG: },
[1697294751.891271][32395:32397] CHIP:DMG: },
[1697294751.891350][32395:32397] CHIP:DMG:
[1697294751.891453][32395:32397] CHIP:DMG: },
[1697294751.891598][32395:32397] CHIP:DMG:
[1697294751.891658][32395:32397] CHIP:DMG: ],
[1697294751.891734][32395:32397] CHIP:DMG:
[1697294751.891794][32395:32397] CHIP:DMG: InteractionModelRevision = 1
[1697294751.891853][32395:32397] CHIP:DMG: },
[1697294751.892005][32395:32397] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1697294751.892230][32395:32397] CHIP:CTL: Received ArmFailSafe response errorCode=0
[1697294751.892303][32395:32397] CHIP:CTL: Successfully finished commissioning step 'ArmFailSafe'
[1697294751.892357][32395:32397] CHIP:CTL: Commissioning stage next step: 'ArmFailSafe' -> 'ConfigRegulatory'
[1697294751.892426][32395:32397] CHIP:CTL: Performing next commissioning step 'ConfigRegulatory'
[1697294751.892477][32395:32397] CHIP:CTL: Setting Regulatory Config
[1697294751.892528][32395:32397] CHIP:CTL: Device does not support configurable regulatory location
[1697294751.892676][32395:32397] CHIP:DMG: ICR moving to [AddingComm]
[1697294751.892869][32395:32397] CHIP:DMG: ICR moving to [AddedComma]
[1697294751.893097][32395:32397] CHIP:EM: <<< [E:8636i S:1189 M:161582295] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1697294751.893203][32395:32397] CHIP:IN: (S) Sending msg 161582295 on secure session with LSID: 1189
[1697294751.894126][32395:32397] CHIP:DMG: ICR moving to [CommandSen]
[1697294751.894298][32395:32397] CHIP:DMG: ICR moving to [AwaitingDe]
[1697294751.976410][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1697294752.293425][32395:32396] CHIP:DL: Indication received, conn = 0xffff80032890
[1697294752.293827][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1697294752.294202][32395:32397] CHIP:EM: >>> [E:8636i S:1189 M:169693656] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1697294752.294289][32395:32397] CHIP:EM: Found matching exchange: 8636i, Delegate: 0xffff78008898
[1697294752.294381][32395:32397] CHIP:DMG: ICR moving to [ResponseRe]
[1697294752.294491][32395:32397] CHIP:DMG: InvokeResponseMessage =
[1697294752.294548][32395:32397] CHIP:DMG: {
[1697294752.294604][32395:32397] CHIP:DMG: suppressResponse = false,
[1697294752.294757][32395:32397] CHIP:DMG: InvokeResponseIBs =
[1697294752.294835][32395:32397] CHIP:DMG: [
[1697294752.294893][32395:32397] CHIP:DMG: InvokeResponseIB =
[1697294752.294971][32395:32397] CHIP:DMG: {
[1697294752.295032][32395:32397] CHIP:DMG: CommandDataIB =
[1697294752.295165][32395:32397] CHIP:DMG: {
[1697294752.295233][32395:32397] CHIP:DMG: CommandPathIB =
[1697294752.295371][32395:32397] CHIP:DMG: {
[1697294752.295559][32395:32397] CHIP:DMG: EndpointId = 0x0,
[1697294752.295703][32395:32397] CHIP:DMG: ClusterId = 0x30,
[1697294752.295780][32395:32397] CHIP:DMG: CommandId = 0x3,
[1697294752.295860][32395:32397] CHIP:DMG: },
[1697294752.295936][32395:32397] CHIP:DMG:
[1697294752.296002][32395:32397] CHIP:DMG: CommandFields =
[1697294752.296069][32395:32397] CHIP:DMG: {
[1697294752.296139][32395:32397] CHIP:DMG: 0x0 = 0,
[1697294752.296284][32395:32397] CHIP:DMG: 0x1 = "" (0 chars),
[1697294752.296369][32395:32397] CHIP:DMG: },
[1697294752.296439][32395:32397] CHIP:DMG: },
[1697294752.296515][32395:32397] CHIP:DMG:
[1697294752.296577][32395:32397] CHIP:DMG: },
[1697294752.296650][32395:32397] CHIP:DMG:
[1697294752.296706][32395:32397] CHIP:DMG: ],
[1697294752.296787][32395:32397] CHIP:DMG:
[1697294752.296845][32395:32397] CHIP:DMG: InteractionModelRevision = 1
[1697294752.296902][32395:32397] CHIP:DMG: },
[1697294752.297053][32395:32397] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0003
[1697294752.297280][32395:32397] CHIP:CTL: Received SetRegulatoryConfig response errorCode=0
[1697294752.297352][32395:32397] CHIP:CTL: Successfully finished commissioning step 'ConfigRegulatory'
[1697294752.297406][32395:32397] CHIP:CTL: Commissioning stage next step: 'ConfigRegulatory' -> 'SendPAICertificateRequest'
[1697294752.297474][32395:32397] CHIP:CTL: Performing next commissioning step 'SendPAICertificateRequest'
[1697294752.297525][32395:32397] CHIP:CTL: Sending request for PAI certificate
[1697294752.297576][32395:32397] CHIP:CTL: Sending Certificate Chain request to 0xffff7800c250 device
[1697294752.297719][32395:32397] CHIP:DMG: ICR moving to [AddingComm]
[1697294752.297903][32395:32397] CHIP:DMG: ICR moving to [AddedComma]
[1697294752.298122][32395:32397] CHIP:EM: <<< [E:8637i S:1189 M:161582296] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1697294752.298222][32395:32397] CHIP:IN: (S) Sending msg 161582296 on secure session with LSID: 1189
[1697294752.299052][32395:32397] CHIP:DMG: ICR moving to [CommandSen]
[1697294752.299216][32395:32397] CHIP:DMG: ICR moving to [AwaitingDe]
[1697294752.515744][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1697294752.655058][32395:32396] CHIP:DL: Indication received, conn = 0xffff80032890
[1697294752.655476][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1697294752.743313][32395:32396] CHIP:DL: Indication received, conn = 0xffff80032890
[1697294752.743797][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1697294752.967463][32395:32396] CHIP:DL: Indication received, conn = 0xffff80032890
[1697294752.968039][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1697294752.968476][32395:32397] CHIP:EM: >>> [E:8637i S:1189 M:169693657] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1697294752.968561][32395:32397] CHIP:EM: Found matching exchange: 8637i, Delegate: 0xffff80034758
[1697294752.968663][32395:32397] CHIP:DMG: ICR moving to [ResponseRe]
[1697294752.968775][32395:32397] CHIP:DMG: InvokeResponseMessage =
[1697294752.968832][32395:32397] CHIP:DMG: {
[1697294752.968890][32395:32397] CHIP:DMG: suppressResponse = false,
[1697294752.968945][32395:32397] CHIP:DMG: InvokeResponseIBs =
[1697294752.969020][32395:32397] CHIP:DMG: [
[1697294752.969081][32395:32397] CHIP:DMG: InvokeResponseIB =
[1697294752.969160][32395:32397] CHIP:DMG: {
[1697294752.969221][32395:32397] CHIP:DMG: CommandDataIB =
[1697294752.969289][32395:32397] CHIP:DMG: {
[1697294752.969356][32395:32397] CHIP:DMG: CommandPathIB =
[1697294752.969441][32395:32397] CHIP:DMG: {
[1697294752.969523][32395:32397] CHIP:DMG: EndpointId = 0x0,
[1697294752.969619][32395:32397] CHIP:DMG: ClusterId = 0x3e,
[1697294752.969709][32395:32397] CHIP:DMG: CommandId = 0x3,
[1697294752.969784][32395:32397] CHIP:DMG: },
[1697294752.969859][32395:32397] CHIP:DMG:
[1697294752.969927][32395:32397] CHIP:DMG: CommandFields =
[1697294752.970006][32395:32397] CHIP:DMG: {
[1697294752.970089][32395:32397] CHIP:DMG: 0x0 = [
[1697294752.970358][32395:32397] CHIP:DMG: 0x30, 0x82, 0x01, 0xcb, 0x30, 0x82, 0x01, 0x71, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x56, 0xad, 0x82, 0x22, 0xad, 0x94, 0x5b, 0x64, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x30, 0x31, 0x18, 0x30, 0x16, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x0f, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x54, 0x65, 0x73, 0x74, 0x20, 0x50, 0x41, 0x41, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x41, 0x9a, 0x93, 0x15, 0xc2, 0x17, 0x3e, 0x0c, 0x8c, 0x87, 0x6d, 0x03, 0xcc, 0xfc, 0x94, 0x48, 0x52, 0x64, 0x7f, 0x7f, 0xec, 0x5e, 0x50, 0x82, 0xf4, 0x05, 0x99, 0x28, 0xec, 0xa8, 0x94, 0xc5, 0x94, 0x15, 0x13, 0x09, 0xac, 0x63, 0x1e, 0x4c, 0xb0, 0x33, 0x92, 0xaf, 0x68, 0x4b, 0x0b, 0xaf, 0xb7, 0xe6, 0x5b, 0x3b, 0x81, 0x62, 0xc2, 0xf5, 0x2b, 0xf9, 0x31, 0xb8, 0xe7, 0x7a, 0xaa, 0x82, 0xa3, 0x66, 0x30, 0x64, 0x30, 0x12, 0x06, 0x03, 0x55, 0x1d, 0x
[1697294752.970535][32395:32397] CHIP:DMG: ] (463 bytes)
[1697294752.970631][32395:32397] CHIP:DMG: },
[1697294752.970707][32395:32397] CHIP:DMG: },
[1697294752.970784][32395:32397] CHIP:DMG:
[1697294752.970845][32395:32397] CHIP:DMG: },
[1697294752.970917][32395:32397] CHIP:DMG:
[1697294752.970973][32395:32397] CHIP:DMG: ],
[1697294752.971049][32395:32397] CHIP:DMG:
[1697294752.971106][32395:32397] CHIP:DMG: InteractionModelRevision = 1
[1697294752.971163][32395:32397] CHIP:DMG: },
[1697294752.971316][32395:32397] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1697294752.971453][32395:32397] CHIP:CTL: Received certificate chain from the device
[1697294752.971527][32395:32397] CHIP:CTL: Successfully finished commissioning step 'SendPAICertificateRequest'
[1697294752.971592][32395:32397] CHIP:CTL: Commissioning stage next step: 'SendPAICertificateRequest' -> 'SendDACCertificateRequest'
[1697294752.971661][32395:32397] CHIP:CTL: Performing next commissioning step 'SendDACCertificateRequest'
[1697294752.971710][32395:32397] CHIP:CTL: Sending request for DAC certificate
[1697294752.971768][32395:32397] CHIP:CTL: Sending Certificate Chain request to 0xffff7800c250 device
[1697294752.971912][32395:32397] CHIP:DMG: ICR moving to [AddingComm]
[1697294752.971985][32395:32397] CHIP:DMG: ICR moving to [AddedComma]
[1697294752.972206][32395:32397] CHIP:EM: <<< [E:8638i S:1189 M:161582297] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1697294752.972301][32395:32397] CHIP:IN: (S) Sending msg 161582297 on secure session with LSID: 1189
[1697294752.973330][32395:32397] CHIP:DMG: ICR moving to [CommandSen]
[1697294752.973510][32395:32397] CHIP:DMG: ICR moving to [AwaitingDe]
[1697294753.190746][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1697294753.419504][32395:32396] CHIP:DL: Indication received, conn = 0xffff80032890
[1697294753.420058][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1697294753.554623][32395:32396] CHIP:DL: Indication received, conn = 0xffff80032890
[1697294753.555209][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1697294753.868649][32395:32396] CHIP:DL: Indication received, conn = 0xffff80032890
[1697294753.868989][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1697294753.869399][32395:32397] CHIP:EM: >>> [E:8638i S:1189 M:169693658] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1697294753.869486][32395:32397] CHIP:EM: Found matching exchange: 8638i, Delegate: 0xffff80034b38
[1697294753.869587][32395:32397] CHIP:DMG: ICR moving to [ResponseRe]
[1697294753.869704][32395:32397] CHIP:DMG: InvokeResponseMessage =
[1697294753.869765][32395:32397] CHIP:DMG: {
[1697294753.869820][32395:32397] CHIP:DMG: suppressResponse = false,
[1697294753.869876][32395:32397] CHIP:DMG: InvokeResponseIBs =
[1697294753.869983][32395:32397] CHIP:DMG: [
[1697294753.870041][32395:32397] CHIP:DMG: InvokeResponseIB =
[1697294753.870120][32395:32397] CHIP:DMG: {
[1697294753.870178][32395:32397] CHIP:DMG: CommandDataIB =
[1697294753.870251][32395:32397] CHIP:DMG: {
[1697294753.870314][32395:32397] CHIP:DMG: CommandPathIB =
[1697294753.870397][32395:32397] CHIP:DMG: {
[1697294753.870470][32395:32397] CHIP:DMG: EndpointId = 0x0,
[1697294753.870555][32395:32397] CHIP:DMG: ClusterId = 0x3e,
[1697294753.870649][32395:32397] CHIP:DMG: CommandId = 0x3,
[1697294753.870739][32395:32397] CHIP:DMG: },
[1697294753.870832][32395:32397] CHIP:DMG:
[1697294753.870901][32395:32397] CHIP:DMG: CommandFields =
[1697294753.870980][32395:32397] CHIP:DMG: {
[1697294753.871061][32395:32397] CHIP:DMG: 0x0 = [
[1697294753.871334][32395:32397] CHIP:DMG: 0x30, 0x82, 0x01, 0xe8, 0x30, 0x82, 0x01, 0x8e, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x6f, 0xdc, 0xb6, 0xed, 0x06, 0xf3, 0x58, 0xf9, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x53, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x44, 0x41, 0x43, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x2f, 0x30, 0x78, 0x38, 0x30, 0x30, 0x35, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x38, 0x30, 0x30, 0x35, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x7e, 0xf2, 0xf1, 0x08, 0x2b, 0x2a, 0x56, 0x4a, 0x05, 0x44, 0xc0, 0xa6, 0x13, 0xd2, 0x1b, 0x15, 0x75, 0x00, 0x55, 0x2d, 0x03, 0x5f, 0x23, 0x02, 0x25, 0x2f, 0xce, 0xe8, 0x1d, 0x6e, 0xc6, 0x74, 0x17, 0x34, 0x18, 0xa9, 0x4a, 0x88, 0xdb, 0x
[1697294753.871569][32395:32397] CHIP:DMG: ] (492 bytes)
[1697294753.871667][32395:32397] CHIP:DMG: },
[1697294753.871743][32395:32397] CHIP:DMG: },
[1697294753.871822][32395:32397] CHIP:DMG:
[1697294753.871882][32395:32397] CHIP:DMG: },
[1697294753.871978][32395:32397] CHIP:DMG:
[1697294753.872036][32395:32397] CHIP:DMG: ],
[1697294753.872111][32395:32397] CHIP:DMG:
[1697294753.872170][32395:32397] CHIP:DMG: InteractionModelRevision = 1
[1697294753.872227][32395:32397] CHIP:DMG: },
[1697294753.872391][32395:32397] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1697294753.872472][32395:32397] CHIP:CTL: Received certificate chain from the device
[1697294753.872538][32395:32397] CHIP:CTL: Successfully finished commissioning step 'SendDACCertificateRequest'
[1697294753.872606][32395:32397] CHIP:CTL: Commissioning stage next step: 'SendDACCertificateRequest' -> 'SendAttestationRequest'
[1697294753.872675][32395:32397] CHIP:CTL: Performing next commissioning step 'SendAttestationRequest'
[1697294753.872724][32395:32397] CHIP:CTL: Sending Attestation Request to the device.
[1697294753.872777][32395:32397] CHIP:CTL: Sending Attestation request to 0xffff7800c250 device
[1697294753.872916][32395:32397] CHIP:DMG: ICR moving to [AddingComm]
[1697294753.872993][32395:32397] CHIP:DMG: ICR moving to [AddedComma]
[1697294753.873219][32395:32397] CHIP:EM: <<< [E:8639i S:1189 M:161582298] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1697294753.873314][32395:32397] CHIP:IN: (S) Sending msg 161582298 on secure session with LSID: 1189
[1697294753.874174][32395:32397] CHIP:DMG: ICR moving to [CommandSen]
[1697294753.874285][32395:32397] CHIP:CTL: Sent Attestation request, waiting for the Attestation Information
[1697294753.874424][32395:32397] CHIP:DMG: ICR moving to [AwaitingDe]
[1697294754.000907][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1697294754.318536][32395:32396] CHIP:DL: Indication received, conn = 0xffff80032890
[1697294754.318819][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1697294755.848285][32395:32396] CHIP:DL: Indication received, conn = 0xffff80032890
[1697294755.848672][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1697294755.984711][32395:32396] CHIP:DL: Indication received, conn = 0xffff80032890
[1697294755.985066][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1697294755.985762][32395:32397] CHIP:EM: >>> [E:8639i S:1189 M:169693659] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1697294755.985847][32395:32397] CHIP:EM: Found matching exchange: 8639i, Delegate: 0xffff80035588
[1697294755.985974][32395:32397] CHIP:DMG: ICR moving to [ResponseRe]
[1697294755.986078][32395:32397] CHIP:DMG: InvokeResponseMessage =
[1697294755.986129][32395:32397] CHIP:DMG: {
[1697294755.986176][32395:32397] CHIP:DMG: suppressResponse = false,
[1697294755.986236][32395:32397] CHIP:DMG: InvokeResponseIBs =
[1697294755.986302][32395:32397] CHIP:DMG: [
[1697294755.986351][32395:32397] CHIP:DMG: InvokeResponseIB =
[1697294755.986421][32395:32397] CHIP:DMG: {
[1697294755.986495][32395:32397] CHIP:DMG: CommandDataIB =
[1697294755.986556][32395:32397] CHIP:DMG: {
[1697294755.986611][32395:32397] CHIP:DMG: CommandPathIB =
[1697294755.986751][32395:32397] CHIP:DMG: {
[1697294755.986868][32395:32397] CHIP:DMG: EndpointId = 0x0,
[1697294755.987122][32395:32397] CHIP:DMG: ClusterId = 0x3e,
[1697294755.987252][32395:32397] CHIP:DMG: CommandId = 0x1,
[1697294755.987422][32395:32397] CHIP:DMG: },
[1697294755.987568][32395:32397] CHIP:DMG:
[1697294755.987630][32395:32397] CHIP:DMG: CommandFields =
[1697294755.987749][32395:32397] CHIP:DMG: {
[1697294755.987886][32395:32397] CHIP:DMG: 0x0 = [
[1697294755.988190][32395:32397] CHIP:DMG: 0x15, 0x31, 0x01, 0x1b, 0x02, 0x30, 0x82, 0x02, 0x17, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x02, 0xa0, 0x82, 0x02, 0x08, 0x30, 0x82, 0x02, 0x04, 0x02, 0x01, 0x03, 0x31, 0x0d, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x82, 0x01, 0x70, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x01, 0xa0, 0x82, 0x01, 0x61, 0x04, 0x82, 0x01, 0x5d, 0x15, 0x24, 0x00, 0x01, 0x25, 0x01, 0xf1, 0xff, 0x36, 0x02, 0x05, 0x00, 0x80, 0x05, 0x01, 0x80, 0x05, 0x02, 0x80, 0x05, 0x03, 0x80, 0x05, 0x04, 0x80, 0x05, 0x05, 0x80, 0x05, 0x06, 0x80, 0x05, 0x07, 0x80, 0x05, 0x08, 0x80, 0x05, 0x09, 0x80, 0x05, 0x0a, 0x80, 0x05, 0x0b, 0x80, 0x05, 0x0c, 0x80, 0x05, 0x0d, 0x80, 0x05, 0x0e, 0x80, 0x05, 0x0f, 0x80, 0x05, 0x10, 0x80, 0x05, 0x11, 0x80, 0x05, 0x12, 0x80, 0x05, 0x13, 0x80, 0x05, 0x14, 0x80, 0x05, 0x15, 0x80, 0x05, 0x16, 0x80, 0x05, 0x17, 0x80, 0x05, 0x18, 0x80, 0x05, 0x19, 0x80, 0x05, 0x1a, 0x80, 0x05, 0x1b, 0x80, 0x05, 0x1c, 0x80, 0x05, 0x1d, 0x80, 0x05, 0x1e, 0x80, 0x05, 0x1f, 0x80, 0x05, 0x20, 0x80, 0x05, 0x21, 0x80, 0x05, 0x22, 0x80, 0x05, 0x23, 0x80, 0x05, 0x24, 0x80, 0x05, 0x25, 0x80, 0x05, 0x26, 0x80, 0x05, 0x27, 0x80, 0x05, 0x28, 0x80, 0x05, 0x29, 0x80, 0x05, 0x2a, 0x80, 0x05, 0x2b, 0x80, 0x05, 0x2c, 0x80, 0x05, 0x2d, 0x80, 0x05, 0x2e, 0x80, 0x05, 0x2f, 0x80, 0x05, 0x30, 0x80, 0x05, 0x31, 0x80, 0x05, 0x32, 0x80, 0x05, 0x33, 0x80, 0x05, 0x34, 0x80, 0x05, 0x35, 0x80, 0x05, 0x36, 0x80, 0x05, 0x37, 0x80, 0x05, 0x38, 0x80, 0x05, 0x39, 0x80, 0x05, 0x3a, 0x80, 0x05, 0x3b, 0x80, 0x05, 0x3c, 0x80, 0x05, 0x3d, 0x80, 0x05, 0x3e, 0x80, 0x05, 0x3f, 0x80, 0x05, 0x40, 0x80, 0x05, 0x41, 0x80, 0x05, 0x42, 0x80, 0x05, 0x43, 0x80, 0x
[1697294755.988352][32395:32397] CHIP:DMG: ] (583 bytes)
[1697294755.988489][32395:32397] CHIP:DMG: 0x1 = [
[1697294755.988660][32395:32397] CHIP:DMG: 0xea, 0x4a, 0xec, 0xe0, 0xfe, 0x17, 0xcd, 0xec, 0xf2, 0xd7, 0x7c, 0x36, 0x7f, 0xd3, 0x12, 0xda, 0x7d, 0x41, 0xbe, 0x6f, 0x50, 0x9f, 0x2f, 0x69, 0x22, 0xda, 0x38, 0xd7, 0x3c, 0x34, 0xfe, 0xbd, 0x18, 0x4a, 0x97, 0x43, 0xc6, 0xfa, 0x38, 0xcf, 0x08, 0x80, 0x42, 0xea, 0x6f, 0x26, 0x2f, 0xdd, 0x1e, 0x27, 0x86, 0x22, 0x43, 0x4c, 0x56, 0x1f, 0x36, 0x16, 0x50, 0x18, 0x3b, 0x5c, 0xe3, 0xf2,
[1697294755.988800][32395:32397] CHIP:DMG: ] (64 bytes)
[1697294755.988951][32395:32397] CHIP:DMG: },
[1697294755.989064][32395:32397] CHIP:DMG: },
[1697294755.989212][32395:32397] CHIP:DMG:
[1697294755.989286][32395:32397] CHIP:DMG: },
[1697294755.989405][32395:32397] CHIP:DMG:
[1697294755.989478][32395:32397] CHIP:DMG: ],
[1697294755.989548][32395:32397] CHIP:DMG:
[1697294755.989600][32395:32397] CHIP:DMG: InteractionModelRevision = 1
[1697294755.989649][32395:32397] CHIP:DMG: },
[1697294755.989801][32395:32397] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0001
[1697294755.989872][32395:32397] CHIP:CTL: Received Attestation Information from the device
[1697294755.989932][32395:32397] CHIP:CTL: Successfully finished commissioning step 'SendAttestationRequest'
[1697294755.989982][32395:32397] CHIP:CTL: AutoCommissioner setting attestationElements buffer size 583/583
[1697294755.990083][32395:32397] CHIP:CTL: Commissioning stage next step: 'SendAttestationRequest' -> 'AttestationVerification'
[1697294755.990148][32395:32397] CHIP:CTL: Performing next commissioning step 'AttestationVerification'
[1697294755.990191][32395:32397] CHIP:CTL: Verifying attestation
[1697294756.017850][32395:32397] CHIP:CR: mbedTLS error: ERROR - Generic error
[1697294756.082581][32395:32397] CHIP:CTL: Successfully validated 'Attestation Information' command received from the device.
[1697294756.082628][32395:32397] CHIP:CTL: Successfully finished commissioning step 'AttestationVerification'
[1697294756.082648][32395:32397] CHIP:CTL: Commissioning stage next step: 'AttestationVerification' -> 'SendOpCertSigningRequest'
[1697294756.082674][32395:32397] CHIP:CTL: Performing next commissioning step 'SendOpCertSigningRequest'
[1697294756.082694][32395:32397] CHIP:CTL: Sending CSR request to 0xffff7800c250 device
[1697294756.082769][32395:32397] CHIP:DMG: ICR moving to [AddingComm]
[1697294756.082798][32395:32397] CHIP:DMG: ICR moving to [AddedComma]
[1697294756.082911][32395:32397] CHIP:EM: <<< [E:8640i S:1189 M:161582299] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1697294756.082950][32395:32397] CHIP:IN: (S) Sending msg 161582299 on secure session with LSID: 1189
[1697294756.083437][32395:32397] CHIP:DMG: ICR moving to [CommandSen]
[1697294756.083911][32395:32397] CHIP:CTL: Sent CSR request, waiting for the CSR
[1697294756.083988][32395:32397] CHIP:DMG: ICR moving to [AwaitingDe]
[1697294756.205891][32395:32397] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1697294757.163125][32395:32397] CHIP:BLE: BLE scan error: src/platform/Linux/bluez/ChipDeviceScanner.cpp:154: CHIP Error 0x00000032: Timeout
[1697294761.473903][32395:32396] CHIP:DL: Bluez disconnected
[1697294761.474171][32395:32396] CHIP:DL: Bluez notify CHIPoBluez connection disconnected
[1697294761.474822][32395:32397] CHIP:IN: Clearing BLE pending packets.
[1697294786.107882][32395:32397] CHIP:DMG: Time out! failed to receive invoke command response from Exchange: 8640i
[1697294786.108021][32395:32397] CHIP:CTL: Device failed to receive the CSR request Response: src/app/CommandSender.cpp:248: CHIP Error 0x00000032: Timeout
[1697294786.108102][32395:32397] CHIP:CTL: Error on commissioning step 'SendOpCertSigningRequest': 'src/app/CommandSender.cpp:248: CHIP Error 0x00000032: Timeout'
[1697294786.108160][32395:32397] CHIP:CTL: Failed to perform commissioning step 9
[1697294786.108222][32395:32397] CHIP:CTL: Going from commissioning step 'SendOpCertSigningRequest' with lastErr = 'src/app/CommandSender.cpp:248: CHIP Error 0x00000032: Timeout' -> 'Cleanup'
[1697294786.108304][32395:32397] CHIP:CTL: Performing next commissioning step 'Cleanup' with completion status = 'src/app/CommandSender.cpp:248: CHIP Error 0x00000032: Timeout'
[1697294786.108362][32395:32397] CHIP:CTL: Expiring failsafe on proxy 0xffff7800c250
[1697294786.108524][32395:32397] CHIP:DMG: ICR moving to [AddingComm]
[1697294786.108600][32395:32397] CHIP:DMG: ICR moving to [AddedComma]
[1697294786.108848][32395:32397] CHIP:EM: <<< [E:8641i S:1189 M:161582300] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1697294786.108952][32395:32397] CHIP:IN: (S) Sending msg 161582300 on secure session with LSID: 1189
[1697294786.109024][32395:32397] CHIP:IN: Message appended to BLE send queue
[1697294786.109084][32395:32397] CHIP:DMG: ICR moving to [CommandSen]
[1697294786.109157][32395:32397] CHIP:DMG: ICR moving to [AwaitingDe]
[1697294803.126501][32395:32397] CHIP:DMG: Time out! failed to receive invoke command response from Exchange: 8641i
[1697294803.126627][32395:32397] CHIP:CTL: Received failure response when disarming failsafesrc/app/CommandSender.cpp:248: CHIP Error 0x00000032: Timeout
[1697294803.126720][32395:32397] CHIP:CTL: Successfully finished commissioning step 'Cleanup'
[1697294803.126794][32395:32397] CHIP:TOO: Device commissioning Failure: src/app/CommandSender.cpp:248: CHIP Error 0x00000032: Timeout
[1697294803.126888][32395:32397] CHIP:DIS: Closing all BLE connections
[1697294803.126937][32395:32397] CHIP:IN: SecureSession[0xffff780095a0]: MarkForEviction Type:1 LSID:1189
[1697294803.126988][32395:32397] CHIP:SC: SecureSession[0xffff780095a0]: Moving from state 'kActive' --> 'kPendingEviction'
[1697294803.127084][32395:32397] CHIP:IN: SecureSession[0xffff780095a0]: Released - Type:1 LSID:1189
[1697294803.127152][32395:32397] CHIP:DMG: ICR moving to [AwaitingDe]
[1697294803.127686][32395:32395] CHIP:CTL: Shutting down the commissioner
[1697294803.127755][32395:32395] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1697294803.127806][32395:32395] CHIP:CTL: Shutting down the controller
[1697294803.127880][32395:32395] CHIP:IN: Expiring all sessions for fabric 0x1!!
[1697294803.127929][32395:32395] CHIP:FP: Forgetting fabric 0x1
[1697294803.127992][32395:32395] CHIP:TS: Pending Last Known Good Time: 2023-07-11T08:00:09
[1697294803.128246][32395:32395] CHIP:TS: Previous Last Known Good Time: 2023-07-11T08:00:09
[1697294803.128385][32395:32395] CHIP:TS: Reverted Last Known Good Time to previous value
[1697294803.128477][32395:32395] CHIP:CTL: Shutting down the commissioner
[1697294803.128523][32395:32395] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1697294803.128591][32395:32395] CHIP:CTL: Shutting down the controller
[1697294803.128633][32395:32395] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
[1697294803.131255][32395:32395] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
[1697294803.131674][32395:32395] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
[1697294803.131809][32395:32395] CHIP:FP: Shutting down FabricTable
[1697294803.131886][32395:32395] CHIP:TS: Pending Last Known Good Time: 2023-07-11T08:00:09
[1697294803.132173][32395:32395] CHIP:TS: Previous Last Known Good Time: 2023-07-11T08:00:09
[1697294803.132252][32395:32395] CHIP:TS: Reverted Last Known Good Time to previous value
[1697294803.133031][32395:32395] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-u1eVY2)
[1697294803.135209][32395:32395] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1697294803.135497][32395:32395] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1697294803.135569][32395:32395] CHIP:DL: Inet Layer shutdown
[1697294803.135619][32395:32395] CHIP:DL: BLE shutdown
[1697294803.136932][32395:32395] CHIP:DL: System Layer shutdown
[1697294803.137641][32395:32395] CHIP:TOO: Run command failure: src/app/CommandSender.cpp:248: CHIP Error 0x00000032: Timeout
The terminal output (last commands):
D: 147125 [DIS]Responding with EFDF42FFEF35D1D6._matterc._udp.local
I: 147131 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: EFDF42FFEF35D1D6.
I: 147141 [DIS]mDNS service published: _matterc._udp
D: 147146 [DIS]Scheduling extended discovery timeout in 900s
D: 147151 [DL]CHIPoBLE advertising set to off
I: 147155 [SVR]Device completed Rendezvous process
E: 147160 [DL]Long dispatch time: 170 ms, for event type 16388
D: 147165 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 147174 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 147182 [EM]>>> [E:8634r S:33323 M:161582293] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 147193 [IM]Received Read request
I: 147201 [EM]<<< [E:8634r S:33323 M:169693654] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 147212 [IN](S) Sending msg 169693654 on secure session with LSID: 33323
D: 147218 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 147350 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 147358 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 21)
D: 147530 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 147576 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 147584 [EM]>>> [E:8635r S:33323 M:161582294] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 147596 [FS]GeneralCommissioning: Received ArmFailSafe (60s)
I: 147602 [EM]<<< [E:8635r S:33323 M:169693655] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 147614 [IN](S) Sending msg 169693655 on secure session with LSID: 33323
D: 147621 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 147755 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 147763 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 147771 [EM]>>> [E:8636r S:33323 M:161582295] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 147785 [EM]<<< [E:8636r S:33323 M:169693656] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 147796 [IN](S) Sending msg 169693656 on secure session with LSID: 33323
D: 147803 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 148160 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 148168 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 148176 [EM]>>> [E:8637r S:33323 M:161582296] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 148188 [ZCL]OpCreds: Certificate Chain request received for PAI
I: 148198 [EM]<<< [E:8637r S:33323 M:169693657] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 148209 [IN](S) Sending msg 169693657 on secure session with LSID: 33323
D: 148216 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 148520 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 148528 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 148610 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 148618 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 48)
D: 148835 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 148843 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 148851 [EM]>>> [E:8638r S:33323 M:161582297] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 148863 [ZCL]OpCreds: Certificate Chain request received for DAC
I: 148873 [EM]<<< [E:8638r S:33323 M:169693658] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 148884 [IN](S) Sending msg 169693658 on secure session with LSID: 33323
D: 148891 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 149285 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 149293 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 149420 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 149428 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 77)
D: 149735 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 149781 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 149789 [EM]>>> [E:8639r S:33323 M:161582298] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 149801 [ZCL]OpCreds: Received an AttestationRequest command
I: 149836 [ZCL]OpCreds: AttestationRequest successful.
I: 149845 [EM]<<< [E:8639r S:33323 M:169693659] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 149856 [IN](S) Sending msg 169693659 on secure session with LSID: 33323
D: 149863 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 150185 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 150193 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 151715 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 151722 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 235)
D: 151850 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 151940 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 151949 [EM]>>> [E:8640r S:33323 M:161582299] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 151961 [ZCL]OpCreds: Received a CSRRequest command
I: 152108 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded
I: 152142 [ZCL]OpCreds: CSRRequest successful.
I: 152149 [EM]<<< [E:8640r S:33323 M:169693660] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 152160 [IN](S) Sending msg 169693660 on secure session with LSID: 33323
D: 152167 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
E: 152175 [DL]Long dispatch time: 235 ms, for event type 16388
D: 162336 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x0e)
D: 162344 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 138)
E: 162352 [DL]BLEManagerImpl::SendIndication() failed: 2000080
D: 162357 [IN]Clearing BLE pending packets.
I: 162361 [BLE]Releasing end point's BLE connection back to application.
I: 162368 [DL]Closing BLE GATT connection (ConnId 00)
E: 162372 [BLE]endpoint conf recvd failed, err = 408
I: 162377 [DL]BLE GAP connection terminated (reason 0x08)
I: 162382 [DL]Current number of connections: 0/1
I: 207601 [FS]Fail-safe timer expired
E: 207604 [SVR]Failsafe timer expired
D: 207608 [IN]SecureSession[0x200041c8]: MarkForEviction Type:1 LSID:33323
I: 207614 [SC]SecureSession[0x200041c8]: Moving from state 'kActive' --> 'kPendingEviction'
D: 207623 [IN]SecureSession[0x200041c8]: Released - Type:1 LSID:33323
E: 207629 [SVR]Commissioning failed (attempt 1): 32
D: 207635 [IN]SecureSession[0x200041c8]: Allocated Type:1 LSID:33325
D: 207641 [DL]CHIPoBLE advertising set to on
I: 207645 [DIS]Updating services using commissioning mode 1
I: 207651 [DIS]CHIP minimal mDNS started advertising.
D: 207656 [DL]Using wifi MAC for hostname
I: 207660 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1
D: 207669 [DIS]Responding with _matterc._udp.local
D: 207674 [DIS]Responding with EFDF42FFEF35D1D6._matterc._udp.local
D: 207680 [DIS]Responding with F4CE36001F4A.local
D: 207684 [DIS]Responding with F4CE36001F4A.local
D: 207689 [DIS]Responding with _V65521._sub._matterc._udp.local
D: 207694 [DIS]Responding with _S15._sub._matterc._udp.local
D: 207700 [DIS]Responding with _L3840._sub._matterc._udp.local
D: 207706 [DIS]Responding with _CM._sub._matterc._udp.local
D: 207711 [DIS]Responding with EFDF42FFEF35D1D6._matterc._udp.local
I: 207717 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: EFDF42FFEF35D1D6.
I: 207727 [DIS]mDNS service published: _matterc._udp
E: 207731 [ZCL]OpCreds: Got FailSafeTimerExpired
E: 207736 [ZCL]OpCreds: Proceeding to FailSafeCleanup on fail-safe expiry!
I: 207743 [TS]Pending Last Known Good Time: 2023-10-14T13:14:12
I: 207749 [TS]Previous Last Known Good Time: 2023-10-14T13:14:12
I: 207754 [TS]Reverted Last Known Good Time to previous value
E: 207760 [DL]Long dispatch time: 156 ms, for event type 32782
I: 207766 [FS]Fail-safe cleanly disarmed
I: 207773 [DL]CHIPoBLE advertising started
I: 207777 [DL]NFC Tag emulation started
I: 237776 [DL]CHIPoBLE advertising mode changed to slow
I: 237785 [DL]CHIPoBLE advertising started
    Please use NCS v2.4.2 and v2.4.2 chip tool from https://github.com/nrfconnect/sdk-connectedhomeip.
    Amanda H.
  • Unfortunately, chip-tool-linux_aarch64.zip (which is available in v2.4.1 release)  is absent in sdk-connectedhomeip v2.4.2 release. Also, I can not build it on Raspberry Pi using these instructions: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/matter/BUILDING.html#.
  • Please use NCS v2.4.2 and v2.4.2 chip tool from https://github.com/nrfconnect/sdk-connectedhomeip.
    Also, I have read the following text from the nordicmakeitmatter  discord channel:
    NordicSemi_Marte
    The downstream Matter repository is identical for nRF Connect SDK v2.4.1 and v2.4.2, so there is no problem with using CHIP Tool from v2.4.1. If CHIP Tool is not part of a release, you can assume that the releases are similar enough that you can use the last released CHIP Tool prebuilt package. However, if the prebuilt package does not work, I recommend building CHIP Tool manually.
    So, I think, my problem is something else.
  • I tried to use the SmartThings application on my mobile phone (instead of Chip-Tool) with scanning QR Code from here:
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/matter/light_bulb/README.html#commissioning-the-device
    There is the following error:
    I: 57506 [DL]Wi-Fi scan done (0)
    E: Unsupported security type: 7
    E: 57519 [DL]Connection request failed
    What does this error mean? I assume that I have the wrong security settings in my router. It is WPA2-Personal.
    The last commands from the terminal:
    D: 52318 [DIS]Responding with _matter._tcp.local
    D: 52322 [DIS]Responding with 95DEAEB7204AF971-B81C34437F364EC1._matter._tcp.local
    D: 52329 [DIS]Responding with 95DEAEB7204AF971-B81C34437F364EC1._matter._tcp.local
    D: 52337 [DIS]Responding with F4CE36001F4A.local
    D: 52341 [DIS]Responding with F4CE36001F4A.local
    D: 52345 [DIS]Responding with _I95DEAEB7204AF971._sub._matter._tcp.local
    I: 52352 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 95DEAEB7204AF971-B81C34437F364EC1.
    I: 52362 [DIS]mDNS service published: _matter._tcp
    I: 52367 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC
    I: 52374 [EM]<<< [E:64697r S:9531 M:67218193] (S) Msg TX to 1:FFFFFFFB00000000 [F971] --- Type 0001:09 (IM:InvokeCommandResponse)
    I: 52386 [IN](S) Sending msg 67218193 on secure session with LSID: 9531
    E: 52392 [DL]Long dispatch time: 227 ms, for event type 16388
    D: 52398 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 52405 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 70)
    D: 52480 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 52488 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 52496 [EM]>>> [E:64698r S:9531 M:14945024] (S) Msg RX from 1:FFFFFFFB00000000 [F971] --- Type 0001:08 (IM:InvokeCommandRequest)
    I: 52509 [EM]<<< [E:64698r S:9531 M:67218194] (S) Msg TX to 1:FFFFFFFB00000000 [F971] --- Type 0001:09 (IM:InvokeCommandResponse)
    I: 52521 [IN](S) Sending msg 67218194 on secure session with LSID: 9531
    D: 52527 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
    D: 52615 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 52623 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 52631 [EM]>>> [E:64699r S:9531 M:14945025] (S) Msg RX from 1:FFFFFFFB00000000 [F971] --- Type 0001:02 (IM:ReadRequest)
    D: 52642 [IM]Received Read request
    I: 52647 [EM]<<< [E:64699r S:9531 M:67218195] (S) Msg TX to 1:FFFFFFFB00000000 [F971] --- Type 0001:05 (IM:ReportData)
    I: 52657 [IN](S) Sending msg 67218195 on secure session with LSID: 9531
    D: 52663 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
    D: 52750 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 52758 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 52766 [EM]>>> [E:64700r S:9531 M:14945026] (S) Msg RX from 1:FFFFFFFB00000000 [F971] --- Type 0001:08 (IM:InvokeCommandRequest)
    D: 52778 [DL]Connecting to WiFi network: Tank
    D: 52784 [DL]WiFi scanning started...
    D: 55265 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
    D: 55360 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    I: 57524 [EM]<<< [E:64700r S:9531 M:67218196] (S) Msg TX to 1:FFFFFFFB00000000 [F971] --- Type 0001:09 (IM:InvokeCommandResponse)
    I: 57535 [IN](S) Sending msg 67218196 on secure session with LSID: 9531
    D: 57541 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 70)
    D: 57610 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 57618 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 57626 [EM]>>> [E:64701r S:9531 M:14945027] (S) Msg RX from 1:FFFFFFFB00000000 [F971] --- Type 0001:0a (IM:TimedRequest)
    I: 57638 [EM]<<< [E:64701r S:9531 M:67218197] (S) Msg TX to 1:FFFFFFFB00000000 [F971] --- Type 0001:01 (IM:StatusResponse)
    I: 57649 [IN](S) Sending msg 67218197 on secure session with LSID: 9531
    D: 57655 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 43)
    D: 57745 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 57753 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 57761 [EM]>>> [E:64701r S:9531 M:14945028] (S) Msg RX from 1:FFFFFFFB00000000 [F971] --- Type 0001:08 (IM:InvokeCommandRequest)
    I: 57773 [FS]GeneralCommissioning: Received ArmFailSafe (1s)
    I: 57780 [EM]<<< [E:64701r S:9531 M:67218198] (S) Msg TX to 1:FFFFFFFB00000000 [F971] --- Type 0001:09 (IM:InvokeCommandResponse)
    I: 57791 [IN](S) Sending msg 67218198 on secure session with LSID: 9531
    D: 57797 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
    D: 57880 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    I: 58778 [FS]Fail-safe timer expired
    E: 58781 [SVR]Failsafe timer expired
    D: 58785 [IN]SecureSession[0x20004158]: MarkForEviction Type:1 LSID:9531
    I: 58791 [SC]SecureSession[0x20004158]: Moving from state 'kActive' --> 'kPendingEviction'
    D: 58799 [IN]SecureSession[0x20004158]: Released - Type:1 LSID:9531
    E: 58805 [SVR]Commissioning failed (attempt 1): 32
    D: 58810 [IN]Clearing BLE pending packets.
    I: 58813 [BLE]Releasing end point's BLE connection back to application.
    I: 58820 [DL]Closing BLE GATT connection (ConnId 00)
    D: 58827 [IN]SecureSession[0x20004158]: Allocated Type:1 LSID:9533
    D: 58833 [DL]CHIPoBLE advertising set to on
    I: 58837 [DIS]Updating services using commissioning mode 1
    I: 58842 [DIS]CHIP minimal mDNS started advertising.
    D: 58847 [DL]Using wifi MAC for hostname
    I: 58851 [DIS]Advertise operational node 95DEAEB7204AF971-B81C34437F364EC1
    D: 58858 [DIS]Responding with _matter._tcp.local
    D: 58862 [DIS]Responding with 95DEAEB7204AF971-B81C34437F364EC1._matter._tcp.local
    D: 58870 [DIS]Responding with 95DEAEB7204AF971-B81C34437F364EC1._matter._tcp.local
    D: 58877 [DIS]Responding with F4CE36001F4A.local
    D: 58882 [DIS]Responding with F4CE36001F4A.local
    D: 58886 [DIS]Responding with _I95DEAEB7204AF971._sub._matter._tcp.local
    I: 58892 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 95DEAEB7204AF971-B81C34437F364EC1.
    I: 58903 [DIS]mDNS service published: _matter._tcp
    D: 58907 [DL]Using wifi MAC for hostname
    I: 58911 [DIS]Advertise commission parameter vendorID=65521 productID=32768 discriminator=3840/15 cm=1
    D: 58921 [DIS]Responding with _matterc._udp.local
    D: 58925 [DIS]Responding with A40D7BA410B91526._matterc._udp.local
    D: 58931 [DIS]Responding with F4CE36001F4A.local
    D: 58935 [DIS]Responding with F4CE36001F4A.local
    D: 58940 [DIS]Responding with _V65521._sub._matterc._udp.local
    D: 58945 [DIS]Responding with _S15._sub._matterc._udp.local
    D: 58951 [DIS]Responding with _L3840._sub._matterc._udp.local
    D: 58956 [DIS]Responding with _CM._sub._matterc._udp.local
    D: 58962 [DIS]Responding with A40D7BA410B91526._matterc._udp.local
    I: 58968 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: A40D7BA410B91526.
    I: 58977 [DIS]mDNS service published: _matterc._udp
    E: 58982 [ZCL]OpCreds: Got FailSafeTimerExpired
    E: 58986 [ZCL]OpCreds: Proceeding to FailSafeCleanup on fail-safe expiry!
    D: 58993 [IN]Expiring all sessions for fabric 0x1!!
    E: 58997 [FP]Reverting pending fabric data for fabric 0x1
    E: 59003 [FP]Warning: metadata not found during delete of fabric 0x1
    I: 59012 [FP]Fabric (0x1) deleted.
    I: 59015 [ZCL]OpCreds: Fabric index 0x1 was removed
    I: 59020 [DIS]Updating services using commissioning mode 1
    I: 59025 [DIS]CHIP minimal mDNS started advertising.
    D: 59030 [DL]Using wifi MAC for hostname
    I: 59034 [DIS]Advertise commission parameter vendorID=65521 productID=32768 discriminator=3840/15 cm=1
    D: 59044 [DIS]Responding with _matterc._udp.local
    D: 59048 [DIS]Responding with A40D7BA410B91526._matterc._udp.local
    D: 59054 [DIS]Responding with F4CE36001F4A.local
    D: 59058 [DIS]Responding with F4CE36001F4A.local
    D: 59063 [DIS]Responding with _V65521._sub._matterc._udp.local
    D: 59068 [DIS]Responding with _S15._sub._matterc._udp.local
    D: 59074 [DIS]Responding with _L3840._sub._matterc._udp.local
    D: 59079 [DIS]Responding with _CM._sub._matterc._udp.local
    D: 59085 [DIS]Responding with A40D7BA410B91526._matterc._udp.local
    I: 59091 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: A40D7BA410B91526.
    I: 59100 [DIS]mDNS service published: _matterc._udp
    I: 59114 [TS]Pending Last Known Good Time: 2023-10-17T13:20:34
    I: 59120 [TS]Previous Last Known Good Time: 2023-10-17T13:20:34
    I: 59126 [TS]Reverted Last Known Good Time to previous value
    E: 59132 [FP]Warning: metadata not found during delete of fabric 0x1
    E: 59140 [ZCL]OpCreds: failed to delete fabric at index 1: d8
    E: 59145 [DL]Long dispatch time: 364 ms, for event type 32782
    I: 59151 [FS]Fail-safe cleanly disarmed
    I: 59155 [DL]BLE GAP connection terminated (reason 0x13)
    I: 59160 [DL]Current number of connections: 0/1
    I: 59167 [DL]CHIPoBLE advertising started
    I: 89171 [DL]CHIPoBLE advertising mode changed to slow
    I: 89180 [DL]CHIPoBLE advertising started
    I: 900280 [SVR]Closing pairing window
    D: 900283 [IN]SecureSession[0x20004158]: Released - Type:1 LSID:9533
    I: 900289 [DIS]Updating services using commissioning mode 0
    I: 900295 [DIS]CHIP minimal mDNS started advertising.
    D: 900300 [DL]Using wifi MAC for hostname
    I: 900304 [DIS]Advertise commission parameter vendorID=65521 productID=32768 discriminator=3840/15 cm=0
    D: 900313 [DIS]Responding with _matterc._udp.local
    D: 900318 [DIS]Responding with A40D7BA410B91526._matterc._udp.local
    D: 900324 [DIS]Responding with F4CE36001F4A.local
    D: 900328 [DIS]Responding with F4CE36001F4A.local
    D: 900333 [DIS]Responding with _V65521._sub._matterc._udp.local
    D: 900338 [DIS]Responding with _S15._sub._matterc._udp.local
    D: 900344 [DIS]Responding with _L3840._sub._matterc._udp.local
    D: 900350 [DIS]Responding with A40D7BA410B91526._matterc._udp.local
    I: 900356 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: A40D7BA410B91526.
    I: 900365 [DIS]mDNS service published: _matterc._udp
    D: 900370 [DIS]Scheduling extended discovery timeout in 900s
    D: 900376 [DL]CHIPoBLE advertising set to off
    Are you testing with NCS v2.4.2 Matter Light bulb example on nRF7002 DK? If not, please use NCS v2.4.2.
    -Amanda H.
