cannot talk to dongle after connect
I connect to the nRF52840-MDK dongle thru the Serial Terminal (nRF52 Connectivity) it found the comm port and set the baudrate automatically. However, the terminal window constantly fills up the screen with ~/ characters. it repeats every 1 second. What I would like is detailed instructions on how to configure this dongle to be a BT 5 sniffer and read the Extended Advertising for any BT device near the dongle. It would also be helpful to filter the devices seen. Eventually I like to use Python to filter the choices and obtain the advertises data where I can parse the data received. I'm using Windows 10 pro.
Thanks.
  • # Copyright (c) Nordic Semiconductor ASA
    # All rights reserved.
    # Redistribution and use in source and binary forms, with or without modification,
    # are permitted provided that the following conditions are met:
    # 1. Redistributions of source code must retain the above copyright notice, this
    #    list of conditions and the following disclaimer.
    # 2. Redistributions in binary form, except as embedded into a Nordic
    #    Semiconductor ASA integrated circuit in a product or a software update for
    #    such product, must reproduce the above copyright notice, this list of
    #    conditions and the following disclaimer in the documentation and/or other
    #    materials provided with the distribution.
    # 3. Neither the name of Nordic Semiconductor ASA nor the names of its
    #    contributors may be used to endorse or promote products derived from this
    #    software without specific prior written permission.
    # 4. This software, with or without modification, must only be used with a
    #    Nordic Semiconductor ASA integrated circuit.
    # 5. Any software provided in binary form under this license must not be reverse
    #    engineered, decompiled, modified and/or disassembled.
    # THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR ASA "AS IS" AND ANY EXPRESS
    # OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
    # OF MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE ARE
    # DISCLAIMED. IN NO EVENT SHALL NORDIC SEMICONDUCTOR ASA OR CONTRIBUTORS BE
    # LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
    # CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
    # GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
    # HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
    # LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
    # OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    import time
    from SnifferAPI import Sniffer, UART
    nPackets = 0
    nPacketsByType = [0,0,0,0,0,0,0,0]
    mySniffer = None
    packets2see = 200
    alldone = False
    MAX_MACS = 7
    look_for_these_macs = [' '] * MAX_MACS
    found_flags = [False] * MAX_MACS
    look_for_these_macs[1] = "D8:84:97:C3:1F:A8"
    look_for_these_macs[2] = "F1:39:E9:5B:2C:18"
    look_for_these_macs[3] = "F1:4B:94:83:92:2C"
    look_for_these_macs[4] = "D5:DC:9F:6C:E8:74"
    look_for_these_macs[5] = "FD:70:6A:BC:33:FC"
    look_for_these_macs[6] = "CB:D8:BD:92:4D:46"
    output_text = open("output_results.txt", "w")
    def setup():
        global mySniffer
        # Find connected sniffers
        ports = UART.find_sniffer()
        if len(ports) > 0:
            # Initialize the sniffer on the first COM port found with baudrate 1000000.
            # If you are using an old firmware version <= 2.0.0, simply remove the baudrate parameter here.
            mySniffer = Sniffer.Sniffer(portnum=ports[0], baudrate=1000000)
        else:
            print("No sniffers found!")
            return
        # Start the sniffer module. This call is mandatory.
        mySniffer.start()
        # Scan for new advertisers
        mySniffer.scan(findAux=True)
        # Wait to allow the sniffer to discover device mySniffer.
        #time.sleep(5)
        # Retrieve list of discovered devicemySniffer.
        #d = mySniffer.getDevices()
        # Find device with name "Example".
        #dev = d.find('Example')
        #if dev is not None:
            # Follow (sniff) device "Example". This call sends a REQ_FOLLOW command over UART.
        #    mySniffer.follow(dev)
        #else:
        #    print("Could not find device")
    def loop():
        # Enter main loop
        nLoops = 0
        while True:
            time.sleep(0.1)
            # Get (pop) unprocessed BLE packets.
            packets = mySniffer.getPackets()
            processPackets(packets) # function defined below
            nLoops += 1
            # # print diagnostics every so often
            # if nLoops % 25 == 0:
            #     #print(mySniffer.getDevices())
            #     print("inConnection", mySniffer.inConnection)
            #     print("currentConnectRequest", mySniffer.currentConnectRequest)
            #     print("packetsInLastConnection", mySniffer.packetsInLastConnection)
            #     print("nPackets", nPackets)
            #     print("packet by type", nPacketsByType)
            #     print()
    # Takes list of packets
    def processPackets(packets):
        global alldone
        global packets2see
        global look_for_these_macs
        for packet in packets:
            # packet is of type Packet
            # packet.blePacket is of type BlePacket
            global nPackets
            if packet.OK:
                # Counts number of packets which are not malformed.
                nPackets += 1
                nPacketsByType[packet.blePacket.advType] += 1
                #if packet.blePacket.advType == 7:
                if packet.RSSI > -65:               # and packet.blePacket.advType == 7:         #  packet.blePacket.advType == 7  and packet.flags == 17
                    if packet.blePacket.advAddress:
                        myAddrhexvalue = packet.blePacket.advAddress
                        myAddrhexvalue = ' '.join(format(x,'02x') for x in myAddrhexvalue).upper()
                        myAddrhexvalue = myAddrhexvalue.replace(' ',':')
                        # print(f"\nSee This-->{myAddrhexvalue}")
                    else:
                        myAddrhexvalue = 'none'
                    for i in range(1,MAX_MACS):
                        if look_for_these_macs[i] in myAddrhexvalue:
                            found_flags[i] = True
                            # print(f"Address= {myAddrhexvalue} flag= {packet.flags} name={packet.blePacket.name}  List={packet.getList()}" )
                            myDataHexvalue = packet.getList()
                            myDataHexvalue = ' '.join(format(x,'02x') for x in myDataHexvalue).upper()
                            # myAddrhexvalue = myAddrhexvalue.strip('[').strip(']')
                            print("i=", str(i), "adv type=", packet.blePacket.advType, " Addr =", myAddrhexvalue, "  flag=", packet.flags, " name=", packet.blePacket.name, " data=", myDataHexvalue)
                            buffer = "\nAddr =" + str(myAddrhexvalue) + " type=" + str(packet.blePacket.advType) + "  flag=" + str(packet.flags) + " name=" + packet.blePacket.name + " data=" + myDataHexvalue
                            output_text.write(buffer)
                            packets2see-=1
                            if packets2see < 1:
                                for idx in range(1,MAX_MACS):
                                    if found_flags[idx] == False:
                                        print(f"\nNever Found this index {idx}  mac --> {look_for_these_macs[idx]}")
                                print("\nAll Done")
                                output_text.close
                                mySniffer = None
                                raise SystemExit
    setup()
    if mySniffer is not None:
        loop()
    This is the modified code.
  • Hi James,
    Torbjørn is away for 2 weeks so I will take over the ticket.
    Have you got any progress on this ?
    Please make sure that you have a scanner that scan for the AUX_ADV_IND and send the AUX_SCAN_REQ. Otherwise the peripheral will not send the AUX_SCA_RSP.
    I'm not so sure why in your output_result you have all packet with flag = 17.
    Is it hexa 0x17 or decimal 17 ?
    The AUX_SCAN_RSP should have the flag 0x17 = 23 when the ADV_EXT_IND has the flag = 0x11 = 17.
  • Hung,
    I took all the advertising type filters off and only print out any of the 6 mac addresses found.
    Maybe all of these have the same type? If you look at line 152 above in the code I print out whatever packet.blePacket.advType is. I'm not sure if its hex or decimal.  I'm sure you have read thru the conversations and know that I'm trying to get the extended advertising data. See output from the wire shark. I'm trying to use python to capture this data. Am I using the correct firmware in the dongle?
    nrf_sniffer_for_bluetooth_le_4.1.1
    Thanks.
    Jim
  • Hi Jim,
    Could you answer my question, have you made sure you have a scanner that send the scan request?  You can use a phone (that support extended advertising) as the scanner.
    Note that the PDU type of ADV_EXT_IND and AUX_SCAN_RSP are the same.
    Please try to use as less filter as possible so you can see the advertising data packet print out and can find the correct filter for it.
    Try to have distinct data for example 0x123456789 in your AUX_SCAN_RSP so you can detect it quickly. If you don't have control over the DUT, please use one of our example in the SDK that can do extended advertising, for example peripheral_hr_code. I attached the main.c file and the hex file that you can use to test.
    4628.zephyr.hex
     * Copyright (c) 2020 Nordic Semiconductor ASA
    /** @file
     *  @brief Peripheral Heart Rate over LE Coded PHY sample
    #include <stddef.h>
    #include <string.h>
    #include <errno.h>
    #include <zephyr/kernel.h>
    #include <zephyr/types.h>
    #include <zephyr/bluetooth/conn.h>
    #include <zephyr/bluetooth/gatt.h>
    #include <zephyr/bluetooth/uuid.h>
    #include <zephyr/bluetooth/services/bas.h>
    #include <zephyr/bluetooth/services/hrs.h>
    #include <dk_buttons_and_leds.h>
    #define DEVICE_NAME             CONFIG_BT_DEVICE_NAME
    #define DEVICE_NAME_LEN         (sizeof(DEVICE_NAME) - 1)
    #define RUN_STATUS_LED          DK_LED1
    #define CON_STATUS_LED          DK_LED2
    #define RUN_LED_BLINK_INTERVAL  1000
    #define NOTIFY_INTERVAL         1000
    static void start_advertising_coded(struct k_work *work);
    static void notify_work_handler(struct k_work *work);
    static K_WORK_DEFINE(start_advertising_worker, start_advertising_coded);
    static K_WORK_DELAYABLE_DEFINE(notify_work, notify_work_handler);
    static struct bt_le_ext_adv *adv;
    static const struct bt_data ad[] = {
    	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
    BT_DATA_BYTES(BT_DATA_UUID16_ALL, BT_UUID_16_ENCODE(BT_UUID_HRS_VAL),
    					  BT_UUID_16_ENCODE(BT_UUID_BAS_VAL),
    					  BT_UUID_16_ENCODE(BT_UUID_DIS_VAL)),
    static const struct bt_data sd[] = {
    		BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN)
    static void connected(struct bt_conn *conn, uint8_t conn_err)
    	int err;
    	struct bt_conn_info info;
    	if (conn_err) {
    		printk("Connection failed (err %d)\n", conn_err);
    		return;
    	err = bt_conn_get_info(conn, &info);
    	if (err) {
    		printk("Failed to get connection info (err %d)\n", err);
    	} else {
    		const struct bt_conn_le_phy_info *phy_info;
    		phy_info = info.le.phy;
    		printk("Connected: %s, tx_phy %u, rx_phy %u\n",
    		       addr, phy_info->tx_phy, phy_info->rx_phy);
    	dk_set_led_on(CON_STATUS_LED);
    	printk("Disconnected (reason 0x%02x)\n", reason);
    	k_work_submit(&start_advertising_worker);
    	dk_set_led_off(CON_STATUS_LED);
    BT_CONN_CB_DEFINE(conn_callbacks) = {
    	.connected = connected,
    	.disconnected = disconnected,
    static int create_advertising_coded(void)
    	int err;
    	struct bt_le_adv_param param =
    		BT_LE_ADV_PARAM_INIT(
    				     BT_LE_ADV_OPT_EXT_ADV|BT_LE_ADV_OPT_SCANNABLE,
    				     BT_GAP_ADV_FAST_INT_MIN_2,
    				     BT_GAP_ADV_FAST_INT_MAX_2,
    				     NULL);
    	err = bt_le_ext_adv_create(&param, NULL, &adv);
    	if (err) {
    		printk("Failed to create advertiser set (err %d)\n", err);
    		return err;
    	printk("Created adv: %p\n", adv);
    	err = bt_le_ext_adv_set_data(adv, NULL,0, sd,ARRAY_SIZE(sd));
    	if (err) {
    		printk("Failed to set advertising data (err %d)\n", err);
    		return err;
    	return 0;
    	int err;
    	err = bt_le_ext_adv_start(adv, NULL);
    	if (err) {
    		printk("Failed to start advertising set (err %d)\n", err);
    		return;
    	printk("Advertiser %p set started\n", adv);
    static void bas_notify(void)
    	uint8_t battery_level = bt_bas_get_battery_level();
    	__ASSERT_NO_MSG(battery_level > 0);
    	battery_level--;
    	if (!battery_level) {
    		battery_level = 100;
    	bt_bas_set_battery_level(battery_level);
    static void hrs_notify(void)
    	static uint8_t heartrate = 100;
    	heartrate++;
    	if (heartrate == 160) {
    		heartrate = 100;
    	bt_hrs_notify(heartrate);
    	/* Services data simulation. */
    	hrs_notify();
    	bas_notify();
    	k_work_reschedule(k_work_delayable_from_work(work), K_MSEC(NOTIFY_INTERVAL));
    	uint32_t led_status = 0;
    	int err;
    	printk("Starting Bluetooth Peripheral HR coded example\n");
    	err = dk_leds_init();
    	if (err) {
    		printk("LEDs init failed (err %d)\n", err);
    		return 0;
    	err = bt_enable(NULL);
    	if (err) {
    		printk("Bluetooth init failed (err %d)\n", err);
    		return 0;
    	printk("Bluetooth initialized\n");
    	err = create_advertising_coded();
    	if (err) {
    		printk("Advertising failed to create (err %d)\n", err);
    		return 0;
    	k_work_schedule(&notify_work, K_NO_WAIT);
    	for (;;) {
    		dk_set_led(RUN_STATUS_LED, (++led_status) % 2);
    		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
    The scan response packet will contain many 0x41 that make it easy to detect.
    If you see the data on wireshark that means you can get the same data  on your python script, I don't see why you think the firmware on the dongle would be an issue here.
  • Hung,
    Forgive me, I'm new to both Bluetooth and Python and most of the time I have to research things on the internet. I think what you are looking for is below. I have a company phone running nrfConnect and this is what it sees.
    I'm not sure what you mean by "that send the scan request". Does the receiver (phone) send out a request for Bluetooth data? Is this what I'm missing in the Python script?
    Jim
