Crash application after LTE CELL found
The version of modem is 1.3.5 and NCS 2.2.0.
The hardware is a custom board.
When the application is running, the reset occurs after MODEM_EVT_CELL_UPDATE.
It's very strange because, I have a pre-prod of 50 x devices and it's concerning someones of them.
I tested udp application provided by the SDK and I have the same issue.
And I don't think it's a power supply issue because I checked voltage during running application and there is no leak.
For finish, I read Case ID: 309798 from devzone and I think it's probebly the same issue.
Do you have an idea ?
Thanks
    Did you do as my colleague suggested in this ticket? I.e. add CONFIG_RESET_ON_FATAL_ERROR=n and CONFIG_THREAD_NAME=y to your prj.conf. You could also try adding CONFIG_ASSERT=y. More logs are needed in order to find the root cause of this issue.
    What makes you think it is related to modem_evt_cell_update? There are sensors enabled after this. To me it seems more of an issue with one of these.
    Did you have a design review of your board? Have you ensured all components are soldered correctly?
    Øyvind
    thanks for your reply.
    I tried to use "udp" application and I added   CONFIG_RESET_ON_FATAL_ERROR=n, CONFIG_THREAD_NAME=y, CONFIG_ASSERT=y in prj.conf.
    You can see below the result :
    When the device find a new cell, it reboot !
    No, sensors are enabled right after reset. There is some messages from drivers written before the message "Booting Zephyr OS build".
    No, I didn't ask to make a review of my board and I would like to do it ! Yes I think I have no problem of compoments poorly soldered.
    Our HW people can help reviewing your design, just register a new DevZone ticket and ask for a HW review Slight smile
    Very strange behavior. Could you please collect a modem trace from the device when the issue occurs? That said, do you have e.g. a nRF9160 DK to test with as well?
    Is this the only configurations you have done to the UDP sample?
    Øyvind
    Yes I have already make a trace modem before I wrote the ticket:
    trace-2023-10-16T05-36-43.524Z.mtrace
    Here is the trace of my application not UDP sample. But it's the same issue.
    I tried to read this trace but I found nothing !
    I think I will have no issue with nRF9160 DK. The issue is specific to my custom board.
    In addition, I received a pre-serie of 50 x devices from my provider and I have 2 x devices with this issue / 10 x prepared !
    Yes I'm going to make the ticket.
    Yes in addition to the other parameters.
