I am using the lpuart between an nRF5340DK and an nRF9160DK.The lpuart is configured to operate in interrupt mode. Everything seems to work fine as long both DK boards come up at the same time. However, if the nRF9160DK takes a while to come up and the nRF5340Dk tries to send data over the lpuart it will timeout, as expected. But once the nRF9160DK is operational, the lpuart tx on the nRF5340 will no loner try to send. I tracked the issue down to a CAS (compare and set) call in the uart_fiffo_fill function. Because the previous TX timed out, data->int_driven.txlen still holds the previous send attempt data length and this causes the CAS to fail and no send attempt is made. There appears to be no way to recover form this aside from rebooting the device. Stepping through the lpuart driver I found the int_driven_evt_handler() function is called with an event type of UART_TX_ABORTED which is not handled. For debugging purposes, I added a UART_TX_ABORTED handler and just set the txlen to zero as it would do in the async mode. This seemed to solve the problem i.e. all lpuart sends would timeout until the nRF9160DK became operational at which point all data transfers between the two devices resumed normally. So my question is, are there other ways to recover from an lpuart TX timeout while operating in interrupt mode?
