The sta sample project is giving me a lot of errors, what should I do?
I am trying to run nRF7002DK, and when I connect to a WiFi network using the sta sample or the shell sample, I get a bunch of errors.
net_pkt: Data buffer (xxx) allocation failed
Someone asked the same question on DevZone, so I tried doubling the CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE as described there, but the error keeps occurring.
https://devzone.nordicsemi.com/f/nordic-q-a/97812/net_pkt-data-buffer-42-allocation-failed
How do I fix this?
Also, I don't know if this is related, but TCP socket communication doesn't work at all. where can I find samples of TCP and UDP communication?
  • Hi Yoshihiro,
    Could you share your prj.conf configuration so I might see if any configurations are missing!!
    Regards
    Lalith RJ
    My prj.conf is the below. This project is an original project with necessary parts extracted from sta and shell.
    CONFIG_WIFI=y
    CONFIG_NET_L2_ETHERNET=y
    CONFIG_NET_IPV6=n
    CONFIG_HEAP_MEM_POOL_SIZE=163840
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    CONFIG_NET_PKT_RX_COUNT=8
    CONFIG_NET_PKT_TX_COUNT=8
    CONFIG_DK_LIBRARY=y
    CONFIG_WIFI_NRF700X=y
    CONFIG_NET_MGMT_EVENT_STACK_SIZE=2048
    CONFIG_WPA_SUPP=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_NEWLIB_LIBC=y
    CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048
    CONFIG_DEBUG_THREAD_INFO=y
    CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=100
    CONFIG_NETWORKING=y
    CONFIG_NET_IPV4=y
    CONFIG_NET_DHCPV4=y
    CONFIG_NET_TCP=y
    CONFIG_NET_TCP_WORKQ_STACK_SIZE=2048
    CONFIG_NET_MAX_CONTEXTS=2
    CONFIG_NET_BUF_RX_COUNT=8
    CONFIG_NET_BUF_TX_COUNT=8
    CONFIG_NET_TX_STACK_SIZE=8192
    CONFIG_NET_RX_STACK_SIZE=8192
    CONFIG_NET_LOG=y
    CONFIG_NET_CONN_LOG_LEVEL_INF=y
    CONFIG_NET_CONFIG_SETTINGS=y
    CONFIG_NET_CONFIG_MY_IPV4_NETMASK="255.255.254.0"
    CONFIG_NET_CONFIG_MY_IPV4_GW="10.0.4.1"
    CONFIG_NET_SOCKETS=y
    CONFIG_DEBUG_OPTIMIZATIONS=y
    I have successfully tested wi-fi sta sample in NCS v2.4.2 using your prj.conf file with the addition of security method, SSID and password.
    CONFIG_STA_KEY_MGMT_WPA2=y
    CONFIG_STA_SAMPLE_SSID="<your_SSID>"
    CONFIG_STA_SAMPLE_PASSWORD="<your_password>"
    Dejan
    My apologies, my explanation was insufficient. Of course, I have the SSID, password, and encryption settings, but that is private information, so I did not post it.
    I am able to connect to the WiFi router with the sta project. The problem is that after a while of connecting, errors occur frequently. Of course I have not done anything other than connecting.
    [00:00:00.505,065] <inf> wifi_nrf: Firmware (v1.2.8.1) booted successfully
    *** Booting Zephyr OS build v3.3.99-ncs1-1 ***
    [00:00:00.675,598] <inf> net_config: Initializing network
    [00:00:00.675,598] <inf> net_config: Waiting interface 1 (0x20000c98) to be up...
    [00:00:00.677,612] <inf> net_config: IPv4 address: 10.0.5.250
    [00:00:00.677,642] <inf> net_config: Running dhcpv4 client...
    [00:00:06.390,289] <inf> sta: Starting nrf7002dk_nrf5340_cpuapp with CPU frequency: 64 MHz
    [00:00:07.390,350] <inf> sta: QSPI Encryption disabled
    [00:00:07.390,411] <inf> sta: Static IP address (overridable): 10.0.5.250/255.255.240.0 -> 10.0.4.1
    [00:00:08.962,066] <inf> sta: Connection requested
    [00:00:09.262,207] <inf> sta: ==================
    [00:00:09.262,237] <inf> sta: State: SCANNING
    [00:00:09.562,377] <inf> sta: ==================
    [00:00:09.562,408] <inf> sta: State: SCANNING
    [00:00:09.862,518] <inf> sta: ==================
    [00:00:09.862,548] <inf> sta: State: SCANNING
    [00:00:10.162,658] <inf> sta: ==================
    [00:00:10.162,689] <inf> sta: State: SCANNING
    [00:00:10.462,799] <inf> sta: ==================
    [00:00:10.462,829] <inf> sta: State: SCANNING
    [00:00:10.762,969] <inf> sta: ==================
    [00:00:10.763,000] <inf> sta: State: SCANNING
    [00:00:11.063,110] <inf> sta: ==================
    [00:00:11.063,140] <inf> sta: State: SCANNING
    [00:00:11.363,250] <inf> sta: ==================
    [00:00:11.363,281] <inf> sta: State: SCANNING
    [00:00:11.663,391] <inf> sta: ==================
    [00:00:11.663,421] <inf> sta: State: SCANNING
    [00:00:11.963,562] <inf> sta: ==================
    [00:00:11.963,592] <inf> sta: State: SCANNING
    [00:00:12.263,732] <inf> sta: ==================
    [00:00:12.263,763] <inf> sta: State: SCANNING
    [00:00:12.563,873] <inf> sta: ==================
    [00:00:12.563,903] <inf> sta: State: SCANNING
    [00:00:12.864,013] <inf> sta: ==================
    [00:00:12.864,044] <inf> sta: State: SCANNING
    [00:00:13.164,184] <inf> sta: ==================
    [00:00:13.164,215] <inf> sta: State: SCANNING
    [00:00:13.367,187] <inf> wifi_nrf: wifi_nrf_wpa_supp_authenticate:Authentication request sent successfully
    [00:00:13.464,324] <inf> sta: ==================
    [00:00:13.464,355] <inf> sta: State: AUTHENTICATING
    [00:00:13.730,712] <inf> wifi_nrf: wifi_nrf_wpa_supp_associate: Association request sent successfully
    [00:00:13.777,252] <inf> sta: ==================
    [00:00:13.777,282] <inf> sta: State: 4WAY_HANDSHAKE
    [00:00:13.777,282] <inf> sta: Interface Mode: STATION
    [00:00:13.777,313] <inf> sta: Link Mode: WIFI 5 (802.11ac/VHT)
    [00:00:13.777,343] <inf> sta: SSID: ************
    [00:00:13.777,404] <inf> sta: BSSID: 00:11:32:96:70:A9
    [00:00:13.777,404] <inf> sta: Band: 5GHz
    [00:00:13.777,435] <inf> sta: Channel: 36
    [00:00:13.777,465] <inf> sta: Security: WPA2-PSK
    [00:00:13.777,465] <inf> sta: MFP: Optional
    [00:00:13.777,496] <inf> sta: RSSI: -55
    [00:00:13.809,844] <inf> sta: Connected
    [00:00:14.092,590] <inf> sta: ==================
    [00:00:14.092,620] <inf> sta: State: COMPLETED
    [00:00:14.092,651] <inf> sta: Interface Mode: STATION
    [00:00:14.092,681] <inf> sta: Link Mode: WIFI 5 (802.11ac/VHT)
    [00:00:14.092,712] <inf> sta: SSID: ************
    [00:00:14.092,742] <inf> sta: BSSID: 00:11:32:96:70:A9
    [00:00:14.092,773] <inf> sta: Band: 5GHz
    [00:00:14.092,773] <inf> sta: Channel: 36
    [00:00:14.092,803] <inf> sta: Security: WPA2-PSK
    [00:00:14.092,834] <inf> sta: MFP: Optional
    [00:00:14.092,834] <inf> sta: RSSI: -55
    [00:00:27.293,121] <inf> net_dhcpv4: Received: 10.0.4.69
    [00:00:27.293,273] <inf> net_config: IPv4 address: 10.0.4.69
    [00:00:27.293,304] <inf> net_config: Lease time: 86400 seconds
    [00:00:27.293,334] <inf> net_config: Subnet: 255.255.240.0
    [00:00:27.293,365] <inf> net_config: Router: 10.0.4.1
    [00:00:27.295,349] <inf> sta: DHCP IP address: 10.0.4.69
    [00:03:54.677,856] <err> net_pkt: Data buffer (1500) allocation failed.
    [00:03:54.677,886] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:03:54.781,616] <err> net_pkt: Data buffer (1496) allocation failed.
    [00:03:54.781,616] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:03:54.885,284] <err> net_pkt: Data buffer (1172) allocation failed.
    [00:03:54.885,314] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:03:54.985,931] <err> net_pkt: Data buffer (1192) allocation failed.
    [00:03:54.985,961] <wrn> net_conn: pkt cloning failed, pkt 0x20034d68 dropped
    [00:03:55.086,517] <err> net_pkt: Data buffer (1500) allocation failed.
    [00:03:55.086,517] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    [00:03:55.190,216] <err> net_pkt: Data buffer (1496) allocation failed.
    [00:03:55.190,246] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    [00:03:55.296,905] <err> net_pkt: Data buffer (1058) allocation failed.
    [00:03:55.296,936] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    [00:03:55.397,491] <err> net_pkt: Data buffer (1078) allocation failed.
    [00:03:55.397,521] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:03:55.500,640] <err> net_pkt: Data buffer (1022) allocation failed.
    [00:03:55.500,671] <wrn> net_conn: pkt cloning failed, pkt 0x20034d68 dropped
    [00:03:55.601,257] <err> net_pkt: Data buffer (1042) allocation failed.
    [00:03:55.601,287] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    [00:03:55.888,244] <err> net_pkt: Data buffer (1168) allocation failed.
    [00:03:55.888,275] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:03:55.988,891] <err> net_pkt: Data buffer (1188) allocation failed.
    [00:03:55.988,922] <wrn> net_conn: pkt cloning failed, pkt 0x20034d68 dropped
    [00:03:57.111,755] <err> net_pkt: Data buffer (1015) allocation failed.
    [00:03:57.111,785] <wrn> net_conn: pkt cloning failed, pkt 0x20034d68 dropped
    [00:03:58.787,200] <err> net_pkt: Data buffer (1152) allocation failed.
    [00:03:58.787,231] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:03:58.887,847] <err> net_pkt: Data buffer (1172) allocation failed.
    [00:03:58.887,878] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    [00:03:59.171,142] <err> net_pkt: Data buffer (1015) allocation failed.
    [00:03:59.171,173] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    [00:03:59.979,675] <err> net_pkt: Data buffer (1058) allocation failed.
    [00:03:59.979,705] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:04:00.080,261] <err> net_pkt: Data buffer (1078) allocation failed.
    [00:04:00.080,291] <wrn> net_conn: pkt cloning failed, pkt 0x20034d68 dropped
    [00:04:01.616,577] <err> net_pkt: Data buffer (1149) allocation failed.
    [00:04:01.616,607] <wrn> net_conn: pkt cloning failed, pkt 0x20034d68 dropped
    [00:04:02.433,380] <err> net_pkt: Data buffer (1465) allocation failed.
    [00:04:02.433,410] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:04:02.534,118] <err> net_pkt: Data buffer (1485) allocation failed.
    [00:04:02.534,149] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    Best Regards,
    Yoshihiro Goto
  • Errors continue to occur, but I think that is enough information, so I will stop at this point.
    [00:04:34.790,771] <err> net_pkt: Data buffer (1116) allocation failed.
    [00:04:34.790,802] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    [00:04:34.891,418] <err> net_pkt: Data buffer (1136) allocation failed.
    [00:04:34.891,448] <wrn> net_conn: pkt cloning failed, pkt 0x20034d68 dropped
    [00:10:02.492,950] <err> net_pkt: Data buffer (1140) allocation failed.
    [00:10:02.492,980] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    [00:10:02.593,475] <err> net_pkt: Data buffer (1103) allocation failed.
    [00:10:02.593,505] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:10:02.697,753] <err> net_pkt: Data buffer (1103) allocation failed.
    [00:10:02.697,784] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:10:02.901,031] <err> net_pkt: Data buffer (1103) allocation failed.
    [00:10:02.901,062] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:10:03.001,678] <err> net_pkt: Data buffer (1140) allocation failed.
    [00:10:03.001,708] <wrn> net_conn: pkt cloning failed, pkt 0x20034d68 dropped
    [00:10:03.717,620] <err> net_pkt: Data buffer (1140) allocation failed.
    [00:10:03.717,651] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    [00:10:03.818,145] <err> net_pkt: Data buffer (1103) allocation failed.
    [00:10:03.818,176] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:10:05.405,548] <err> net_pkt: Data buffer (1140) allocation failed.
    [00:10:05.405,578] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:10:05.506,134] <err> net_pkt: Data buffer (1103) allocation failed.
    [00:10:05.506,164] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    [00:10:05.609,649] <err> net_pkt: Data buffer (1103) allocation failed.
    [00:10:05.609,680] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    [00:10:05.713,043] <err> net_pkt: Data buffer (1140) allocation failed.
    [00:10:05.713,073] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    [00:10:05.813,537] <err> net_pkt: Data buffer (1103) allocation failed.
    [00:10:05.813,568] <wrn> net_conn: pkt cloning failed, pkt 0x20034d68 dropped
    [00:10:06.184,143] <err> net_pkt: Data buffer (1140) allocation failed.
    [00:10:06.184,173] <wrn> net_conn: pkt cloning failed, pkt 0x20034d68 dropped
    [00:10:06.284,667] <err> net_pkt: Data buffer (1103) allocation failed.
    [00:10:06.284,698] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    [00:10:06.403,625] <err> net_pkt: Data buffer (1140) allocation failed.
    [00:10:06.403,656] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:10:22.576,934] <err> net_pkt: Data buffer (1430) allocation failed.
    [00:10:22.576,965] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:10:22.677,703] <err> net_pkt: Data buffer (1450) allocation failed.
    [00:10:22.677,734] <wrn> net_conn: pkt cloning failed, pkt 0x20034d68 dropped
    [00:11:46.992,004] <err> net_pkt: Data buffer (1141) allocation failed.
    [00:11:46.992,034] <wrn> net_conn: pkt cloning failed, pkt 0x20034d68 dropped
    [00:11:47.092,498] <err> net_pkt: Data buffer (1104) allocation failed.
    [00:11:47.092,529] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:11:47.365,203] <err> net_pkt: Data buffer (1141) allocation failed.
    [00:11:47.365,234] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    [00:11:47.515,136] <err> net_pkt: Data buffer (1104) allocation failed.
    [00:11:47.515,167] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    [00:11:47.782,409] <err> net_pkt: Data buffer (1141) allocation failed.
    [00:11:47.782,440] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:11:47.913,482] <err> net_pkt: Data buffer (1104) allocation failed.
    [00:11:47.913,513] <wrn> net_conn: pkt cloning failed, pkt 0x20034d68 dropped
    [00:11:48.215,179] <err> net_pkt: Data buffer (1141) allocation failed.
    [00:11:48.215,209] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    [00:11:53.124,664] <err> net_pkt: Data buffer (1141) allocation failed.
    [00:11:53.124,694] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:11:53.225,158] <err> net_pkt: Data buffer (1104) allocation failed.
    [00:11:53.225,189] <wrn> net_conn: pkt cloning failed, pkt 0x20034d68 dropped
    [00:11:53.544,952] <err> net_pkt: Data buffer (1104) allocation failed.
    [00:11:53.544,982] <wrn> net_conn: pkt cloning failed, pkt 0x20034d68 dropped
    [00:11:53.645,629] <err> net_pkt: Data buffer (1141) allocation failed.
    [00:11:53.645,660] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
    [00:11:53.916,870] <err> net_pkt: Data buffer (1104) allocation failed.
    [00:11:53.916,900] <wrn> net_conn: pkt cloning failed, pkt 0x20034dac dropped
    [00:11:54.017,517] <err> net_pkt: Data buffer (1141) allocation failed.
    [00:11:54.017,547] <wrn> net_conn: pkt cloning failed, pkt 0x20034d68 dropped
    [00:11:54.317,291] <err> net_pkt: Data buffer (1104) allocation failed.
    [00:11:54.317,321] <wrn> net_conn: pkt cloning failed, pkt 0x20034d68 dropped
    [00:11:54.417,938] <err> net_pkt: Data buffer (1141) allocation failed.
    [00:11:54.417,968] <wrn> net_conn: pkt cloning failed, pkt 0x20034df0 dropped
