Level based control of GPIOTE
I have a comparator acting as a UVLO, it connects to a NRF52 pin with a pull-up. The comparator also pulls down two other circuits using a diode, which in turn are connected to other NRF52 pins using pull-ups. It works well.
I'd like if possible to remove the diodes and connecting the UVLO signal via GPIO Event through PPI and controlling the other two pins via GPIOTE SET and CLEAR.
What I can't determine from the datasheet is whether once the initial output of GPIOTE is set if PPI & GPIOTE are fully async to the clock in which case it would be like level control where they couldn't miss an event, or whether the clock is working to determine the event (like a D gate) in which case potentially the event could be missed.
It is only a small optimisation but one I thought I'd look at as I was contemplating moving the comparator to the built-in one.
Andrew
