Level based control of GPIOTE
I have a comparator acting as a UVLO, it connects to a NRF52 pin with a pull-up. The comparator also pulls down two other circuits using a diode, which in turn are connected to other NRF52 pins using pull-ups. It works well.
I'd like if possible to remove the diodes and connecting the UVLO signal via GPIO Event through PPI and controlling the other two pins via GPIOTE SET and CLEAR.
What I can't determine from the datasheet is whether once the initial output of GPIOTE is set if PPI & GPIOTE are fully async to the clock in which case it would be like level control where they couldn't miss an event, or whether the clock is working to determine the event (like a D gate) in which case potentially the event could be missed.
It is only a small optimisation but one I thought I'd look at as I was contemplating moving the comparator to the built-in one.
Andrew
  • Been looking into it this evening. I read that GPIO config is retained when GPIOTE takes over the pin output. I'm unsure but making an assumption that weak pull is still operational when pin is in outmode mode. A hopeful solution is:
    NRF_GPIO->PIN_CNF[CFG_PIN_POWERMANAGER_FRONT_ENABLE] = pinDisconnectInputBuffer
        | GPIO_PIN_CNF_DIR_Output << GPIO_PIN_CNF_DIR_Pos
        | GPIO_PIN_CNF_DRIVE_S0D1 << GPIO_PIN_CNF_DRIVE_Pos
        | GPIO_PIN_CNF_PULL_Pulldown << GPIO_PIN_CNF_PULL_Pos;
    NRF_GPIOTE->CONFIG[CFG_GPIOTE_POWERMANAGER_FRONT] = GPIOTE_CONFIG_OUTINIT_High << GPIOTE_CONFIG_OUTINIT_Pos
        | GPIOTE_CONFIG_MODE_Task << GPIOTE_CONFIG_MODE_Pos
        | CFG_PIN_POWERMANAGER_FRONT_ENABLE << GPIOTE_CONFIG_PSEL_Pos;
    NRF_PPI->CH[CFG_PPI_POWERMANAGER_UVLO_FRONTREAR_GOOD].EEP = (uint32_t) &NRF_COMP->EVENTS_UP;
    NRF_PPI->CH[CFG_PPI_POWERMANAGER_UVLO_FRONTREAR_GOOD].TEP = (uint32_t) &NRF_GPIOTE->TASKS_SET[CFG_GPIOTE_POWERMANAGER_FRONT];
    NRF_PPI->CH[CFG_PPI_POWERMANAGER_UVLO_FRONTREAR_BAD].EEP = (uint32_t) &NRF_COMP->EVENTS_DOWN;
    NRF_PPI->CH[CFG_PPI_POWERMANAGER_UVLO_FRONTREAR_BAD].TEP = (uint32_t) &NRF_GPIOTE->TASKS_CLR[CFG_GPIOTE_POWERMANAGER_FRONT];
    // UVLO
    NRF_COMP->REFSEL = UVLO_REFERENCE << COMP_REFSEL_REFSEL_Pos;
    NRF_COMP->TH = UVLO_HYSTERESIS_UP << COMP_TH_THUP_Pos | UVLO_HYSTERESIS_DOWN << COMP_TH_THDOWN_Pos;
    NRF_COMP->PSEL = COMP_UVLO << COMP_PSEL_PSEL_Pos;
    NRF_COMP->ENABLE = COMP_ENABLE_ENABLE_Enabled << COMP_ENABLE_ENABLE_Pos;
    NRF_COMP->TASKS_SAMPLE = COMP_TASKS_SAMPLE_TASKS_SAMPLE_Trigger << COMP_TASKS_SAMPLE_TASKS_SAMPLE_Pos;
    // wait a moment for voltage to stablize
    // if it doesn't happen watchdog will reset
    while (!NRF_COMP->RESULT) {
      NRF_COMP->TASKS_SAMPLE = 1;
    NRF_COMP->EVENTS_DOWN = 0;
    // must come after comparator to ensure output sync
    NRF_PPI->CHENSET = 1 << CFG_PPI_POWERMANAGER_UVLO_FRONTREAR_GOOD
      | 1 << CFG_PPI_POWERMANAGER_UVLO_FRONTREAR_BAD
      | 1 << CFG_PPI_POWERMANAGER_UVLO_USB_BAD;
    Then to enable the pin
        | GPIO_PIN_CNF_DRIVE_S0S1 << GPIO_PIN_CNF_DRIVE_Pos;
    And to disable it again
    A pull-resistor cannot be enabled on a output device, so the GPIO_PIN_CNF_PULL line does not have any effect when the GPIO is configured with GPIO_PIN_CNF_DIR_Output.
    When you disable, you have setup the specific GPIO to be a open-drain, commonly used in I2C pin operation.
    The drive-level is set to standard-drive on '0' (output low), and disconnected on output high '1'.
    This means that the GPIO will float when set to '1'.
    You have 3 states:
    * EVENTS_DOWN
    * EVENTS_UP
    * "default state"
    How do you want your GPIO(s) to be set in each of these states?
    Håkon
  • EVENTS_DOWN = task, 0,  GPIO_PIN_CNF_DRIVE_S0S1
    EVENTS_UP = task, 1, GPIO_PIN_CNF_DRIVE_S0S1
    DEFAULT (OVERRIDE) = external weak pull-down, GPIO_PIN_CNF_DRIVE_S0D1
    The diagram within the gpio section indicates drive_strength will be respected. I only need to add an external weak-pull down resistor.
  • Pull-up and pull-down resistors can be enabled on an output pin on nRF52832 and nRF52840 (others not tested) and this is a really useful feature.
    "A pull-resistor cannot be enabled on a output device" is not correct, although the Product Specification does show the pull-up and pull-down don't apply to an output pin. I have pointed out this issue in older posts, but the Product Specifications were not updated.
    // Here are my measurement results, which prove the pullup/pull-down resistor is connected to the pin regardless
    // of the input setting. nRF52832, 32MHz crystal, no 32kHz crystal, no Reset pin, SoftDevice loaded but not
    // enabled, no peripherals enabled, idle. Power CR2032 coin cell, no ground other than PPK-2, no J-Link.
    // This first table is default port settings after a reset, no changes:
    // PPK-2  Meter  Conditions
    // 1.66uA 2.971V with errata workarounds, no i/o
    // 1.51uA 2.985V   no errata workarounds, no i/o
    // This Next table is port settings made after a reset, all 32 port pins identical, nothing connected to any of
    // the 32 port pins, no errata applied:
    // PPK-2  Meter   Direction    Input            Pullup         Drive Level      Sense Level    Output
    // 1.49uA 2.989V (PIN_OUTPUT | PIN_DISCONNECT | PIN_PULLNONE | PIN_DRIVE_S0S1 | PIN_SENSE_OFF) Driven Low
    // 1.49uA 2.999V (PIN_OUTPUT | PIN_DISCONNECT | PIN_PULLDOWN | PIN_DRIVE_S0S1 | PIN_SENSE_OFF) Driven Low
    // 6.47mA 2.894V (PIN_OUTPUT | PIN_DISCONNECT | PIN_PULLUP   | PIN_DRIVE_S0S1 | PIN_SENSE_OFF) Driven Low
    // 6.47mA 2.889V (PIN_OUTPUT | PIN_CONNECT    | PIN_PULLUP   | PIN_DRIVE_S0S1 | PIN_SENSE_OFF) Driven Low
    // 1.51uA 2.959V (PIN_OUTPUT | PIN_DISCONNECT | PIN_PULLNONE | PIN_DRIVE_S0S1 | PIN_SENSE_OFF) Driven High
    // 6.42mA 2.877V (PIN_OUTPUT | PIN_DISCONNECT | PIN_PULLDOWN | PIN_DRIVE_S0S1 | PIN_SENSE_OFF) Driven High
    // 1.53uA 2.938V (PIN_OUTPUT | PIN_DISCONNECT | PIN_PULLUP   | PIN_DRIVE_S0S1 | PIN_SENSE_OFF) Driven High
    // This shows setting a port pin into active low output driven low is as good as leaving a pin floating
    // when unused, with the added benefit that there is no possibility of port feedthrough if a floating pin
    // drifts through the threshold.
    // Looking at pull-up and pull down resistor values for the 32 pins:
    //   (2.877Volts / 6.42mA) * 32 ==> 14.34K Ohm
    Here is one of my older responses nrf52832-power-leakage which stian reported internally at the time
