TXADDRESS, RXADDRESSES registers: what are these and how we can use them?
Based on the NRF Radio manual, the over the air address of the packets, is configured using "BASEn" and "PREFIXn" registers.
However, there are
also two other registers called "TXADDRESS" and "RXADDRESSES".
ThinkingThinking What is the application of these registers and how we can use them?
My current reading of the specification tells me that these are used to facilitate the filtering of the unwanted packets in the hardware level but I am not sure.
The BLE standard does not seem to have any instructions for this type of addresses (which is called logical addresses sometimes in the NRF Radio specification). Is this something that NRF has designed for extra flexibility and fast filtering and connection?
As far as APIs are concerned, I have found the following:
NRF_RADIO->RXADDRESSES = (uint32_t)(rxaddresses);
NRF_RADIO->TXADDRESS = ((uint32_t)txaddress) << RADIO_TXADDRESS_TXADDRESS_Pos;
Could you tell me what does the left shift operation in the second code do? (why we do that)
Thanks
    BLE is a full protocol, requiring loads of handling in firmware, and should not be compared to the register content of the NRF_RADIO peripheral.
    What do you actually want to do here? If you need BLE capabilities, please see bluetooth samples.
    It shifts the data into the RADIO_TXADDRESS bit position. The bit position of this specific register is at bit 0:
    https://infocenter.nordicsemi.com/topic/ps_nrf52833/radio.html?cp=5_1_0_5_17_14_57#register.TXADDRESS
    So, it basically does not shift anything in this scenario, but it is considered "good practice" to include this, in cases where you write to bit fields located on other bit positions.
    Håkon
  • Hi Hokan, thanks, but could you also answer my first question? What is the purpose of these registers? Also, I intentionally mentioned the BLE standard to highlight the fact that this "logical address" is not being discussed anywhere except in the NRF Radio document. Any ways, my main question is what is the purpose of these addresses and what uses that.
  • Thank you Hokon, this makes it a lot more clear.
    Just one more follow up question on:
    This is because you can be in RX and receive payloads from RXADDRESSES that you have enabled.
    Does this mean, in the RX mode, we can listen to the air addresses that we provide?
    If so, does it also mean we will only be able to listen to those addresses?
    If so, I am wondering if it means that we can listen to several air addresses at the same time? depending how many base and prefix addresses we provided?
    Thank you very much.
    Yes, that is correct.
    Yes, you can listen to up to 8 addresses in total.
    One can ofcourse extend this to use parts of the user-payload as an "extended addressing" based on the BASE+PREFIX that is already setup in the NRF_RADIO peripheral, but this will require specific handling in firmware.
    Håkon
  • Thank Hokan,
    Just a follow up question.
    What I have realized, by trial and error, is that no matter what is used for base and prefix addresses, the radio always gives back the Address, Payload and End signals and populates the packet pointer, is this something expected? Because based on our discussion here, I am not suppose to get any populated packets if the addresses are not matching.
    Well, at first I thought that might be just a coincidental match, but I tried several random and weird addresses, but it seems that the radio populates the packet pointer regardless. I believe it is very unlikely that I would always get such coincidental matches.
    Also, I should mention that I have tried a very ridiculously large prefix and in that case the radio did not populate the pointer and the address, payload, and end signals are not received. However, I am not very sure about the fact that having such a long prefix is right thing to do.
    Can you share what you are setting in the registers?
    If you set an address that you're not listening to, it should not give you an address match unless a payload with that specific address is registered.
    Håkon
  • Hi Hokan, thanks for the reply. The issue was essentially the fact that I thought BIT(1) gives the bit-map of "0b00000001". Then I realized the thing I am looking for is BIT(0) to be used by RXADDRESSES. When I was passing a wrong bit-map, it populated the pointer even-though there was not any match and the address and payload and end also were given back. Once I switched to the write bit map, everything started working flawlessly.
