MPU FAULT Error on memcpy(value + offset, buf, len) of bluetooth peripheral write_vnd callback
I am getting this error:
[00:00:43.670,227] <err> os: ***** MPU FAULT *****
[00:00:43.670,257] <err> os: Data Access Violation
[00:00:43.670,257] <err> os: MMFAR Address: 0x0
[00:00:43.670,288] <err> os: r0/a1: 0x00000000 r1/a2: 0x2000fe15 r2/a3: 0x2000fe1b
[00:00:43.670,288] <err> os: r3/a4: 0xffffffff r12/ip: 0x000387f3 r14/lr: 0x00000619
[00:00:43.670,288] <err> os: xpsr: 0x81000000
[00:00:43.670,318] <err> os: Faulting instruction address (r15/pc): 0x00038200
[00:00:43.670,349] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
[00:00:43.670,349] <err> os: Current thread: 0x200015e0 (unknown)
event_clock_init2] <err> fatal_error: Resetting system
When running this code:
static ssize_t write_vnd(struct bt_conn *conn, const struct bt_gatt_attr *attr,
const void *buf, uint16_t len, uint16_t offset,
uint8_t flags)
    printf("write_vnd\n");
    uint8_t *value = attr->user_data;
    if (offset + len > sizeof(ct)) {
        return BT_GATT_ERR(BT_ATT_ERR_INVALID_OFFSET);
    printf("memcpy\n");
	memcpy(value + offset, buf, len);
    printf("memcpy done\n");
    ct_update = 1U;
    return len;
The terminal shows this before the error:
write_vnd
memcpy
so it seems to happen on this line:
I don't understand how memcpy dest is represented as value + offset.
Which was taken from this sample and I also see reference here.
