I am trying to modify the zigbee light switch example in nrf Connect SDK to control multiple endpoints.
I am developing using the nrf52833 development kit and the aim is to use the nrf52840 dongle for the final implementation.
Note: The aim is to control the endpoints (zigbee devices) using a DWIN screen via the dongle hence the UART blocks in the code.
Below is the main.c file
#include <zephyr/kernel.h> #include <zephyr/device.h> #include <zephyr/logging/log.h> #include <ram_pwrdn.h> #include <zboss_api.h> #include <zboss_api_addons.h> #include <zigbee/zigbee_app_utils.h> #include <zigbee/zigbee_error_handler.h> #include <zb_nrf_platform.h> #include "zb_mem_config_custom.h" #include "zb_dimmer_switch.h" /* Source endpoint used to control light bulb. */ #define LIGHT_SWITCH_ENDPOINT_1 1 #define LIGHT_SWITCH_ENDPOINT_2 2 #define LIGHT_SWITCH_ENDPOINT_3 3 #define LIGHT_SWITCH_ENDPOINT_4 4 #define LIGHT_SWITCH_ENDPOINT_5 5 /* Delay between the light switch startup and light bulb finding procedure. */ #define MATCH_DESC_REQ_START_DELAY K_SECONDS(2) /* Timeout for finding procedure. */ #define MATCH_DESC_REQ_TIMEOUT K_SECONDS(5) /* Find only non-sleepy device. */ #define MATCH_DESC_REQ_ROLE ZB_NWK_BROADCAST_RX_ON_WHEN_IDLE /* Do not erase NVRAM to save the network parameters after device reboot or * power-off. NOTE: If this option is set to ZB_TRUE then do full device erase * for all network devices before running other samples. */ #define ERASE_PERSISTENT_CONFIG ZB_FALSE /* Dim step size - increases/decreses current level (range 0x000 - 0xfe). */ #define DIMM_STEP 15 /* Transition time for a single step operation in 0.1 sec units. * 0xFFFF - immediate change. */ #define DIMM_TRANSACTION_TIME 2 LOG_MODULE_REGISTER(app, LOG_LEVEL_INF); struct bulb_context { zb_uint8_t endpoint; zb_uint16_t short_addr; struct k_timer find_alarm; }; struct zb_device_ctx { zb_zcl_basic_attrs_t basic_attr; zb_zcl_identify_attrs_t identify_attr; }; static struct bulb_context bulb_ctx; static struct zb_device_ctx dev_ctx; /* Declare attribute list for Basic cluster (server). */ ZB_ZCL_DECLARE_BASIC_SERVER_ATTRIB_LIST( basic_server_attr_list, &dev_ctx.basic_attr.zcl_version, &dev_ctx.basic_attr.power_source); /* Declare attribute list for Identify cluster (client). */ ZB_ZCL_DECLARE_IDENTIFY_CLIENT_ATTRIB_LIST( identify_client_attr_list); /* Declare attribute list for Identify cluster (server). */ ZB_ZCL_DECLARE_IDENTIFY_SERVER_ATTRIB_LIST( identify_server_attr_list, &dev_ctx.identify_attr.identify_time); /* Declare attribute list for On/Off cluster (client). */ ZB_ZCL_DECLARE_ON_OFF_CLIENT_ATTRIB_LIST( on_off_client_attr_list); /* Declare attribute list for Level control cluster (client). */ ZB_ZCL_DECLARE_LEVEL_CONTROL_CLIENT_ATTRIB_LIST( level_control_client_attr_list); /* Declare cluster list for Dimmer Switch device. */ ZB_DECLARE_DIMMER_SWITCH_CLUSTER_LIST( dimmer_switch_clusters, basic_server_attr_list, identify_client_attr_list, identify_server_attr_list, NULL, NULL, on_off_client_attr_list, level_control_client_attr_list); /* Declare endpoint for Dimmer Switch device. */ ZB_DECLARE_DIMMER_SWITCH_EP( dimmer_switch_ep_1, LIGHT_SWITCH_ENDPOINT_1, dimmer_switch_clusters); ZB_DECLARE_DIMMER_SWITCH_EP( dimmer_switch_ep_2, LIGHT_SWITCH_ENDPOINT_2, dimmer_switch_clusters); ZB_DECLARE_DIMMER_SWITCH_EP( dimmer_switch_ep_3, LIGHT_SWITCH_ENDPOINT_3, dimmer_switch_clusters); // ZB_DECLARE_DIMMER_SWITCH_EP( // dimmer_switch_ep_4, // LIGHT_SWITCH_ENDPOINT_4, // dimmer_switch_clusters); // ZB_DECLARE_DIMMER_SWITCH_EP( // dimmer_switch_ep_5, // LIGHT_SWITCH_ENDPOINT_5, // dimmer_switch_clusters); // Declare application's device context (list of registered endpoints) for Dimmer Switch device. // ZBOSS_DECLARE_DEVICE_CTX_1_EP(dimmer_switch_ctx, dimmer_switch_ep_1); // ZBOSS_DECLARE_DEVICE_CTX_2_EP(dimmer_switch_ctx, dimmer_switch_ep_1, dimmer_switch_ep_2); ZBOSS_DECLARE_DEVICE_CTX_3_EP(dimmer_switch_ctx, dimmer_switch_ep_1, dimmer_switch_ep_2, dimmer_switch_ep_3); // ZBOSS_DECLARE_DEVICE_CTX_EP_VA(dimmer_switch_ctx, dimmer_switch_ep_1, dimmer_switch_ep_2, dimmer_switch_ep_3, dimmer_switch_ep_4, dimmer_switch_ep_5); int light_switch_endpoint; // =================================================== uart =============================================================== #include <zephyr/devicetree.h> #include <zephyr/drivers/gpio.h> #include <zephyr/sys/printk.h> #include <zephyr/drivers/uart.h> #define SLEEP_TIME_MS 1000 #define RECEIVE_BUFF_SIZE 9 #define RECEIVE_TIMEOUT 100 /* STEP 4.1 - Get the device pointer of the UART hardware */ const struct device *uart = DEVICE_DT_GET(DT_NODELABEL(uart0)); /* STEP 9.1 - Define the transmission buffer, which is a buffer to hold the data to be sent over UART */ static uint8_t tx_buf[] = {"nRF Connect SDK Fundamentals Course\n\r" "Press 1/0 on your keyboard to toggle bulb on zigbee network\n\r"}; /* STEP 10.1.2 - Define the receive buffer */ static uint8_t rx_buf[RECEIVE_BUFF_SIZE] = {0}; // ================================================================================================================== /**@brief Zigbee stack event handler. * * @param[in] bufid Reference to the Zigbee stack buffer * used to pass signal. */ void zboss_signal_handler(zb_bufid_t bufid) { zb_zdo_app_signal_hdr_t *sig_hndler = NULL; zb_zdo_app_signal_type_t sig = zb_get_app_signal(bufid, &sig_hndler); zb_ret_t status = ZB_GET_APP_SIGNAL_STATUS(bufid); switch (sig) { case ZB_BDB_SIGNAL_DEVICE_REBOOT: /* fall-through */ case ZB_BDB_SIGNAL_STEERING: /* Call default signal handler. */ ZB_ERROR_CHECK(zigbee_default_signal_handler(bufid)); if (status == RET_OK) /* Check the light device address. */ if (bulb_ctx.short_addr == 0xFFFF) k_timer_start(&bulb_ctx.find_alarm, MATCH_DESC_REQ_START_DELAY, MATCH_DESC_REQ_TIMEOUT); break; case ZB_ZDO_SIGNAL_LEAVE: /* If device leaves the network, reset bulb short_addr. */ if (status == RET_OK) { zb_zdo_signal_leave_params_t *leave_params = ZB_ZDO_SIGNAL_GET_PARAMS(sig_hndler, zb_zdo_signal_leave_params_t); if (leave_params->leave_type == ZB_NWK_LEAVE_TYPE_RESET) bulb_ctx.short_addr = 0xFFFF; } /* Call default signal handler. */ ZB_ERROR_CHECK(zigbee_default_signal_handler(bufid)); break; default: /* Call default signal handler. */ ZB_ERROR_CHECK(zigbee_default_signal_handler(bufid)); break; } if (bufid) zb_buf_free(bufid); } // ================================================================================================================== /**@brief Starts identifying the device. * * @param bufid Unused parameter, required by ZBOSS scheduler API. */ static void start_identifying(zb_bufid_t bufid) { LOG_INF("start identifying function called"); ZVUNUSED(bufid); if (ZB_JOINED()) { /* Check if endpoint is in identifying mode, * if not, put desired endpoint in identifying mode. */ if (dev_ctx.identify_attr.identify_time == ZB_ZCL_IDENTIFY_IDENTIFY_TIME_DEFAULT_VALUE) { LOG_INF("Endpoint: %d", light_switch_endpoint); zb_ret_t zb_err_code = zb_bdb_finding_binding_target(light_switch_endpoint); if (zb_err_code == RET_OK) LOG_INF("Enter identify mode"); else if (zb_err_code == RET_INVALID_STATE) LOG_INF("RET_INVALID_STATE - Cannot enter identify mode"); else { LOG_INF("error in start identifying"); ZB_ERROR_CHECK(zb_err_code); } } else { LOG_INF("Cancel identify mode"); zb_bdb_finding_binding_target_cancel(); } } else LOG_INF("Device not in a network - cannot enter identify mode"); } /*@brief Function for sending step requests to the light bulb. * * @param[in] bufid Non-zero reference to Zigbee stack buffer that * will be used to construct step request. * @param[in] cmd_id ZCL command id. */ static void light_switch_send_step(zb_bufid_t bufid, zb_uint16_t cmd_id) { LOG_INF("Send step level command: %d", cmd_id); LOG_INF("Endpoint: %d", light_switch_endpoint); ZB_ZCL_LEVEL_CONTROL_SEND_STEP_REQ(bufid, bulb_ctx.short_addr, ZB_APS_ADDR_MODE_16_ENDP_PRESENT, bulb_ctx.endpoint, light_switch_endpoint, ZB_AF_HA_PROFILE_ID, ZB_ZCL_DISABLE_DEFAULT_RESPONSE, NULL, cmd_id, DIMM_STEP, DIMM_TRANSACTION_TIME); } // @brief Function for sending ON/OFF requests to the light bulb. static void light_switch_send_on_off(zb_bufid_t bufid, zb_uint16_t cmd_id) { LOG_INF("Send ON/OFF command in switch_func: %d", cmd_id); LOG_INF("Endpoint: %d", light_switch_endpoint); ZB_ZCL_ON_OFF_SEND_REQ(bufid, bulb_ctx.short_addr, ZB_APS_ADDR_MODE_16_ENDP_PRESENT, bulb_ctx.endpoint, light_switch_endpoint, ZB_AF_HA_PROFILE_ID, ZB_ZCL_DISABLE_DEFAULT_RESPONSE, cmd_id, NULL); } // ================================================================================================================== void toggle_light(struct uart_event *evt) { zb_uint16_t cmd_id; zb_ret_t zb_err_code; if (evt->data.rx.buf[evt->data.rx.offset + 8] == 0x00) cmd_id = ZB_ZCL_CMD_ON_OFF_OFF_ID; else if (evt->data.rx.buf[evt->data.rx.offset + 8] == 0x01) cmd_id = ZB_ZCL_CMD_ON_OFF_ON_ID; LOG_INF("String: %s", evt->data.rx.buf); zb_err_code = zb_buf_get_out_delayed_ext(light_switch_send_on_off, cmd_id, 0); ZB_ERROR_CHECK(zb_err_code); } void dim_controller(struct uart_event *evt) { zb_uint16_t cmd_id; zb_ret_t zb_err_code; if (evt->data.rx.buf[evt->data.rx.offset + 8] == 0x00) cmd_id = ZB_ZCL_LEVEL_CONTROL_STEP_MODE_DOWN; else if (evt->data.rx.buf[evt->data.rx.offset + 8] == 0x01) cmd_id = ZB_ZCL_LEVEL_CONTROL_STEP_MODE_UP; /* Allocate output buffer and send step command. */ zb_err_code = zb_buf_get_out_delayed_ext(light_switch_send_step, cmd_id, 0); if (!zb_err_code) LOG_WRN("Buffer is full"); } void factoryReset_pairing_mode(struct uart_event *evt) { if (evt->data.rx.buf[evt->data.rx.offset + 8] == 0x00) ZB_SCHEDULE_APP_CALLBACK(zb_bdb_reset_via_local_action, 0); else if (evt->data.rx.buf[evt->data.rx.offset + 8] == 0x01) ZB_SCHEDULE_APP_CALLBACK(start_identifying, 0); } // ================================================================================================================== /* STEP 7 - Define the callback function for UART */ static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data) { /* Inform default signal handler about user input at the device. */ user_input_indicate(); if (bulb_ctx.short_addr == 0xFFFF) { LOG_INF("No bulb found yet."); return; } switch (evt->type) { case UART_RX_RDY: /* For ON/OFF of Light */ if (evt->data.rx.buf[evt->data.rx.offset] == 0x5A) { // ============================================ for LIGHT_SWITCH_ENDPOINT_1 ============================================ if (evt->data.rx.buf[evt->data.rx.offset + 4] == 0x15) { light_switch_endpoint = LIGHT_SWITCH_ENDPOINT_1; LOG_INF("Endpoint: %d", light_switch_endpoint); toggle_light(evt); } else if ((evt->data.rx.buf[evt->data.rx.offset + 4] == 0x16) || (evt->data.rx.buf[evt->data.rx.offset + 4] == 0x17)) { light_switch_endpoint = LIGHT_SWITCH_ENDPOINT_1; LOG_INF("Endpoint: %d", light_switch_endpoint); dim_controller(evt); } else if ((evt->data.rx.buf[evt->data.rx.offset + 4] == 0x18) || (evt->data.rx.buf[evt->data.rx.offset + 4] == 0x19)) { light_switch_endpoint = LIGHT_SWITCH_ENDPOINT_1; LOG_INF("Endpoint: %d", light_switch_endpoint); factoryReset_pairing_mode(evt); } // ============================================ for LIGHT_SWITCH_ENDPOINT_2 ============================================ else if (evt->data.rx.buf[evt->data.rx.offset + 4] == 0x25) { light_switch_endpoint = LIGHT_SWITCH_ENDPOINT_2; LOG_INF("Endpoint: %d", light_switch_endpoint); toggle_light(evt); } else if ((evt->data.rx.buf[evt->data.rx.offset + 4] == 0x26) || (evt->data.rx.buf[evt->data.rx.offset + 4] == 0x27)) { light_switch_endpoint = LIGHT_SWITCH_ENDPOINT_2; LOG_INF("Endpoint: %d", light_switch_endpoint); dim_controller(evt); } else if ((evt->data.rx.buf[evt->data.rx.offset + 4] == 0x28) || (evt->data.rx.buf[evt->data.rx.offset + 4] == 0x29)) { light_switch_endpoint = LIGHT_SWITCH_ENDPOINT_2; LOG_INF("Endpoint: %d", light_switch_endpoint); factoryReset_pairing_mode(evt); } // ============================================ for LIGHT_SWITCH_ENDPOINT_3 ============================================ else if (evt->data.rx.buf[evt->data.rx.offset + 4] == 0x35) { light_switch_endpoint = LIGHT_SWITCH_ENDPOINT_3; LOG_INF("Endpoint: %d", light_switch_endpoint); toggle_light(evt); } else if ((evt->data.rx.buf[evt->data.rx.offset + 4] == 0x36) || (evt->data.rx.buf[evt->data.rx.offset + 4] == 0x37)) { light_switch_endpoint = LIGHT_SWITCH_ENDPOINT_3; LOG_INF("Endpoint: %d", light_switch_endpoint); dim_controller(evt); } else if ((evt->data.rx.buf[evt->data.rx.offset + 4] == 0x38) || (evt->data.rx.buf[evt->data.rx.offset + 4] == 0x39)) { light_switch_endpoint = LIGHT_SWITCH_ENDPOINT_3; LOG_INF("Endpoint: %d", light_switch_endpoint); factoryReset_pairing_mode(evt); } // // ============================================ for LIGHT_SWITCH_ENDPOINT_4 ============================================ // else if (evt->data.rx.buf[evt->data.rx.offset + 4] == 0x45) // { // light_switch_endpoint = LIGHT_SWITCH_ENDPOINT_4; // toggle_light(evt); // } // else if ((evt->data.rx.buf[evt->data.rx.offset + 4] == 0x46) || (evt->data.rx.buf[evt->data.rx.offset + 4] == 0x47)) // { // light_switch_endpoint = LIGHT_SWITCH_ENDPOINT_4; // dim_controller(evt); // } // else if ((evt->data.rx.buf[evt->data.rx.offset + 4] == 0x48) || (evt->data.rx.buf[evt->data.rx.offset + 4] == 0x49)) // { // light_switch_endpoint = LIGHT_SWITCH_ENDPOINT_4; // factoryReset_pairing_mode(evt); // } // // ============================================ for LIGHT_SWITCH_ENDPOINT_5 ============================================ // else if (evt->data.rx.buf[evt->data.rx.offset + 4] == 0x55) // { // light_switch_endpoint = LIGHT_SWITCH_ENDPOINT_5; // toggle_light(evt); // } // else if ((evt->data.rx.buf[evt->data.rx.offset + 4] == 0x56) || (evt->data.rx.buf[evt->data.rx.offset + 4] == 0x57)) // { // light_switch_endpoint = LIGHT_SWITCH_ENDPOINT_5; // dim_controller(evt); // } // else if ((evt->data.rx.buf[evt->data.rx.offset + 4] == 0x58) || (evt->data.rx.buf[evt->data.rx.offset + 4] == 0x59)) // { // light_switch_endpoint = LIGHT_SWITCH_ENDPOINT_5; // factoryReset_pairing_mode(evt); // } else LOG_INF("VP error"); } else LOG_INF("First hex is not 0x5A"); break; case UART_RX_DISABLED: uart_rx_enable(dev, rx_buf, sizeof rx_buf, RECEIVE_TIMEOUT); break; default: break; } } // ================================================================================================================== // @brief Callback function receiving finding procedure results. static void find_light_bulb_cb(zb_bufid_t bufid) { LOG_INF("find_light_bulb_cb called"); /* Get the beginning of the response. */ zb_zdo_match_desc_resp_t *resp = (zb_zdo_match_desc_resp_t *)zb_buf_begin(bufid); /* Get the pointer to the parameters buffer, which stores APS layer * response. */ zb_apsde_data_indication_t *ind = ZB_BUF_GET_PARAM(bufid, zb_apsde_data_indication_t); zb_uint8_t *match_ep; if ((resp->status == ZB_ZDP_STATUS_SUCCESS) && (resp->match_len > 0) && (bulb_ctx.short_addr == 0xFFFF)) { /* Match EP list follows right after response header. */ match_ep = (zb_uint8_t *)(resp + 1); /* We are searching for exact cluster, so only 1 EP * may be found. */ bulb_ctx.endpoint = *match_ep; bulb_ctx.short_addr = ind->src_addr; LOG_INF("Found bulb addr: %d ep: %d", bulb_ctx.short_addr, bulb_ctx.endpoint); k_timer_stop(&bulb_ctx.find_alarm); } else LOG_INF("Bulb not found, try again"); if (bufid) zb_buf_free(bufid); } /**@brief Function for sending ON/OFF and Level Control find request. * * @param[in] bufid Reference to Zigbee stack buffer that will be used to * construct find request. */ static void find_light_bulb(zb_bufid_t bufid) { LOG_INF("find_light_bulb called"); zb_zdo_match_desc_param_t *req; zb_uint8_t tsn = ZB_ZDO_INVALID_TSN; /* Initialize pointers inside buffer and reserve space for * zb_zdo_match_desc_param_t request. */ req = zb_buf_initial_alloc(bufid, sizeof(zb_zdo_match_desc_param_t) + (1) * sizeof(zb_uint16_t)); req->nwk_addr = MATCH_DESC_REQ_ROLE; req->addr_of_interest = MATCH_DESC_REQ_ROLE; req->profile_id = ZB_AF_HA_PROFILE_ID; /* We are searching for 2 clusters: On/Off and Level Control Server. */ req->num_in_clusters = 2; req->num_out_clusters = 0; req->cluster_list[0] = ZB_ZCL_CLUSTER_ID_ON_OFF; req->cluster_list[1] = ZB_ZCL_CLUSTER_ID_LEVEL_CONTROL; /* Set 0xFFFF to reset short address in order to parse * only one response. */ bulb_ctx.short_addr = 0xFFFF; tsn = zb_zdo_match_desc_req(bufid, find_light_bulb_cb); /* Free buffer if failed to send a request. */ if (tsn == ZB_ZDO_INVALID_TSN) { zb_buf_free(bufid); LOG_INF("Failed to send Match Descriptor request"); } } /**@brief Find bulb alarm handler. * * @param[in] timer Address of timer. */ static void find_light_bulb_alarm(struct k_timer *timer) { LOG_INF("find_light_bulb_alarm called"); ZB_ERROR_CHECK(zb_buf_get_out_delayed(find_light_bulb)); } // ================================================================================================================== int main(void) { int ret; /* STEP 4.2 - Verify that the UART device is ready */ if (!device_is_ready(uart)) { printk("UART device not ready\r\n"); return 1; } /* STEP 8 - Register the UART callback function */ ret = uart_callback_set(uart, uart_cb, NULL); if (ret) return 1; /* STEP 9.2 - Send the data over UART by calling uart_tx() */ ret = uart_tx(uart, tx_buf, sizeof(tx_buf), SYS_FOREVER_US); if (ret) return 1; /* STEP 10.3 - Start receiving by calling uart_rx_enable() and pass it the address of the receive buffer */ ret = uart_rx_enable(uart, rx_buf, sizeof rx_buf, RECEIVE_TIMEOUT); if (ret) return 1; // ================================================================================================================== LOG_INF("Starting ZBOSS Light Switch example"); k_timer_init(&bulb_ctx.find_alarm, find_light_bulb_alarm, NULL); zigbee_erase_persistent_storage(ERASE_PERSISTENT_CONFIG); zb_set_ed_timeout(ED_AGING_TIMEOUT_64MIN); zb_set_keepalive_timeout(ZB_MILLISECONDS_TO_BEACON_INTERVAL(3000)); /* Set default bulb short_addr. */ bulb_ctx.short_addr = 0xFFFF; /* Power off unused sections of RAM to lower device power consumption. */ if (IS_ENABLED(CONFIG_RAM_POWER_DOWN_LIBRARY)) power_down_unused_ram(); /* Register dimmer switch device context (endpoints). */ ZB_AF_REGISTER_DEVICE_CTX(&dimmer_switch_ctx); /* Basic cluster attributes data. */ dev_ctx.basic_attr.zcl_version = ZB_ZCL_VERSION; dev_ctx.basic_attr.power_source = ZB_ZCL_BASIC_POWER_SOURCE_UNKNOWN; /* Identify cluster attributes data. */ dev_ctx.identify_attr.identify_time = ZB_ZCL_IDENTIFY_IDENTIFY_TIME_DEFAULT_VALUE; /* Start Zigbee default thread. */ zigbee_enable(); // ================================================================================================================== LOG_INF("ZBOSS Light Switch example started"); while (1) { k_sleep(K_FOREVER); // k_msleep(SLEEP_TIME_MS); } }
I keep getting this error again and again.
I tried changing a few lines in zboss files but couldnt resolve the error. I am still pretty new at this so any help would be appreciated.
Thanks in advance.
