Controlling BLE TX Power in nrf52840
Currently, I am running a BLE application in my nrf52840 DK. I Need to increase the BLE TX power and for that, I have used the static TX power method via the KConfig macro
CONFIG_BT_CTLR_TX_PWR_PLUS_8=y.
I have used the NRF Connect mobile app to scan my BLE with the above macro and without the above macro and identified the difference in the BLE RSSI.
However, when I flash the same code into one of my custom boards running on nRF52840. However, I am not able to visualize the difference in the BLE RSSI in the same mobile app.
Is there any other macro that I need to include along with the above macro?
One more thing, I have seen one other macro CONFIG_BT_CTLR_TX_PWR_ANTENNA in the same KConfig file. I wanted to know the difference between these two macros CONFIG_BT_CTLR_TX_PWR_ANTENNA and CONFIG_BT_CTLR_TX_PWR_PLUS_8.
    Using RSSI to check the TX power isn't very reliable, especially if the antenna on the board haven't been tuned. A better way to check if the TX power is set correctly is to read the TXPOWER register for the radio peripheral.
    This can easily be done using nrfjprog:
    nrfjprog --memrd 0x4000150C
    Both CONFIG_BT_CTLR_TX_PWR_PLUS_8 and CONFIG_BT_CTLR_TX_PWR_ANTENNA can be used for setting the TX power. CONFIG_BT_CTLR_TX_PWR_ANTENNA will set the TX power at the antenna, so if a FEM is used it will calculate the required TX power from the SoC based on the TX gain of the FEM to give the final TX power requested using CONFIG_BT_CTLR_TX_PWR_ANTENNA.
    Bendik
