I have tested the Matter bridge example and I am facing an issue. This is how I proceeded:
1) Compiling the example with the nRF Connect SDK 2.5.0 works correctly.
2) Uploading to the nRF7002-DK card works correctly.
3) Start of pairing and connection to WIFI works correctly
4) Discovery of bridged accessories fails
5) nRF7002-DK reboots.
Environment
- Controller : iOS 17.0.3
Could you help me identify the root cause?
Regards
eived for CHIPoBLE RX characteristic (ConnId 0x00) D: 126899 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 126972 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 129432 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 131939 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 132012 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 134472 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 136980 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 137052 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 139513 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 142021 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 142092 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 144552 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 147059 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 147132 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) I: 148932 [DL]BLE GAP connection terminated (reason 0x13) I: 148938 [DL]Current number of connections: 0/1 E: 162067 [BLE]ack recv timeout, closing ep 0x2000b5a0 D: 162072 [IN]Clearing BLE pending packets. I: 162076 [BLE]Releasing end point's BLE connection back to application. I: 162082 [DL]Closing BLE GATT connection (ConnId 00) I: 199639 [FS]Fail-safe timer expired E: 199642 [SVR]Failsafe timer expired D: 199645 [IN]SecureSession[0x20004808]: MarkForEviction Type:1 LSID:46460 I: 199652 [SC]SecureSession[0x20004808]: Moving from state 'kActive' --> 'kPendingEviction' D: 199660 [IN]SecureSession[0x20004808]: Released - Type:1 LSID:46460 E: 199666 [SVR]Commissioning failed (attempt 1): 32 D: 199671 [IN]SecureSession[0x20004808]: Allocated Type:1 LSID:46463 D: 199677 [DL]CHIPoBLE advertising set to on I: 199681 [DIS]Updating services using commissioning mode 1 E: 199687 [IN]SO_REUSEPORT failed: 109 I: 199690 [DIS]CHIP minimal mDNS started advertising. D: 199717 [DL]Using wifi MAC for hostname I: 199722 [DIS]Advertise operational node 6737064BB76EA725-0000000028C71E1A D: 199730 [DIS]Responding with _matter._tcp.local D: 199734 [DIS]Responding with 6737064BB76EA725-0000000028C71E1A._matter._tcp.local D: 199742 [DIS]Responding with 6737064BB76EA725-0000000028C71E1A._matter._tcp.local D: 199749 [DIS]Responding with F4CE360013BC.local D: 199753 [DIS]Responding with F4CE360013BC.local D: 199758 [DIS]Responding with _I6737064BB76EA725._sub._matter._tcp.local I: 199764 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 6737064BB76EA725-0000000028C71E1A. I: 199785 [DIS]mDNS service published: _matter._tcp D: 199790 [DL]Using wifi MAC for hostname I: 199794 [DIS]Advertise commission parameter vendorID=65521 productID=32770 discriminator=3840/15 cm=1 D: 199804 [DIS]Responding with _matterc._udp.local D: 199808 [DIS]Responding with 6D832A75C95C609E._matterc._udp.local D: 199814 [DIS]Responding with F4CE360013BC.local D: 199818 [DIS]Responding with F4CE360013BC.local D: 199823 [DIS]Responding with _V65521._sub._matterc._udp.local D: 199841 [DIS]Responding with _S15._sub._matterc._udp.local D: 199847 [DIS]Responding with _L3840._sub._matterc._udp.local D: 199852 [DIS]Responding with _CM._sub._matterc._udp.local D: 199858 [DIS]Responding with 6D832A75C95C609E._matterc._udp.local I: 199864 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: 6D832A75C95C609E. I: 199920 [DIS]mDNS service published: _matterc._udp E: 199925 [ZCL]OpCreds: Got FailSafeTimerExpired E: 199931 [ZCL]OpCreds: Proceeding to FailSafeCleanup on fail-safe expiry! D: 199937 [IN]Expiring all sessions for fabric 0x1!! E: 199942 [FP]Reverting pending fabric data for fabric 0x1 E: 199947 [FP]Warning: metadata not found during delete of fabric 0x1 I: 199957 [FP]Fabric (0x1) deleted. I: 199960 [ZCL]OpCreds: Fabric index 0x1 was removed I: 199964 [DIS]Updating services using commissioning mode 1 E: 199970 [IN]SO_REUSEPORT failed: 109 I: 199974 [DIS]CHIP minimal mDNS started advertising. D: 200094 [DL]Using wifi MAC for hostname I: 200098 [DIS]Advertise commission parameter vendorID=65521 productID=32770 discriminator=3840/15 cm=1 D: 200108 [DIS]Responding with _matterc._udp.local D: 200112 [DIS]Responding with 6D832A75C95C609E._matterc._udp.local D: 200118 [DIS]Responding with F4CE360013BC.local D: 200122 [DIS]Responding with F4CE360013BC.local D: 200127 [DIS]Responding with _V65521._sub._matterc._udp.local D: 200133 [DIS]Responding with _S15._sub._matterc._udp.local D: 200139 [DIS]Responding with _L3840._sub._matterc._udp.local D: 200145 [DIS]Responding with _CM._sub._matterc._udp.local D: 200150 [DIS]Responding with 6D832A75C95C609E._matterc._udp.local I: 200156 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: 6D832A75C95C609E. I: 200188 [DIS]mDNS service published: _matterc._udp I: 200202 [TS]Pending Last Known Good Time: 2023-10-26T16:15:20 I: 200208 [TS]Previous Last Known Good Time: 2023-10-26T16:15:20 I: 200214 [TS]Reverted Last Known Good Time to previous value E: 200220 [FP]Warning: metadata not found during delete of fabric 0x1 E: 200227 [ZCL]OpCreds: failed to delete fabric at index 1: d8 OK D: 200258 [DL]Disconnect requested E: 200266 [DL]Long dispatch time: 620 ms, for event type 32782 I: 200271 [FS]Fail-safe cleanly disarmed I: 200275 [DL]WiFi station disconnected E: 200289 [DIS]Failed to reply to query: 2000073 I: 200960 [TS]Pending Last Known Good Time: 2023-10-26T16:15:20 I: 200966 [TS]Previous Last Known Good Time: 2023-10-26T16:15:20 I: 200972 [TS]Reverted Last Known Good Time to previous value I: 200977 [DL]Performing factory reset uart:~$ *** Booting nRF Connect SDK v2.5.0 *** I: Init CHIP stack I: 151 [DL]BLE address: FF:9C:35:29:37:C9 OK D: 182 [DL]WiFiManager has been initialized I: 187 [SVR]Subscription persistence not supported I: 191 [SVR]Server initializing... I: 194 [TS]Last Known Good Time: [unknown] I: 198 [TS]Setting Last Known Good Time to firmware build time 2023-10-26T16:15:20 I: 206 [DMG]AccessControl: initializing I: 210 [DMG]Examples::AccessControlDelegate::Init I: 214 [DMG]AccessControl: setting I: 217 [DMG]DefaultAclStorage: initializing I: 221 [DMG]DefaultAclStorage: 0 entries loaded D: 226 [IN]UDP::Init bind&listen port=5540 E: 229 [IN]SO_REUSEPORT failed: 109 D: 233 [IN]UDP::Init bound to port=5540 D: 236 [IN]BLEBase::Init - setting/overriding transport D: 241 [IN]TransportMgr initialized I: 248 [ZCL]Using ZAP configuration... I: 253 [DMG]AccessControlCluster: initializing D: 257 [DL]Boot reason: 6 I: 259 [ZCL]Initiating Admin Commissioning cluster. I: 264 [ZCL]ERR: writing SceneCount 0x1 D: 268 [IN]SecureSession[0x20004808]: Allocated Type:1 LSID:52835 D: 274 [DL]CHIPoBLE advertising set to on I: 278 [DIS]Updating services using commissioning mode 1 I: 283 [DIS]CHIP minimal mDNS started advertising. D: 288 [DL]Using wifi MAC for hostname I: 291 [DIS]Advertise commission parameter vendorID=65521 productID=32770 discriminator=3840/15 cm=1 D: 300 [DIS]Responding with _matterc._udp.local D: 305 [DIS]Responding with DAB2D2F5D27B91A4._matterc._udp.local D: 310 [DIS]Responding with F4CE360013BC.local D: 315 [DIS]Responding with F4CE360013BC.local D: 319 [DIS]Responding with _V65521._sub._matterc._udp.local D: 324 [DIS]Responding with _S15._sub._matterc._udp.local D: 329 [DIS]Responding with _L3840._sub._matterc._udp.local D: 335 [DIS]Responding with _CM._sub._matterc._udp.local D: 340 [DIS]Responding with DAB2D2F5D27B91A4._matterc._udp.local I: 346 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: DAB2D2F5D27B91A4. I: 355 [DIS]mDNS service published: _matterc._udp I: 359 [DIS]Updating services using commissioning mode 1 I: 364 [DIS]CHIP minimal mDNS started advertising. D: 369 [DL]Using wifi MAC for hostname I: 373 [DIS]Advertise commission parameter vendorID=65521 productID=32770 discriminator=3840/15 cm=1 D: 382 [DIS]Responding with _matterc._udp.local D: 386 [DIS]Responding with DAB2D2F5D27B91A4._matterc._udp.local D: 392 [DIS]Responding with F4CE360013BC.local D: 396 [DIS]Responding with F4CE360013BC.local D: 400 [DIS]Responding with _V65521._sub._matterc._udp.local D: 406 [DIS]Responding with _S15._sub._matterc._udp.local D: 411 [DIS]Responding with _L3840._sub._matterc._udp.local D: 416 [DIS]Responding with _CM._sub._matterc._udp.local D: 421 [DIS]Responding with DAB2D2F5D27B91A4._matterc._udp.local I: 427 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: DAB2D2F5D27B91A4. I: 436 [DIS]mDNS service published: _matterc._udp I: 441 [IN]CASE Server enabling CASE session setups D: 446 [IN]SecureSession[0x200048c0]: Allocated Type:2 LSID:52836 I: 451 [SVR]Joining Multicast groups I: 455 [SVR]Server Listening... I: 458 [DL]Device Configuration: I: 461 [DL] Serial Number: 11223344556677889900 I: 465 [DL] Vendor Id: 65521 (0xFFF1) I: 468 [DL] Product Id: 32770 (0x8002) I: 472 [DL] Product Name: not-specified I: 476 [DL] Hardware Version: 0 I: 479 [DL] Setup Pin Code (0 for UNKNOWN/ERROR): 20202021 I: 484 [DL] Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00) I: 490 [DL] Manufacturing Date: 2022-01-01 I: 494 [DL] Device Type: 65535 (0xFFFF) I: 498 [SVR]SetupQRCode: [MT:06PS042C00KA0648G00] I: 502 [SVR]Copy/paste the below URL in a browser to see the QR Code: I: 508 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A06PS042C00KA0648G00 I: 517 [SVR]Manual pairing code: [34970112332] I: 522 [ZCL]Shuting down on/off server cluster on endpoint 2 I: No bridged devices to load from the storage. I: 532 [DL]CHIP task running I: 538 [DL]CHIPoBLE advertising started I: 15957 [DL]BLE connection established (ConnId: 0x00) I: 15962 [DL]Current number of connections: 1/1 E: 15968 [DL]Failed to start CHIPoBLE advertising: -12 E: 15973 [DL]Disabling CHIPoBLE service due to error: 200000c I: 30541 [DL]CHIPoBLE advertising mode changed to slow I: 30546 [DL]CHIPoBLE advertising stopped D: 32061 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 32068 [BLE]local and remote recv window sizes = 5 I: 32073 [BLE]selected BTP version 4 I: 32076 [BLE]using BTP fragment sizes rx 244 / tx 244. D: 32301 [DL]ConnId: 0x00, New CCCD value: 0x0002 D: 32306 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6) D: 32313 [IN]BLE EndPoint 0x2000b5a0 Connection Complete I: 32318 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 498) D: 32421 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 32429 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 32436 [EM]>>> [E:24174r S:0 M:181340528] (U) Msg RX from 0:1382DFE11BEB45CB [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest) I: 32449 [EM]<<< [E:24174r S:0 M:246808799] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse) I: 32461 [IN](U) Sending msg 246808799 to IP address 'BLE' D: 32467 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 140) D: 32541 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 32602 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 32609 [EM]>>> [E:24174r S:0 M:181340529] (U) Msg RX from 0:1382DFE11BEB45CB [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1) I: 33969 [EM]<<< [E:24174r S:0 M:246808800] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2) I: 33980 [IN](U) Sending msg 246808800 to IP address 'BLE' D: 33985 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 132) E: 33993 [DL]Long dispatch time: 1391 ms, for event type 16388 D: 34101 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 34109 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 34116 [EM]>>> [E:24174r S:0 M:181340530] (U) Msg RX from 0:1382DFE11BEB45CB [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3) I: 34128 [EM]<<< [E:24174r S:0 M:246808801] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport) I: 34140 [IN](U) Sending msg 246808801 to IP address 'BLE' D: 34145 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 35) I: 34153 [SC]SecureSession[0x20004808]: Moving from state 'kEstablishing' --> 'kActive' D: 34161 [IN]SecureSession[0x20004808]: Activated - Type:1 LSID:52835 D: 34168 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:52835 PSID:25573! I: 34176 [SVR]Commissioning completed session establishment step I: 34182 [DIS]Updating services using commissioning mode 0 I: 34188 [DIS]CHIP minimal mDNS started advertising. D: 34193 [DL]CHIPoBLE advertising set to off I: 34197 [SVR]Device completed Rendezvous process D: 34221 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 34229 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 34237 [EM]>>> [E:24175r S:52835 M:25251511] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 34248 [IM]Received Read request I: 34252 [EM]<<< [E:24175r S:52835 M:57895832] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData) I: 34263 [IN](S) Sending msg 57895832 on secure session with LSID: 52835 D: 34269 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 73) D: 34341 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 34349 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 34357 [EM]>>> [E:24176r S:52835 M:25251512] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 34368 [IM]Received Read request I: 34373 [EM]<<< [E:24176r S:52835 M:57895833] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData) I: 34383 [IN](S) Sending msg 57895833 on secure session with LSID: 52835 D: 34390 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 95) D: 34461 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 34469 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 34477 [EM]>>> [E:24177r S:52835 M:25251513] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 34488 [IM]Received Read request I: 34493 [EM]<<< [E:24177r S:52835 M:57895834] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData) I: 34503 [IN](S) Sending msg 57895834 on secure session with LSID: 52835 D: 34509 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72) D: 34581 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 34701 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 34709 [EM]>>> [E:24178r S:52835 M:25251514] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 34720 [IM]Received Read request I: 34725 [EM]<<< [E:24178r S:52835 M:57895835] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData) I: 34735 [IN](S) Sending msg 57895835 on secure session with LSID: 52835 D: 34742 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 34821 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 34829 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 34837 [EM]>>> [E:24179r S:52835 M:25251515] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 34848 [IM]Received Read request I: 34852 [EM]<<< [E:24179r S:52835 M:57895836] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData) I: 34863 [IN](S) Sending msg 57895836 on secure session with LSID: 52835 D: 34869 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 34941 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 34949 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 34957 [EM]>>> [E:24180r S:52835 M:25251516] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) D: 34972 [DL]WiFi scanning started... D: 37457 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 37581 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) I: 39587 [DL]Wi-Fi scan done (0) I: 39593 [EM]<<< [E:24180r S:52835 M:57895837] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 39604 [IN](S) Sending msg 57895837 on secure session with LSID: 52835 D: 39611 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 39681 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 39689 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 39801 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 39809 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 33) D: 39921 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 39929 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 40042 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 40050 [EM]>>> [E:24181r S:52835 M:25251517] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 40060 [IM]Received Read request I: 40065 [EM]<<< [E:24181r S:52835 M:57895838] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData) I: 40076 [IN](S) Sending msg 57895838 on secure session with LSID: 52835 D: 40082 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72) D: 40161 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 40282 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 40291 [EM]>>> [E:24182r S:52835 M:25251518] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 40301 [IM]Received Read request I: 40310 [EM]<<< [E:24182r S:52835 M:57895839] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData) I: 40321 [IN](S) Sending msg 57895839 on secure session with LSID: 52835 D: 40327 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 40401 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 40409 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 21) D: 40521 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 40529 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 40537 [EM]>>> [E:24183r S:52835 M:25251519] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 40549 [FS]GeneralCommissioning: Received ArmFailSafe (60s) I: 40556 [EM]<<< [E:24183r S:52835 M:57895840] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 40567 [IN](S) Sending msg 57895840 on secure session with LSID: 52835 D: 40573 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 40701 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 40709 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 40717 [EM]>>> [E:24184r S:52835 M:25251520] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 40731 [EM]<<< [E:24184r S:52835 M:57895841] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 40742 [IN](S) Sending msg 57895841 on secure session with LSID: 52835 D: 40749 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 40821 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 40829 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 40837 [EM]>>> [E:24185r S:52835 M:25251521] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 40849 [ZCL]OpCreds: Certificate Chain request received for PAI I: 40858 [EM]<<< [E:24185r S:52835 M:57895842] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 40869 [IN](S) Sending msg 57895842 on secure session with LSID: 52835 D: 40876 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 41001 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 41009 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 41121 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 41129 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 48) D: 41241 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 41249 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 41257 [EM]>>> [E:24186r S:52835 M:25251522] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 41269 [ZCL]OpCreds: Certificate Chain request received for DAC I: 41278 [EM]<<< [E:24186r S:52835 M:57895843] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 41290 [IN](S) Sending msg 57895843 on secure session with LSID: 52835 D: 41296 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 41421 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 41429 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 41541 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 41549 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 77) D: 41661 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 41669 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 41677 [EM]>>> [E:24187r S:52835 M:25251523] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 41689 [ZCL]OpCreds: Received an AttestationRequest command I: 41724 [ZCL]OpCreds: AttestationRequest successful. I: 41733 [EM]<<< [E:24187r S:52835 M:57895844] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 41745 [IN](S) Sending msg 57895844 on secure session with LSID: 52835 D: 41751 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 41841 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 41849 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) D: 41961 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 41969 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 237) D: 42081 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 42089 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 42097 [EM]>>> [E:24188r S:52835 M:25251524] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 42109 [FS]GeneralCommissioning: Received ArmFailSafe (60s) I: 42116 [EM]<<< [E:24188r S:52835 M:57895845] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 42127 [IN](S) Sending msg 57895845 on secure session with LSID: 52835 D: 42134 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 42261 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 44721 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 45022 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 45030 [EM]>>> [E:24189r S:52835 M:25251525] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 45042 [ZCL]OpCreds: Received a CSRRequest command I: 45186 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded I: 45221 [ZCL]OpCreds: CSRRequest successful. I: 45228 [EM]<<< [E:24189r S:52835 M:57895846] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 45239 [IN](S) Sending msg 57895846 on secure session with LSID: 52835 D: 45245 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244) E: 45253 [DL]Long dispatch time: 231 ms, for event type 16388 D: 45321 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 45329 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 138) D: 45441 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 45449 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 45562 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 45571 [EM]>>> [E:24190r S:52835 M:25251526] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 45583 [ZCL]OpCreds: Received an AddTrustedRootCertificate command I: 45642 [ZCL]OpCreds: AddTrustedRootCertificate successful. I: 45648 [EM]<<< [E:24190r S:52835 M:57895847] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse) I: 45660 [IN](S) Sending msg 57895847 on secure session with LSID: 52835 D: 45666 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 68) E: 45674 [DL]Long dispatch time: 112 ms, for event type 16388 D: 45741 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 45749 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 45862 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 45872 [EM]>>> [E:24191r S:52835 M:25251527] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 45884 [ZCL]OpCreds: Received an AddNOC command I: 45890 [FP]Validating NOC chain I: 45947 [FP]NOC chain validation successful I: 45951 [FP]Added new fabric at index: 0x1 I: 45955 [FP]Assigned compressed fabric ID: 0x016B47F377E5FE0B, node ID: 0x000000003BDE7705 I: 45963 [TS]Last Known Good Time: 2023-10-26T16:15:20 I: 45968 [TS]New proposed Last Known Good Time: 2023-10-26T14:24:33 I: 45974 [TS]Retaining current Last Known Good Time I: 45986 [ZCL]OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0x00000000212740BC D: 45995 [DL]Using wifi MAC for hostname I: 45999 [DIS]Advertise operational node 016B47F377E5FE0B-000000003BDE7705 D: 46006 [DIS]Responding with _matter._tcp.local D: 46010 [DIS]Responding with 016B47F377E5FE0B-000000003BDE7705._matter._tcp.local D: 46017 [DIS]Responding with 016B47F377E5FE0B-000000003BDE7705._matter._tcp.local D: 46025 [DIS]Responding with F4CE360013BC.local D: 46029 [DIS]Responding with F4CE360013BC.local D: 46033 [DIS]Responding with _I016B47F377E5FE0B._sub._matter._tcp.local I: 46040 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 016B47F377E5FE0B-000000003BDE7705. I: 46050 [DIS]mDNS service published: _matter._tcp I: 46055 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC I: 46062 [EM]<<< [E:24191r S:52835 M:57895848] (S) Msg TX to 1:FFFFFFFB00000000 [FE0B] --- Type 0001:09 (IM:InvokeCommandResponse) I: 46073 [IN](S) Sending msg 57895848 on secure session with LSID: 52835 D: 46080 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) E: 46087 [DL]Long dispatch time: 225 ms, for event type 16388 D: 46161 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 46169 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 46177 [EM]>>> [E:24192r S:52835 M:25251528] (S) Msg RX from 1:FFFFFFFB00000000 [FE0B] --- Type 0001:08 (IM:InvokeCommandRequest) I: 46190 [EM]<<< [E:24192r S:52835 M:57895849] (S) Msg TX to 1:FFFFFFFB00000000 [FE0B] --- Type 0001:09 (IM:InvokeCommandResponse) I: 46202 [IN](S) Sending msg 57895849 on secure session with LSID: 52835 D: 46208 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 46281 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 46289 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 46297 [EM]>>> [E:24193r S:52835 M:25251529] (S) Msg RX from 1:FFFFFFFB00000000 [FE0B] --- Type 0001:08 (IM:InvokeCommandRequest) I: 46309 [FS]GeneralCommissioning: Received ArmFailSafe (76s) I: 46316 [EM]<<< [E:24193r S:52835 M:57895850] (S) Msg TX to 1:FFFFFFFB00000000 [FE0B] --- Type 0001:09 (IM:InvokeCommandResponse) I: 46327 [IN](S) Sending msg 57895850 on secure session with LSID: 52835 D: 46334 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 46461 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 46469 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 46477 [EM]>>> [E:24194r S:52835 M:25251530] (S) Msg RX from 1:FFFFFFFB00000000 [FE0B] --- Type 0001:08 (IM:InvokeCommandRequest) D: 46489 [DL]Connecting to WiFi network: FL-IoT D: 46495 [DL]WiFi scanning started... D: 48976 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 49101 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) I: 50949 [DL]Wi-Fi scan done (0) OK OK OK OK OK OK OK OK OK OK I: 52506 [DL]Connection to FL-IoT requested [RSSI=-38] E: 52510 [DL]Long dispatch time: 1561 ms, for event type 3 D: 52516 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 55023 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 55101 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) I: 57258 [DL]Connected to WiFi network I: 57264 [EM]<<< [E:24194r S:52835 M:57895851] (S) Msg TX to 1:FFFFFFFB00000000 [FE0B] --- Type 0001:09 (IM:InvokeCommandResponse) I: 57277 [IN](S) Sending msg 57895851 on secure session with LSID: 52835 D: 57283 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 69) D: 57291 [DL]Using wifi MAC for hostname I: 57294 [DIS]Advertise operational node 016B47F377E5FE0B-000000003BDE7705 D: 57301 [DIS]Responding with _matter._tcp.local D: 57306 [DIS]Responding with 016B47F377E5FE0B-000000003BDE7705._matter._tcp.local D: 57313 [DIS]Responding with 016B47F377E5FE0B-000000003BDE7705._matter._tcp.local D: 57320 [DIS]Responding with F4CE360013BC.local D: 57325 [DIS]Responding with F4CE360013BC.local D: 57329 [DIS]Responding with _I016B47F377E5FE0B._sub._matter._tcp.local I: 57336 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 016B47F377E5FE0B-000000003BDE7705. I: 57346 [DIS]mDNS service published: _matter._tcp I: 57351 [SVR]Operational advertising enabled I: 57356 [SWU]Stopping the watchdog timer I: 57360 [SWU]Starting the periodic query timer, timeout: 86400 seconds E: 57366 [SVR]Server initialization complete I: 57370 [DIS]Updating services using commissioning mode 0 E: 57377 [IN]SO_REUSEPORT failed: 109 I: 57382 [DIS]CHIP minimal mDNS started advertising. D: 57397 [DL]Using wifi MAC for hostname I: 57401 [DIS]Advertise operational node 016B47F377E5FE0B-000000003BDE7705 D: 57408 [DIS]Responding with _matter._tcp.local D: 57413 [DIS]Responding with 016B47F377E5FE0B-000000003BDE7705._matter._tcp.local D: 57420 [DIS]Responding with 016B47F377E5FE0B-000000003BDE7705._matter._tcp.local D: 57427 [DIS]Responding with F4CE360013BC.local D: 57432 [DIS]Responding with F4CE360013BC.local D: 57436 [DIS]Responding with _I016B47F377E5FE0B._sub._matter._tcp.local I: 57442 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 016B47F377E5FE0B-000000003BDE7705. I: 57457 [DIS]mDNS service published: _matter._tcp D: 57463 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) I: 57471 [DIS]Updating services using commissioning mode 0 E: 57490 [IN]SO_REUSEPORT failed: 109 I: 57493 [DIS]CHIP minimal mDNS started advertising. D: 57508 [DL]Using wifi MAC for hostname I: 57512 [DIS]Advertise operational node 016B47F377E5FE0B-000000003BDE7705 D: 57519 [DIS]Responding with _matter._tcp.local D: 57524 [DIS]Responding with 016B47F377E5FE0B-000000003BDE7705._matter._tcp.local D: 57531 [DIS]Responding with 016B47F377E5FE0B-000000003BDE7705._matter._tcp.local D: 57538 [DIS]Responding with F4CE360013BC.local D: 57543 [DIS]Responding with F4CE360013BC.local D: 57547 [DIS]Responding with _I016B47F377E5FE0B._sub._matter._tcp.local I: 57553 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 016B47F377E5FE0B-000000003BDE7705. I: 57569 [DIS]mDNS service published: _matter._tcp E: 57574 [DL]Long dispatch time: 103 ms, for event type 32784 D: 57581 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 60088 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 60201 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 62661 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 65168 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 65241 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 67701 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 70209 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 70281 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 72741 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 74842 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 74850 [EM]>>> [E:24197r S:52835 M:25251531] (S) Msg RX from 1:FFFFFFFB00000000 [FE0B] --- Type 0001:08 (IM:InvokeCommandRequest) I: 74862 [FS]GeneralCommissioning: Received ArmFailSafe (67s) I: 74868 [EM]<<< [E:24197r S:52835 M:57895852] (S) Msg TX to 1:FFFFFFFB00000000 [FE0B] --- Type 0001:09 (IM:InvokeCommandResponse) I: 74880 [IN](S) Sending msg 57895852 on secure session with LSID: 52835 D: 74892 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 74961 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 77421 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 79929 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 80001 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 82461 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 84973 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 85101 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 87561 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 90069 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 90141 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 90922 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 90930 [EM]>>> [E:24198r S:52835 M:25251532] (S) Msg RX from 1:FFFFFFFB00000000 [FE0B] --- Type 0001:08 (IM:InvokeCommandRequest) I: 90942 [FS]GeneralCommissioning: Received ArmFailSafe (68s) I: 90948 [EM]<<< [E:24198r S:52835 M:57895853] (S) Msg TX to 1:FFFFFFFB00000000 [FE0B] --- Type 0001:09 (IM:InvokeCommandResponse) I: 90960 [IN](S) Sending msg 57895853 on secure session with LSID: 52835 D: 90967 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 91041 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 93501 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 96008 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 96081 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 98542 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 101050 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 101121 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 103581 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 106088 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 106161 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 108262 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 108271 [EM]>>> [E:24200r S:52835 M:25251533] (S) Msg RX from 1:FFFFFFFB00000000 [FE0B] --- Type 0001:08 (IM:InvokeCommandRequest) I: 108283 [FS]GeneralCommissioning: Received ArmFailSafe (103s) I: 108290 [EM]<<< [E:24200r S:52835 M:57895854] (S) Msg TX to 1:FFFFFFFB00000000 [FE0B] --- Type 0001:09 (IM:InvokeCommandResponse) I: 108301 [IN](S) Sending msg 57895854 on secure session with LSID: 52835 D: 108308 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 108381 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 110841 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 113348 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 113421 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 115881 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 118388 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 118461 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 120921 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 123429 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 123501 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 125961 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 128470 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 128541 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 131001 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 133515 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 133641 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 136101 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 138610 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 138682 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 141142 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 143650 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 143722 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 146181 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 148689 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 148762 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 151221 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 153729 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 153862 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 156322 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 158829 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 158902 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 160522 [DL]ConnId: 0x00, New CCCD value: 0x0000 D: 160526 [IN]Clearing BLE pending packets. I: 160530 [BLE]Releasing end point's BLE connection back to application. I: 160536 [DL]Closing BLE GATT connection (ConnId 00) I: 160582 [DL]BLE GAP connection terminated (reason 0x13) I: 160587 [DL]Current number of connections: 0/1 I: 211292 [FS]Fail-safe timer expired E: 211295 [SVR]Failsafe timer expired D: 211299 [IN]SecureSession[0x20004808]: MarkForEviction Type:1 LSID:52835 I: 211305 [SC]SecureSession[0x20004808]: Moving from state 'kActive' --> 'kPendingEviction' D: 211313 [IN]SecureSession[0x20004808]: Released - Type:1 LSID:52835 E: 211319 [SVR]Commissioning failed (attempt 1): 32 D: 211325 [IN]SecureSession[0x20004808]: Allocated Type:1 LSID:52837 D: 211331 [DL]CHIPoBLE advertising set to on I: 211335 [DIS]Updating services using commissioning mode 1 E: 211340 [IN]SO_REUSEPORT failed: 109 I: 211344 [DIS]CHIP minimal mDNS started advertising. D: 211370 [DL]Using wifi MAC for hostname I: 211375 [DIS]Advertise operational node 016B47F377E5FE0B-000000003BDE7705 D: 211382 [DIS]Responding with _matter._tcp.local D: 211386 [DIS]Responding with 016B47F377E5FE0B-000000003BDE7705._matter._tcp.local D: 211395 [DIS]Responding with 016B47F377E5FE0B-000000003BDE7705._matter._tcp.local D: 211402 [DIS]Responding with F4CE360013BC.local D: 211407 [DIS]Responding with F4CE360013BC.local D: 211411 [DIS]Responding with _I016B47F377E5FE0B._sub._matter._tcp.local I: 211418 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 016B47F377E5FE0B-000000003BDE7705. I: 211438 [DIS]mDNS service published: _matter._tcp D: 211444 [DL]Using wifi MAC for hostname I: 211447 [DIS]Advertise commission parameter vendorID=65521 productID=32770 discriminator=3840/15 cm=1 D: 211457 [DIS]Responding with _matterc._udp.local D: 211461 [DIS]Responding with DAB2D2F5D27B91A4._matterc._udp.local D: 211467 [DIS]Responding with F4CE360013BC.local D: 211472 [DIS]Responding with F4CE360013BC.local D: 211476 [DIS]Responding with _V65521._sub._matterc._udp.local D: 211482 [DIS]Responding with _S15._sub._matterc._udp.local D: 211487 [DIS]Responding with _L3840._sub._matterc._udp.local D: 211508 [DIS]Responding with _CM._sub._matterc._udp.local D: 211513 [DIS]Responding with DAB2D2F5D27B91A4._matterc._udp.local I: 211519 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: DAB2D2F5D27B91A4. I: 211577 [DIS]mDNS service published: _matterc._udp E: 211582 [ZCL]OpCreds: Got FailSafeTimerExpired E: 211586 [ZCL]OpCreds: Proceeding to FailSafeCleanup on fail-safe expiry! D: 211593 [IN]Expiring all sessions for fabric 0x1!! E: 211599 [FP]Reverting pending fabric data for fabric 0x1 E: 211604 [FP]Warning: metadata not found during delete of fabric 0x1 I: 211614 [FP]Fabric (0x1) deleted. I: 211617 [ZCL]OpCreds: Fabric index 0x1 was removed I: 211621 [DIS]Updating services using commissioning mode 1 E: 211627 [IN]SO_REUSEPORT failed: 109 I: 211631 [DIS]CHIP minimal mDNS started advertising. D: 211755 [DL]Using wifi MAC for hostname I: 211758 [DIS]Advertise commission parameter vendorID=65521 productID=32770 discriminator=3840/15 cm=1 D: 211768 [DIS]Responding with _matterc._udp.local D: 211772 [DIS]Responding with DAB2D2F5D27B91A4._matterc._udp.local D: 211778 [DIS]Responding with F4CE360013BC.local D: 211783 [DIS]Responding with F4CE360013BC.local D: 211787 [DIS]Responding with _V65521._sub._matterc._udp.local D: 211793 [DIS]Responding with _S15._sub._matterc._udp.local D: 211799 [DIS]Responding with _L3840._sub._matterc._udp.local D: 211805 [DIS]Responding with _CM._sub._matterc._udp.local D: 211810 [DIS]Responding with DAB2D2F5D27B91A4._matterc._udp.local I: 211816 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: DAB2D2F5D27B91A4. I: 211848 [DIS]mDNS service published: _matterc._udp I: 211862 [TS]Pending Last Known Good Time: 2023-10-26T16:15:20 I: 211868 [TS]Previous Last Known Good Time: 2023-10-26T16:15:20 I: 211874 [TS]Reverted Last Known Good Time to previous value E: 211880 [FP]Warning: metadata not found during delete of fabric 0x1 E: 211887 [ZCL]OpCreds: failed to delete fabric at index 1: d8 OK D: 211918 [DL]Disconnect requested E: 211921 [DL]Long dispatch time: 626 ms, for event type 32782 I: 211927 [FS]Fail-safe cleanly disarmed I: 211930 [DL]WiFi station disconnected I: 212617 [TS]Pending Last Known Good Time: 2023-10-26T16:15:20 I: 212623 [TS]Previous Last Known Good Time: 2023-10-26T16:15:20 I: 212629 [TS]Reverted Last Known Good Time to previous value I: 212634 [DL]Performing factory reset uart:~$ *** Booting nRF Connect SDK v2.5.0 *** I: Init CHIP stack I: 152 [DL]BLE address: C1:AD:46:EC:63:A8 OK D: 182 [DL]WiFiManager has been initialized I: 187 [SVR]Subscription persistence not supported I: 191 [SVR]Server initializing... I: 194 [TS]Last Known Good Time: [unknown] I: 198 [TS]Setting Last Known Good Time to firmware build time 2023-10-26T16:15:20 I: 207 [DMG]AccessControl: initializing I: 210 [DMG]Examples::AccessControlDelegate::Init I: 214 [DMG]AccessControl: setting I: 218 [DMG]DefaultAclStorage: initializing I: 221 [DMG]DefaultAclStorage: 0 entries loaded D: 226 [IN]UDP::Init bind&listen port=5540 E: 230 [IN]SO_REUSEPORT failed: 109 D: 233 [IN]UDP::Init bound to port=5540 D: 236 [IN]BLEBase::Init - setting/overriding transport D: 241 [IN]TransportMgr initialized I: 248 [ZCL]Using ZAP configuration... I: 253 [DMG]AccessControlCluster: initializing D: 257 [DL]Boot reason: 6 I: 259 [ZCL]Initiating Admin Commissioning cluster. I: 264 [ZCL]ERR: writing SceneCount 0x1 D: 268 [IN]SecureSession[0x20004808]: Allocated Type:1 LSID:4369 D: 274 [DL]CHIPoBLE advertising set to on I: 278 [DIS]Updating services using commissioning mode 1 I: 283 [DIS]CHIP minimal mDNS started advertising. D: 288 [DL]Using wifi MAC for hostname I: 291 [DIS]Advertise commission parameter vendorID=65521 productID=32770 discriminator=3840/15 cm=1 D: 300 [DIS]Responding with _matterc._udp.local D: 305 [DIS]Responding with 0A028DE8EC7144F1._matterc._udp.local D: 310 [DIS]Responding with F4CE360013BC.local D: 315 [DIS]Responding with F4CE360013BC.local D: 319 [DIS]Responding with _V65521._sub._matterc._udp.local D: 324 [DIS]Responding with _S15._sub._matterc._udp.local D: 329 [DIS]Responding with _L3840._sub._matterc._udp.local D: 335 [DIS]Responding with _CM._sub._matterc._udp.local D: 340 [DIS]Responding with 0A028DE8EC7144F1._matterc._udp.local I: 346 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: 0A028DE8EC7144F1. I: 355 [DIS]mDNS service published: _matterc._udp I: 359 [DIS]Updating services using commissioning mode 1 I: 364 [DIS]CHIP minimal mDNS started advertising. D: 369 [DL]Using wifi MAC for hostname I: 373 [DIS]Advertise commission parameter vendorID=65521 productID=32770 discriminator=3840/15 cm=1 D: 382 [DIS]Responding with _matterc._udp.local D: 386 [DIS]Responding with 0A028DE8EC7144F1._matterc._udp.local D: 392 [DIS]Responding with F4CE360013BC.local D: 396 [DIS]Responding with F4CE360013BC.local D: 400 [DIS]Responding with _V65521._sub._matterc._udp.local D: 406 [DIS]Responding with _S15._sub._matterc._udp.local D: 411 [DIS]Responding with _L3840._sub._matterc._udp.local D: 416 [DIS]Responding with _CM._sub._matterc._udp.local D: 421 [DIS]Responding with 0A028DE8EC7144F1._matterc._udp.local I: 427 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: 0A028DE8EC7144F1. I: 436 [DIS]mDNS service published: _matterc._udp I: 441 [IN]CASE Server enabling CASE session setups D: 446 [IN]SecureSession[0x200048c0]: Allocated Type:2 LSID:4370 I: 452 [SVR]Joining Multicast groups I: 455 [SVR]Server Listening... I: 458 [DL]Device Configuration: I: 461 [DL] Serial Number: 11223344556677889900 I: 465 [DL] Vendor Id: 65521 (0xFFF1) I: 469 [DL] Product Id: 32770 (0x8002) I: 472 [DL] Product Name: not-specified I: 476 [DL] Hardware Version: 0 I: 479 [DL] Setup Pin Code (0 for UNKNOWN/ERROR): 20202021 I: 484 [DL] Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00) I: 490 [DL] Manufacturing Date: 2022-01-01 I: 494 [DL] Device Type: 65535 (0xFFFF) I: 498 [SVR]SetupQRCode: [MT:06PS042C00KA0648G00] I: 502 [SVR]Copy/paste the below URL in a browser to see the QR Code: I: 509 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A06PS042C00KA0648G00 I: 517 [SVR]Manual pairing code: [34970112332] I: 522 [ZCL]Shuting down on/off server cluster on endpoint 2 I: No bridged devices to load from the storage. I: 532 [DL]CHIP task running I: 538 [DL]CHIPoBLE advertising started
