[SOLVED] nrfjprog.exe "ERROR: Two arguments were provided that cannot be combined."
nrfjprog is reporting known errors while I'm trying to burn the pca10028 dual_bank_ble_s110 bootloader to the nRF51-DK.
    ".\_build\nrf51422_xxac.axf" - 0 Error(s), 0 Warning(s).
Build Time Elapsed:  00:00:06
nrfjprog.exe --reset --program "C:\Development\nRF51_SDK_8.0.0_5fc2c3a\examples\dfu\bootloader\pca10028\dual_bank_ble_s110\arm5_no_packs\_build\nrf51422_xxac.HEX"
ERROR: Two arguments were provided that cannot be combined. Use --help to read
ERROR: about the valid argument combinations.
Here is the full build output: nrfjprog_error.txt
So far, I've seen two proposed solutions which haven't worked for me.
  1. This question proposed splitting the --program and --reset arguments into two commands. However, Chuan-Zheng Lee correctly points out that
...because the configuration dialog admits only one command, splitting the command as suggested above can't be used as a workaround.
I'm using Keil as well and there doesn't seem to be an option to provide more than one command. image description
  1. The second proposed solution recommended using the bootloader from the 8.0 SDK. So I downloaded nRF51_SDK_8.0.0_5fc2c3a.zip and nRF51_SDK_8.1.0_b6ed55f.zip and tried both. Each produced the exact same error messages. This leads me to think I'm again missing something critical. Has there been a resolution to this which I've missed? Thanks! :)
