I am using the PPK-II to measure our system board current (our system uses the nRF9160 and nRF52840) over a long period (many hours).
System is run from a Li-Po battery, so PPK-II is connected between battery and system board.
PPK-II is in datalogger mode. 100 samples/second, sample for 6 hours.
At the moment, the initial baseline current is measured at an average of 1.52mA. See screenshot.
But after an LTE call-in the average baseline current increases to ~2.00mA (excludes the call-in current).
In the screenshots, the >50mA current spikes are LTE call-in each hour.
In investigating to the reason for this, i have additionally connected a DMM to simultaneously measure the current with the PPK-II.
The DMM measurement remains at 1.52mA while the PPK-II is measuring higher at ~2.00mA.
This seems to be reproducible after a long runtime > 2 hours, and after an LTE call-in where there is an increase in current possibly when the current reaches >150mA (poor signal).
Interestingly, the current measurement on the PPK-II returns to the correct measurement after the datalogger is stopped and restarted again from the PC Power Profiler App (v3.5.5).
Power not is removed from the PPK-II (USB to PC). Only button press to stop and start the datalogger.
Note. when stopping the datalogger, the power to the system is not turned off, so the system remains ON. The system is still running normally and has no change when the datalogger is halted.
The screenshots below is a zoomed version of the above where you can see the increased baseline current after the LTE connection has completed.
Are you able to provide a reason why this could be occurring?
