S120 central discover service fail
I am using NUS service as a peripheral with read and write characteristics and tested on master control panel. Now I am using S120 stack for central device and able to scan for the device. But when central tries to connect, I am getting Service not found event. Can anyone tell me the cause for this?
Update: I added uuid in both server and client, still I am getting BLE_DB_DISCOVERY_SRV_NOT_FOUND event.
Here is the code snippet for peripheral:
    ble_uuid_t        service_uuid;
ble_uuid128_t     base_uuid = BLE_UUID_OUR_BASE_UUID;
service_uuid.uuid = BLE_UUID_NUS_SERVICE;
// Initialize the service structure.
p_hrs->conn_handle             = BLE_CONN_HANDLE_INVALID;
p_hrs->data_handler            = p_hrs_init->evt_handler;
p_hrs->is_notification_enabled = false;
// add custom base UUID
err_code = sd_ble_uuid_vs_add(&base_uuid, &p_hrs->uuid_type);
if(err_code != NRF_SUCCESS)
 	return err_code;
service_uuid.type = p_hrs->uuid_type;
// Add the service
err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
                                    &service_uuid,
                                    &p_hrs->service_handle);
 	return err_code;
// Add the RX Characteristic.
err_code = heart_rate_measurement_char_add(p_hrs, p_hrs_init);
if (err_code != NRF_SUCCESS)
    return err_code;
err_code = heart_rate_measurement_read_char_add(p_hrs, p_hrs_init);
    return err_code;
 return NRF_SUCCESS;
Here is the code snippet for central:
void client_handling_init(void)
uint32_t err_code;
uint32_t i;
err_code = sd_ble_uuid_vs_add(&base_uuid, &m_base_uuid_type);
for (i = 0; i < MAX_CLIENTS; i++)
    m_client[i].state  = IDLE;
m_client_count = 0;
db_discovery_init();
// Register with discovery module for the discovery of the service.
ble_uuid_t uuid;
uuid.type = m_base_uuid_type;
uuid.uuid = BLE_UUID_DEVICE_INFORMATION_SERVICE;
err_code = ble_db_discovery_evt_register(&uuid,
                                         db_discovery_evt_handler);
Sowmya
  • You can check the event in on_ble_evt(). Then you can print out:
    p_ble_evt->evt.gattc_evt.params.prim_srvc_disc_rsp.services[0].uuid.uuid - This should match the short UUID of service
    and
    p_ble_evt->evt.gattc_evt.params.prim_srvc_disc_rsp.services[0].uuid.type -This should match the type of the base UUID returned from sd_ble_uuid_vs_add(&base_uuid, &m_base_uuid_type);
    You will get the BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP event as an response to calling sd_ble_gattc_primary_services_discover(), the example should already be calling this.
    and
