Arducam Mega project not working
I am trying to use arducam 3MegaP with nrf52840dk.
I am using VS code, windows 11.
I cloned the ncs-arducam-mega-driver from github, and I am to run the take_picture project.
It builds but it doesn't run on the board.
* Executing task: nRF Connect: Generate config nrf52840dk_nrf52840 for d:\Cypod\ncs-arducam-mega-driver\samples\take_picture
Building take_picture
C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir d:/Cypod/ncs-arducam-mega-driver/samples/take_picture/build d:/Cypod/ncs-arducam-mega-driver/samples/take_picture --pristine --board nrf52840dk_nrf52840 --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="d:/Cypod/ncs-arducam-mega-driver/samples/take_picture/prj.conf" -DBOARD_ROOT:STRING="d:/cypod/ncs-arducam-mega-driver/samples/take_picture""
-- Application: D:/Cypod/ncs-arducam-mega-driver/samples/take_picture
-- CMake version: 3.20.5
-- Found Python3: C:/ncs/toolchains/31f4403e35/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.4.1/zephyr/.cache
-- Zephyr version: 3.3.99 (C:/ncs/v2.4.1/zephyr)
-- Found west (found suitable version "1.0.0", minimum required is "0.7.1")
-- Board: nrf52840dk_nrf52840
-- Found host-tools: zephyr 0.16.0 (C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.0 (C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/31f4403e35/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.4.1/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840.dts
-- Found devicetree overlay: D:/Cypod/ncs-arducam-mega-driver/samples/take_picture/boards/nrf52840dk_nrf52840.overlay
'label' is marked as deprecated in 'properties:' in C:/ncs/v2.4.1/zephyr/dts/bindings\spi\nordic,nrf-spim.yaml for node /soc/spi@4002f000.
-- Generated zephyr.dts: D:/Cypod/ncs-arducam-mega-driver/samples/take_picture/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: D:/Cypod/ncs-arducam-mega-driver/samples/take_picture/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: D:/Cypod/ncs-arducam-mega-driver/samples/take_picture/build/zephyr/dts.cmake
Parsing C:/ncs/v2.4.1/zephyr/Kconfig
Loaded configuration 'C:/ncs/v2.4.1/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840_defconfig'
Merged configuration 'd:/Cypod/ncs-arducam-mega-driver/samples/take_picture/prj.conf'
Configuration saved to 'D:/Cypod/ncs-arducam-mega-driver/samples/take_picture/build/zephyr/.config'
Kconfig header saved to 'D:/Cypod/ncs-arducam-mega-driver/samples/take_picture/build/zephyr/include/generated/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
CMake Warning at C:/ncs/v2.4.1/zephyr/CMakeLists.txt:839 (message):
No SOURCES given to Zephyr library: lib__libc__common
Excluding target from build.
-- Configuring done
-- Generating done
-- Build files have been written to: D:/Cypod/ncs-arducam-mega-driver/samples/take_picture/build
[1/186] Generating include/generated/version.h
-- Zephyr version: 3.3.99 (C:/ncs/v2.4.1/zephyr), build: v3.3.99-ncs1-1
[2/186] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[3/186] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[4/186] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[5/186] Generating include/generated/driver-validation.h
[6/186] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[7/186] Generating include/generated/offsets.h
[8/186] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[9/186] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[10/186] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[11/186] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[12/186] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[13/186] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[14/186] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[15/186] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[16/186] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[17/186] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[18/186] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[19/186] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[20/186] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[21/186] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[22/186] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[23/186] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[24/186] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[25/186] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[26/186] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[27/186] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[28/186] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[29/186] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[30/186] Generating linker_zephyr_pre0.cmd
[31/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[32/186] Generating linker_zephyr_pre1.cmd
[33/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[34/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[35/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[36/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[37/186] Building C object CMakeFiles/app.dir/src/main.c.obj
../src/main.c: In function 'main':
d:\Cypod\ncs-arducam-mega-driver\samples\take_picture\src\main.c:17:13: warning: unused variable 'err' [-Wunused-variable]
17 | int err;
[38/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[39/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[40/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[41/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[42/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[43/186] Generating ../../../include/generated/libc/minimal/strerror_table.h
[44/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[45/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[46/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[47/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[48/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[49/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[50/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[51/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[52/186] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[53/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[54/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[55/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[56/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[57/186] Linking C static library zephyr\arch\common\libisr_tables.a
[58/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[59/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
[60/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
[61/186] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[62/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[63/186] Linking C static library app\libapp.a
[64/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[65/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
[66/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[67/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[68/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[69/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[70/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[71/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[72/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[73/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
[74/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[75/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
[76/186] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[77/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[78/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[79/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[80/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[81/186] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[82/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/ring_buffer.c.obj
[83/186] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[84/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[85/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
[86/186] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj
[87/186] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[88/186] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[89/186] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[90/186] Linking C static library zephyr\arch\common\libarch__common.a
[91/186] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[92/186] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[93/186] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[94/186] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj
[95/186] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_mgmt.c.obj
[96/186] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_cache.c.obj
[97/186] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj
[98/186] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[99/186] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj
[100/186] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.1/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[101/186] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/backends/log_backend_uart.c.obj
[102/186] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[103/186] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj
[104/186] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj
[105/186] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[106/186] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/backends/log_backend_rtt.c.obj
[107/186] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/power.c.obj
[108/186] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
[109/186] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[110/186] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[111/186] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[112/186] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[113/186] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[114/186] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[115/186] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
[116/186] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[117/186] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spi.c.obj
[118/186] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[119/186] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[120/186] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[121/186] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[122/186] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.1/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[123/186] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[124/186] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.1/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[125/186] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.1/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[126/186] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.1/modules/hal/nordic/nrfx/mdk/system_nrf52840.c.obj
[127/186] Linking C static library zephyr\soc\arm\nordic_nrf\nrf52\libsoc__arm__nordic_nrf__nrf52.a
[128/186] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[129/186] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.1/modules/hal/nordic/nrfx/drivers/src/nrfx_spi.c.obj
[130/186] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.1/modules/hal/nordic/nrfx/drivers/src/nrfx_ppi.c.obj
[131/186] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.1/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj
[132/186] Building C object modules/segger/CMakeFiles/modules__segger.dir/C_/ncs/v2.4.1/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
[133/186] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
[134/186] Building C object modules/arducam_mega/lib/arducam_mega/CMakeFiles/D____Cypod__ncs-arducam-mega-driver__modules__arducam_mega__lib__arducam_mega.dir/arducam_mega.c.obj
D:/Cypod/ncs-arducam-mega-driver/modules/arducam_mega/lib/arducam_mega/arducam_mega.c: In function 'uart_event_thread_func':
D:\Cypod\ncs-arducam-mega-driver\modules\arducam_mega\lib\arducam_mega\arducam_mega.c:45:42: warning: unused variable 'new_event' [-Wunused-variable]
45 | static struct arducam_mega_evt_t new_event;
D:/Cypod/ncs-arducam-mega-driver/modules/arducam_mega/lib/arducam_mega/arducam_mega.c: At top level:
D:\Cypod\ncs-arducam-mega-driver\modules\arducam_mega\lib\arducam_mega\arducam_mega.c:78:13: warning: Macro is deprecated
78 | DT_INST_FOREACH_STATUS_OKAY (ARDUCAM_MEGA_DEFINE)
D:\Cypod\ncs-arducam-mega-driver\modules\arducam_mega\lib\arducam_mega\arducam_mega.c:45:42: warning: 'new_event' defined but not used [-Wunused-variable]
[135/186] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[136/186] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[137/186] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
[138/186] Building C object modules/arducam_mega/lib/arducam_mega/CMakeFiles/D____Cypod__ncs-arducam-mega-driver__modules__arducam_mega__lib__arducam_mega.dir/arducam_nordic_hal.c.obj
[139/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[140/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[141/186] Building C object modules/arducam_mega/lib/arducam_mega/CMakeFiles/D____Cypod__ncs-arducam-mega-driver__modules__arducam_mega__lib__arducam_mega.dir/ArducamCamera.c.obj
[142/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[143/186] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[144/186] Linking C static library zephyr\drivers\spi\libdrivers__spi.a
[145/186] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
[146/186] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[147/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[148/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[149/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[150/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[151/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[152/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[153/186] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
[154/186] Linking C static library zephyr\libzephyr.a
[155/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[156/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[157/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[158/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
[159/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
[160/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[161/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[162/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[163/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[164/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[165/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[166/186] Linking C static library modules\segger\libmodules__segger.a
[167/186] Linking C static library zephyr\drivers\console\libdrivers__console.a
[168/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[169/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[170/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[171/186] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[172/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[173/186] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[174/186] Linking C static library modules\arducam_mega\lib\arducam_mega\libD____Cypod__ncs-arducam-mega-driver__modules__arducam_mega__lib__arducam_mega.a
[175/186] Linking C static library zephyr\kernel\libkernel.a
[176/186] Linking C executable zephyr\zephyr_pre0.elf
[177/186] Generating dev_handles.c
[178/186] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
[179/186] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
[180/186] Linking C executable zephyr\zephyr_pre1.elf
[181/186] Generating linker.cmd
[182/186] Generating isr_tables.c, isrList.bin
[183/186] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[184/186] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[185/186] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[186/186] Linking C executable zephyr\zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 43556 B 1 MB 4.15%
RAM: 11648 B 256 KB 4.44%
IDT_LIST: 0 GB 2 KB 0.00%
* Terminal will be reused by tasks, press any key to close it.
