nRF Connect with VSCode: how to generate assembly files
I'm using the latest nRF Connect (2.4.2) in VSCode (on Windows) to develop an application on an nRF52840.  I would like to look at some of the assembly code generated by the compiler.  How do I do that in this environment?  With gcc I would use the -S switch; is it the same here?  Where do I add this switch--Build Configuration (how?), CMakeLists.txt (what would the magic incantation be?), or somewhere else?
I can't easily hook up my j-link pod and just look at it in the debugger, since it requires a fair amount of mechanical disassembly.
Thanks in advance for any info.
--mkj
  • Hi mkj,
    As you mention, normally you output .asm via the "-S" switch in GCC.
    Adding custom compiler switches can be done using "CONFIG_COMPILER_OPT", but the adding the -S switch does not combine well with the build system in zephyr.
    What you can do is, after the fact, use objdump to disassemble your .elf file:
    arm-zephyr-eabi-objdump -S --disassemble my-build-folder/zephyr/zephyr.elf > disassembly.lst
    Håkon
  • That did the trick (once I remembered to add the "nRF Connect" shell in VSCode, since it has the correct PATH already set up).  And, with the DEBUG build anyway, there is enough context from the C code to easily find the functions I was interested in.
    Thanks so much for the quick response!
    --mkj
  • Hi mkj,
    Glad to hear that this helped!
    Sorry about this, I should have added a c:\PATH\to\ in my former post. You can do an absolute path towards objdump if you want to add this to some sort of "post build operation" in vscode, , ie. : c:\ncs\toolchains\...\bin\arm-zephyr-eabi-objdump <file.elf>
    Håkon
    isn't the a way to get assembly files to be kept in the build folder? I'm so far using arm-none-eabi-objdump to get assembly from zephyr.elf but would prefer to get it automatically at every build. I have tried different directives in CMakeLists.txt without any success.
    BR
    Mattias
  • Hi Mattias,
    I spent some extra time on this, and found that this seems to work:
    set(MY_OBJDUMP /opt/zephyr-sdk/zephyr-sdk-0.16.0/arm-zephyr-eabi/bin/arm-zephyr-eabi-objdump)
    set_property(GLOBAL APPEND PROPERTY extra_post_build_byproducts
      COMMAND ${MY_OBJDUMP} -S --disassemble ${CMAKE_BINARY_DIR}/zephyr/zephyr.elf > ${CMAKE_BINARY_DIR}/zephyr/zephyr.asm
    cmake_minimum_required(VERSION 3.20.0)
    find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
    ...rest of file
    Note that the placement is before find_package(...) in the projects CMakeLists.txt file.
    Could you try this and see if it works in your project as well?
    Håkon
