Understanding basic button sample code
I'm studying the code for the button sample program in the nrf in zephyr.
 * Copyright (c) 2016 Open-RnD Sp. z o.o.
 * Copyright (c) 2020 Nordic Semiconductor ASA
#include <zephyr.h>
#include <device.h>
#include <drivers/gpio.h>
#include <sys/util.h>
#include <sys/printk.h>
#include <inttypes.h>
#define SLEEP_TIME_MS	1
 * Get button configuration from the devicetree sw0 alias. This is mandatory.
#define SW0_NODE	DT_ALIAS(sw0)
#if !DT_NODE_HAS_STATUS(SW0_NODE, okay)
#error "Unsupported board: sw0 devicetree alias is not defined"
static const struct gpio_dt_spec button = GPIO_DT_SPEC_GET_OR(SW0_NODE, gpios,
							      {0});
static struct gpio_callback button_cb_data;
 * The led0 devicetree alias is optional. If present, we'll use it
 * to turn on the LED whenever the button is pressed.
static struct gpio_dt_spec led = GPIO_DT_SPEC_GET_OR(DT_ALIAS(led0), gpios,
						     {0});
void button_pressed(const struct device *dev, struct gpio_callback *cb,
		    uint32_t pins)
	printk("Button pressed at %" PRIu32 "\n", k_cycle_get_32());
void main(void)
	int ret;
	if (!device_is_ready(button.port)) {
		printk("Error: button device %s is not ready\n",
		       button.port->name);
		return;
	ret = gpio_pin_configure_dt(&button, GPIO_INPUT);
	if (ret != 0) {
		printk("Error %d: failed to configure %s pin %d\n",
		       ret, button.port->name, button.pin);
		return;
	ret = gpio_pin_interrupt_configure_dt(&button,
					      GPIO_INT_EDGE_TO_ACTIVE);
	if (ret != 0) {
		printk("Error %d: failed to configure interrupt on %s pin %d\n",
		return;
	gpio_init_callback(&button_cb_data, button_pressed, BIT(button.pin));
	gpio_add_callback(button.port, &button_cb_data);
	printk("Set up button at %s pin %d\n", button.port->name, button.pin);
	if (led.port && !device_is_ready(led.port)) {
		printk("Error %d: LED device %s is not ready; ignoring it\n",
		       ret, led.port->name);
		led.port = NULL;
	if (led.port) {
		ret = gpio_pin_configure_dt(&led, GPIO_OUTPUT);
		if (ret != 0) {
			printk("Error %d: failed to configure LED device %s pin %d\n",
			       ret, led.port->name, led.pin);
			led.port = NULL;
		} else {
			printk("Set up LED at %s pin %d\n", led.port->name, led.pin);
	printk("Press the button\n");
	if (led.port) {
		while (1) {
			/* If we have an LED, match its state to the button's. */
			int val = gpio_pin_get_dt(&button);
			if (val >= 0) {
				gpio_pin_set_dt(&led, val);
			k_msleep(SLEEP_TIME_MS);
I would like to ask for assistance in understanding some parts of the code.
#include <device.h>
Is there a diffence between the above code and #include <zephyr/device.h>? which should be the better choice?
May I know if this code is relevant? I assume this is used for unit testing?
		    uint32_t pins)
This is the first time I have encountered "PRIu32", is this a time data?
if (led.port) {
		if (ret != 0) {
			led.port = NULL;
		} else {
What is "led.port->name"? why does it point to name? I tried to look for it in the led0 part of nrf52840dk_nrf52840.dts and then to the gpio0 part of nrf52840.dtsi but only found "port = <0>;"
