nRF52832 Nordic UART code: What defines are needed to build for the UARTE
I am currently using Nordic's UART code and wish to build to use the UARTE rather than the legacy UART. I am currently using the following definitions in nrf_drv_config.h:
#define UART_EASY_DMA_SUPPORT     1
#define UART_LEGACY_SUPPORT       0
#define UART0_CONFIG_USE_EASY_DMA true
However, when I build the code I get the following error
#ifdef NRF52
    m_cb.use_easy_dma = p_config->use_easy_dma;
struct "<unnamed>" has no field "use_easy_dma"
Obviously use_easy_dma is not defined as a member for my compile time definitions. Any ideas ?
  • It is actually a bug in the SDK. Use this for now (no easyDMA support):
    #define UART0_CONFIG_USE_EASY_DMA false
    #define UART_LEGACY_SUPPORT       1
    The bug has been reported.
  • Thanks. The code now builds fine. The issue now is that the printfs that were working with
    now seem to do nothing.
  • Another error there, app_uart_fifo_init(...) returns error, should have tested before I suggested that. I will check tomorrow if there is anything you can do.
