Dear Nordic Support Team,
I am reaching out for assistance with an issue I’ve encountered on my new nRF7002DK board. After successfully flashing the Azure IoT Hub example with Device Provisioning Service (DPS) enabled, I am experiencing unexpected behaviour upon resetting the board.
Problem Description: Post-flashing, every reset of the board results in LED 5 blinking at an unusually high rate. My system recognizes the board as it appears in the connected devices list, but it seems stuck in a loop, perpetually attempting to establish a connection.
System and Tools:
- Operating System: Windows 11 Pro
- Nordic SDK: nRF Connect SDK (NCS) version 2.5.0
- Programming/Debugging Tool: nRF Command Line Tools
Steps Already Taken:
- Attempted to recover the board using the
nrfjprogtool with the following command:nrfjprog.exe --recover --log. - I reviewed the log for apparent errors but couldn't find a clear cause.
Request: I would appreciate guidance on how to troubleshoot this issue further. Is there a known issue with the Azure IoT Hub example in NCS 2.5.0 that could cause this behaviour? Additionally, if there are any specific logs or details you require to assist me better, please let me know.
Thank you for your time and assistance.
Looking forward to your response.
[2023-Nov-07 14:59:13] [debug] -------------------------------------------------------------------------------- [2023-Nov-07 14:59:13] [debug] C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe --recover --log . [2023-Nov-07 14:59:13] [debug] nrfjprog version 10.23.2 external [2023-Nov-07 14:59:13] [debug] -------------------------------------------------------------------------------- [2023-Nov-07 14:59:13] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll. [2023-Nov-07 14:59:13] [ info] Library loaded, loading member functions. [2023-Nov-07 14:59:13] [ info] Member functions succesfully loaded. [2023-Nov-07 14:59:13] [debug] [ Client] - open [2023-Nov-07 14:59:13] [debug] [ Client] - start [2023-Nov-07 14:59:13] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence d0881295-8880-4214-8240-8bc449420a40. [2023-Nov-07 14:59:13] [trace] [ Client] - Command open executed for 47 milliseconds with result 0 [2023-Nov-07 14:59:13] [debug] [ Client] - config [2023-Nov-07 14:59:13] [trace] [ Client] - Command config executed for 15 milliseconds with result 0 [2023-Nov-07 14:59:13] [debug] [ Client] - enum_emu_snr [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger [2023-Nov-07 14:59:13] [debug] [ JLink] - Logger sink registered in JLink logger [2023-Nov-07 14:59:13] [debug] [ nRFXX] - open [2023-Nov-07 14:59:13] [debug] [ nRFXX] - just_check_family [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - open_dll [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect. [2023-Nov-07 14:59:13] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink\JLink_x64.dll. [2023-Nov-07 14:59:13] [ info] [SeggerBackend] - Library loaded, loading member functions. [2023-Nov-07 14:59:13] [ info] [SeggerBackend] - Member functions succesfully loaded. [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - Set batch mode [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - dll_version [2023-Nov-07 14:59:13] [ info] [SeggerBackend] - Segger dll version 7.88.j loaded. [2023-Nov-07 14:59:13] [trace] [ Worker] - Command open executed for 3 milliseconds with result 0 [2023-Nov-07 14:59:13] [debug] [ nRFXX] - config [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - enum_emu_snr [2023-Nov-07 14:59:13] [trace] [ Worker] - Command config executed for 2 milliseconds with result 0 [2023-Nov-07 14:59:13] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0 [2023-Nov-07 14:59:13] [debug] [ Client] - connect_to_emu_with_snr [2023-Nov-07 14:59:13] [debug] [ nRFXX] - enum_emu_con_info [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - is_connected_to_emu [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - enum_emu_con_info [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - is_connected_to_emu [2023-Nov-07 14:59:13] [trace] [ Worker] - Command enum_emu_con_info executed for 2 milliseconds with result 0 [2023-Nov-07 14:59:13] [debug] [ nRFXX] - connect_to_emu_with_snr [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - is_connected_to_emu [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - connect_to_emu_with_snr [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - is_connected_to_emu [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - ---just_enum_emu_snr [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - ---just_get_num_emus [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - Segger logging enabled. [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - ***** Error: [2023-Nov-07 14:59:13] [trace] [ JLink] - Cannot connect to J-Link [2023-Nov-07 14:59:13] [trace] [ JLink] - - 1.563ms returns "Cannot connect to J-Link" [2023-Nov-07 14:59:13] [trace] [ JLink] - JLINK_HasError() [2023-Nov-07 14:59:13] [trace] [ JLink] - JLINK_OpenEx(...) [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - ***** Error: [2023-Nov-07 14:59:13] [trace] [ JLink] - Cannot connect to J-Link [2023-Nov-07 14:59:13] [trace] [ JLink] - - 0.924ms returns "Cannot connect to J-Link" [2023-Nov-07 14:59:13] [trace] [ JLink] - JLINK_HasError() [2023-Nov-07 14:59:13] [trace] [ JLink] - JLINK_OpenEx(...) [2023-Nov-07 14:59:13] [error] [ Client] - Encountered error -102: Command connect_to_emu_with_snr executed for 31 milliseconds with result -102 [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - Out of sync , resynchronizing... [2023-Nov-07 14:59:13] [trace] [ JLink] - ***** Error: [2023-Nov-07 14:59:13] [trace] [ JLink] - Cannot connect to J-Link [2023-Nov-07 14:59:13] [trace] [ JLink] - - 0.951ms returns "Cannot connect to J-Link" [2023-Nov-07 14:59:13] [trace] [ JLink] - JLINK_HasError() [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - is_connected_to_emu [2023-Nov-07 14:59:13] [trace] [ JLink] - JLINK_IsOpen() [2023-Nov-07 14:59:13] [trace] [ JLink] - - 0.005ms returns 0x00 [2023-Nov-07 14:59:13] [trace] [ JLink] - JLINK_HasError() [2023-Nov-07 14:59:13] [error] [ Worker] - JLinkARM.dll Open returned error 'Cannot connect to J-Link' [2023-Nov-07 14:59:13] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 16 milliseconds with result -102 [2023-Nov-07 14:59:13] [debug] [ nRFXX] - close [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - is_connected_to_emu [2023-Nov-07 14:59:13] [trace] [ JLink] - JLINK_IsOpen() [2023-Nov-07 14:59:13] [trace] [ JLink] - - 0.015ms returns 0x00 [2023-Nov-07 14:59:13] [trace] [ JLink] - JLINK_HasError() [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - close [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - disconnect_from_emu [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - is_connected_to_emu [2023-Nov-07 14:59:13] [trace] [ JLink] - JLINK_IsOpen() [2023-Nov-07 14:59:13] [trace] [ JLink] - - 0.029ms returns 0x00 [2023-Nov-07 14:59:13] [trace] [ JLink] - JLINK_HasError() [2023-Nov-07 14:59:13] [debug] [SeggerBackend] - Segger Backend closed. [2023-Nov-07 14:59:13] [debug] [ nRFXX] - nRF family DLL closed [2023-Nov-07 14:59:13] [trace] [ Client] - Command close executed for 45 milliseconds with result 0 [2023-Nov-07 14:59:13] [debug] [ Client] - terminate [2023-Nov-07 14:59:13] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0 [2023-Nov-07 14:59:13] [trace] [ Worker] - Command close executed for 30 milliseconds with result 0 [2023-Nov-07 14:59:13] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0 [2023-Nov-07 14:59:13] [trace] [ Worker] - Executed 6 commands for 53 milliseconds [2023-Nov-07 14:59:13] [debug] [ Client] - Worker process exited with code: 0 [2023-Nov-07 14:59:13] [debug] [ Client] - Worker process exited with code: 0 [2023-Nov-07 14:59:13] [debug] [ Client] - Child process terminated with result 0 [2023-Nov-07 14:59:13] [trace] [ Client] - Executed 6 commands for 153 milliseconds [2023-Nov-07 14:59:13] [debug] [ Client] - terminate
