Interfacing the SPH0645 Mic with the I2S in Zephyr.
I want to interface the sph0645 mic in zephyr with the I2S but I am not able to do the same.
I am using the following code, because of the I2S 24 bit protocol with 32 bit word size is currently not supported in master mode by Nordic NRFX drivers. I am using the i2s as slave mode by using pwm. I am getting the error as the -11 while reading using the i2s_read() command.
#include <zephyr/zephyr.h>
#include <zephyr/device.h>
#include <zephyr/drivers/pwm.h>
#include <zephyr/drivers/i2s.h>
#include <string.h>
#include <zephyr/logging/log_ctrl.h>
//#include <zephyr/pm/device.h>
#define MODULE main
#define LED0ON
#define LED1ON
LOG_MODULE_REGISTER(MODULE, 3);
#define MIC_CTRL  2
#define I2S_RX_NODE         DT_NODELABEL(i2s_rx)
#define SAMPLE_FREQUENCY 44100
#define SAMPLE_BIT_WIDTH 24
#define BYTES_PER_SAMPLE sizeof(int32_t)
#define NUMBER_OF_CHANNELS 2
#define SAMPLES_PER_BLOCK ((SAMPLE_FREQUENCY / 10) * NUMBER_OF_CHANNELS)
#define INITIAL_BLOCKS 2
#define TIMEOUT 1000
/* Size of a block for 100 ms of audio data. */
#define BLOCK_SIZE(_sample_rate, _number_of_channels) \
    (BYTES_PER_SAMPLE * (_sample_rate / 10) * _number_of_channels)
/* Driver will allocate blocks from this slab to receive audio data into them.
 * Application, after getting a given block from the driver and processing its
 * data, needs to free that block.
#define MAX_BLOCK_SIZE   BLOCK_SIZE(SAMPLE_FREQUENCY, 2)
#define BLOCK_COUNT      5
K_MEM_SLAB_DEFINE_STATIC(mem_slab, MAX_BLOCK_SIZE, BLOCK_COUNT, 4);
#ifdef LED0ON
static const struct pwm_dt_spec pwm_led0 = PWM_DT_SPEC_GET(DT_ALIAS(pwm_led0));
#ifdef LED1ON
static const struct pwm_dt_spec pwm_led1 = PWM_DT_SPEC_GET(DT_ALIAS(pwm_led1));
#define MIN_PERIOD PWM_SEC(1U) / 128U
#define MAX_PERIOD PWM_SEC(1U)
// LOG_MODULE_REGISTER(Recording, LOG_LEVEL_DBG);
K_THREAD_STACK_DEFINE(recording_thread_stack, 20000);
static const struct device *mic = DEVICE_DT_GET(I2S_RX_NODE);
static K_SEM_DEFINE(enable_recording, 1, 1);
static bool recording_active=false;
static struct k_thread recording_thread;
static k_tid_t worker_thread_id ;
void mic_worker_thread(void *p1, void *p2, void *p3) ;
int ret;
void recording_init() {
    if (!device_is_ready(mic)) {
        LOG_INF("Microphone device is not supported : %s", mic->name);
        return;
    struct i2s_config config = {
        .word_size= SAMPLE_BIT_WIDTH,
        .channels = NUMBER_OF_CHANNELS,
        .format = I2S_FMT_DATA_FORMAT_I2S,
        .options = I2S_OPT_BIT_CLK_MASTER | I2S_OPT_FRAME_CLK_MASTER,
        .frame_clk_freq = SAMPLE_FREQUENCY, /* Sampling rate */
        .mem_slab = &mem_slab,/* Memory slab to store rx/tx data */
        .block_size = MAX_BLOCK_SIZE,/* size of memory buffer in bytes */
        .timeout = TIMEOUT, /* Number of milliseconds to wait in case Tx queue is full or RX queue is empty, or 0, or SYS_FOREVER_MS */
        //62.3 KHz dso
    int err = i2s_configure(mic, I2S_DIR_RX, &config);
    i2s_trigger(mic, I2S_DIR_RX, I2S_TRIGGER_PREPARE);
    k_sleep(K_MSEC(100));
    if (err < 0) {
        LOG_ERR("Failed to initialize Microphone (%d)", err);
        return;
    k_sem_take(&enable_recording, K_FOREVER);
    LOG_INF("Recording module initialized");
    worker_thread_id = k_thread_create(&recording_thread, recording_thread_stack,
                    K_THREAD_STACK_SIZEOF(recording_thread_stack),
                    mic_worker_thread,
                    NULL, NULL, NULL,
                    4, 0, K_NO_WAIT);
void start_recording() {
    recording_active = true;
    // Initialize file for recording.
    int ret = i2s_trigger(mic, I2S_DIR_RX, I2S_TRIGGER_START);
    if (ret) {
        LOG_ERR("Unable to configure trigger start for I2S bus (%d)", ret);
        return;
    k_sem_give(&enable_recording);
void stop_recording() {
    recording_active = false;
    LOG_INF("Stopping recording");
    int ret = i2s_trigger(mic, I2S_DIR_RX, I2S_TRIGGER_STOP);
    if (ret) {
        LOG_ERR("Unable to stop trigger for I2S bus (%d)", ret);
void mic_worker_thread(void *p1, void *p2, void *p3) {
    LOG_INF("Worker thread started");
    void* rx_buffer;
    size_t bytes_read;
    while (k_sem_take(&enable_recording, K_FOREVER) == 0) {
            bytes_read=0;
            int ret=0;
            if  (k_mem_slab_alloc(&mem_slab, &rx_buffer, K_MSEC(200)) == 0) {
                ret = i2s_read(mic, &rx_buffer, &bytes_read);
                if (ret < 0) {
                    if ( ret != -5) {
                        LOG_INF("Worker thread error (%d)\r\n", ret);
                } else {
                    LOG_INF(" raw rx: %d - Received %d bytes => %d samples ", ((uint32_t *)rx_buffer)[0], bytes_read, bytes_read / sizeof(uint32_t));
                k_mem_slab_free(&mem_slab, &rx_buffer);
    LOG_INF("Worker thread ended");
void main(){
    uint32_t max_period;
    uint32_t period;
    uint8_t dir = 0U;
    int ret;
    // period = (1000000/freq);
    uint32_t period1 = period*64;
  LOG_INF("Starting main thread\n\r");
  recording_init();
  const struct device *mic_ctrl_dev = device_get_binding("GPIO_0");
    gpio_pin_configure(mic_ctrl_dev,MIC_CTRL,GPIO_OUTPUT);
   int pin = gpio_pin_set(mic_ctrl_dev,MIC_CTRL,1);
   LOG_INF("%d", pin);
    #ifdef LED0ON
        if (!device_is_ready(pwm_led0.dev)) {
            LOG_INF("Error: PWM device %s is not ready",
                pwm_led0.dev->name);
            return;
    #ifdef LED1ON
        if (!device_is_ready(pwm_led1.dev)) {
                pwm_led1.dev->name);
            return;
  while(1) {
    #ifdef LED0ON
        LOG_INF("GREEN LED");
        //static inline int pwm_set_dt(const struct pwm_dt_spec *spec, uint32_t period, uint32_t pulse)
        ret = pwm_set_dt(&pwm_led0, period, period / 2U);   //
        if (ret) {
            LOG_INF("Error %d: failed to set pulse width", ret);
            return;
        //k_sleep(K_SECONDS(4U));
        //ret = pwm_set_dt(&pwm_led0, period, 0);
    #ifdef LED1ON
        LOG_INF("BLUE LED");
        ret = pwm_set_dt(&pwm_led1, period1, period1 / 2U);
        if (ret) {
            return;
        //ret = pwm_set_dt(&pwm_led1, period1, 0);
    LOG_INF("Start recording again\r\n");
    start_recording();
    k_sleep(K_MSEC(2000));
    LOG_INF("Stop recording again\r\n");
    stop_recording();
I would like any insight into what I'm missing and how I can get this to work. Thank you for your patience and support.
