4 LEDs to 4 buttons
I made a code from the button sample code from the nrf connect sdk where if each button lights up there corresponding led ex. button 0 turns on led 0.
 * Copyright (c) 2016 Open-RnD Sp. z o.o.
 * Copyright (c) 2020 Nordic Semiconductor ASA
#include <zephyr.h>
#include <device.h>
#include <drivers/gpio.h>
#include <sys/util.h>
#include <sys/printk.h>
#include <inttypes.h>
#define SLEEP_TIME_MS	1
 * Get button configuration from the devicetree sw0 alias. This is mandatory.
#define SW0_NODE DT_ALIAS(sw0)
#define SW1_NODE DT_ALIAS(sw1)
#define SW2_NODE DT_ALIAS(sw2)
#define SW3_NODE DT_ALIAS(sw3)
#define LED0_NODE DT_ALIAS(led0)
#define LED1_NODE DT_ALIAS(led1)
#define LED2_NODE DT_ALIAS(led2)
#define LED3_NODE DT_ALIAS(led3)
#if !DT_NODE_HAS_STATUS(SW0_NODE, okay)
#error "Unsupported board: sw0 devicetree alias is not defined"
static const struct gpio_dt_spec button[] = {
	GPIO_DT_SPEC_GET_OR(SW0_NODE, gpios, {0}),
	GPIO_DT_SPEC_GET_OR(SW1_NODE, gpios, {0}),
	GPIO_DT_SPEC_GET_OR(SW2_NODE, gpios, {0}),
	GPIO_DT_SPEC_GET_OR(SW3_NODE, gpios, {0})
static struct gpio_callback button_cb_data;
 * The led0 devicetree alias is optional. If present, we'll use it
 * to turn on the LED whenever the button is pressed.
static struct gpio_dt_spec led[] = {
	GPIO_DT_SPEC_GET_OR(LED0_NODE, gpios,{0}),
	GPIO_DT_SPEC_GET_OR(LED1_NODE, gpios,{0}),
	GPIO_DT_SPEC_GET_OR(LED2_NODE, gpios,{0}),
	GPIO_DT_SPEC_GET_OR(LED3_NODE, gpios,{0})
void button_pressed(const struct device *dev, struct gpio_callback *cb,
		    uint32_t pins)
	printk("Button pressed at %" PRIu32 "\n", k_cycle_get_32());
void main(void)
	int ret;
	int led_num = ARRAY_SIZE(led);
	int button_num = ARRAY_SIZE(button);
	// printk("here 1\n");
	if (!device_is_ready(button[0].port)) {
		printk("Error: button device %s is not ready\n",
		       button[0].port->name);
		return;
	for (int j=0; j < button_num; j++){
		ret = gpio_pin_configure_dt(&button[j], GPIO_INPUT);
		if (ret != 0) {
		printk("Error %d: failed to configure %s pin %d\n",
		       ret, button[j].port->name, button[j].pin);
		return;
	for (int k=0; k < button_num; k++){
		ret = gpio_pin_interrupt_configure_dt(&button[k], GPIO_INT_EDGE_TO_ACTIVE);
		if (ret != 0) {
		printk("Error %d: failed to configure interrupt on %s pin %d\n",
			ret, button[k].port->name, button[k].pin);
		return;
	for (int l=0; l < button_num; l++){
		gpio_init_callback(&button_cb_data, button_pressed, BIT(button[l].pin));
		gpio_add_callback(button[l].port, &button_cb_data);
		printk("Set up button at %s pin %d\n", button[l].port->name, button[l].pin);
	for (int m=0; m < led_num; m++){
		if (led[m].port && !device_is_ready(led[m].port)) {
			printk("Error %d: LED device %s is not ready; ignoring it\n",
				ret, led[m].port->name);
			led[m].port = NULL;
		if (led[m].port) {
			ret = gpio_pin_configure_dt(&led[m], GPIO_OUTPUT);
			if (ret != 0) {
				printk("Error %d: failed to configure LED device %s pin %d\n",
					ret, led[m].port->name, led[m].pin);
				led[m].port = NULL;
			} else {
				printk("Set up LED at %s pin %d\n", led[m].port->name, led[m].pin);
	printk("Press the button\n");
	if (led[0].port) {
		while (1) {
			for (int n=0; n < led_num; n++){
				/* If we have an LED, match its state to the button's. */
				int val = gpio_pin_get_dt(&button[n]);
				if (val >= 0) {
					gpio_pin_set_dt(&led[n], val);
				k_msleep(SLEEP_TIME_MS);
I'd like to ask if there's a way to improve my code above? Right now, the code "works" but it seems that the button_pressed function print only works when I press button3
button_pressed code below:
		    uint32_t pins)
What made it so far work is replacing the for gpio callback loop in the code:
	gpio_add_callback(button[0].port, &button_cb_data);
	printk("Set up button at %s pin %d\n", button[0].port->name, button[l].pin);
with this:
gpio_init_callback(&button_cb_data_0, button_pressed, BIT(button[0].pin));
gpio_init_callback(&button_cb_data_1, button_pressed, BIT(button[1].pin));
gpio_init_callback(&button_cb_data_2, button_pressed, BIT(button[2].pin));
gpio_init_callback(&button_cb_data_3, button_pressed, BIT(button[3].pin));
gpio_add_callback(button[0].port, &button_cb_data_0);
gpio_add_callback(button[1].port, &button_cb_data_1);
gpio_add_callback(button[2].port, &button_cb_data_2);
gpio_add_callback(button[3].port, &button_cb_data_3);
but this looks like not the proper way to do it. Hoping to hear how to go about this concern.
Board: nrf52840dk
