Serial Monitor and RTT are not working
I am working on custom PCB and have BMD-300 Module (nrf52832). When I am running the code on NRF52832 Eval Kit the serial monitor is working fine but when I am using custom board it do not print any data and some garbage data after some time. Other operations are working fine. I am using SEGGER Jlink v9 (SWIO).
I have also followed another tutorial for RTT with simple Hello World example but it is also not working:
Setting up console over SWD interface
My configurations are mentioned below:
prj.conf:
# Copyright (c) 2019 Nordic Semiconductor ASA
CONFIG_GPIO=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_BT=y
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_MAX_CONN=2
CONFIG_BT_MAX_PAIRED=2
CONFIG_BT_L2CAP_TX_BUF_COUNT=5
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Nordic_HIDS_mouse"
CONFIG_BT_DEVICE_APPEARANCE=962
CONFIG_BT_BAS=y
CONFIG_BT_HIDS=y
CONFIG_BT_HIDS_MAX_CLIENT_COUNT=2
CONFIG_BT_GATT_UUID16_POOL_SIZE=40
CONFIG_BT_GATT_CHRC_POOL_SIZE=20
CONFIG_BT_CONN_CTX=y
CONFIG_BT_DIS=y
CONFIG_BT_DIS_PNP=y
CONFIG_BT_DIS_MANUF="NordicSemiconductor"
CONFIG_BT_DIS_PNP_VID_SRC=2
CONFIG_BT_DIS_PNP_VID=0x1915
CONFIG_BT_DIS_PNP_PID=0xEEEE
CONFIG_BT_DIS_PNP_VER=0x0100
CONFIG_MAIN_STACK_SIZE=1536
CONFIG_DK_LIBRARY=y
CONFIG_NEWLIB_LIBC=y
CONFIG_I2C=y
CONFIG_SENSOR=y
CONFIG_MPU6050_TRIGGER_NONE=y
CONFIG_CBPRINTF_FP_SUPPORT=y
ubx_bmd300eval_nrf52832_defconfig:
CONFIG_SOC_SERIES_NRF52X=y
CONFIG_SOC_NRF52832_QFAA=y
CONFIG_BOARD_UBX_BMD300EVAL_NRF52832=y
# Enable MPU
CONFIG_ARM_MPU=y
# Enable hardware stack protection
CONFIG_HW_STACK_PROTECTION=y
# Enable RTT
CONFIG_USE_SEGGER_RTT=y
# enable GPIO
CONFIG_GPIO=y
# enable uart driver
CONFIG_SERIAL=y
# enable console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
# additional board options
CONFIG_GPIO_AS_PINRESET=y
CONFIG_PINCTRL=y
