Private GATT NOTIFY
I have defined a private GATT Service with several cahractersitics.  I have defined a 128bit UUID::
static struct bt_uuid_128 data_uuid = BT_UUID_INIT_128(
	BT_UUID_128_ENCODE(0xE700AA94, 0xB681, 0xFF0C, 0xAC74, 0x8C4A1EBDA6805));
Then I define the charactersitic:
	BT_GATT_CHARACTERISTIC(&data_uuid.uuid,
		BT_GATT_CHRC_NOTIFY,
		BT_GATT_CHRC_NOTIFY, NULL, NULL, NULL),
	BT_GATT_CCC(data_ccc_cfg_changed, BT_GATT_PERM_READ | BT_GATT_PERM_WRITE),
In my NOTIFY callback:
static void data_ccc_cfg_changed(const struct bt_gatt_attr *attr, uint16_t value)
	privateAttr = attr;
	data_notif_enabled = (value == BT_GATT_CCC_NOTIFY);
	LOG_INF("Log notifications %s", data_notif_enabled ? "enabled" : "disabled");
Then I've defined a notify function where i invoke:
bt_gatt_notify_uuid(NULL, &data_uuid.uuid, privateAttr, &myData, sizeof(myData));
But my NOTIFY characteristic isn't updating.  I have followed the exact same pattern as a I did with a public GATT that works perfectly.
NOTE:
One thing I am not sure of is about how I'm getting the attr parameter from the function call i'm using to notify;
static inline int bt_gatt_notify_uuid(struct bt_conn *conn,
				      const struct bt_uuid *uuid,
				      const void *data, uint16_t len)
	struct bt_gatt_notify_params params;
	memset(&params, 0, sizeof(params));
	params.uuid = uuid;
	params.attr = attr;
	params.data = data;
	params.len = len;
#if defined(CONFIG_BT_EATT)
	params.chan_opt = BT_ATT_CHAN_OPT_NONE;
#endif /* CONFIG_BT_EATT */
	return bt_gatt_notify_cb(conn, &params);
Can anyone please help me. This code has to go out to the custimer tomorrow.
Thanks, Drew
  • Hello Drew,
    Could you share what return value you receive from your call to bt_gatt_notify_uuid?
    Helmut Lord
  • As coded above the bt_gatt_notify_uuid() function returns "-128".  I also receive a LOG_WRN message "Link is not encrypted".
    As A workaround, this is how I've had to define the characteristic:
            BT_GATT_CHRC_NOTIFY | BT_GATT_CHRC_READ,
            BT_GATT_PERM_READ, read_data, NULL, NULL),
    Then I declare a bt_gatt_attr in global scope:
    struct bt_gatt_attr *privateAttr;
    And assign it to the attr passed into the read callback:
    static ssize_t read_data(
        void *buf, uint16_t len, uint16_t offset)
    	privateAttr = attr; // TODO: Acquire attribute
    	uint8_t logData[10];
    	getLogData((uint8_t*)&logData);
        return bt_gatt_attr_read(conn, attr, buf, len, offset, &logData, sizeof(logData));
    And that is used in my bt_gatt_notify_uuid() call:
    uint8_t data_notify(void)
    	//LOG_INF("Data Notification");
    	int err;
    	err = bt_gatt_notify_uuid(NULL, &data_uuid.uuid, privateAttr, &logData, sizeof(logData));
    	if(err) {
    		LOG_DBG("Data Notify Error = %d", err);
    		return err;
    	return 1;
    This works but it is a bit of a hack as our customer only required a NOTIFY property on this characteristic.
    Again, I believe the issue might be in how I am acquiring the "attr" parameter from the bt_gatt_notify_uuid() call.
    Any suggestions would be appreciated.
    -Drew
  • Yes!! This allows me to define an attrs struct:
    static struct bt_gatt_attr svc_attrs[] = {{&data_uuid.uuid}};
    static struct bt_gatt_service logAttrs;
    Then in main:
    logAttrs = (struct bt_gatt_service)BT_GATT_SERVICE(svc_attrs);
    In my notify function:
    err = bt_gatt_notify_uuid(NULL, &data_uuid.uuid, logAttrs.attrs, &logData, sizeof(logData));
    And I'm able to eliminate the write property from my characteristic:
    		BT_GATT_PERM_READ, NULL, NULL, NULL),
    Thank you, Amanda for your guidance. If you see any glaring errors in my implementation above, I welcome your suggestions. Otherwise you may consider this matter solved.
    Drew
