ZephyrRTOS: Interrupts and threads
I have a problem when it comes to implementing interrupts and threads in Zephyr. So from my previous experience with bare metal programming i know what Interrupts are number 1 priority in embedded systems, but somehow it doesn't work in zephyr:
-Here is a code that im struggling with:
I want an application that has 2 threads for blinking diodes and an interrupt button to stop blinking.
So here it how it works:
When the threads are running I can see diodes blinking, and when i click button_2 interrupt I can see printed counter number, but if i press button that is responsible for changing toggler and diode blinking the code sometimes stops, i have to press it like 5-6 times so code starts working again and its not working fluently. In my mind it should work like this:
Diodes blinking
I press the button and diodes stops blinking and i see LogINF that toggler is not parity
but it doesnt work like this it mostly gets  stuck, and i have to press it like ive said above 5-6 times and i see 100 Logs printed immediately and the diode start to blink again.
-How does interrupts affect threads?
-where should i implement interrupts code?- From my POV it shouldnt be inside thread entry function because what if thread 1 that has interrupt is terminated or aborted, the interrupt wont work I guess
#include <zephyr/kernel.h>
#include <zephyr/device.h>
// 2 diody na threadach, button->intterupt set0
#define LED1_NODE DT_NODELABEL(led4)
#define LED2_NODE DT_NODELABEL(led5)
#define BUTTON_NODE DT_NODELABEL(button1)
#define BUTTON_NODE_2 DT_NODELABEL(button2)
#define SLEEP_TIME_MS 1000
#define STACKSIZE 1024
#define PRIORITY 5
#if !DT_NODE_HAS_STATUS(BUTTON_NODE, okay)
#error "Unsupported board: sw0 devicetree alias is not defined"
LOG_MODULE_REGISTER(Fist_Exercise,LOG_LEVEL_DBG);
K_TIMER_DEFINE(debounce_timer, NULL, NULL);
K_THREAD_STACK_DEFINE(thread_led1_stack,STACKSIZE);
K_THREAD_STACK_DEFINE(thread_led2_stack,STACKSIZE);
int toggler;
int counter=0;
static struct k_thread thread_led1;
static struct k_thread thread_led2;
static const struct gpio_dt_spec button = GPIO_DT_SPEC_GET_OR(BUTTON_NODE,gpios,{0});
static struct gpio_callback button_cb_data;
static const struct gpio_dt_spec button_2 = GPIO_DT_SPEC_GET_OR(BUTTON_NODE_2,gpios,{0});
static struct gpio_callback button_cb_data_2;
struct led {
struct gpio_dt_spec spec;
static const struct led led0 ={
.spec = GPIO_DT_SPEC_GET(LED1_NODE, gpios),
static const struct led led1 ={
.spec = GPIO_DT_SPEC_GET(LED2_NODE, gpios),
void button_pressed(const struct device *dev, struct gpio_callback*cb){
if (k_timer_status_get(&debounce_timer) > 0) {
// Timer is running, this means a button press was recently handled
// Ignore the new button press
return;
toggler++;
LOG_INF("Toggler count %d \n", toggler);
k_timer_start(&debounce_timer, K_MSEC(100), K_NO_WAIT); //
void button_pressed_2(const struct device *dev, struct gpio_callback*cb){
LOG_INF("Counter %d \n",counter);
counter++;
void blink( const struct led *led, int sleep){
if (!device_is_ready(button.port)) {
printk("Error: button device %s is not ready\n",
button.port->name);
return;
const struct gpio_dt_spec *spec = &led->spec;
gpio_pin_configure_dt(spec, GPIO_OUTPUT);
while(1){
if(toggler%2==0){
gpio_pin_toggle(spec->port, spec->pin);
k_msleep(sleep);
else{
LOG_INF("TOGGLER IS NOR PARITY\n");
void blink0(void){
blink(&led0, SLEEP_TIME_MS);
void blink1(void){
blink(&led1, SLEEP_TIME_MS);
void main(void){
gpio_pin_configure_dt(&button, GPIO_INPUT);
gpio_pin_interrupt_configure_dt(&button,
GPIO_INT_EDGE_RISING);
gpio_init_callback(&button_cb_data, button_pressed,BIT(button.pin));
gpio_add_callback(button.port, &button_cb_data);
gpio_pin_configure_dt(&button_2, GPIO_INPUT);
gpio_pin_interrupt_configure_dt(&button_2,
gpio_init_callback(&button_cb_data_2, button_pressed_2,BIT(button_2.pin));
gpio_add_callback(button_2.port, &button_cb_data_2);
k_timer_init(&debounce_timer, NULL, NULL);
k_thread_create(&thread_led1, thread_led1_stack,
K_THREAD_STACK_SIZEOF(thread_led1_stack),
blink0, NULL, NULL, NULL,
PRIORITY, 0, K_FOREVER);
k_thread_name_set(&thread_led1, "thread_led1");
k_thread_create(&thread_led2, thread_led2_stack,
K_THREAD_STACK_SIZEOF(thread_led2_stack),
blink1, NULL, NULL, NULL,
k_thread_start(&thread_led1);
// k_thread_start(&thread_led2);
