nRF5340 power management
Hi Support team,
We plan to develop an IoT device with nRF5340 and the power consumption management is a key feature for us. I just verified some functionalities with nRF5340 DK.
Our requeirements are:
(1) The network core only wakes up once a week to report data (most time it is in Force-OFF mode). When it sleeps, all of its peripherals will be in low-energy mode.
(2) Application core works in the RUN state of System-on mode collects data from sensors per minute, and then goes into IDLE state. When it goes into IDLE, all of its peripherals will be in low-energy mode.
My questions are:
1. For the power management of peripherals, which peripherals of the application core and network core can be controlled separately?
2. Should I use API pm_device_action_run() in \external\zephyr\subsys\pm\device.c to conntrol peripherals power mode?
3. Could you provide a sample to force/release the network core to Force-OFF mode?
4. Is it possible to control the peripherals of both application and network cores from the application core?
Thank you very much!
Yanpeng Wu
    All peripherals can be controlled separately, though they use some of the same resources (like clocks and regulators). In a low power application you typically suspend peripherals whenever they are not in use.
    Yes. Peripherals that are handled by the stack like the Radio, or the TIMER used by the stack, etc will be automatically handled. But other peripherals that you use (say UART, TWI or similar), you will have to suspend when no longer needed and resume when needed again i order to reduce power usage.
    Is force off a real requirement (if so why?) or is it enough for it to be in system on sleep mode? The latter is the approach used by our SDK, and that will also result in a very low sleep current (essentially the net core can sleep for the entire time when Bluetooth or other network protocols are not needed). You can refer to the implementation of nrf_reset_network_force_off() to see how to force the network core off (the first register write, the later part release it again). But there are no examples of it being kept off, and it will cause inter process communication to get out of sync. (You can refer to theIPC Service - icmsg sample for a lower-level example which demonstrates resetting the network core and continuing IPC communication).
  • Hi Einar,
    Thank you for the detailed reply.
    In our application, the network core only wakes up once a week to read data from flash memory and report it with LTE. In our initial idea maybe the Force-OFF is a solution, but as you mentioned the IPC will be out of sync after the Force-OFF also needs to be considered, thanks for reminding of this.
    As you mentioned, the typical approach used by NCS is to let the network-core in sleep mode. Is there a sample for this? I want to try to set the network core in sleep mode and wake it from applicaiton-core side. Thank you very much.
    1. CAF is a framwork that is used by the Applications under nrf, and may or may not be usefull also for other applications. It does not replace Zephyr functionality (including power management), but is rather at a somewhat different layer. The CAF power management is more on the device level. Depending on your application, it could be better and simpler to avoid using CAF as you need to have a high-level approach that fit your specific product.
    2. In the complete PM strategy, you need to ensure that peripherals and other resources are in idle/low power mode or disabled when ever not needed. This is highly application dependent, and I recommend that you manage this yourself (utilizing the Zephyr power management API's).
    3. The nRF Desktop reference design is power optimized using CAF (and is what this module was designed for). For using the power management API's you can find different examples, often by searching in the code for "pm_device_action_run".
    A key point here is that the Zephyr power management API is quite powerful even though it is simpe. For instance, you can configure pin states for active and sleep states in the Device tree like in this example:
    	uart1_default: uart1_default {
    		group1 {
    			psels = <NRF_PSEL(UART_TX, 2, 4)>,
    				<NRF_PSEL(UART_RTS, 2, 0)>;
    		group2 {
    			psels = <NRF_PSEL(UART_RX, 2, 5)>,
    				<NRF_PSEL(UART_CTS, 2, 6)>;
    			bias-pull-up;
    	uart1_sleep: uart1_sleep {
    		group1 {
    				<NRF_PSEL(UART_RTS, 2, 0)>,
    			low-power-enable;
    So when pm_device_action_run() is called with PM_DEVICE_ACTION_SUSPEND, not only is the UART peripheral stopped, but the pins are also re-configured (as disconnected inputs with no pull in this case, to minimize leakage). And when you call pm_device_action_run() with PM_DEVICE_ACTION_RESUME, the pins are reconfigured and UART re-enabled).
  • Hi Einar,
    Thanks for the comprehensive explanation, which helped me a lot get out of the confusion of the CAF power manager and Zephyr PM:).
    In my understanding, the main advantage of CAF power manager module is it can use the 'Application Event Manager' and be event-driven, thus it can easily interact with other modules. Mainly it is designed for the 'nRF Desktop Human Interface Device (HID) application', is it right?
    For my application, I agree with your opinion that we need to manage the power by ourselves. In my current understanding, in our application the PM on the application core also should include two parts: system level and device level.
    1 From the information you provided, I can know pm_device_action_run() can be used for device-level PM to suspend/resume the UART/SPI/I2C devices.
    2 Besides this, which APIs should I use for system-level to put the application core into the lower power mode?
  • A little addition:
    Can I call pm_system_suspend(int32_t ticks) and pm_system_resume(void) in \zephyr\subsys\pm\pm.c for hold/release application core system to lower energy mode? To use these two APIs, what kconfig option should I set to 'y'?
    I tried 'CONFIG_PM_CPU_OPS=y', but compile failed with error 'undefined reference to `pm_system_suspend''.
    Your understanding about the CAF power management module is correct.
    No. The idle thread will enter system ON idle (CPU sleep with WFE) so you don't need to do anything explicitly to make the system itself low power, other than stopping peripherals etc when not needed. Regarding pm_system_suspend() that is not a function you should call, but it is called by the kernel to inform listeners if enabled by CONFIG_PM. You can read more about the Zephyr power management system here.
  • Hi Einar,
    Thank you for your detailed explanation, which helped me create an understanding of power management on Zephyr and NCS.
    Thank you so much.
    Yanpeng Wu
