Moving from NRF5340 DK to custom board
We are moving from the 5340DK to our custom board. I have noticed one concerning difference between how the code behaves on the development board versus our own board in that k_msleep seems wildly wrong, with a 5ms delay on the the dev board (the correct behavior) taking ~ 30 milliseconds on our board.
The uart is operating with the correct baud rate, which would suggest the problem isnt simply the wrong crystal or some other hardware-level fault.
I am thinking this is a configuration issue; I notice the following schematic differences between the dev and our board:
  1. QKAA vs CLAA for the NRF package
  2. Dev board has both 32.7K and 32MHz oscillators, we only have the 32mhz
  3. Dev board has internal capacitors on the external 32M oscillator, we are using external caps
I can share the schematic if you think that would help. At this juncture I am fairly confident the hardware is working correctly, and that the problem is somehow firmware/configuration related. Do you have any suggestions?
Thank you for your help
  • I take it you mean dev board has both crystals. Also assuming usage of softdevice.
    The 32768Hz RC has to be periodically tuned by the 32M oscillator and maybe it's adding a little overhead or wakeups etc.
    What nRF Connect SDK version are you using and can you share you project config file?
    What is the internal load capacitance of the external crystal and what is the size of the parallel load capacitors that you load it with?
    Could you also share the .config file that is generated in the build folder?
    regards
    Jared
    Thank you for your answer; you are correct that the dev board has both Xtals is what I meant, and yes we are using zephyr.
    While I wouldnt mind a little overhead, right now delays are six times longer than I would expect, and this is a little too much. Also delays seem to _always_ be six times too long; 1 ms takes 6, 10 ms takes 60, etc. That is not the behavior I would expect if the problem were overhead-related.
  • Hello, and thank you for your reply. I am using SDK 2.5.0.
    The external capacitors are 10pF, while per the datasheet the internal shunt capacitance in the crystal is 2pF. Here is the datasheet if you need it: https://ecsxtal.com/store/pdf/ECX-1048.pdf
    Here is my prj.config file:
    CONFIG_GPIO=y
    CONFIG_PINCTRL=y
    CONFIG_SERIAL=y
    CONFIG_SOC_HFXO_CAP_EXTERNAL=y
    CONFIG_SOC_HFXO_CAP_INTERNAL=n
    CONFIG_SOC_ENABLE_LFXO=n
    CONFIG_I2C=y
    Finally, as requested, here is the .config file from the build folder:
    # CONFIG_INPUT is not set
    # CONFIG_WIFI is not set
    # CONFIG_LV_COLOR_16_SWAP is not set
    CONFIG_LV_DPI_DEF=130
    # CONFIG_MIPI_DSI is not set
    # CONFIG_MODEM is not set
    # CONFIG_UART_INTERRUPT_DRIVEN is not set
    # CONFIG_SPI is not set
    CONFIG_BOARD="nrf5340dk_nrf5340_cpuapp"
    CONFIG_BUILD_WITH_TFM=y
    CONFIG_TFM_FLASH_MERGED_BINARY=y
    CONFIG_FLASH_LOAD_SIZE=0x30000
    CONFIG_SRAM_SIZE=192
    CONFIG_FLASH_LOAD_OFFSET=0x50000
    CONFIG_HEAP_MEM_POOL_SIZE=0
    CONFIG_NUM_IRQS=69
    CONFIG_SOC_SERIES="nrf53"
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_SOC="nRF5340_CPUAPP_QKAA"
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_DCACHE_LINE_SIZE=32
    CONFIG_ROM_START_OFFSET=0
    CONFIG_PINCTRL=y
    CONFIG_CLOCK_CONTROL=y
    # CONFIG_WATCHDOG is not set
    # CONFIG_RESET is not set
    CONFIG_GPIO=y
    CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    # CONFIG_PM_DEVICE is not set
    CONFIG_NRF_RTC_TIMER=y
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_BUILD_OUTPUT_HEX=y
    CONFIG_SERIAL_INIT_PRIORITY=55
    # CONFIG_FPU is not set
    # CONFIG_MBEDTLS is not set
    # CONFIG_MEMC is not set
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    # CONFIG_TINYCRYPT is not set
    CONFIG_SERIAL=y
    CONFIG_MAIN_STACK_SIZE=1024
    # CONFIG_SRAM_VECTOR_TABLE is not set
    # CONFIG_USE_DT_CODE_PARTITION is not set
    CONFIG_PLATFORM_SPECIFIC_INIT=y
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_BUILD_OUTPUT_BIN=y
    CONFIG_MP_MAX_NUM_CPUS=1
    CONFIG_HAS_DTS=y
    # Devicetree Info
    CONFIG_DT_HAS_ARDUINO_UNO_ADC_ENABLED=y
    CONFIG_DT_HAS_ARDUINO_HEADER_R3_ENABLED=y
    CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
    CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
    CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CTRLAPPERI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DCNF_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_FORWARDER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_MUTEX_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_NFCT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_OSCILLATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_REGULATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RESET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBREG_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_PSA_CRYPTO_RNG_ENABLED=y
    # end of Devicetree Info
    # Modules
    # Available modules.
    # nrf (C:/ncs/v2.5.0/nrf)
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
    # CONFIG_INIT_STACKS is not set
    # CONFIG_MBEDTLS_CIPHER_MODE_CBC is not set
    # CONFIG_MBEDTLS_CIPHER_MODE_CTR is not set
    CONFIG_MBEDTLS_CIPHER_MODE_CFB=y
    CONFIG_MBEDTLS_CIPHER_MODE_OFB=y
    # CONFIG_MBEDTLS_CHACHA20_C is not set
    # CONFIG_MBEDTLS_POLY1305_C is not set
    # CONFIG_MBEDTLS_DHM_C is not set
    # CONFIG_MBEDTLS_RSA_C is not set
    CONFIG_MBEDTLS_SHA512_C=y
    # CONFIG_MBEDTLS_GCM_C is not set
    # CONFIG_MBEDTLS_CIPHER_MODE_XTS is not set
    # CONFIG_MBEDTLS_SHA1_C is not set
    # CONFIG_MBEDTLS_TLS_VERSION_1_2 is not set
    # CONFIG_MBEDTLS_MAC_SHA256_ENABLED is not set
    # CONFIG_MBEDTLS_CTR_DRBG_ENABLED is not set
    CONFIG_MBEDTLS_MD_C=y
    # CONFIG_MBEDTLS_TLS_LIBRARY is not set
    # CONFIG_MBEDTLS_X509_LIBRARY is not set
    # CONFIG_MBEDTLS_ENABLE_HEAP is not set
    # CONFIG_MBEDTLS_ECP_C is not set
    # CONFIG_MBEDTLS_CTR_DRBG_C is not set
    # CONFIG_MBEDTLS_CMAC_C is not set
    # CONFIG_MBEDTLS_CCM_C is not set
    CONFIG_MBEDTLS_LEGACY_CRYPTO_C=y
    CONFIG_TFM_MCUBOOT_IMAGE_NUMBER=1
    CONFIG_TFM_CRYPTO_RNG_MODULE_ENABLED=y
    CONFIG_TFM_PARTITION_CRYPTO=y
    CONFIG_TFM_PARTITION_PLATFORM=y
    # Nordic nRF Connect
    CONFIG_BOOT_BANNER_STRING="Booting nRF Connect SDK"
    CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=y
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    CONFIG_BT_BUF_CMD_TX_COUNT=10
    CONFIG_ENTROPY_GENERATOR=y
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # CONFIG_GETOPT is not set
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # CONFIG_NRF700X_RADIO_TEST_COMBO is not set
    # Image build variants
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # end of Image build variants
    # Bootloader
    # CONFIG_BUILD_S1_VARIANT is not set
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    # CONFIG_SECURE_BOOT_CRYPTO is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # end of Bootloader
    # Bluetooth Low Energy
    # BLE over nRF RPC
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    # CONFIG_ESB is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # nRF Cloud
    # Client ID (nRF Cloud Device ID)
    CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
    CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
    # end of Client ID (nRF Cloud Device ID)
    # CONFIG_NRF_CLOUD_MQTT is not set
    # CONFIG_NRF_CLOUD_FOTA is not set
    # CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
    # CONFIG_NRF_CLOUD_REST is not set
    # CONFIG_NRF_CLOUD_ALERT is not set
    CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
    CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
    # CONFIG_NRF_CLOUD_COAP is not set
    # CONFIG_NRF_CLOUD_GATEWAY is not set
    # end of nRF Cloud
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # CONFIG_WIFI_CREDENTIALS is not set
    # CONFIG_WIFI_CREDENTIALS_STATIC is not set
    # CONFIG_MQTT_HELPER is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
    # end of Application protocols
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # Trusted Execution Non-Secure
    # Peripheral Secure mapping
    # CONFIG_NRF_FPU_SECURE is not set
    # CONFIG_NRF_DCNF_SECURE is not set
    # CONFIG_NRF_OSCILLATORS_SECURE is not set
    # CONFIG_NRF_REGULATORS_SECURE is not set
    # CONFIG_NRF_CLOCK_SECURE is not set
    # CONFIG_NRF_POWER_SECURE is not set
    # CONFIG_NRF_RESET_SECURE is not set
    # CONFIG_NRF_CTRLAP_SECURE is not set
    # CONFIG_NRF_SPIM0_SECURE is not set
    # CONFIG_NRF_TWIM0_SECURE is not set
    # CONFIG_NRF_UARTE0_SECURE is not set
    # CONFIG_NRF_SPIM1_SECURE is not set
    # CONFIG_NRF_TWIM1_SECURE is not set
    # CONFIG_NRF_UARTE1_SECURE is not set
    # CONFIG_NRF_SPIM4_SECURE is not set
    # CONFIG_NRF_SPIM2_SECURE is not set
    # CONFIG_NRF_TWIM2_SECURE is not set
    # CONFIG_NRF_UARTE2_SECURE is not set
    # CONFIG_NRF_SPIM3_SECURE is not set
    # CONFIG_NRF_TWIM3_SECURE is not set
    # CONFIG_NRF_UARTE3_SECURE is not set
    # CONFIG_NRF_SAADC_SECURE is not set
    # CONFIG_NRF_TIMER0_SECURE is not set
    # CONFIG_NRF_TIMER1_SECURE is not set
    # CONFIG_NRF_TIMER2_SECURE is not set
    # CONFIG_NRF_RTC0_SECURE is not set
    # CONFIG_NRF_RTC1_SECURE is not set
    # CONFIG_NRF_DPPI_SECURE is not set
    # CONFIG_NRF_WDT0_SECURE is not set
    # CONFIG_NRF_WDT1_SECURE is not set
    # CONFIG_NRF_COMP_SECURE is not set
    # CONFIG_NRF_EGU0_SECURE is not set
    # CONFIG_NRF_EGU1_SECURE is not set
    # CONFIG_NRF_EGU2_SECURE is not set
    # CONFIG_NRF_EGU3_SECURE is not set
    # CONFIG_NRF_EGU4_SECURE is not set
    # CONFIG_NRF_EGU5_SECURE is not set
    # CONFIG_NRF_PWM0_SECURE is not set
    # CONFIG_NRF_PWM1_SECURE is not set
    # CONFIG_NRF_PWM2_SECURE is not set
    # CONFIG_NRF_PWM3_SECURE is not set
    # CONFIG_NRF_PDM_SECURE is not set
    # CONFIG_NRF_I2S_SECURE is not set
    # CONFIG_NRF_IPC_SECURE is not set
    # CONFIG_NRF_QSPI_SECURE is not set
    # CONFIG_NRF_NFCT_SECURE is not set
    # CONFIG_NRF_MUTEX_SECURE is not set
    # CONFIG_NRF_QDEC0_SECURE is not set
    # CONFIG_NRF_QDEC1_SECURE is not set
    # CONFIG_NRF_USBD_SECURE is not set
    # CONFIG_NRF_USBREG_SECURE is not set
    # CONFIG_NRF_NVMC_SECURE is not set
    # CONFIG_NRF_GPIO0_SECURE is not set
    # CONFIG_NRF_GPIO1_SECURE is not set
    # CONFIG_NRF_VMC_SECURE is not set
    # CONFIG_NRF_GPIOTE0_SECURE is not set
    CONFIG_NRF_GPIO0_PIN_MASK_SECURE=0x00000000
    CONFIG_NRF_GPIO1_PIN_MASK_SECURE=0x00000000
    CONFIG_NRF_DPPI_CHANNEL_MASK_SECURE=0x00000000
    # end of Peripheral Secure mapping
    # end of Trusted Execution Non-Secure
    # CONFIG_NRF_PROFILER is not set
    # CONFIG_FW_INFO is not set
    # CONFIG_FW_INFO_API is not set
    # Debug
    # CONFIG_CPU_LOAD is not set
    # CONFIG_PPI_TRACE is not set
    # end of Debug
    # CONFIG_MPSL_FEM_ONLY is not set
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    CONFIG_MPSL_THREAD_COOP_PRIO=8
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    # Partition Manager
    CONFIG_PARTITION_MANAGER_ENABLED=y
    CONFIG_FLASH_MAP_CUSTOM=y
    CONFIG_SRAM_BASE_ADDRESS=0x20040000
    # Zephyr subsystem configurations
    CONFIG_RPMSG_NRF53_SRAM_SIZE=0x10000
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    CONFIG_PM_SINGLE_IMAGE=y
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_PATH=""
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
    # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x80000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # CONFIG_ZIGBEE is not set
    # Full Modem Firmware Update Management(FMFU)
    # end of Full Modem Firmware Update Management(FMFU)
    # CONFIG_CAF is not set
    # Nordic IEEE 802.15.4
    # end of Nordic IEEE 802.15.4
    # CONFIG_DM_MODULE is not set
    # nRF Security
    CONFIG_NORDIC_SECURITY_BACKEND=y
    CONFIG_NRF_SECURITY=y
    CONFIG_MBEDTLS_CFG_FILE="nrf-config.h"
    CONFIG_MBEDTLS_USER_CONFIG_FILE="nrf-config-user.h"
    CONFIG_GENERATE_MBEDTLS_CFG_FILE=y
    CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    # PSA RNG support
    CONFIG_PSA_WANT_GENERATE_RANDOM=y
    CONFIG_PSA_WANT_ALG_CTR_DRBG=y
    # CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
    # end of PSA RNG support
    # PSA key type support
    # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_AES is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_PUBLIC_KEY is not set
    # end of PSA key type support
    # PSA AEAD support
    # CONFIG_PSA_WANT_ALG_CCM is not set
    # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
    # CONFIG_PSA_WANT_ALG_GCM is not set
    # CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
    # end of PSA AEAD support
    # PSA MAC support
    # CONFIG_PSA_WANT_ALG_CMAC is not set
    # CONFIG_PSA_WANT_ALG_HMAC is not set
    # end of PSA MAC support
    # PSA Hash support
    # CONFIG_PSA_WANT_ALG_SHA_1 is not set
    # CONFIG_PSA_WANT_ALG_SHA_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512 is not set
    # CONFIG_PSA_WANT_ALG_RIPEMD160 is not set
    # CONFIG_PSA_WANT_ALG_MD5 is not set
    # end of PSA Hash support
    # PSA Cipher support
    # CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
    # CONFIG_PSA_WANT_ALG_CFB is not set
    # CONFIG_PSA_WANT_ALG_CTR is not set
    # CONFIG_PSA_WANT_ALG_OFB is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    # CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
    # end of PSA Cipher support
    # PSA Key derivation support
    # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
    # CONFIG_PSA_WANT_ALG_TLS12_PRF is not set
    # CONFIG_PSA_WANT_ALG_TLS12_PSK_TO_MS is not set
    # CONFIG_PSA_WANT_ALG_TLS12_ECJPAKE_TO_PMS is not set
    # end of PSA Key derivation support
    # PSA Asymmetric support
    # CONFIG_PSA_WANT_ALG_ECDH is not set
    # CONFIG_PSA_WANT_ALG_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS is not set
    # end of PSA Asymmetric support
    # CONFIG_PSA_WANT_ALG_JPAKE is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P is not set
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    CONFIG_MBEDTLS_PSA_CRYPTO_EXTERNAL_RNG=y
    CONFIG_PSA_CORE_OBERON=y
    # PSA Driver Support
    CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS=y
    CONFIG_PSA_DEFAULT_OFF=y
    CONFIG_PSA_CRYPTO_ACCELERATOR_DRIVER_PRESENT=y
    CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT=y
    CONFIG_PSA_CRYPTO_DRIVER_OBERON=y
    # CONFIG_PSA_CRYPTO_DRIVER_CC3XX is not set
    # Choose DRBG algorithm
    CONFIG_PSA_USE_CTR_DRBG_DRIVER=y
    # end of Choose DRBG algorithm
    # CryptoCell PSA Driver Configuration
    CONFIG_PSA_USE_CC3XX_CTR_DRBG_DRIVER=y
    # end of CryptoCell PSA Driver Configuration
    # AES key size configuration
    CONFIG_PSA_WANT_AES_KEY_SIZE_128=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_192=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_256=y
    # end of AES key size configuration
    # RSA key size configuration
    CONFIG_PSA_WANT_RSA_KEY_SIZE_1024=y
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_1536 is not set
    CONFIG_PSA_WANT_RSA_KEY_SIZE_2048=y
    CONFIG_PSA_WANT_RSA_KEY_SIZE_3072=y
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_4096 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_6144 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_8192 is not set
    CONFIG_PSA_MAX_RSA_KEY_BITS=3072
    # end of RSA key size configuration
    CONFIG_PSA_ACCEL_RANDOM=y
    CONFIG_PSA_NEED_CC3XX_CTR_DRBG_DRIVER=y
    # PSA API support
    CONFIG_MBEDTLS_USE_PSA_CRYPTO=y
    # end of PSA API support
    CONFIG_MBEDTLS_PLATFORM_MEMORY=y
    CONFIG_MBEDTLS_PLATFORM_C=y
    CONFIG_MBEDTLS_MEMORY_C=y
    CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C=y
    CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT=y
    CONFIG_MBEDTLS_AES_SETKEY_ENC_ALT=y
    CONFIG_MBEDTLS_AES_SETKEY_DEC_ALT=y
    CONFIG_MBEDTLS_AES_ENCRYPT_ALT=y
    CONFIG_MBEDTLS_AES_DECRYPT_ALT=y
    CONFIG_MBEDTLS_CHACHA20_ALT=y
    CONFIG_MBEDTLS_POLY1305_ALT=y
    CONFIG_MBEDTLS_ECDH_GEN_PUBLIC_ALT=y
    CONFIG_MBEDTLS_ECDH_COMPUTE_SHARED_ALT=y
    CONFIG_MBEDTLS_ECDSA_GENKEY_ALT=y
    CONFIG_MBEDTLS_ECDSA_SIGN_ALT=y
    CONFIG_MBEDTLS_ECDSA_VERIFY_ALT=y
    CONFIG_MBEDTLS_ECJPAKE_ALT=y
    CONFIG_MBEDTLS_SHA1_ALT=y
    CONFIG_MBEDTLS_SHA224_ALT=y
    CONFIG_MBEDTLS_SHA256_ALT=y
    CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256=y
    CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES=1
    CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY=y
    # CONFIG_NRF_SECURITY_ADVANCED is not set
    CONFIG_OBERON_ONLY_PSA_ENABLED=y
    CONFIG_OBERON_ONLY_ENABLED=y
    # Legacy mbed TLS crypto APIs
    CONFIG_MBEDTLS_MPI_WINDOW_SIZE=6
    CONFIG_MBEDTLS_MPI_MAX_SIZE=256
    # CONFIG_CC3XX_BACKEND is not set
    CONFIG_OBERON_BACKEND=y
    CONFIG_MBEDTLS_HMAC_DRBG_C=y
    CONFIG_MBEDTLS_AES_C=y
    # Cipher Selection
    # AEAD  - Authenticated Encryption with Associated Data
    # end of AEAD  - Authenticated Encryption with Associated Data
    CONFIG_MBEDTLS_HKDF_C=y
    # SHA - Secure Hash Algorithm
    CONFIG_MBEDTLS_SHA224_C=y
    CONFIG_MBEDTLS_SHA256_C=y
    CONFIG_MBEDTLS_SHA384_C=y
    # end of SHA - Secure Hash Algorithm
    CONFIG_MBEDTLS_CIPHER_C=y
    # CONFIG_MBEDTLS_PK_C is not set
    CONFIG_MBEDTLS_PKCS5_C=y
    # CONFIG_MBEDTLS_PK_WRITE_C is not set
    # CONFIG_MBEDTLS_PK_PARSE_C is not set
    # end of Legacy mbed TLS crypto APIs
    # Zephyr legacy configurations
    # CONFIG_MBEDTLS_KEY_EXCHANGE_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_KEY_EXCHANGE_SOME_PSK_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_CIPHER_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_MAC_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_MAC_MD5_ENABLED is not set
    # CONFIG_MBEDTLS_HMAC_DRBG_ENABLED is not set
    # CONFIG_MBEDTLS_CIPHER is not set
    # CONFIG_MBEDTLS_MD is not set
    # CONFIG_MBEDTLS_ENTROPY_ENABLED is not set
    # CONFIG_MBEDTLS_GENPRIME_ENABLED is not set
    # end of Zephyr legacy configurations
    # end of nRF Security
    # CONFIG_NET_CORE_MONITOR is not set
    CONFIG_TFM_BOARD="C:/ncs/v2.5.0/nrf/modules/tfm/tfm/boards/nrf5340_cpuapp"
    # Platform partition component configs
    CONFIG_TFM_PLATFORM_SERVICE_INPUT_BUFFER_SIZE=64
    CONFIG_TFM_PLATFORM_SERVICE_OUTPUT_BUFFER_SIZE=64
    CONFIG_TFM_PLATFORM_SP_STACK_SIZE=0x500
    CONFIG_TFM_PLATFORM_NV_COUNTER_MODULE_DISABLED=y
    # end of Platform partition component configs
    # Crypto component configs
    # CONFIG_TFM_CRYPTO_SINGLE_PART_FUNCS_DISABLED is not set
    # end of Crypto component configs
    # CONFIG_TFM_ITS_MAX_ASSET_SIZE_OVERRIDE is not set
    # TF-M SPM component configs
    CONFIG_TFM_CONN_HANDLE_MAX_NUM=8
    # CONFIG_TFM_DOORBELL_API is not set
    # end of TF-M SPM component configs
    # CONFIG_WPA_SUPP is not set
    CONFIG_POSIX_MAX_FDS=4
    # Libraries
    # Binary libraries
    # CONFIG_BT_LL_ACS_NRF53 is not set
    # Log levels
    # end of Log levels
    # end of Binary libraries
    # CONFIG_ADP536X is not set
    # CONFIG_AT_MONITOR is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x4000
    CONFIG_FPROTECT_BLOCK_SIZE=0x4000
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_AT_CMD_PARSER is not set
    # CONFIG_MODEM_INFO is not set
    CONFIG_RESET_ON_FATAL_ERROR=y
    # CONFIG_SMS is not set
    # CONFIG_SUPL_CLIENT_LIB is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
    # CONFIG_MODEM_JWT is not set
    # CONFIG_LOCATION is not set
    # CONFIG_QOS is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # CONFIG_FEM_AL_LIB is not set
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    # CONFIG_ETH_RTT is not set
    # CONFIG_SENSOR is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # Test
    CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (C:/ncs/v2.5.0/nrf)
    # wfa-qt-control-app (C:/ncs/v2.5.0/modules/lib/wfa-qt-control-app)
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=4096
    CONFIG_ZEPHYR_WFA_QT_CONTROL_APP_MODULE=y
    # end of wfa-qt-control-app (C:/ncs/v2.5.0/modules/lib/wfa-qt-control-app)
    # mcuboot (C:/ncs/v2.5.0/bootloader/mcuboot)
    # MCUboot
    CONFIG_BOOT_SIGNATURE_KEY_FILE=""
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_MCUBOOT_USB_SUPPORT=y
    # CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (C:/ncs/v2.5.0/bootloader/mcuboot)
    # mbedtls (C:/ncs/v2.5.0/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    # CONFIG_MBEDTLS_BUILTIN is not set
    # CONFIG_MBEDTLS_LIBRARY is not set
    # PSA RNG support
    # PSA AEAD support
    # PSA MAC support
    # PSA Hash support
    # end of mbedtls (C:/ncs/v2.5.0/modules/crypto/mbedtls)
    # trusted-firmware-m (C:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_TFM_ISOLATION_LEVEL=1
    # CONFIG_TFM_BL2 is not set
    # CONFIG_TFM_REGRESSION_NS is not set
    # CONFIG_TFM_SECURE_UART is not set
    # TF-M UART pins
    CONFIG_TFM_UART0_TXD_PIN=20
    CONFIG_TFM_UART0_RXD_PIN=22
    CONFIG_TFM_UART0_RTS_PIN=19
    CONFIG_TFM_UART0_CTS_PIN=21
    # CONFIG_TFM_UART0_HWFC_ENABLED is not set
    # CONFIG_TFM_UART1_HWFC_ENABLED is not set
    # end of TF-M UART pins
    CONFIG_TFM_PROFILE_TYPE_MINIMAL=y
    CONFIG_TFM_QCBOR_PATH="C:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/../qcbor"
    CONFIG_TFM_CRYPTO_ENGINE_BUF_SIZE=1
    CONFIG_TFM_CRYPTO_CONC_OPER_NUM=1
    CONFIG_TFM_CRYPTO_IOVEC_BUFFER_SIZE=1024
    CONFIG_TFM_CRYPTO_PARTITION_STACK_SIZE=0x800
    # CONFIG_TFM_ITS_ENCRYPTED is not set
    # CONFIG_TFM_HW_INIT_RESET_ON_BOOT is not set
    # CONFIG_TFM_HALT_ON_CORE_PANIC is not set
    CONFIG_TFM_ALLOW_NON_SECURE_RESET=y
    CONFIG_TFM_S_CODE_VECTOR_TABLE_SIZE=0x154
    # CONFIG_BOOTLOADER_MCUBOOT is not set
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    CONFIG_TFM_KEY_FILE_S="C:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/bl2/ext/mcuboot/root-RSA-3072.pem"
    CONFIG_TFM_KEY_FILE_NS="C:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/bl2/ext/mcuboot/root-RSA-3072_1.pem"
    # CONFIG_TFM_PROFILE_TYPE_NOT_SET is not set
    # CONFIG_TFM_PROFILE_TYPE_SMALL is not set
    # CONFIG_TFM_PROFILE_TYPE_MEDIUM is not set
    # CONFIG_TFM_PROFILE_TYPE_LARGE is not set
    # CONFIG_TFM_CMAKE_BUILD_TYPE_RELEASE is not set
    # CONFIG_TFM_CMAKE_BUILD_TYPE_RELWITHDEBINFO is not set
    CONFIG_TFM_CMAKE_BUILD_TYPE_MINSIZEREL=y
    # CONFIG_TFM_CMAKE_BUILD_TYPE_DEBUG is not set
    # CONFIG_TFM_ITS_NUM_ASSETS_OVERRIDE is not set
    CONFIG_TFM_PARTITION_PLATFORM_CUSTOM_REBOOT=y
    CONFIG_TFM_IMAGE_VERSION_S="0.0.0+0"
    CONFIG_TFM_IMAGE_VERSION_NS="0.0.0+0"
    # CONFIG_TFM_BUILD_NS is not set
    # CONFIG_TFM_CONNECTION_BASED_SERVICE_API is not set
    CONFIG_TFM_IPC=y
    # CONFIG_TFM_SFN is not set
    # CONFIG_TFM_REGRESSION_S is not set
    # CONFIG_TFM_PSA_TEST_PROTECTED_STORAGE is not set
    # CONFIG_TFM_PSA_TEST_INTERNAL_TRUSTED_STORAGE is not set
    # CONFIG_TFM_PSA_TEST_STORAGE is not set
    CONFIG_TFM_PSA_TEST_NONE=y
    CONFIG_TFM_LOG_LEVEL_SILENCE=y
    # CONFIG_TFM_EXCEPTION_INFO_DUMP is not set
    CONFIG_PM_PARTITION_SIZE_TFM_SRAM=0x8000
    CONFIG_PM_PARTITION_SIZE_BL2=0
    CONFIG_PM_PARTITION_SIZE_TFM=0x8000
    CONFIG_PM_PARTITION_SIZE_TFM_PROTECTED_STORAGE=0
    CONFIG_PM_PARTITION_SIZE_TFM_INTERNAL_TRUSTED_STORAGE=0
    CONFIG_PM_PARTITION_SIZE_TFM_OTP_NV_COUNTERS=0
    # end of trusted-firmware-m (C:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m)
    # cjson (C:/ncs/v2.5.0/modules/lib/cjson)
    # CONFIG_CJSON_LIB is not set
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (C:/ncs/v2.5.0/modules/lib/cjson)
    # azure-sdk-for-c (C:/ncs/v2.5.0/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (C:/ncs/v2.5.0/modules/lib/azure-sdk-for-c)
    # cirrus-logic (C:/ncs/v2.5.0/modules/hal/cirrus-logic)
    # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (C:/ncs/v2.5.0/modules/hal/cirrus-logic)
    # openthread (C:/ncs/v2.5.0/modules/lib/openthread)
    # CONFIG_OPENTHREAD is not set
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (C:/ncs/v2.5.0/modules/lib/openthread)
    # memfault-firmware-sdk (C:/ncs/v2.5.0/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (C:/ncs/v2.5.0/modules/lib/memfault-firmware-sdk)
    # canopennode (C:/ncs/v2.5.0/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (C:/ncs/v2.5.0/modules/lib/canopennode)
    # chre (C:/ncs/v2.5.0/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (C:/ncs/v2.5.0/modules/lib/chre)
    # cmsis (C:/ncs/v2.5.0/modules/hal/cmsis)
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_DSP is not set
    # CONFIG_CMSIS_NN is not set
    CONFIG_ZEPHYR_CMSIS_MODULE=y
    # end of cmsis (C:/ncs/v2.5.0/modules/hal/cmsis)
    # fatfs (C:/ncs/v2.5.0/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (C:/ncs/v2.5.0/modules/fs/fatfs)
    # hal_nordic (C:/ncs/v2.5.0/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_SER_HOST is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    CONFIG_NRFX_CLOCK=y
    CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
    # CONFIG_NRFX_COMP is not set
    CONFIG_NRFX_DPPI=y
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    CONFIG_NRFX_GPIOTE=y
    # CONFIG_NRFX_I2S0 is not set
    # CONFIG_NRFX_IPC is not set
    # CONFIG_NRFX_NFCT is not set
    # CONFIG_NRFX_NVMC is not set
    # CONFIG_NRFX_PDM is not set
    # CONFIG_NRFX_POWER is not set
    # CONFIG_NRFX_PWM0 is not set
    # CONFIG_NRFX_PWM1 is not set
    # CONFIG_NRFX_PWM2 is not set
    # CONFIG_NRFX_PWM3 is not set
    # CONFIG_NRFX_QDEC0 is not set
    # CONFIG_NRFX_QDEC1 is not set
    # CONFIG_NRFX_QSPI is not set
    # CONFIG_NRFX_RTC0 is not set
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_SAADC is not set
    # CONFIG_NRFX_SPIM0 is not set
    # CONFIG_NRFX_SPIM1 is not set
    # CONFIG_NRFX_SPIM2 is not set
    # CONFIG_NRFX_SPIM3 is not set
    # CONFIG_NRFX_SPIM4 is not set
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TIMER0 is not set
    # CONFIG_NRFX_TIMER1 is not set
    # CONFIG_NRFX_TIMER2 is not set
    # CONFIG_NRFX_TWIM0 is not set
    # CONFIG_NRFX_TWIM1 is not set
    # CONFIG_NRFX_TWIM2 is not set
    # CONFIG_NRFX_TWIM3 is not set
    # CONFIG_NRFX_UARTE0 is not set
    # CONFIG_NRFX_UARTE1 is not set
    # CONFIG_NRFX_UARTE2 is not set
    # CONFIG_NRFX_UARTE3 is not set
    # CONFIG_NRFX_USBD is not set
    # CONFIG_NRFX_USBREG is not set
    # CONFIG_NRFX_WDT0 is not set
    # CONFIG_NRFX_WDT1 is not set
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    # end of nrfx drivers
    # end of hal_nordic (C:/ncs/v2.5.0/modules/hal/nordic)
    # liblc3 (C:/ncs/v2.5.0/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # end of liblc3 (C:/ncs/v2.5.0/modules/lib/liblc3)
    # littlefs (C:/ncs/v2.5.0/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (C:/ncs/v2.5.0/modules/fs/littlefs)
    # loramac-node (C:/ncs/v2.5.0/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (C:/ncs/v2.5.0/modules/lib/loramac-node)
    # lvgl (C:/ncs/v2.5.0/modules/lib/gui/lvgl)
    # LVGL configuration
    # CONFIG_LV_CONF_SKIP is not set
    # CONFIG_LV_CONF_MINIMAL is not set
    # Color settings
    # CONFIG_LV_COLOR_DEPTH_32 is not set
    CONFIG_LV_COLOR_DEPTH_16=y
    # CONFIG_LV_COLOR_DEPTH_8 is not set
    # CONFIG_LV_COLOR_DEPTH_1 is not set
    CONFIG_LV_COLOR_DEPTH=16
    # CONFIG_LV_COLOR_SCREEN_TRANSP is not set
    CONFIG_LV_COLOR_MIX_ROUND_OFS=128
    CONFIG_LV_COLOR_CHROMA_KEY_HEX=0x00FF00
    # end of Color settings
    # Memory settings
    # CONFIG_LV_MEM_CUSTOM is not set
    CONFIG_LV_MEM_SIZE_KILOBYTES=32
    CONFIG_LV_MEM_ADDR=0x0
    CONFIG_LV_MEM_BUF_MAX_NUM=16
    # CONFIG_LV_MEMCPY_MEMSET_STD is not set
    # end of Memory settings
    # HAL Settings
    CONFIG_LV_DISP_DEF_REFR_PERIOD=30
    CONFIG_LV_INDEV_DEF_READ_PERIOD=30
    # CONFIG_LV_TICK_CUSTOM is not set
    # end of HAL Settings
    # Feature configuration
    # Drawing
    CONFIG_LV_DRAW_COMPLEX=y
    CONFIG_LV_SHADOW_CACHE_SIZE=0
    CONFIG_LV_CIRCLE_CACHE_SIZE=4
    CONFIG_LV_LAYER_SIMPLE_BUF_SIZE=24576
    CONFIG_LV_IMG_CACHE_DEF_SIZE=0
    CONFIG_LV_GRADIENT_MAX_STOPS=2
    CONFIG_LV_GRAD_CACHE_DEF_SIZE=0
    # CONFIG_LV_DITHER_GRADIENT is not set
    CONFIG_LV_DISP_ROT_MAX_BUF=10240
    # end of Drawing
    # GPU
    # CONFIG_LV_USE_GPU_ARM2D is not set
    # CONFIG_LV_USE_GPU_STM32_DMA2D is not set
    # CONFIG_LV_USE_GPU_SWM341_DMA2D is not set
    # CONFIG_LV_USE_GPU_NXP_PXP is not set
    # CONFIG_LV_USE_GPU_NXP_VG_LITE is not set
    # CONFIG_LV_USE_GPU_SDL is not set
    # end of GPU
    # Logging
    # CONFIG_LV_USE_LOG is not set
    # end of Logging
    # Asserts
    CONFIG_LV_USE_ASSERT_NULL=y
    CONFIG_LV_USE_ASSERT_MALLOC=y
    # CONFIG_LV_USE_ASSERT_STYLE is not set
    # CONFIG_LV_USE_ASSERT_MEM_INTEGRITY is not set
    # CONFIG_LV_USE_ASSERT_OBJ is not set
    CONFIG_LV_ASSERT_HANDLER_INCLUDE="assert.h"
    # end of Asserts
    # Others
    # CONFIG_LV_USE_PERF_MONITOR is not set
    # CONFIG_LV_USE_MEM_MONITOR is not set
    # CONFIG_LV_USE_REFR_DEBUG is not set
    # CONFIG_LV_SPRINTF_CUSTOM is not set
    # CONFIG_LV_SPRINTF_USE_FLOAT is not set
    CONFIG_LV_USE_USER_DATA=y
    # CONFIG_LV_ENABLE_GC is not set
    # end of Others
    # Compiler settings
    # CONFIG_LV_BIG_ENDIAN_SYSTEM is not set
    CONFIG_LV_ATTRIBUTE_MEM_ALIGN_SIZE=1
    # CONFIG_LV_ATTRIBUTE_FAST_MEM_USE_IRAM is not set
    # CONFIG_LV_USE_LARGE_COORD is not set
    # end of Compiler settings
    # end of Feature configuration
    # Font usage
    # Enable built-in fonts
    # CONFIG_LV_FONT_MONTSERRAT_8 is not set
    # CONFIG_LV_FONT_MONTSERRAT_10 is not set
    # CONFIG_LV_FONT_MONTSERRAT_12 is not set
    CONFIG_LV_FONT_MONTSERRAT_14=y
    # CONFIG_LV_FONT_MONTSERRAT_16 is not set
    # CONFIG_LV_FONT_MONTSERRAT_18 is not set
    # CONFIG_LV_FONT_MONTSERRAT_20 is not set
    # CONFIG_LV_FONT_MONTSERRAT_22 is not set
    # CONFIG_LV_FONT_MONTSERRAT_24 is not set
    # CONFIG_LV_FONT_MONTSERRAT_26 is not set
    # CONFIG_LV_FONT_MONTSERRAT_28 is not set
    # CONFIG_LV_FONT_MONTSERRAT_30 is not set
    # CONFIG_LV_FONT_MONTSERRAT_32 is not set
    # CONFIG_LV_FONT_MONTSERRAT_34 is not set
    # CONFIG_LV_FONT_MONTSERRAT_36 is not set
    # CONFIG_LV_FONT_MONTSERRAT_38 is not set
    # CONFIG_LV_FONT_MONTSERRAT_40 is not set
    # CONFIG_LV_FONT_MONTSERRAT_42 is not set
    # CONFIG_LV_FONT_MONTSERRAT_44 is not set
    # CONFIG_LV_FONT_MONTSERRAT_46 is not set
    # CONFIG_LV_FONT_MONTSERRAT_48 is not set
    # CONFIG_LV_FONT_MONTSERRAT_12_SUBPX is not set
    # CONFIG_LV_FONT_MONTSERRAT_28_COMPRESSED is not set
    # CONFIG_LV_FONT_DEJAVU_16_PERSIAN_HEBREW is not set
    # CONFIG_LV_FONT_SIMSUN_16_CJK is not set
    # CONFIG_LV_FONT_UNSCII_8 is not set
    # CONFIG_LV_FONT_UNSCII_16 is not set
    # CONFIG_LV_FONT_CUSTOM is not set
    # end of Enable built-in fonts
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_8 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_12 is not set
    CONFIG_LV_FONT_DEFAULT_MONTSERRAT_14=y
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_16 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_18 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_20 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_22 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_24 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_26 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_28 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_30 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_32 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_34 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_36 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_38 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_40 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_42 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_44 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_46 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_48 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_12_SUBPX is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_28_COMPRESSED is not set
    # CONFIG_LV_FONT_DEFAULT_DEJAVU_16_PERSIAN_HEBREW is not set
    # CONFIG_LV_FONT_DEFAULT_SIMSUN_16_CJK is not set
    # CONFIG_LV_FONT_DEFAULT_UNSCII_8 is not set
    # CONFIG_LV_FONT_DEFAULT_UNSCII_16 is not set
    # CONFIG_LV_FONT_FMT_TXT_LARGE is not set
    # CONFIG_LV_USE_FONT_COMPRESSED is not set
    # CONFIG_LV_USE_FONT_SUBPX is not set
    CONFIG_LV_USE_FONT_PLACEHOLDER=y
    # end of Font usage
    # Text Settings
    CONFIG_LV_TXT_ENC_UTF8=y
    # CONFIG_LV_TXT_ENC_ASCII is not set
    CONFIG_LV_TXT_BREAK_CHARS=" ,.;:-_"
    CONFIG_LV_TXT_LINE_BREAK_LONG_LEN=0
    CONFIG_LV_TXT_COLOR_CMD="#"
    # CONFIG_LV_USE_BIDI is not set
    # CONFIG_LV_USE_ARABIC_PERSIAN_CHARS is not set
    # end of Text Settings
    # Widget usage
    CONFIG_LV_USE_ARC=y
    CONFIG_LV_USE_BAR=y
    CONFIG_LV_USE_BTN=y
    CONFIG_LV_USE_BTNMATRIX=y
    CONFIG_LV_USE_CANVAS=y
    CONFIG_LV_USE_CHECKBOX=y
    CONFIG_LV_USE_DROPDOWN=y
    CONFIG_LV_USE_IMG=y
    CONFIG_LV_USE_LABEL=y
    CONFIG_LV_LABEL_TEXT_SELECTION=y
    CONFIG_LV_LABEL_LONG_TXT_HINT=y
    CONFIG_LV_USE_LINE=y
    CONFIG_LV_USE_ROLLER=y
    CONFIG_LV_ROLLER_INF_PAGES=7
    CONFIG_LV_USE_SLIDER=y
    CONFIG_LV_USE_SWITCH=y
    CONFIG_LV_USE_TEXTAREA=y
    CONFIG_LV_TEXTAREA_DEF_PWD_SHOW_TIME=1500
    CONFIG_LV_USE_TABLE=y
    # end of Widget usage
    # Extra Widgets
    CONFIG_LV_USE_ANIMIMG=y
    CONFIG_LV_USE_CALENDAR=y
    # CONFIG_LV_CALENDAR_WEEK_STARTS_MONDAY is not set
    CONFIG_LV_USE_CALENDAR_HEADER_ARROW=y
    CONFIG_LV_USE_CALENDAR_HEADER_DROPDOWN=y
    CONFIG_LV_USE_CHART=y
    CONFIG_LV_USE_COLORWHEEL=y
    CONFIG_LV_USE_IMGBTN=y
    CONFIG_LV_USE_KEYBOARD=y
    CONFIG_LV_USE_LED=y
    CONFIG_LV_USE_LIST=y
    CONFIG_LV_USE_MENU=y
    CONFIG_LV_USE_METER=y
    CONFIG_LV_USE_MSGBOX=y
    CONFIG_LV_USE_SPAN=y
    CONFIG_LV_SPAN_SNIPPET_STACK_SIZE=64
    CONFIG_LV_USE_SPINBOX=y
    CONFIG_LV_USE_SPINNER=y
    CONFIG_LV_USE_TABVIEW=y
    CONFIG_LV_USE_TILEVIEW=y
    CONFIG_LV_USE_WIN=y
    # end of Extra Widgets
    # Themes
    CONFIG_LV_USE_THEME_DEFAULT=y
    # CONFIG_LV_THEME_DEFAULT_DARK is not set
    CONFIG_LV_THEME_DEFAULT_GROW=y
    CONFIG_LV_THEME_DEFAULT_TRANSITION_TIME=80
    CONFIG_LV_USE_THEME_BASIC=y
    # CONFIG_LV_USE_THEME_MONO is not set
    # end of Themes
    # Layouts
    CONFIG_LV_USE_FLEX=y
    CONFIG_LV_USE_GRID=y
    # end of Layouts
    # 3rd Party Libraries
    # CONFIG_LV_USE_FS_STDIO is not set
    # CONFIG_LV_USE_FS_POSIX is not set
    # CONFIG_LV_USE_FS_WIN32 is not set
    # CONFIG_LV_USE_FS_FATFS is not set
    # CONFIG_LV_USE_PNG is not set
    # CONFIG_LV_USE_BMP is not set
    # CONFIG_LV_USE_SJPG is not set
    # CONFIG_LV_USE_GIF is not set
    # CONFIG_LV_USE_QRCODE is not set
    # CONFIG_LV_USE_FREETYPE is not set
    # CONFIG_LV_USE_RLOTTIE is not set
    # CONFIG_LV_USE_FFMPEG is not set
    # end of 3rd Party Libraries
    # Others
    CONFIG_LV_USE_SNAPSHOT=y
    # CONFIG_LV_USE_MONKEY is not set
    # CONFIG_LV_USE_GRIDNAV is not set
    # CONFIG_LV_USE_FRAGMENT is not set
    # CONFIG_LV_USE_IMGFONT is not set
    # CONFIG_LV_USE_MSG is not set
    # CONFIG_LV_USE_IME_PINYIN is not set
    # end of Others
    # Examples
    CONFIG_LV_BUILD_EXAMPLES=y
    # end of Examples
    # Demos
    # CONFIG_LV_USE_DEMO_WIDGETS is not set
    # CONFIG_LV_USE_DEMO_KEYPAD_AND_ENCODER is not set
    # CONFIG_LV_USE_DEMO_BENCHMARK is not set
    # CONFIG_LV_USE_DEMO_STRESS is not set
    # CONFIG_LV_USE_DEMO_MUSIC is not set
    # end of Demos
    # end of LVGL configuration
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (C:/ncs/v2.5.0/modules/lib/gui/lvgl)
    # lz4 (C:/ncs/v2.5.0/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (C:/ncs/v2.5.0/modules/lib/lz4)
    # nanopb (C:/ncs/v2.5.0/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (C:/ncs/v2.5.0/modules/lib/nanopb)
    # picolibc (C:/ncs/v2.5.0/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (C:/ncs/v2.5.0/modules/lib/picolibc)
    # segger (C:/ncs/v2.5.0/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    # CONFIG_USE_SEGGER_RTT is not set
    # end of segger (C:/ncs/v2.5.0/modules/debug/segger)
    # TraceRecorder (C:/ncs/v2.5.0/modules/debug/TraceRecorder)
    CONFIG_ZEPHYR_TRACERECORDER_MODULE=y
    # end of TraceRecorder (C:/ncs/v2.5.0/modules/debug/TraceRecorder)
    # uoscore-uedhoc (C:/ncs/v2.5.0/modules/lib/uoscore-uedhoc)
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (C:/ncs/v2.5.0/modules/lib/uoscore-uedhoc)
    # zcbor (C:/ncs/v2.5.0/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    # CONFIG_ZCBOR is not set
    # end of zcbor (C:/ncs/v2.5.0/modules/lib/zcbor)
    # zscilib (C:/ncs/v2.5.0/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (C:/ncs/v2.5.0/modules/lib/zscilib)
    # nrfxlib (C:/ncs/v2.5.0/nrfxlib)
    # Nordic nrfxlib
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    # Crypto libraries for nRF5x SOCs.
    CONFIG_CRYPTOCELL_CC312_USABLE=y
    CONFIG_CRYPTOCELL_USABLE=y
    CONFIG_NRF_OBERON=y
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_GZLL is not set
    # CONFIG_NRF_DM is not set
    # CONFIG_LC3_PLC_DISABLED is not set
    CONFIG_LC3_ENC_CHAN_MAX=1
    CONFIG_LC3_DEC_CHAN_MAX=1
    # Encoder sample rates
    CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Encoder sample rates
    # Decoder sample rates
    CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Decoder sample rates
    # CONFIG_NRF_FUEL_GAUGE is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (C:/ncs/v2.5.0/nrfxlib)
    # connectedhomeip (C:/ncs/v2.5.0/modules/lib/matter)
    # CONFIG_CHIP is not set
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (C:/ncs/v2.5.0/modules/lib/matter)
    # Optional modules. Make sure they're installed, via the project manifest.
    # CONFIG_LIBMETAL is not set
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    # CONFIG_OPENAMP is not set
    # CONFIG_SOF is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    # CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
    # Unavailable modules, please install those via the project manifest.
    # hal_gigadevice module not available.
    # Trusted-firmware-a module not available.
    # THRIFT module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD_REVISION="$BOARD_REVISION"
    # CONFIG_NET_DRIVERS is not set
    # CONFIG_BOARD_NRF5340DK_NRF5340_CPUAPP is not set
    CONFIG_BOARD_NRF5340DK_NRF5340_CPUAPP_NS=y
    # Board Options
    CONFIG_BOARD_ENABLE_DCDC_APP=y
    CONFIG_BOARD_ENABLE_DCDC_NET=y
    CONFIG_BOARD_ENABLE_DCDC_HV=y
    # CONFIG_BOARD_ENABLE_CPUNET is not set
    # end of Board Options
    # CONFIG_SOC_SERIES_APOLLO4X is not set
    # CONFIG_SOC_SERIES_BEETLE is not set
    # CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
    # CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set
    # CONFIG_SOC_SERIES_MPS2 is not set
    # CONFIG_SOC_SERIES_MPS3 is not set
    # CONFIG_SOC_SERIES_MUSCA_B1 is not set
    # CONFIG_SOC_SERIES_MUSCA_S1 is not set
    # CONFIG_SOC_SERIES_AST10X0 is not set
    # CONFIG_SOC_SERIES_SAMC20 is not set
    # CONFIG_SOC_SERIES_SAMC21 is not set
    # CONFIG_SOC_SERIES_SAMD20 is not set
    # CONFIG_SOC_SERIES_SAMD21 is not set
    # CONFIG_SOC_SERIES_SAMD51 is not set
    # CONFIG_SOC_SERIES_SAME51 is not set
    # CONFIG_SOC_SERIES_SAME53 is not set
    # CONFIG_SOC_SERIES_SAME54 is not set
    # CONFIG_SOC_SERIES_SAML21 is not set
    # CONFIG_SOC_SERIES_SAMR21 is not set
    # CONFIG_SOC_SERIES_SAMR34 is not set
    # CONFIG_SOC_SERIES_SAMR35 is not set
    # CONFIG_SOC_SERIES_SAM3X is not set
    # CONFIG_SOC_SERIES_SAM4E is not set
    # CONFIG_SOC_SERIES_SAM4L is not set
    # CONFIG_SOC_SERIES_SAM4S is not set
    # CONFIG_SOC_SERIES_SAME70 is not set
    # CONFIG_SOC_SERIES_SAMV71 is not set
    # CONFIG_SOC_SERIES_VALKYRIE is not set
    # CONFIG_SOC_SERIES_VIPER is not set
    # CONFIG_SOC_SERIES_PSOC62 is not set
    # CONFIG_SOC_SERIES_PSOC63 is not set
    # CONFIG_SOC_SERIES_GD32A50X is not set
    # CONFIG_SOC_SERIES_GD32E10X is not set
    # CONFIG_SOC_SERIES_GD32E50X is not set
    # CONFIG_SOC_SERIES_GD32F3X0 is not set
    # CONFIG_SOC_SERIES_GD32F403 is not set
    # CONFIG_SOC_SERIES_GD32F4XX is not set
    # CONFIG_SOC_SERIES_GD32L23X is not set
    # CONFIG_SOC_SERIES_PSOC_60 is not set
    # CONFIG_SOC_SERIES_PSOC_61 is not set
    # CONFIG_SOC_SERIES_PSOC_62 is not set
    # CONFIG_SOC_SERIES_PSOC_63 is not set
    # CONFIG_SOC_SERIES_PSOC_64 is not set
    # CONFIG_SOC_SERIES_XMC_4XXX is not set
    # CONFIG_SOC_SERIES_CYCLONE5 is not set
    # CONFIG_SOC_SERIES_MEC1501X is not set
    # CONFIG_SOC_SERIES_MEC172X is not set
    # CONFIG_SOC_SERIES_NRF51X is not set
    # CONFIG_SOC_SERIES_NRF52X is not set
    CONFIG_SOC_SERIES_NRF53X=y
    # CONFIG_SOC_SERIES_NRF91X is not set
    # CONFIG_SOC_SERIES_NPCX4 is not set
    # CONFIG_SOC_SERIES_NPCX7 is not set
    # CONFIG_SOC_SERIES_NPCX9 is not set
    # CONFIG_SOC_SERIES_M46X is not set
    # CONFIG_SOC_SERIES_M48X is not set
    # CONFIG_SOC_SERIES_IMX_6X_M4 is not set
    # CONFIG_SOC_SERIES_IMX7_M4 is not set
    # CONFIG_SOC_SERIES_IMX8ML_M7 is not set
    # CONFIG_SOC_SERIES_IMX8MM_M4 is not set
    # CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
    # CONFIG_SOC_SERIES_IMX_RT5XX is not set
    # CONFIG_SOC_SERIES_IMX_RT6XX is not set
    # CONFIG_SOC_SERIES_IMX_RT is not set
    # CONFIG_SOC_SERIES_KINETIS_K2X is not set
    # CONFIG_SOC_SERIES_KINETIS_K6X is not set
    # CONFIG_SOC_SERIES_KINETIS_K8X is not set
    # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
    # CONFIG_SOC_SERIES_KINETIS_KL2X is not set
    # CONFIG_SOC_SERIES_KINETIS_KV5X is not set
    # CONFIG_SOC_SERIES_KINETIS_KWX is not set
    # CONFIG_SOC_SERIES_LPC11U6X is not set
    # CONFIG_SOC_SERIES_LPC51U68 is not set
    # CONFIG_SOC_SERIES_LPC54XXX is not set
    # CONFIG_SOC_SERIES_LPC55XXX is not set
    # CONFIG_SOC_SERIES_S32K3_M7 is not set
    # CONFIG_SOC_SERIES_S32ZE_R52 is not set
    # CONFIG_SOC_EOS_S3 is not set
    # CONFIG_SOC_SERIES_RCAR_GEN3 is not set
    # CONFIG_SOC_SERIES_DA1469X is not set
    # CONFIG_SOC_SERIES_RP2XXX is not set
    # CONFIG_SOC_SERIES_EFM32GG11B is not set
    # CONFIG_SOC_SERIES_EFM32GG12B is not set
    # CONFIG_SOC_SERIES_EFM32HG is not set
    # CONFIG_SOC_SERIES_EFM32JG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG1B is not set
    # CONFIG_SOC_SERIES_EFM32WG is not set
    # CONFIG_SOC_SERIES_EFR32BG13P is not set
    # CONFIG_SOC_SERIES_EFR32BG22 is not set
    # CONFIG_SOC_SERIES_EFR32BG27 is not set
    # CONFIG_SOC_SERIES_EFR32FG13P is not set
    # CONFIG_SOC_SERIES_EFR32FG1P is not set
    # CONFIG_SOC_SERIES_EFR32MG12P is not set
    # CONFIG_SOC_SERIES_EFR32MG21 is not set
    # CONFIG_SOC_SERIES_EFR32MG24 is not set
    # CONFIG_SOC_SERIES_STM32C0X is not set
    # CONFIG_SOC_SERIES_STM32F0X is not set
    # CONFIG_SOC_SERIES_STM32F1X is not set
    # CONFIG_SOC_SERIES_STM32F2X is not set
    # CONFIG_SOC_SERIES_STM32F3X is not set
    # CONFIG_SOC_SERIES_STM32F4X is not set
    # CONFIG_SOC_SERIES_STM32F7X is not set
    # CONFIG_SOC_SERIES_STM32G0X is not set
    # CONFIG_SOC_SERIES_STM32G4X is not set
    # CONFIG_SOC_SERIES_STM32H5X is not set
    # CONFIG_SOC_SERIES_STM32H7X is not set
    # CONFIG_SOC_SERIES_STM32L0X is not set
    # CONFIG_SOC_SERIES_STM32L1X is not set
    # CONFIG_SOC_SERIES_STM32L4X is not set
    # CONFIG_SOC_SERIES_STM32L5X is not set
    # CONFIG_SOC_SERIES_STM32MP1X is not set
    # CONFIG_SOC_SERIES_STM32U5X is not set
    # CONFIG_SOC_SERIES_STM32WBX is not set
    # CONFIG_SOC_SERIES_STM32WBAX is not set
    # CONFIG_SOC_SERIES_STM32WLX is not set
    # CONFIG_SOC_SERIES_AM62X_M4 is not set
    # CONFIG_SOC_TI_LM3S6965 is not set
    # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
    # CONFIG_SOC_SERIES_CC13X2X7_CC26X2X7 is not set
    # CONFIG_SOC_SERIES_CC32XX is not set
    # CONFIG_SOC_SERIES_MSP432P4XX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
    # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
    # Hardware Configuration
    CONFIG_CPU_HAS_ARM_MPU=y
    CONFIG_CPU_HAS_NRF_IDAU=y
    CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
    CONFIG_HAS_SWO=y
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_GPIO_INIT_PRIORITY=40
    CONFIG_SOC_FAMILY_NRF=y
    CONFIG_HAS_HW_NRF_CC312=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_CTRLAP=y
    CONFIG_HAS_HW_NRF_DCNF=y
    CONFIG_HAS_HW_NRF_DPPIC=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIOTE=y
    CONFIG_HAS_HW_NRF_IPC=y
    CONFIG_HAS_HW_NRF_KMU=y
    CONFIG_HAS_HW_NRF_MUTEX=y
    CONFIG_HAS_HW_NRF_NFCT=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_OSCILLATORS=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_REGULATORS=y
    CONFIG_HAS_HW_NRF_RESET=y
    CONFIG_HAS_HW_NRF_SAADC=y
    CONFIG_HAS_HW_NRF_SPIM4=y
    CONFIG_HAS_HW_NRF_TWIM1=y
    CONFIG_HAS_HW_NRF_UARTE0=y
    CONFIG_HAS_HW_NRF_USBD=y
    CONFIG_HAS_HW_NRF_USBREG=y
    CONFIG_HAS_HW_NRF_VMC=y
    CONFIG_HAS_HW_NRF_WDT0=y
    CONFIG_SOC_NRF5340_CPUAPP=y
    CONFIG_SOC_NRF5340_CPUAPP_QKAA=y
    # CONFIG_SOC_NRF5340_CPUNET_QKAA is not set
    CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED=y
    CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND=y
    CONFIG_SOC_NRF53_RTC_PRETICK=y
    CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_FROM_NET=10
    CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_TO_NET=11
    CONFIG_SOC_DCDC_NRF53X_APP=y
    CONFIG_SOC_DCDC_NRF53X_NET=y
    CONFIG_SOC_DCDC_NRF53X_HV=y
    # CONFIG_SOC_ENABLE_LFXO is not set
    # CONFIG_SOC_HFXO_CAP_DEFAULT is not set
    # CONFIG_SOC_HFXO_CAP_INTERNAL is not set
    CONFIG_NRF_ENABLE_CACHE=y
    # CONFIG_NRF53_SYNC_RTC is not set
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    # CONFIG_NFCT_PINS_AS_GPIOS is not set
    # CONFIG_NRF_TRACE_PORT is not set
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF53X=y
    CONFIG_SOC_COMPATIBLE_NRF5340_CPUAPP=y
    # ARM Options
    CONFIG_ARCH="arm"
    CONFIG_CPU_CORTEX=y
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK=y
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_BUILTIN_STACK_GUARD=y
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_ARM_NONSECURE_FIRMWARE=y
    CONFIG_ARM_NONSECURE_PREEMPTIBLE_SECURE_CALLS=y
    CONFIG_ARM_STORE_EXC_RETURN=y
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M33=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_CPU_CORTEX_M_HAS_CMSE=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_SE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    CONFIG_ARMV8_M_DSP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
    CONFIG_GEN_ISR_TABLES=y
    # CONFIG_ZERO_LATENCY_IRQS is not set
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DWT is not set
    # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    CONFIG_ARM_TRUSTZONE_M=y
    # ARM TrustZone-M Options
    # Non-secure firmware
    # CONFIG_ARM_FIRMWARE_USES_SECURE_ENTRY_FUNCS is not set
    # end of ARM TrustZone-M Options
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    # CONFIG_MPU_STACK_GUARD is not set
    # CONFIG_MPU_ALLOW_FLASH_WRITE is not set
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    CONFIG_LITTLE_ENDIAN=y
    # CONFIG_TRUSTED_EXECUTION_SECURE is not set
    CONFIG_TRUSTED_EXECUTION_NONSECURE=y
    CONFIG_HW_STACK_PROTECTION=y
    # CONFIG_USERSPACE is not set
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # Interrupt Configuration
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    CONFIG_GEN_IRQ_START_VECTOR=0
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_TEE=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
    CONFIG_MPU_GAP_FILLING=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # Floating Point Options
    # end of Floating Point Options
    # Cache Options
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    # General Kernel Options
    CONFIG_MULTITHREADING=y
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    CONFIG_LIBC_ERRNO=y
    CONFIG_ERRNO=y
    CONFIG_SCHED_DUMB=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_DUMB=y
    # Kernel Debugging and Metrics
    CONFIG_BOOT_BANNER=y
    CONFIG_BOOT_DELAY=0
    # CONFIG_THREAD_MONITOR is not set
    # CONFIG_THREAD_NAME is not set
    # CONFIG_THREAD_RUNTIME_STATS is not set
    # end of Kernel Debugging and Metrics
    # Work Queue Options
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    # end of Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_SIZE=0
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    # CONFIG_POLL is not set
    # end of Timer API Options
    # Other Kernel Object Options
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    # CONFIG_EVENTS is not set
    # CONFIG_PIPES is not set
    CONFIG_KERNEL_MEM_POOL=y
    # end of Other Kernel Object Options
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    CONFIG_XIP=y
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Security Options
    # CONFIG_STACK_CANARIES is not set
    CONFIG_STACK_POINTER_RANDOM=0
    # end of Security Options
    # SMP Options
    CONFIG_MP_NUM_CPUS=1
    # end of SMP Options
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_THREAD_LOCAL_STORAGE=y
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_DEPS is not set
    # end of Device Options
    # Virtual Memory Support
    # end of Virtual Memory Support
    # Device Drivers
    # CONFIG_ADC is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_AUDIO is not set
    # CONFIG_BBRAM is not set
    # CONFIG_CACHE is not set
    # CONFIG_CAN is not set
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    CONFIG_CONSOLE=y
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    # CONFIG_CONSOLE_HANDLER is not set
    CONFIG_CONSOLE_INIT_PRIORITY=60
    CONFIG_UART_CONSOLE=y
    # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
    # CONFIG_UART_CONSOLE_MCUMGR is not set
    # CONFIG_RAM_CONSOLE is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_GSM_MUX is not set
    # CONFIG_EFI_CONSOLE is not set
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_COUNTER is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    CONFIG_ENTROPY_INIT_PRIORITY=50
    CONFIG_ENTROPY_PSA_CRYPTO_RNG=y
    CONFIG_ENTROPY_HAS_DRIVER=y
    # CONFIG_ESPI is not set
    # CONFIG_FLASH is not set
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    # CONFIG_GPIO_HOGS is not set
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRFX_INTERRUPT=y
    # CONFIG_HWINFO is not set
    # CONFIG_I2C is not set
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    # CONFIG_SMBUS is not set
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    CONFIG_1ST_LEVEL_INTERRUPT_BITS=8
    CONFIG_2ND_LEVEL_INTERRUPT_BITS=8
    CONFIG_3RD_LEVEL_INTERRUPT_BITS=8
    # CONFIG_INTC_ESP32 is not set
    # CONFIG_PLIC_SUPPORTS_EDGE_IRQ is not set
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_KSCAN is not set
    # CONFIG_LED is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    # CONFIG_MBOX is not set
    # CONFIG_MDIO is not set
    # CONFIG_MFD is not set
    # Miscellaneous Drivers
    # CONFIG_GROVE_LCD_RGB is not set
    # end of Miscellaneous Drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_NEURAL_NET_ACCEL is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_POWER_DOMAIN is not set
    # CONFIG_PS2 is not set
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_PWM is not set
    # CONFIG_REGULATOR is not set
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    CONFIG_UART_USE_RUNTIME_CONFIGURE=y
    # CONFIG_UART_ASYNC_API is not set
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # Serial Drivers
    CONFIG_UART_NRFX=y
    CONFIG_UART_NRFX_UARTE=y
    CONFIG_UART_0_ENHANCED_POLL_OUT=y
    # CONFIG_UART_0_NRF_PARITY_BIT is not set
    CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
    CONFIG_UART_ENHANCED_POLL_OUT=y
    # CONFIG_SYSCON is not set
    # Timer drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
    # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # end of Timer drivers
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    # CONFIG_HWSPINLOCK is not set
    # CONFIG_REQUIRES_FULL_LIBC is not set
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_NEWLIB_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    # C Library
    # CONFIG_MINIMAL_LIBC is not set
    CONFIG_PICOLIBC=y
    # CONFIG_NEWLIB_LIBC is not set
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_COMMON_LIBC_ABORT=y
    CONFIG_COMMON_LIBC_MALLOC=y
    CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
    CONFIG_COMMON_LIBC_CALLOC=y
    CONFIG_COMMON_LIBC_REALLOCARRAY=y
    # CONFIG_PICOLIBC_USE_MODULE is not set
    CONFIG_PICOLIBC_HEAP_SIZE=-2
    CONFIG_PICOLIBC_IO_LONG_LONG=y
    # CONFIG_PICOLIBC_IO_FLOAT is not set
    CONFIG_STDOUT_CONSOLE=y
    # end of C Library
    # C++ Language Support
    # CONFIG_CPP is not set
    # Deprecated
    # CONFIG_CPLUSPLUS is not set
    # CONFIG_LIB_CPLUSPLUS is not set
    # end of Deprecated
    # end of C++ Language Support
    # CONFIG_CRC is not set
    # Additional libraries
    # Hash Function Support
    # CONFIG_SYS_HASH_FUNC32 is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # OS Support Library
    # CONFIG_JSON_LIBRARY is not set
    # CONFIG_RING_BUFFER is not set
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    # CONFIG_PRINTK_SYNC is not set
    # CONFIG_MPSC_PBUF is not set
    CONFIG_ONOFF=y
    # CONFIG_SPSC_PBUF is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # CONFIG_WINSTREAM is not set
    CONFIG_REBOOT=y
    CONFIG_HAS_POWEROFF=y
    # CONFIG_POWEROFF is not set
    # CONFIG_UTF8 is not set
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    # CONFIG_CBPRINTF_FP_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_ALWAYS_A is not set
    CONFIG_CBPRINTF_N_SPECIFIER=y
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    # CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_VALIDATE is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_SMALL_ONLY is not set
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    CONFIG_SYS_HEAP_AUTO=y
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Heap and Memory Allocation
    # end of OS Support Library
    # CONFIG_POSIX_API is not set
    # CONFIG_POSIX_CLOCK is not set
    # CONFIG_EVENTFD is not set
    # CONFIG_FNMATCH is not set
    # CONFIG_POSIX_MQUEUE is not set
    CONFIG_SEM_VALUE_MAX=32767
    # CONFIG_POSIX_SIGNAL is not set
    # CONFIG_TIMER is not set
    CONFIG_MAX_TIMER_COUNT=5
    CONFIG_TIMER_CREATE_WAIT=100
    CONFIG_TIMER_DELAYTIMER_MAX=20
    # CONFIG_POSIX_UNAME is not set
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # CONFIG_SMF is not set
    CONFIG_ACPI_HID_LEN_MAX=12
    CONFIG_LIBGCC_RTLIB=y
    # end of Additional libraries
    # Subsystems and OS Services
    # CONFIG_BT is not set
    # Controller Area Network (CAN) bus subsystem
    # CONFIG_ISOTP is not set
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_STACK_USAGE is not set
    # CONFIG_STACK_SENTINEL is not set
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    # CONFIG_ASSERT is not set
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_INFO is not set
    # CONFIG_DEBUG_THREAD_INFO is not set
    # CONFIG_DEBUG_COREDUMP is not set
    # end of Debugging Options
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FILE_SYSTEM is not set
    # CONFIG_NVS is not set
    # end of File Systems
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    # CONFIG_IPC_SERVICE is not set
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # Logging
    # CONFIG_LOG is not set
    # CONFIG_LOG_OUTPUT is not set
    # end of Logging
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # CONFIG_MODEM_MODULES is not set
    # Networking
    # CONFIG_NET_BUF is not set
    # CONFIG_NETWORKING is not set
    # end of Networking
    # Power Management
    # end of Power Management
    # Portability
    # end of Portability
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
    # CONFIG_XOROSHIRO_RANDOM_GENERATOR is not set
    # CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
    CONFIG_CSPRING_ENABLED=y
    CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
    # end of Random Number Generators
    # CONFIG_RTIO is not set
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    # CONFIG_SETTINGS is not set
    # CONFIG_SHELL is not set
    # CONFIG_STATS is not set
    # Storage
    # CONFIG_STREAM_FLASH is not set
    # end of Storage
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_ZBUS is not set
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_16=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    CONFIG_SRAM_OFFSET=0
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    CONFIG_LINKER_USE_RELAX=y
    # end of Linker Sections
    # end of Linker Options
    # Compiler Options
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_COMPILER_FREESTANDING is not set
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    # CONFIG_FORTIFY_SOURCE_NONE is not set
    CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19 is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # CONFIG_BUILD_OUTPUT_META is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_CHECK_INIT_PRIORITIES_FAIL_ON_WARNING is not set
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_WARN_DEPRECATED=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    # Compatibility
    CONFIG_COMPAT_INCLUDES=y
    # end of Compatibility
    Thank you for your reply.
    Can you share your whole build folder?
    Also, your 32 MHz crystal is a bit bad matched. The datasheet specifies the internal load capacitance to be 10 pF, that means that the crystal should be loaded with 16 pF. If the LFCLK use the HFCLK to produce the low frequency crystal then this bad match will also follow the LF signal resulting in a inaccurate LF clock as well. Are you able to reproduce this on a devkit?
    regards
    Jared
