We had the UICR used to store our persistent data relevant for a coap client. Recently I saw a hard fault occurring sometimes when we try to access UICR. Further research to this showed its not advisable to use UICR as accessing UICR will halt the processor and this can cause hard faults. It was suggested to use the Settings API to store persistent data.
So I looked at littleFS sample and trying to integrate that to our coap client code. First I added these to my prj.conf.
CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_MAP=y CONFIG_FILE_SYSTEM=y CONFIG_FILE_SYSTEM_LITTLEFS=y CONFIG_SETTINGS_FS=y CONFIG_SETTINGS_FS_FILE="/lfs"
Then I have the init code as follows.
#define STORAGE_PARTITION storage_partition
#define STORAGE_PARTITION_ID FIXED_PARTITION_ID(STORAGE_PARTITION)
#define PARTITION_NODE DT_NODELABEL(lfs1)
void littlefs_initialization(void)
int rc;
#if IS_ENABLED(CONFIG_FILE_SYSTEM_LITTLEFS)
FS_LITTLEFS_DECLARE_DEFAULT_CONFIG(storage);
/* mounting info */
static struct fs_mount_t littlefs_mnt = {
.type = FS_LITTLEFS,
.fs_data = &storage,
.storage_dev = (void *)FLASH_AREA_ID (storage),
.mnt_point = "/lfs"
rc = fs_mount(&littlefs_mnt);
if (rc != 0) {
LOG_ERR ("mounting littlefs error: [%d]\n", rc);
} else {
rc = fs_unlink(CONFIG_SETTINGS_FS_FILE);
if ((rc != 0) && (rc != -ENOENT)) {
LOG_ERR ("can't delete config file%d", rc);
} else {
LOG_INF ("FS initialized: OK");
rc = settings_subsys_init();
if (rc) {
LOG_ERR ("settings subsys initialization: fail (err %d)", rc);
return;
LOG_INF ("settings subsys initialization: OK");
I get the following from the console.
*** Booting Zephyr OS build v3.2.99-ncs2 *** [00:00:00.099,731] <inf> coap_client: ------- Sensor Start -------- [00:00:00.100,158] <inf> littlefs: LittleFS version 2.5, disk version 2.0 [00:00:00.100,372] <inf> littlefs: FS at flash-controller@4001e000:0xf8000 is 8 0x1000-byte blocks with 512 cycle [00:00:00.100,372] <inf> littlefs: sizes: rd 16 ; pr 16 ; ca 64 ; la 32 [00:00:00.100,646] <inf> littlefs: /lfs mounted [00:00:00.100,708] <err> fs: mount point not found!! [00:00:00.100,738] <err> fs: mount point not found!! uart:~$ [00:00:00.100,769] <err> coap_client_utils: settings subsys initialization: fail (err -2) [00:00:00.101,043] <dbg> coap_utils: coap_init: CoAP socket receive thread started [00:00:00.101,776] <inf> [N] Mle-----------: Mode 0x0c -> 0x04 [rx-on:no ftd:no full-net:no] [00:00:00.101,898] <err> fs: file open error (-21) [00:00:00.102,081] <err> fs: file open error (-21) [00:00:00.102,233] <err> fs: file open error (-21) [00:00:00.102,355] <err> fs: file open error (-21) [00:00:00.102,508] <err> fs: file open error (-21) [00:00:00.102,630] <err> fs: file open error (-21) [00:00:00.102,783] <err> fs: file open error (-21) [00:00:00.102,935] <err> fs: file open error (-21) [00:00:00.103,149] <err> fs: file open error (-21) [00:00:00.103,302] <err> fs: file open error (-21) [00:00:00.104,644] <err> fs: file open error (-21) [00:00:00.100,769] <err> coap_client_utils: settings subsys initialization: fail (err -2)
it says the "/lfs" is mounted, but then I get "mount point not found" and all the other errors.
I am on a really tight time budget. So looking for some urgent help here.
Cheers,
Kay
