Hello everyone,
I am working on an application based on dhcpv4_client from the zephyr SDK samples https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.4.99-dev2/zephyr/samples/net/dhcpv4_client/README.html#dhcpv4-client-sample.
I am using wiz550io v3 ethernet controller which uses W5500 driver.
I made the same implementation on nrf 2.3 SDK and it works, however the same implementation dose not work with 2.4 SDK. I can build the app and flash it. however no data is received, I am not sure it seems that the callback function dose not receive any interpret signal.
The serial monitor print initializing the dhcp_client and then remains stuck.
Note: I am using nrf 2.4 SDK with the nrf52833dk
# Networking General CONFIG_NETWORKING=y CONFIG_NET_IPV4=y CONFIG_NET_ARP=y CONFIG_NET_UDP=y CONFIG_NET_DHCPV4=y CONFIG_NET_MGMT=y CONFIG_NET_MGMT_EVENT=y CONFIG_NET_LOG=y CONFIG_LOG=y CONFIG_NET_STATISTICS=y CONFIG_NET_L2_ETHERNET=y # Networking Protocols and Extensions CONFIG_NET_IPV6=n CONFIG_NET_TCP=y CONFIG_DNS_RESOLVER=y CONFIG_DNS_SERVER_IP_ADDRESSES=y CONFIG_DNS_SERVER1="8.8.8.8" CONFIG_NET_SOCKETS=y # Testing and Debugging CONFIG_TEST_RANDOM_GENERATOR=y CONFIG_NET_SHELL=y # System and Library Configurations CONFIG_NEWLIB_LIBC=y CONFIG_MAIN_STACK_SIZE=1200 CONFIG_GPIO=y CONFIG_ENTROPY_GENERATOR=y CONFIG_INIT_STACKS=y Networking Hardware Suppor CONFIG_NETWORKING = y CONFIG_ETH_DRIVER=y CONFIG_ETH_W5500=y CONFIG_ETH_W5500_TIMEOUT=1000
Prj.conf file
&spi1 {
compatible = "nordic,nrf-spi";
status = "okay";
cs-gpios = <&gpio1 9 GPIO_ACTIVE_LOW>;
w5500: w5500@0 {
compatible = "wiznet,w5500";
label = "w5500";
reg = <0>;
spi-max-frequency = <1000000>;
int-gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>;
reset-gpios = <&gpio1 6 GPIO_ACTIVE_HIGH>;
nrf52833dk overlay file
