Enable to pair between my computer on windows and my board runing the ble sample peripheral_hids_keyboard
Hi
I am using the sample peripheral_hids_keyboard on nRFconnect with toolchain and SDK @ V2.3.0
Using the sample, I've been able to connect and bound with this smartphone :
I've also been able to bound with an iPhone 11 pro on ios16, after modifing this macro : OUTPUT_REP_KEYS_REF_ID from 1 to 2 (so it is not the same ID as INPUT report)
But I can't connect with a portable computer, I've tried with one on Windows 10 and one on Windows 11.
Here the log when I try to connect with the PC on Windows 11 :
As you can see, I've tried to connect 2 times but it failed both.
I've also can't connect with an Android 13.
Thibaud
  • I will try this afternoon if it help me to decrease CONFIG_BT_MAX CONN & CONFIG_BT_MAX_PAIRED to 2, because I don't have anymore the phone which is causing me troubles.
    But it did not help me to go back to the SoftDevice Controller. I still need Zephyr controller to be able to bound with Windows computer
    Regards
    Thibaud
  • The only two you should need are really:
    CONFIG_BT_KEYS_OVERWRITE_OLDEST=y
    CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE=y
    Also, maybe the Windows PC's you have issue with le secure connections, it should be possible to disable le secure connection by for instance using:
    BT_TINYCRYPT_ECC=n
    BT_CTLR_ECDH=n
    I rather you experiment with this than you start modifying the application in any way. I am not able to see anyone else reporting your problems, so I still suspect it is something in specific at your end that cause this.
    Kenneth
  • Hi
    I need secure connection for HID keyboard on iPhone.
    I also spend a lot of time on the devzone searching for someone with the same problem and I didn't find anyone.
    Which I do not understand because I tried to flash the sample from a couple of computer and with all recent sdk versions and everytime it ended up the same. I can't connect to Windows PC. We have 5 PC in the room, every one on windows and  I can connect to only one, after a lot of try.
    I tried to flash the sample with the programmer in nRF Connect for Desktop and same issue.
    This issue is annoying me a lot, I saw on the devzone that Nordic does not certify Zephyr Controller on nRF series and my product need to be certify.
    Do you know anything about disconnection for reason 8. I know it is BLE_HCI_CONNECTION_TIMEOUT  but I do not change anything in this part so it should not be a problem isn't it ?
    At this moment the LOGs when I try to connect to my PC  are :
    Sometimes it is reason 19 (0x13) as I send at the begining of this case, and sometimes it is 8.
    Regards
    THibaud
    8 means connection timeout, this can happen when there is much noise in the system, but also if there is a problem with the tolerance of lfclk.
    19 means remote user terminated connection, could be several reasons for that, but given your problems possible for instance that the peer (e.g Windows) already had an active bond with the device in question, and when it detected that the keys did not match it disconnected. Typically removing the device from the Bluetooth list in Windows will solve that.
    Kenneth
  • Hello
    It appened even with the device removed from my Bluetooth list.
    Where can I look at to solve this problem ?
    Thibaud
