lvgl sample code build is not working
I am trying to build basic LVGL code and it is giving me the following error. I did not customize the code.
https://github.com/nrfconnect/sdk-zephyr/tree/v3.4.99-ncs1-rc2/samples/subsys/display/lvgl/
prj.conf
CONFIG_LV_Z_MEM_POOL_NUMBER_BLOCKS=8
CONFIG_LV_Z_SHELL=y
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_DISPLAY=y
CONFIG_DISPLAY_LOG_LEVEL_ERR=y
CONFIG_LOG=y
CONFIG_SHELL=y
CONFIG_LVGL=y
CONFIG_LV_MEM_CUSTOM=y
CONFIG_LV_USE_LOG=y
CONFIG_LV_USE_LABEL=y
CONFIG_LV_USE_BTN=y
CONFIG_LV_USE_IMG=y
CONFIG_LV_USE_MONKEY=y
CONFIG_LV_FONT_MONTSERRAT_14=y
nrf52dk_nrf52832_deconfig
CONFIG_SOC_SERIES_NRF52X=y
CONFIG_SOC_NRF52832_QFAA=y
CONFIG_BOARD_NRF52DK_NRF52832=y
# Enable MPU
CONFIG_ARM_MPU=y
# Enable hardware stack protection
CONFIG_HW_STACK_PROTECTION=y
# Enable RTT
CONFIG_USE_SEGGER_RTT=y
# enable GPIO
CONFIG_GPIO=y
# enable uart driver
CONFIG_SERIAL=y
# enable console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_PINCTRL=y
nrf52dk_nrf52832.dts
 * Copyright (c) 2017 Shawn Nock <[email protected]>
 * Copyright (c) 2017 Linaro Limited
/dts-v1/;
#include <nordic/nrf52832_qfaa.dtsi>
#include "nrf52dk_nrf52832-pinctrl.dtsi"
#include <zephyr/dt-bindings/input/input-event-codes.h>
	model = "Nordic nRF52 DK NRF52832";
	compatible = "nordic,nrf52-dk-nrf52832";
	chosen {
		zephyr,console = &uart0;
		zephyr,shell-uart = &uart0;
		zephyr,uart-mcumgr = &uart0;
		zephyr,bt-mon-uart = &uart0;
		zephyr,bt-c2h-uart = &uart0;
		zephyr,sram = &sram0;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_partition;
	leds {
		compatible = "gpio-leds";
		led0: led_0 {
			gpios = <&gpio0 17 GPIO_ACTIVE_LOW>;
			label = "Green LED 0";
		led1: led_1 {
			gpios = <&gpio0 18 GPIO_ACTIVE_LOW>;
			label = "Green LED 1";
		led2: led_2 {
			gpios = <&gpio0 19 GPIO_ACTIVE_LOW>;
			label = "Green LED 2";
		led3: led_3 {
			gpios = <&gpio0 20 GPIO_ACTIVE_LOW>;
			label = "Green LED 3";
	pwmleds {
		compatible = "pwm-leds";
		pwm_led0: pwm_led_0 {
			pwms = <&pwm0 0 PWM_MSEC(20) PWM_POLARITY_INVERTED>;
	buttons {
		compatible = "gpio-keys";
		button0: button_0 {
			gpios = <&gpio0 13 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "Push button switch 0";
			zephyr,code = <INPUT_KEY_0>;
		button1: button_1 {
			gpios = <&gpio0 14 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "Push button switch 1";
			zephyr,code = <INPUT_KEY_1>;
		button2: button_2 {
			gpios = <&gpio0 15 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "Push button switch 2";
			zephyr,code = <INPUT_KEY_2>;
		button3: button_3 {
			gpios = <&gpio0 16 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "Push button switch 3";
			zephyr,code = <INPUT_KEY_3>;
	arduino_header: connector {
		compatible = "arduino-header-r3";
		#gpio-cells = <2>;
		gpio-map-mask = <0xffffffff 0xffffffc0>;
		gpio-map-pass-thru = <0 0x3f>;
		gpio-map = <0 0 &gpio0 3 0>,	/* A0 */
			   <1 0 &gpio0 4 0>,	/* A1 */
			   <2 0 &gpio0 28 0>,	/* A2 */
			   <3 0 &gpio0 29 0>,	/* A3 */
			   <4 0 &gpio0 30 0>,	/* A4 */
			   <5 0 &gpio0 31 0>,	/* A5 */
			   <6 0 &gpio0 11 0>,	/* D0 */
			   <7 0 &gpio0 12 0>,	/* D1 */
			   <8 0 &gpio0 13 0>,	/* D2 */
			   <9 0 &gpio0 14 0>,	/* D3 */
			   <10 0 &gpio0 15 0>,	/* D4 */
			   <11 0 &gpio0 16 0>,	/* D5 */
			   <12 0 &gpio0 17 0>,	/* D6 */
			   <13 0 &gpio0 18 0>,	/* D7 */
			   <14 0 &gpio0 19 0>,	/* D8 */
			   <15 0 &gpio0 20 0>,	/* D9 */
			   <16 0 &gpio0 22 0>,	/* D10 */
			   <17 0 &gpio0 23 0>,	/* D11 */
			   <18 0 &gpio0 24 0>,	/* D12 */
			   <19 0 &gpio0 25 0>,	/* D13 */
			   <20 0 &gpio0 26 0>,	/* D14 */
			   <21 0 &gpio0 27 0>;	/* D15 */
	arduino_adc: analog-connector {
		compatible = "arduino,uno-adc";
		#io-channel-cells = <1>;
		io-channel-map = <0 &adc 1>,	/* A0 = P0.3 = AIN1 */
				 <1 &adc 2>,	/* A1 = P0.4 = AIN2 */
				 <2 &adc 4>,	/* A2 = P0.28 = AIN4 */
				 <3 &adc 5>,	/* A3 = P0.29 = AIN5 */
				 <4 &adc 6>,	/* A4 = P0.30 = AIN6 */
				 <5 &adc 7>;	/* A5 = P0.31 = AIN7 */
	/* These aliases are provided for compatibility with samples */
	aliases {
		led0 = &led0;
		led1 = &led1;
		led2 = &led2;
		led3 = &led3;
		pwm-led0 = &pwm_led0;
		sw0 = &button0;
		sw1 = &button1;
		sw2 = &button2;
		sw3 = &button3;
		bootloader-led0 = &led0;
		mcuboot-button0 = &button0;
		mcuboot-led0 = &led0;
		watchdog0 = &wdt0;
&adc {
	status = "okay";
&uicr {
	gpio-as-nreset;
&gpiote {
	status = "okay";
&gpio0 {
	status = "okay";
arduino_serial: &uart0 {
	status = "okay";
	current-speed = <115200>;
	pinctrl-0 = <&uart0_default>;
	pinctrl-1 = <&uart0_sleep>;
arduino_i2c: &i2c0 {
	compatible = "nordic,nrf-twi";
	status = "okay";
	pinctrl-0 = <&i2c0_default>;
	pinctrl-1 = <&i2c0_sleep>;
&i2c1 {
	/* Cannot be used together with spi1. */
	/* status = "okay"; */
	pinctrl-0 = <&i2c1_default>;
	pinctrl-1 = <&i2c1_sleep>;
&pwm0 {
	status = "okay";
	pinctrl-0 = <&pwm0_default>;
	pinctrl-1 = <&pwm0_sleep>;
&spi0 {
	compatible = "nordic,nrf-spi";
	/* Cannot be used together with i2c0. */
	pinctrl-0 = <&spi0_default>;
	pinctrl-1 = <&spi0_sleep>;
&spi1 {
	status = "okay";
	pinctrl-0 = <&spi1_default>;
	pinctrl-1 = <&spi1_sleep>;
arduino_spi: &spi2 {
	status = "okay";
	cs-gpios = <&arduino_header 16 GPIO_ACTIVE_LOW>; /* D10 */
	pinctrl-0 = <&spi2_default>;
	pinctrl-1 = <&spi2_sleep>;
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x00000000 0xc000>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0x0000C000 0x37000>;
		slot1_partition: partition@43000 {
			label = "image-1";
			reg = <0x00043000 0x37000>;
		storage_partition: partition@7a000 {
			label = "storage";
			reg = <0x0007a000 0x00006000>;
Error:
main.c.obj -c ../src/main.c
In file included from C:\ncs\v2.5.0-rc2\zephyr\include\zephyr\toolchain\gcc.h:92,
from C:\ncs\v2.5.0-rc2\zephyr\include\zephyr\toolchain.h:50,
from C:\ncs\v2.5.0-rc2\zephyr\include\zephyr\sys\time_units.h:10,
from C:\ncs\v2.5.0-rc2\zephyr\include\zephyr\sys\util.h:615,
from C:\ncs\v2.5.0-rc2\zephyr\include\zephyr\devicetree.h:25,
from C:\ncs\v2.5.0-rc2\zephyr\include\zephyr\device.h:12,
from d:\nrf\test_proj\test\lvgl\src\main.c:7:
../src/main.c: In function 'main':
C:\ncs\v2.5.0-rc2\zephyr\include\zephyr\device.h:85:41: error: '__device_dts_ord_DT_CHOSEN_zephyr_display_ORD' undeclared (first use in this function)
85 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id)
C:\ncs\v2.5.0-rc2\zephyr\include\zephyr\toolchain\common.h:132:26: note: in definition of macro '_DO_CONCAT'
132 | #define _DO_CONCAT(x, y) x ## y
C:\ncs\v2.5.0-rc2\zephyr\include\zephyr\device.h:85:33: note: in expansion of macro '_CONCAT'
C:\ncs\v2.5.0-rc2\zephyr\include\zephyr\device.h:211:37: note: in expansion of macro 'DEVICE_NAME_GET'
211 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_ID(node_id))
C:\ncs\v2.5.0-rc2\zephyr\include\zephyr\device.h:228:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
228 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
d:\nrf\test_proj\test\lvgl\src\main.c:46:23: note: in expansion of macro 'DEVICE_DT_GET'
46 | display_dev = DEVICE_DT_GET(DT_CHOSEN(zephyr_display));
C:\ncs\v2.5.0-rc2\zephyr\include\zephyr\device.h:85:41: note: each undeclared identifier is reported only once for each function it appears in
[48/357] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[49/357] Building C object zephyr/CMakeFiles/zephyr.dir/lib/posix/getopt/getopt.c.obj
[50/357] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[51/357] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[52/357] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' --build 'd:\nrf\test_proj\test\lvgl\build'
  • I was using the wrong command to build. I was trying to build lvgl for adafruit display and I wanted to build it for st7735.
    PS D:\nrf\test_proj\test\lvgl> C:\Windows\system32\cmd.exe /d /s /c "west build --build-dir d:/nrf/test_proj/test/lvgl/build d:/nrf/test_proj/test/lvgl --pristine --board nrf52dk_nrf52832 -- -DSHIELD=adafruit_2_8_tft_touch_v2"
  • Done!
      Thanks a lot for the guidance. It wouldn't be possible to do this task without your help.
    I am sharing the following details so it can help others navigate through this issue:
    1. Build Error:
    I was using the following command to build but I was getting error that nrf52832 is not available board. But the issue was that I was using v2.5.0-rc and I think it was not stable version so I had to shift my version to v2.5.0 and then it worked.
     Command: C:\Windows\system32\cmd.exe /d /s /c "west build --build-dir d:/nrf/test_proj/test/lvgl/build d:/nrf/test_proj/test/lvgl --pristine --board nrf52dk_nrf52832 -- -DSHIELD=st7735r_ada_160x128"
    2. Ram Overflow Error:
    section `bss' will not
    fit in region `RAM'
    I was getting this error when I was trying to build lvgl code for Adafruit LCD and adafruit have their own UI libraries so I will not recommend to use lvgl with Adafruit LCD.
    It was working fine when I tried to build it for st7735.
    Command:
    3. GPIO Issue:
    After building I was unable to identify the pins that should be used to communicate. I tried multiple examples on community but it didn't work. It was only mentioned that you should use D8-D13 (https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.5.0-rc2/zephyr/boards/shields/st7735r/doc/index.html )but I was not sure where to connect it on nrf52832 development kit. This information was available in "nrf52dk_nrf52832.dts" file as shown in the image attached.
    gpio 19 is refering to P0.19 pin on nrf52832 development kit.
