two interupts on same gpiote with two different pins nrf5340
hello,
i am using sdk 2.4.0 with nrf5340 i want to enable two diffferents buttons with interupts without disabling the one interupt because i need these two button for different scenario i cant basically trun off one interupt while using other
/* API Prototypes */
void gpio_init()
	nrfx_err_t err;
	// Connect GPIOTE_0 IRQ to nrfx_gpiote_irq_handler
	IRQ_CONNECT(DT_IRQN(DT_NODELABEL(gpiote)),
				DT_IRQ(DT_NODELABEL(gpiote), priority),
				nrfx_isr, nrfx_gpiote_irq_handler, 0);
	err = nrfx_gpiote_init(0);
	if (err != NRFX_SUCCESS)
		// LOG_ERR("nrfx_gpiote_init error: %08x", err);
		return;
nrfx_gpiote_in_config_t const mode_in_config = {
		.sense = NRF_GPIOTE_POLARITY_HITOLO,
		.pull = NRF_GPIO_PIN_NOPULL,
		.is_watcher = false,
		.hi_accuracy = true,
		.skip_gpio_setup = false,
	nrfx_gpiote_in_config_t const in_config = {
/*	err = nrfx_gpiote_in_init(BUTTON_1_Pin, &mode_in_config, mode_button_handler);
		 printf("nrfx_gpiote_in_init error 111111: %08x", err);
		return;
	nrfx_gpiote_in_event_enable(BUTTON_1_Pin, true);*/
		err = nrfx_gpiote_in_init(BUTTON_2_Pin, &in_config, button_handler);
		 printf("nrfx_gpiote_in_init error 2222222: %08x", err);
		return;
nrfx_gpiote_in_event_enable(BUTTON_2_Pin, true);
i am getting error nrfx_gpiote_in_init error: 0bad0002 while initilaising second interupt
regards
manikandan
  • That suggests you have used up all 8 GPIOTE channels. A solution is to GPIOTE PORT events to detect the button interrupts. This is done by setting the .hi_accuracy flag to 'False'.
  • hi,thanks for the reply if i set that to flag to flase button interupts were not detected this is how i am doing it
    #define BUTTON_2_Pin		43//_PINNUM(1, 11)	//B20(P1.11)
    static void button_handler(nrfx_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    	if (action == NRF_GPIOTE_POLARITY_LOTOHI && pin == BUTTON_2_Pin)
    	//	printk("MY HANDLING\n");
    void gpio_init()
    	nrfx_err_t err;
    	/* Connect GPIOTE_0 IRQ to nrfx_gpiote_irq_handler */
    	/* Initialize GPIOTE (the interrupt priority passed as the parameter
    	 * here is ignored, see nrfx_glue.h).
    		return;
    		.sense = NRF_GPIOTE_POLARITY_LOTOHI,
    		.pull = NRF_GPIO_PIN_PULLUP,
    		.hi_accuracy = false,
    	/* Initialize input pin to generate event on high to low transition
    	 * (falling edge) and call button_handler()
    		// LOG_ERR("nrfx_gpiote_in_init error: %08x", err);
    		return;
    regards
    manikandan v
  • I don't see any obvious errors in the code. Please try to debug your application in VS code and see if P1.11 becomes configured correctly after  the nrfx_gpiote_in_init() function has been run.
    It should look like this:
